Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
File Name 6080IM.pdf
Date 08.07.08
File Size 1.96 MB
File Name 6080QRG.pdf
Date 08.07.08
File Size 736.00 KB
Model Name DR-6080 Document Scanner
Type Production Document Scanner
Document Feeding Automatic or Manual
Document Size Width 2.2" - 12"
Document Size Length 2.8" - 17" (up to 39.4" long doc. mode)
Thickness Automatic Feeding 0.06 - 0.15mm
Thickness Manual Feeding 0.05 - 0.3mm
Feeder Capacity 500 sheets (LTR)
Grayscale 8-bit
Scanning Element Contact Image Sensor (CMOS)
Light Source RGB LED x 4
Operating Modes Simplex, Duplex, Grayscale, Black & White, Advanced Text Enhancement, Smoothing, Multistream&#153;
Drop Out Color RGB - User selectable (front/back/both)
Optical Resolution 600 dpi
Output Resolution 100/150/200/300/400/600 dpi
Scanning Speeds
Black And White 60ppm / 120ipm
Grayscale 60 ppm / 120ipm
File Format Bundled with Canon CapturePerfect Software for choice of output file formats.
Interface 1 USB 2.0 and 2 SCSI-III
Scanner Drivers For Windows&reg; 98SE/2000/Me/XP, Windows NT&reg;: ISIS&reg;, TWAIN
Dimensions 12.2" x 18.1" x 20.7"
Weight Approx. 55 lbs.
Power Consumption Max 28W
Options Imprinter, Endorser, Mechanical Counter, Barcode Module, Exchange Roller kit
Title To Users of the imageFORMULA R-Series, P-Series and DR-Series Scanners
Advisory Type
Date 11.13.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
