Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.30.26
File Size 4.70 MB
Date 11.20.25
File Size 408.40 KB
Date 11.26.25
File Size 6.79 MB
Date 11.26.25
File Size 1.10 MB
Date 11.26.25
File Size 4.69 MB
Date 12.10.25
File Size 185.38 KB
Date 07.08.26
File Size 5.51 MB
Date 09.30.26
File Size 9.13 MB
Color Options Satin Black / Titanium White
Image Sensor 1/2.3-inch, CMOS (single board)
Total pixels: approx. 21.14 megapixels
29.97/25.00/23.98 Hz - Effective pixels: Approx. 8.29 megapixels (3840 x 2160)
59.94/50.00 Hz - Effective pixels: Approx. 7.88 megapixels (3744 x 2104)
Lens f=3.67 73.4 mm, F/1.8 2.8, 20x optical zoom, 8-bladed iris diaphragm
59.94/50 Hz - 35mm equivalent focal length: Approx. 30mm (W) 616 mm (T)
29.97/25.00/23.98 Hz - 35mm equivalent focal length: Approx. 29.3mm (W) 601 mm (T)
Zoom Optical: 20x
Digital: 20x
Advanced Zooom (Full HD): 40x
Lens Configuration 10 groups of 12 lenses (two aspherical lenses used)
Minimum Focusing Distance 1 cm at wide end, 60 cm across entire zooming range
Angle of View 59.94/50.00 Hz - Horizontal: 63.3 (W) 3.5° (T) - Vertical: 38.9° (W) 2.0° (T)
29/97/25.00/23.98 Hz - Horizontal: 65.6 (W) 3.6° (T) - Vertical: 39.8° (W) 2.0° (T)
Shutter Speed 1/3 1/2000 sec. (specific values depend on the frame frequency)
Iris Manual/Automatic aperture
Gain 0.0 db - 36.0 db
ND Filter Built-in (1/8 at maximum, gradation ND), motor operated
White Balance AUTO (AWB), Set A, Set B, preset settings (daylight: 5,600 K*, tungsten lamp: 3,200 K*), color temperature setting (2,000 K 15,000 K), Manual
Focus Focus mode: Manual, Continuous AF, Face Detection & Tracking, Face only AF, Eye Detection.
AF type: Hybrid AF, Contrast AF
Gamma BT.709 Wide DR, BT.709 Standard, Canon Log 3, Canon 709, HDR (PQ), HDR(HLG)
Image Stabilizer Optical
Min. Subject Illumination Frame frequency 59.94/29.97 Hz:
Approx. 3 lux (at shutter speed 1/60 sec, frame rate 59.94P, gain 30.0 dB)
Approx. 1.5 (at shutter speed 1/30 sec, frame rate 59.94P, gain 30.0 dB)
Frame frequency 50.00/25.00 Hz:
Approx. 2.5 lux (at shutter speed 1/50 sec, frame rate 50.00P, gain 30 dB)
Approx. 1.3 lux (at shutter speed 1/25 sec, frame rate 50.00P, gain 21 dB)
*All of the above are when high sensitivity mode is set to "On"
Pan and Tilt Pan operation range: Horizontal ±170°
Pan operation speed: 0.1° 100°/sec.
(Up to 200°/sec. using presets)
Tilt operation range: Vertical -30° +90°
Tilt operation speed: 0.1° 100°/sec.
