Canon Support for Elura 2 | Canon U.S.A., Inc.
Elura 2
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Battery packs BP-406, BP-412 & BP-422
File Name
Power Adapter CB-400
File Name
Power Adapter CH-910 Instruction Manual
File Name
DV Messenger Ver 1.0 Instruction Manual
File Name
File Name
File Name
Video Light VL-10Li
File Name
Elura 2 and Elura 2MC Instruction Manual
File Name
Elura 2 Instruction Manual
File Name
File Name
Battery Packs BP-406, BP-412 & BP-422
File Name
Video Light VL-10Li
Camera Connect
image.canon
SELECT ERROR CODE
| Power Supply (rated) | 7.4 V DC |
| Power Consumption | 4.4 W ( using viewfinder), 5.4 W (using LCD screen) |
| Television System | EIA standard ( 525 lines, 60 fields) NTSC color signal |
| Video Recording system | 2 rotary heads, helical scanning system DV system (consumer digital VCR SD system); Digital component recording |
| Audio Recording system | PCM digital sound, 16 bit (48 kHz/2 ch, 12bit(32 kHz/4 ch) |
| Image Sensor | 1/4" Progressive Scan CCD (charge coupled device) 680,000 pixels (360,00 effective pixels) |
| Tape Format | Videocassettes bearing the MiniDV mark |
| Tape Speed | SP: 3/4 ips (18.81 mm/sec.); LP 1/2 ips (12.56 mm/sec) |
| Maximum Recording Time (with an 80-min. cassette) | SP: 80 min ; LP: 120 min |
| Fast Forward/Rewind Time | 2 min 20 sec (with a 60 min cassette) |
| Lens | f1.6-2.5, 10x power zoom, 3.5-35.0mm |
| Focusing System | TTL autofocus, manual focusing possible |
| Focusing System | 3ft 3/68 om (1m); 3/8 in. (1cm) on maximum wide angle |
| Minimum Illumination | 7.5 lux using the Low-Light program |
| Recommended Illumination | More than 100 lux |
| Filter Diameter | 27 mm |
| Viewfinder | 0.44 in. color LCD; (approx. 113,000 pixels) |
| LCD Screen | 2.5 in measured diagonally (approx. 200,000 pixels) |
| Microphone | Stereo electret condenser microphone |
| DV Terminal | Special 4-pin connector (based on IEEE 1394) |
| Video Terminal | 1 Vp-p/75 ohm unbalanced |
| Output Levels | Video terminal: 1 vp-p/75 ohms unbalanced |
| S-video Terminal | 1 Vp-p (Y signal) 0.286 Vp-p (C signal) |
| Microphone Terminal | 3.5 mm stereo minijack, -57 dBV (with 600 kohm mic) at least 5 kohms |
| Operating Temperature range | 32-104° F ( 0° - 40° C) |
| Dimensions | 1 7/8 x 4 1/8 x 3 3/8 in. (48 x 106 x 86mm) |
| Weight | 13 3/4 oz. (390g ) |
Memory Card
| Recording Media | MultiMedia Card |
| Image Format | Design rule for Camera File system (DCF); Digital Print Order Format (DPOF) |
ADDITIONAL SUPPORT
CONTACT US
next to your download
