Canon Support for Color imageCLASS X MF1538C | Canon U.S.A., Inc.
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Products | ChromeOS |
MAIN UNIT |
CORE FUNCTIONS |
Standard: Print, Copy, Scan, Send, Fax |
PROCESSOR |
1 GHz Dual Core Processor |
CONTROL PANEL |
7" TFT LCD WVGA Color Touch Panel |
MEMORY |
2 GB |
STANDARD INTERFACE CONNECTION |
USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n |
PAPER CAPACITY (LETTER, 20 LB. BOND) |
Standard: 650 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) |
Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) |
Standard: 200 Sheets |
SUPPORTED MEDIA TYPES |
Cassette: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Labels |
SUPPORTED MEDIA SIZES |
Cassette: Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" x 5" to Max. 8.5" x 14") |
SUPPORTED MEDIA WEIGHTS |
Cassettes: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2) |
WARM-UP TIME |
From Power On: 12 Seconds or Less |
DIMENSIONS (W x D x H) |
Standard (Desktop): 19.7" x 21.9" x 25.2" (500 mm x 556 mm x 640 mm) |
INSTALLATION SPACE (W x D x H) |
Standard (Desktop): 28.2" x 31" (717 mm x 785 mm) |
WEIGHT4 |
Unit: Approx. 90.4 lb. (41 kg) |
OPERATING SYSTEM |
Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 /Mac OS X v10.10 (or later) |
PRINT SPECIFICATIONS |
PRINTING METHOD |
Laser Beam Printing |
PRINT SPEED (COLOR)5 |
Up to 40 ppm (Letter) |
FIRST PRINT OUT TIME |
Approx. 6 Seconds |
RECOMMENDED MONTHLY PAGE VOLUME |
2,000 - 4,000 Pages |
PRINT RESOLUTION (dpi) |
600 x 600 |
STANDARD PAGE DESCRIPTION LANGUAGES |
UFR II, PCL®6, PCL®5, Adobe PostScript® 3TM |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1 |
Apple® AirPrint®, Canon PRINT Business, Mopria™ Print Service, Universal Print, uniFLOW Secure Mobile Printing6 |
FONTS |
PCL: 93 Fonts |
PRINT FEATURES |
Secure Print, Secure Watermark, Header/Footer, Page Layout, Two-sided Printing, Mixed Paper Sizes/ Orientations, Toner Reduction, Poster Printing, Forced Hold Printing, Print Date, Scheduled Printing, Printing Using a Virtual Printer |
COPY SPECIFICATIONS |
FIRST-COPY-OUT TIME (LETTER) |
Approx. 5.9 Seconds/6.9 seconds or Less (BW/Color) |
COPY RESOLUTION (dpi) |
600 x 600 |
COPY SIZE |
Platen: Up to Legal |
MULTIPLE COPIES |
Up to 999 Copies |
MAGNIFICATION |
25% - 400% (1% Increments) |
PRESET REDUCTIONS |
25%, 50%, 70% |
PRESET ENLARGEMENTS |
141%, 200%, 400% |
COPY FEATURES |
Preset R/E Ratios by Area, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Two-sided Original, Sort, Job Build, N on 1, Sharpness, Erase Frame, Copy ID Card, Skip Blank Pages, Color Mode, Reserved Copy, Copy Sample |
SCAN SPECIFICATIONS |
TYPE |
Single-Pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY |
100 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES |
Letter, Legal, Statement, Custom Size: 1.9" x 5" to 8.5" x 14"(48 mm x 128 mm to 216 mm x 355.6 mm) |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS |
15.5 lb. Cover to 47.3 lb. Cover (42 to 128 g/m2) |
PLATEN ACCEPTABLE ORIGINALS |
Sheet, Book |
PULL SCAN |
Color Network ScanGear 2 for both TWAIN and WIA |
SCAN RESOLUTION (dpi) |
Up to 600 x 600 |
SCAN-TO-MOBILE DEVICES |
Canon PRINT Business |
SCAN SPEED (LETTER) (BW/COLOR) |
Single-sided: 100/100 (300 dpi), 50/50 (600 dpi) |
MEMORY MEDIA |
Standard USB Memory (JPEG, TIFF, PDF) |
SEND SPECIFICATIONS |
DESTINATION |
E-mail/Internet FAX (SMTP), Super G3 FAX, SMB3.0, FTP, WebDAV |
ADDRESS BOOK |
LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION (dpi) |
Push/Pull: Up to 600 x 600 |
COMMUNICATON PROTOCOL |
File: FTP (TCP/IP), SMB (TCP/IP), WebDAV |
FILE FORMAT |
Standard: TIFF ,JPEG, PDF (Compact, Searchable, Encrypted), XPS (Compact, Searchable), PDF/XPS (Device Signature, Office Open XML (PowerPoint®, Word) |
FAX SPECIFICATIONS |
MODEM SPEED |
Super G3: 33.6 Kbps |
COMPRESSION METHOD |
MH, MR, MMR, JBIG |
