Canon Support for Color imageCLASS MF9280Cdn | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.29.16
File Size 717.77 KB
Date 09.16.24
File Size 1.32 MB
Date 12.21.17
File Size 940.90 KB
Date 04.26.23
File Size 460.45 KB
Date 01.30.23
File Size 2.16 MB
Date 12.23.20
File Size 819.56 KB
Date 12.19.23
File Size 1.85 MB
Date 01.30.23
File Size 2.26 MB
Date 12.21.17
File Size 809.44 KB
Date 10.27.10
File Size 132.47 MB
Date 10.03.19
File Size 958.35 KB
Date 09.16.24
File Size 1.85 MB
Date 04.26.23
File Size 1.72 MB
Date 12.19.23
File Size 1.32 MB
Date 12.01.20
File Size 961.90 KB
Date 03.26.17
File Size 716.21 KB
Date 10.27.10
File Size 18.25 MB
Date 01.30.23
File Size 1.63 MB
Date 12.19.16
File Size 42.28 MB
Date 10.03.19
File Size 815.82 KB
Date 12.19.23
File Size 476.17 KB
Date 04.23.19
File Size 815.66 KB
Date 09.17.18
File Size 948.95 KB
Date 09.11.25
File Size 1.32 MB
Date 03.02.26
File Size 1.85 MB
Date 09.16.26
File Size 1.32 MB
Date 09.16.26
File Size 1.85 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Printer
Printing Method Color Laser
Print Speed (up to) Color:Up to 22 ppm color (letter)
Black:Up to 22 ppm color (letter)
Print Resolution (Up to) Color:Up to 600 x 600 dpi (2400 x 600 dpi quality)
Toner Compatibility (for Laser MFP) Canon Cartridge 111
CRG yield* (6,000)
Based on 5% coverage document
Printer Features Printer Language
UFR II LT (Host-based), PCL 5c/6, PS 3 Emulation
Print Modes
Poster, N on 1 (up to 16 on 1), Scaling
Print Memory
768MB (Shared)
Copier
Copy Resolution (up to) Up to 600 x 600 dpi
Copy Speed (up to) Up to 22 ppm color/black (letter)
Type Color Laser
No. of Copies 99 copies
Zoom 50 - 200% in 1% increments
Halftones 256 Levels
First Copy Time Approx. 13 seconds
Paper Weight 16 to 32 lb. bond (cassette)
16 to 47 lb. bond (multipurpose tray)
Reduction / Enlargement 50%, 64%, 78% , 129%, 200%
Document Feeder 250-sheet cassette plus 100-sheet multipurpose tray
Copy Size Platen : Up to Legal
ADF: Up to Legal
Copy Features Auto Color Select, Frame Erase, Memory Sort, Toner Save, 2 on 1, 4 on 1, ID Card Copy
Scanner
Scanner Type Color Charge-Coupled Device (CCD)
Max. Resolutions Optical:600x600 dpi
Scanner Features Rotate Image, Neg/Pos Reversal, Mirror Image, Scan to USB, Duplex Scan
Color Depth 24-bit
Max. Document Size Platen: Up to 8.5" x 14"
ADF: Up to 8.5" x 14"
Fax
Modem Speed Up to 33.6 Kbps (Super G3)
Transmission Speed (approx.) JBIG (approx 3 seconds)1
Memory Capacity Up to 1,000 sheets2
Fax Resolution Up to 406 x 391 dpi (ultra fine)
Document Feeder 50-sheet duplex3
Speed Dialing 200 one-touch speed dials
100 address book dials
Group Dialing 299 destinations
Receive Mode Fax Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Remote RX, Delayed TX, Dual Access
Other Features Fax Forwarding
Fax/I-Fax -> Fax, I-Fax, Email, SMB, FTP
Sequential Broadcasting
Up to 332 destinations
Report Reference Activity Results & Activity Management
General
Other Features Compatibility
TWAIN, WIA
Media Card Support
Compact Flash, Micro Drive, Memory Stick, Memory Stick Duo (adaptor required), Memory Stick Pro, SD Memory Card, MiniSD Memory Card (adaptor required), USB memory (x2)
OS Compatibility Windows&reg; 7, Windows Server&reg; 2008, Windows Vista&reg;, Windows Server 2003, Windows XP/20005, Mac&reg; OS X 10.4.9 & up6, Linux (print only)
USB Functions
Print, PC Fax
Network Functions
Print, PC Fax, Scan, Send4
Standard Interface USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (Network)
Software Included Canon Drivers
Power Consumption (approx.) 1300W (Max)
1W (Energy Saver Mode)
Dimension (W x D x H) 21.5"(W) x 20.8"(D) x 24.9"(H)
Weight 96 lbs. with cartridge
85 lbs. without cartridge
Warranty 1 year limited on-site warranty7
Canon imageCLASS MF9220Cdn/MF9280Cdn LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the Canon Color imageCLASS MF9200 Series product and accessories packaged with this limited warranty (collectively, the "Product") when purchased and used in the United States.
CARTRIDGES FOR THE PRODUCT (EXCEPT THE STARTER CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser (“Purchaser”) by Canon USA or its authorized dealer. During the relevant warranty period, Canon USA shall repair or replace, without charge, any defective part with a new or comparable rebuilt part. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
Canon USA shall provide assistance for installation, operation and support* of the Product as follows:
(a) Toll-free telephone support for troubleshooting issues at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. E.T. (b) E-mail support via our Web site at www.usa.canon.com.
If Canon USA's remote assistance cannot fix your Product's malfunction, Canon USA shall schedule an on-site service call, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product.
If on-site service is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then-current service call rates of Canon USA or any authorized Canon USA service provider (the “Service Provider”).
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Defective parts must be returned to Canon USA or a Service Provider with all necessary documentation.
Click Here to download the Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Incompatibilities between Mac OS X Lion (10.7) and our previously released Mac OS X 10.6 Printer and Fax drivers
Advisory Type
Date 07.27.11
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
