Canon Support for Color imageCLASS MF726Cdw | Canon U.S.A., Inc.
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
Wireless Setup How-To Videos
SELECT ERROR CODE
WINDOWS
macOS X
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Printer Specifications
Printer Type | Color Laser MFP |
Print Speed | Up to 10ppm (2-sided plain paper letter) Up to 21ppm (1-sided plain paper letter)1 |
First Print Time | 14.3 seconds or less (letter)2 |
Printer Language | UFR II LT (Host-based) |
Print Resolution | Up to 1200 x 1200 dpi (9600 x 600 dpi quality) |
Maximum Print Size | Up to Legal |
Duplex Print | All mode (Print, Scan, Copy, Fax) |
Print Modes | Poster, Booklet, Watermark, Page Composer, Toner Saver |
Print Memory | 1GB (shared) |
Direct Print from USB | via USB Host v1.1 Print File format: JPEG, TIFF, PDF |
Copier Specifications
Copy Type | Color Laser |
Copy Speed | LTR: Up to 21ppm (Black/Color)1 A4: Up to 20ppm (Black/Color )1 |
Duplex Copy Speed | LTR/A4: Up to 10ppm (Black/Color)1 |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo/Map |
Halftones | 256 Levels |
Warm-up Time | 23 sec or less from power-on |
First Copy Time | Black/Color: Approx. 15.5/16.2sec (A4), 15.3/16.0 sec (LTR)3 |
Recovery Time | Approx. 8 sec |
Maximum Number of Copies | Up to 99 copies |
Duplex Copy/Bind Time | Yes |
Reduction/Enlargement | 25 - 400% in 1% increments |
Zoom | 25 - 400% in 1% increments |
Copy Size | Platen: Up to Letter, ADF: 5.5" x 5" to Legal |
Copy Features | Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Copy Memory | 1GB (shared) |
Fax Specifications
Modem Speed | Up to 33.6 Kbps4 |
Fax Resolution | Up to 406 x 391 dpi |
Transmission Time | JBIG (approx. 3 seconds) |
Memory Capacity | Up to 512 pages5 |
Speed Dials | Up to 281 dials |
Group Dialing | Max. 199 dials / Max. 199 destinations |
Sequential Broadcasting | Max. 310 destinations |
Duplex Fax | Yes |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | FAX Forwarding, Dual Access, Remote Reception, PC FAX(TX only), DRPD, ECM, Auto Redial, Fax Activity Reports, Fax Activity Result Reports, Fax Activity Management Reports |
Memory Backup | Permanent fax memory backup. ( Backup with flash memory) |
Activity Reports | Activity Result & Activity Management |
pC Fax | Sending only |
Fax Forwarding | SMB, E-mail, FTP, iFax Simple |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Optical: Up to 600 x 600 dpi Driver(digital): Up to 9600 x 9600 dpi |
Scan Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA (Scan Driver Compatibility) |
Output File Formats | JPEG, TIFF, PDF, Compact PDF, PDF (OCR), PDF (Device Support) |
Scan Features | Yes |
Pull Scan | Yes, USB and Network |
Push Scan (Scan to pC) | Yes, USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette, 50-sheet multipurpose tray6 |
Optional Paper Source(s) | 250-sheet cassette |
Document Feeder | 50-sheet duplex |
Paper Output | 125 sheets (face down) |
Paper Weight | 16-58 lb. bond (cassette / multipurpose tray) |
Media Sizes | Letter, Legal, A4, A5, B5, Executive |
Media Types | Plain, Heavy, Recycled, Color, Coated, Transparency, Label, Envelope, Index |
Envelope Capacity | 10 envelopes (cassette), 5 envelopes (manual feed slot) |
Envelope Types | Com 10, Monarch, DL, C5, B5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 High-Speed, 10/100 Base-T Ethernet, Wi-Fi 802.11b/g/n Wireless7 |
WiFi Access Mode | Infrastructure Mode |
WiFi Authentication Methods | Open System, Shared Key, WPA-PSK, WPA2-PSK |
WiFi Encryption Modes | WEP (64/128 bit), TKIP, AES |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | Canon PRINT Business8, Apple AirPrint™9, Mopria Print Service10, Google Cloud Print™11 |
Network Functions | Print, Copy, Scan, Fax, PC Fax, Print/Scan to USB |
Embedded Web Server (Remote UI) | Yes |
Web Browser Support for Remote UI | Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6), Email, SMB, WSD-Scan (IPv4,IPv6) |
TCP/IP Set of Application Services | Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4,IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
OS Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003, Mac OS X® 10.5.8 & up, Linux (print only) |
Cable Included | Power Cord, Telephone Cable (USB not included) |
Bundled Software | Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager |
Environmental Specifications
Power Consumption | Max: 1,200W or less. During Operation: Approx. 450W. Standby: Approx. 23W. Energy Saver: Approx. 2W |
Typical Energy Consumption | 0.9 kWh |
General Specifications
Dimensions | 17" (W) x 19.2" (D) x 18.9" (H) |
Unit Weight (without/with cartridge) | 63.1 lbs. (w/o cartridge), 68.3 lbs (w/cartridge) |
Package Weight | Approx. 81.6 lbs |
Cartridge Type | Cartridge 118 VP Black (Yields approximately 6,800 pages) Cartridge 118 Black (Yields approximately 3,400 pages) Cartridge 118 YMC (Yields approximately 2,900 pages) *Yields based on ISO/IEC Standard |
LCD Display | 7-line QVGA Color Touch LCD |
Duty Cycle | Up to 40,000 pages per month |
Department ID Management | Yes, Up to 300 ID's |
Security | Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC, LDAP |
Languages | English, French, Spanish, Portuguese |
One-Touch Keys | Favorites Settings |
Warranty | 1 Year Exchange / Carry-in (Extended warranty available)12 |
Scanning Software Included: MF Scan Utility Sending Method: SMB, E-mail, FTP, iFAX Simple Color Mode: Full Color, Grayscale, Monochrome Scan Resolution: 300 x 300 dpi, 200 x 200 dpi Other Features: EPEAT Silver Rating, NFC13 Capability |
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Click Here to download the Color imageCLASS MF624Cw, Color imageCLASS MF628Cw, Color imageCLASS MF726Cdw, Color imageCLASS MF729Cdw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