RESOLUTION (dpi) |
400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING/RECORDING SIZE |
Statement to Legal |
FAX MEMORY |
Up to 30,000 Pages |
SPEED DIALS |
Max. 200 |
GROUP DIALS/DESTINATIONS |
Max. 199 Dials |
SEQUENTIAL BROADCAST |
Max. 256 Addresses |
MEMORY BACKUP |
Yes |
SECURITY SPECIFICATIONS |
AUTHENTICATION AND ACCESS CONTROL |
User Authentication (Picture Login, Picture and PIN Login, Username and Password Login, Function Level Login, Mobile Login), Department ID Authentication (Department ID and PIN Login, Function Level Login), uniFLOW Online Express (PIN Login, Picture Login, Picture and PIN Login, Card Login, Card and PIN Login, Username and Password Login, Department ID and PIN Login, Function Level Login), Access Management System (Access Control) |
DOCUMENT |
Print Security (Secure Print, Encrypted Secure Print, Forced Hold Printing, uniFLOW Secure Print6 ), Recieve Data Security (Confidential Fax Inbox Forwarding Received Documents Automatically), Scan Security (Encrypted PDF, Device Signature, User Signature PDF/XPS7), Send Data Security (Setting for requesting password input per transmission, Restricted E-mail/File send functions, Confirming FAX Number, Allow/Restrict Fax Driver Transmissions, Allow/Restrict Sending from History, S/MIME Support) |
NETWORK |
TLS 1.3, IPSec, IEEE802.1X authentication, SNMPv3, Firewall Functionality (IP/MAC Address Filtering), Dual Network Support (Wired LAN/Wireless LAN, Wired LAN/Wired LAN), Enabling/Disabling (Network Applications, Remote UI, USB Interface), G3 FAX separation from LAN, USB Port separation from LAN, Scan and Send -Virus Concerns for E-mail Reception |
DEVICE |
Standard Storage Initialize, Job Log Conceal Function, Verify System at Startup, Runtime Intrusion Detection |
DEVICE MANAGEMENT AND AUDITING |
Administrator Password, Digital Certificate and Key Management, Audit Log, Cooperating with External Security Audit System (Security Information and Event Management), Security Policy Setting |
ENVIRONMENTAL SPECIFICATIONS |
OPERATING ENVIRONMENT |
Temperature: 50 to 86º F |
POWER REQUIREMENTS |
110-127V, 60Hz, 7.2A |
POWER CONSUMPTION |
Maximum: Approx. 1500 W |
STANDARDS |
ENERGY STAR® Qualified, Rated EPEAT Silver3 |
CONSUMABLES |
TONER |
Toner T10 Black Yields 13,000 Pages |
CANON imageCLASS SERIES ON-SITE LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser (“Purchaser”) by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider (“Service Provider”) to, without charge, repair or replace any defective part with a new or comparable rebuilt part. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
Canon USA offers assistance for installation, operation and support* of the Product as follows:
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads at www.usa.canon.com/support (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
If Canon USA's remote assistance above cannot fix your Product's malfunction, Canon USA shall schedule an on-site service call via a Service Provider, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product.
If on-site service is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then current service rates of Canon USA or the Service Provider.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
This warranty shall be limited void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon USA who are acting in accordance with Canon USA's service bulletins, (d) use of supplies or parts (other than those distributed by Canon USA) which damage the Product or cause abnormally frequent service calls or service problems, or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this limited warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE CD- ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
CANON U.S.A., INC.One Canon Park
Melville, NY 11747
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
