Canon Support for Elura 65 | Canon U.S.A., Inc.
Elura 65
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Elura 60/65/70 Instruction Manual
Camera Connect
image.canon
SELECT ERROR CODE
| Power Supply (rated) | 7.4 V DC |
| Power Consumption (While recording AF="ON") | 2.6 W (using viewfinder), 3.3 W (using LCD screen) |
| Television System | EIA standard (525 lines, 60 fields) NTSC color signal |
| Video Recording system | 2 rotary heads, helical scanning system DV system (Consumer digital system) Digital component recording |
| Audio Recording system | PCM digital sound: 16-bit (48 kHz/2 ch.), 12-bit (32 kHz/4 ch.) |
| Image Sensor | 1/4.5-inch CCD, approx. 1,330,000 pixels. Effective pixels: Tape approx. 690,000 pixels; Card approx. 1,230,000 pixels |
| Tape Format | Videocassettes bearing the MiniDV mark |
| Tape Speed | SP: 0.74 ips (18.81 mm/s), LP: 0.49 ips (12.56 mm/s) |
| Maximum Recording Time (with an 80-min. cassette) | SP: 80 min., LP: 120 min. |
| Lens | f=3.5-56, f/1.8-3.3, 16x power zoom |
| Focusing System | TTL autofocus, manual focusing possible |
| Focusing System | 3 ft. 3 3/8 in. (1 m), 3/8 in. (1 cm), on maximum wide angle |
| Minimum Illumination | 1.8 lx (using the night mode) |
| Recommended Illumination | More than 100 lx |
| Viewfinder | 0.33-inch TFT color, (approx. 113,000 pixels) |
| LCD Screen | 2.5-inch TFT color, (approx. 123,000 pixels) |
| Microphone | Stereo electret condenser microphone |
| DV Terminal | Special 4-pin connector (IEEE1394 compliant) |
| Video Terminal | 1 Vp-p/75 ohms unbalanced |
| S-video Terminal | 1 Vp-p/75 ohms (Y signal), 0.286 Vp-p/75 ohms (C signal) |
| Audio Terminal | Audio input: -10 dBV/40 kohms or more. Audio output: -10dBV (47 Kohm load)/3 Kohms or less. |
| Microphone Terminal | Elura 70/Elura 65 only: ø3.5 mm stereo mini-jack, -57 dBV (with 600 ohm mic)/5 kohms or more |
| Operating Temperature range | 32 - 104° F (0 - 40° C) |
| Dimensions | 3.1 x 2.9 x 5.1 in. (78 x 74 x 130 mm) excluding protrusions |
| Weight (not including lens and battery pack) | approx. 1.1 lb. (500g) |
Memory Card
| Recording Media | SD Memory Card, MultiMediaCard |
| Image Format | Still image: JPEG (compression: Superfine / Fine / Normal), Movie: AVI (image data: Motion JPEG; audio data: WAVE (monaural)) |
| File Format | Design rule for Camera File system (DCF), Exif 2.2 compliant, Digital Print Order Format (DPOF) compliant (only images marked for printing or transfer) |
ADDITIONAL SUPPORT
CONTACT US
next to your download
