Canon Support for Color imageCLASS MF9280Cdn | Canon U.S.A., Inc.
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 | Golden Gate 27 |
Printer
| Printing Method | Color Laser |
| Print Speed (up to) | Color:Up to 22 ppm color (letter) Black:Up to 22 ppm color (letter) |
| Print Resolution (Up to) | Color:Up to 600 x 600 dpi (2400 x 600 dpi quality) |
| Toner Compatibility (for Laser MFP) | Canon Cartridge 111 CRG yield* (6,000) Based on 5% coverage document |
| Printer Features | Printer Language UFR II LT (Host-based), PCL 5c/6, PS 3 Emulation Print Modes Poster, N on 1 (up to 16 on 1), Scaling Print Memory 768MB (Shared) |
Copier
| Copy Resolution (up to) | Up to 600 x 600 dpi |
| Copy Speed (up to) | Up to 22 ppm color/black (letter) |
| Type | Color Laser |
| No. of Copies | 99 copies |
| Zoom | 50 - 200% in 1% increments |
| Halftones | 256 Levels |
| First Copy Time | Approx. 13 seconds |
| Paper Weight | 16 to 32 lb. bond (cassette) 16 to 47 lb. bond (multipurpose tray) |
| Reduction / Enlargement | 50%, 64%, 78% , 129%, 200% |
| Document Feeder | 250-sheet cassette plus 100-sheet multipurpose tray |
| Copy Size | Platen : Up to Legal ADF: Up to Legal |
| Copy Features | Auto Color Select, Frame Erase, Memory Sort, Toner Save, 2 on 1, 4 on 1, ID Card Copy |
Scanner
| Scanner Type | Color Charge-Coupled Device (CCD) |
| Max. Resolutions | Optical:600x600 dpi |
| Scanner Features | Rotate Image, Neg/Pos Reversal, Mirror Image, Scan to USB, Duplex Scan |
| Color Depth | 24-bit |
| Max. Document Size | Platen: Up to 8.5" x 14" ADF: Up to 8.5" x 14" |
Fax
| Modem Speed | Up to 33.6 Kbps (Super G3) |
| Transmission Speed (approx.) | JBIG (approx 3 seconds)1 |
| Memory Capacity | Up to 1,000 sheets2 |
| Fax Resolution | Up to 406 x 391 dpi (ultra fine) |
| Document Feeder | 50-sheet duplex3 |
| Speed Dialing | 200 one-touch speed dials 100 address book dials |
| Group Dialing | 299 destinations |
| Receive Mode | Fax Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Remote RX, Delayed TX, Dual Access |
| Other Features | Fax Forwarding Fax/I-Fax -> Fax, I-Fax, Email, SMB, FTP Sequential Broadcasting Up to 332 destinations |
| Report Reference | Activity Results & Activity Management |
General
| Other Features | Compatibility TWAIN, WIA Media Card Support Compact Flash, Micro Drive, Memory Stick, Memory Stick Duo (adaptor required), Memory Stick Pro, SD Memory Card, MiniSD Memory Card (adaptor required), USB memory (x2) |
| OS Compatibility | Windows® 7, Windows Server® 2008, Windows Vista®, Windows Server 2003, Windows XP/20005, Mac® OS X 10.4.9 & up6, Linux (print only) USB Functions Print, PC Fax Network Functions Print, PC Fax, Scan, Send4 |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (Network) |
| Software Included | Canon Drivers |
| Power Consumption (approx.) | 1300W (Max) 1W (Energy Saver Mode) |
| Dimension (W x D x H) | 21.5"(W) x 20.8"(D) x 24.9"(H) |
| Weight | 96 lbs. with cartridge 85 lbs. without cartridge |
| Warranty | 1 year limited on-site warranty7 |
Canon imageCLASS MF9220Cdn/MF9280Cdn LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the Canon Color imageCLASS MF9200 Series product and accessories packaged with this limited warranty (collectively, the "Product") when purchased and used in the United States.
CARTRIDGES FOR THE PRODUCT (EXCEPT THE STARTER CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser (“Purchaser”) by Canon USA or its authorized dealer. During the relevant warranty period, Canon USA shall repair or replace, without charge, any defective part with a new or comparable rebuilt part. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
Canon USA shall provide assistance for installation, operation and support* of the Product as follows:
(a) Toll-free telephone support for troubleshooting issues at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. E.T. (b) E-mail support via our Web site at www.usa.canon.com.
If Canon USA's remote assistance cannot fix your Product's malfunction, Canon USA shall schedule an on-site service call, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product.
If on-site service is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then-current service call rates of Canon USA or any authorized Canon USA service provider (the “Service Provider”).
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Defective parts must be returned to Canon USA or a Service Provider with all necessary documentation.
Click Here to download the Warranty Card.
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
