Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 11.26.25
File Size 1.10 MB
Date 11.26.25
File Size 4.69 MB
Date 07.30.25
File Size 3.28 MB
Date 12.10.25
File Size 185.38 KB
Date 11.20.25
File Size 10.49 MB
Date 01.15.26
File Size 4.48 MB
Color Options Satin Black / Titanium White
Image Sensor Type 1/2.3 (1/2.3 in.) single-plate CMOS sensor
Total pixels: approx. 21.14 megapixels
Effective pixels: approx. 8.29 megapixels (3840 x 2160)
Lens f=3.67 73.4 mm, F/1.8 2.8, 20x optical zoom, 8-bladed circular aperture
35mm equivalent focal length:
[4K UHD] approx. 29.3 (W) 601 mm (T)
[Full HD] approx. 30.5 (W) 627 mm (T)
Zoom Digital: 20x
Optical: 20x
Lens Configuration 12 elements in 10 groups (including 2 aspheric elements)
Minimum Focusing Distance 1 cm (0.39 in.) at full wide angle, 60 cm (2.0 ft.)
throughout the zoom range
Angle of View [4K UHD]
Horizontal: 65.6 (W) 3.6° (T)
Vertical: 39.8° (W) 2.0° (T)
[Full HD]
Horizontal: 63.5 (W) 3.4° (T)
Vertical: 38.4° (W) 1.9° (T)
Shutter Speed 1/6 1/2000 sec. (specific values depend on the frame frequency and frame rate)
Iris Manual/Automatic aperture
Gain 0.0 dB 36 dB
White Balance AUTO (AWB), Set A, Set B, preset settings (daylight: 5,600 K*, tungsten lamp:
3,200 K*), color temperature setting (2,000 K 15,000 K), Manual
*Color temperatures are given for reference purposes only
Focus Focus mode: Manual, Continuous AF, Face AF, Tracking AF type: Hybrid AF, Contrast AF
Gamma Normal1 (Standard), Normal3 (BT.709)
Image Stabilizer Optical-shift
Min. Subject Illumination Approx. 1.5 lux (shutter speed 1/30 sec., frame rate 59.947P (P (Programmed AE) shooting mode, auto slow shutter on)
Pan and Tilt Pan operation range: Horizontal ±170°
Pan operation speed: 0.2° 300°/sec.
Tilt operation range: Vertical -30° +100°
Tilt operation speed: 0.2° 180°/sec.
Frame Frequency 59.94 Hz 1920 x 1080: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
Frame Frequency 29.97 Hz 3840 x 2160: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
1920 x 1080: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
Frame Frequency 50.00 Hz 1920 x 1080: 50.00 fps, 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 50.00 fps, 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 50.00 fps, 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
Frame Frequency 25.00 Hz 3840 x 2160: 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
1920 x 1080: 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
Frame Frequency 23.98 Hz 3840 x 2160: 23.98 fps, 11.99 fps, 5.99 fps (4:2:0 8 bit)
1920 x 1080: 23.98 fps, 11.99 fps, 5.99 fps (4:2:0 8 bit)
1280 x 720: 23.98 fps, 11.99 fps, 5.99 fps (4:2:0 8 bit)
640 x 360: 23.98 fps, 11.99 fps, 5.99 fps (4:2:0 8 bit)
JPEG has one fixed pattern depending on the frame frequency (format is fixed and cannot be selected) Resolution: 1280 x 720
When frame frequency is 59.94/29.97 Hz: 14.99 fps
When frame frequency is 50.00/25.00 Hz: 12.50 fps
When frame frequency is 23.98 Hz: 11.99 fps
HDMI 3840 x 2160: 29.97P, 25.00P, 23.98P (4:2:2 10 bit)
1920 x 1080: 59.94P/59.94i, 50.00P/50.00i/25.00P, 29.97P/23.98P (4:2:2 10 bit)
1280 x 720: 59.94P, 50.00P (4:2:2 10 bit)
IP 3840 x 2160: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit) 1920 x 1080: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit) 1280 x 720: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit) 640 x 360: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit) *If 59.94/50.00 Hz is selected for the frame frequency, the 3840 x 2160 format cannot be selected.
*A frame rate that exceeds the frame frequency cannot be selected. *JPEG has one pattern fixed depending on the frame frequency (format is fixed and cannot be selected) Resolution: 1280 x 720 When frame frequency is 59.94/50.00 Hz: 14.99 fps, when frame frequency is 23.98 Hz: 11.99 fps, when frame frequency is 29.97/25.00 Hz: 12.50 fps
Supported Video and Control Protocols Protocol: XC Protocol, RTSP/RTP, NDI®HX2, SRT, RTMP/RTMPS, Standard Protocol Communication (Serial), Standard Protocol Communication (IP)
Number of Presets Max. 100 (including home position)
Communication Control LAN, Serial, IR
Network Terminal LAN x 1, RJ45, 1000Base-T
HDMI OUT Terminal HDMI connector x 1, output only
RS-422 Terminal RJ45 connector x 1
Mic Terminal 3.5 mm stereo mini jack (unbalanced, plug-in power supported)
Sensitivity (MIC): -72 dBV (Manual volume center, full scale -18 dB)/1 k or
more/Att.: 20 dB
Sensitivity (LINE): -10 dBV (Manual volume center, full scale -18 dB)/1 k or more
Supply Voltage: 2.4 V DC (Bias resistance: 2.2 k)
USB Terminal Type-C (USB 3.0) x 1
Operating Environment Temperature: 0°C +40°C (+32°F +104°F)
Humidity: 10% 90% (without condensation)
Power Supply PoE: PoE+ power supply via LAN connector (IEEE802.3at compliant) PoE cannot be used
External power source: 24 V DC (using included AC adaptor)
Power Consumption PoE+ Input: Approx. 13.9 W max. (body only)
DC Input: Approx. 13.3 W max. (body only)
Dimensions (W x H x D) Approx. 154 x 178 x 164 mm (6.06 x 7.01 x 6.46 in.)
(excluding protrusions)
Weight Approx. 2.2 kg (4.86 lb.) (body only)
Supported Controllers Hardware: RC-IP100, RC-IP1000
Software: Remote Camera Control Application
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