(Up to 180°/sec. using presets)
3G-SDI 1920 x 1080: 59.94P/59.94i/50.00P/50.00i/29.97P/25.00P/23.98P (4:2:2 10bit)
1280 x 720: 59.94p/50.00P (4:2:2 10bit)
12G-SDI 3840 x 2160: 59.94P/50.00P/29.97P/25.00P/23.98P (4:2:2 10bit)
720 x 576: 50.00i (4:2:2 10bit)
720 x 480: 59.94i (4:2:2 10bit)
HDMI 3840 x 2160: 59.94P/50.00P/29.97P/25.00P/23.98P (4:2:2 10bit)
720x576: 50.00P (4:2:2 10bit)
720x480: 59.94P (4:2:2 10bit)
IP 3840 x 2160: 59.94fps, 50.00fps, 29.97 fps, 25.00fps, 23.98fps, 14.99 fps, 12.50fps, 11.99fps, 5.99fps, 5.00 fps (4:2:0 8 bit)
1920 x 1080: 59.94fps, 50.00fps, 29.97 fps, 25.00fps, 23.98fps, 14.99 fps, 12.50fps, 11.99fps, 5.99fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 59.94fps, 50.00fps, 29.97 fps, 25.00fps, 23.98fps, 14.99 fps, 12.50fps, 11.99fps, 5.99fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 59.94fps, 50.00fps, 29.97 fps, 25.00fps, 23.98fps, 14.99 fps, 12.50fps, 11.99fps, 5.99fps, 5.00 fps (4:2:0 8 bit)
Supported Video and Control Protocols Protocol: XC Protocol, RTSP/RTP, NDI HX2, RTMP/RTMPS, Standard Communication (Serial), Standard Communication (IP), FreeD, SRT
Number of Presets Max. 100 (including home position)
Communication Control LAN, Wi-Fi, Serial, IR, USB
Network Terminal LAN x 1, RJ45, 1000Base-T
12G/3G-SDI OUT Terminal BNC jack x1 12GSDI & x1 3G-SDI, 0.8 Vp-p/75
SMPTE ST 259, SMPTE ST 292, SMPTE ST 424/425, SMPTE ST2081, SMPTE ST 2082, SMPTE ST 272, SMPTE ST 299 compliant
Embedded audio, Time code (VITC/LTC)
GEN-LOCK Terminal BNC jack x 1, 1.0 Vp-p/75
Time Code Terminal BNC jack x 1, 1.3 Vp-p/50 or less
HDMI OUT Terminal HDMI connector x 1, output only
RS-422 Terminal RJ45 connector x 1
Audio Input 1 / Input 2 Terminals INPUT (3-pin jack) (pin1: shield, pin2: hot, pin3: cold), 2 sets, balanced
Sensitivity (MIC): -60 dBu (Manual volume center, full scale -18 dB)/1 k/Att.: 20 dB
Sensitivity (LINE): +4 dBu (Manual volume center, full scale -18 dB)/1 k or more
Supply Voltage: 48 V DC (Bias resistance: 6.8 k)
Mic Terminal 3.5 mm stereo mini jack (unbalanced, plug-in power supported)
Sensitivity (MIC): -72 dBV (Manual volume center, full scale -18 dB)/1 k or more/Att.: 20 dB
Sensitivity (LINE): -12 dBV (Manual volume center, full scale -18 dB)/1 k or more
Supply Voltage: 2.4 V DC (Bias resistance: 2.2 k)
Media Slot SD Card x1, future expansion, recording unavailable
Operating Environment Temperature: 0°C +40°C (+32°F +104°F)
Humidity: 10% 90% (without condensation)
Storage Environment Temperature: 0°C +40°C (+32°F +104°F)
Power Supply PoE: PoE++ power supply via LAN connector (IEEE802.3bt compliant)
External power source: 12 V DC Terminal
Power Consumption PoE++ Input: Approx. 34.4 W max. (body only)
DC Input: Approx. 33.8 W max. (body only)
Quietness NC35 or lower
Dimensions (W x H x D) Approx. 176 x 220 x 194 mm (6.93 x 8.66 x 7.64 in.) (excluding protrusions)
Weight Approx. 3.1 kg (6.8 lb.) (body only)
Supported Controllers Hardware: RC-IP100, RC-IP1000
Software: Remote Camera Control Application, Mulit-Camera Control Application, Multi-Camera Management Application, Camera Search tool
Title Firmware Notice: CR-N400: Firmware Version 1.1.0
Advisory Type Firmware Notice
Date 10.15.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
