Canon Support for Color imageCLASS MF9170c | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.16.24
File Size 1.32 MB
Date 12.19.16
File Size 37.41 MB
Date 12.23.20
File Size 819.56 KB
Date 12.21.17
File Size 809.44 KB
Date 04.26.23
File Size 1.72 MB
Date 12.19.23
File Size 1.32 MB
Date 10.26.08
File Size 26.56 MB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 04.23.19
File Size 815.66 KB
Date 09.11.25
File Size 1.32 MB
Date 09.16.26
File Size 1.32 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Printer
Printing Method Color Laser
Print Speed (up to) Black/Color: Up to 22 ppm (letter)1
Print Resolution (Up to) Up to 600 x 600 dpi; 2400 x 600 dpi quality
Toner Compatibility (for Laser MFP) Canon Cartridge 111 C/M/Y/Bk (Yield:6,000 pages per cartridge*)
Maximum Monthly Duty Cycle: 65,000 pages
*yield is based on 5% coverage document
Paper Weights 16 to 32 lb. (cassette)
16 to 47 lb. (multipurpose tray)
Copier
Copy Resolution (up to) Up to 600 x 600 dpi
Copy Speed (up to) Black/Color: Up to 22 cpm (letter)1
Type Color Laser
Halftones 256 levels
First Copy Time Approx. 13 seconds (black/color)
Reduction / Enlargement 50%, 64%, 78%, 129%, 200%
Document Feeder 50-sheet5
Copy Size Platen: Up to 8.5" x 14"
ADF: 5.5" x 5" to 8.5" x 14"
Copy Features ACS (Auto Color Select), AE (Auto Exposure), Frame Erase, Memory Sort, Toner Saver Mode, 2 on 1, 4 on 1
Scanner
Scanner Type Color CCD3
Max. Resolutions Black: 600 x 600 dpi
Color: 300 x 600 dpi
Scanner Features Scan to USB
USB Host (x2): USB 2.0 Hi-Speed2
Supported Media: USB Flash
Output File format: JPEG, TIFF, Text
Max. Document Size Platen: Up to 8.5" x 14"
ADF: Up to 8.5" x 14"
File Format JPEG, PDF, TIFF
Fax
Modem Speed Up to 33.6 Kbps (Super G3)
Memory Capacity Up to 1,000 pages4
Fax Resolution Up to 406 x 391 dpi (ultra fine)
Speed Dialing 200 locations
Receive Mode Fax Only, Manual, Answering, Fax/Tel Auto Switch
General
Other Features 3.5-inch color TFT LCD Display
2 Memory Card Slots
Memory Direct Print
Supported Media: USB Flash, CF, Micro Drive, SD, Memory Stick
Scan to E-Mail, SMB, USB Memory & FTP
OS Compatibility USB: Windows® 7, Windows Vista®, Windows XP/2000. Mac® OS X 10.2.8 - 10.6.
Network: Windows® 7, Windows Server® 2008, Windows Vista®, Windows Server 2003, Windows XP/2000. Mac® OS X 10.2.8 - 10.6.
USB Functions:
Windows: Print/PC Fax
Mac: Print/PC Fax
Network Functions:
Windows: Print/PC Fax/Scan
Mac: Print/PC Fax
Standard Interface USB 2.0 Hi-Speed2, 10 Base T/100 Base TX (embedded)
Power Consumption (approx.) 1350W (Max), 1W (Energy Saver Mode)
Dimension (W x D x H) 21.5" (W) x 20.8" (D) x 24.7" (H)
Weight (Without/with Cartridge) Approx. 85 lbs./96 lbs.
Warranty One-year limited warranty with one-year on-site service6
Canon Color imageCLASS MF9100/8400 Series Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the Canon Color imageCLASS MF9100/8400 Series product and accessories packaged with this limited warranty (collectively, the "Product") when purchased and used in the United States.
THIS LIMITED WARRANTY DOES NOT COVER THE CARTRIDGE FOR WHICH A SEPARATE WARRANTY IS GIVEN. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE CARTRIDGE LIMITED WARRANTY.
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser (“Purchaser”) by Canon USA or its authorized dealer. During the relevant warranty period, Canon USA shall repair or replace, without charge, any defective part with a new or comparable rebuilt part. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
Canon USA shall provide assistance for installation, operation and support of the Product as follows:
(a) Toll-free telephone support for troubleshooting issues at 1-800-423-2366, Monday through Friday from 8:00 a.m. to 8:00 p.m. E.T. (b) E-mail support via our Web site at www.usa.canon.com
If Canon USA's remote assistance cannot fix your Product's malfunction, Canon USA shall schedule an on-site service call, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product. If on-site service is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then-current service call rates of Canon USA or any authorized Canon USA service provider (the “Service Provider”).
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
This warranty shall be void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon USA who are acting in accordance with Canon USA's service bulletins, (d) use of supplies or parts (other than those distributed by Canon USA) which damage the Product or cause abnormally frequent service calls or service problems, or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced,removed, or altered.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON USA NOR ANY AUTHORIZED SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY AUTHORIZED SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY AUTHORIZED SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY AUTHORIZED SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY AUTHORIZED SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
CONDITIONS OF WARRANTY
Defective parts must be returned to Canon USA or a Service Provider with all necessary documentation.
THIS WARRANTY APPLIES TO PRODUCTS PURCHASED AND USED IN THE UNITED STATES ONLY.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Incompatibilities between Mac OS X Lion (10.7) and our previously released Mac OS X 10.6 Printer and Fax drivers
Advisory Type
Date 07.27.11
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
