Canon Support for EOS-1D | Canon U.S.A., Inc.
EOS-1D
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type
Type | Digital AF SLR (CCD sensor/Direct imaging) |
Recording Media | Type I and II CF card |
Image Format | 28.7 x 19.1 mm |
Compatible Lenses | Canon EF lenses |
Lens Mount | Canon EF lens mount |
Image Sensor
Type | High-sensitivity, high-resolution, large-area single-plate CCD sensor |
Pixels | Effective pixels: Approx. 4.15 megapixels (2496 x 1665) |
Aspect Ratio | 2:3 |
Color Filter System | RGB primary colors |
Low Pass Filter | Located in front of the CCD sensor, fixed |
Recording System
Recording Format | Design rule for Camera File system |
Image Format | JPEG and RAW, 36-bit true color (12 bits/RGB color), RAW + JPEG simultaneous recording |
File Size | (1) Large/Fine: approx. 2.4 MB (2464 x 1648 pixels)(2) Large/Normal: approx. 1.3 MB (2464 x 1648 pixels)(3) Small/Fine: approx. 1.1 MB (2464 x 1648 pixels)(4) RAW: approx. 4.8 MB (2496 x 1662 pixels)* Exact file sizes depend on the subject and ISO speed. |
Folders | Folder creation and selection possible |
File Numbering | Consecutive numbering, Auto reset, Manual reset |
Interface | IEEE 1394 (with dedicated cable) |
White Balance
Settings | 10 Settings: Auto, daylight, shade, overcast, tungsten light, fluorescent light, flash, custom, manual color temperature setting, personal white balance |
Auto White Balance | Hybrid auto balance with the CCD sensor and a dedicated, external sensor |
Color Temperature Compensation | White balance bracketing: +/- 3 steps in whole step increments (1 step = 5 mireds) |
Viewfinder
Type | Glass pentaprism, eye-level type with eyesight correction |
Coverage | 100% vertically and horizontally with respect the effective pixels |
Magnification | 0.72x (-1 diopter with 50mm at infinity) |
Eye Point | 20mm |
Dioptric Adjustment Correction | -3.0 - +1.0 diopter |
Focusing Screen | Interchangeable (9 types)Standard focusing screen: Ec-CIII |
Mirror | Quick-return half mirror (Transmission: reflection ratio of 63:37, no mirror cut off with EF 1200mm f/5.6 or shorter lens) |
Viewfinder Information | AF information (AF points, focus confirmation light), exposure information (shutter, speed, aperture, manual exposure, metering range, ISO speed, exposure level, exposure warning), flash information (flash ready, FP flash, FE lock, flash exposure level), JPEG format, number of remaining shots,CF card information |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Eyepiece Shutter | Built-in |
Autofocus
Type | TTL-AREA-SIR with CMOS sensor |
AF Frame | 45-point Area AF (W x H: 15mm x 8mm) |
AF Working Range | EV 0-18 (at ISO 100) |
Focusing Modes | One-Shot AF, AI Servo AF, Manual focusing (MF) |
AF Point Selection | Automatic selection, manual selection, home position (switch to registered AF point) |
Selected AF Point Display | Superimposed in viewfinder and indicated on top LCD panel |
AF Assist Beam | Emitted by the dedicated Speedlite's built-in AF-assist beam |
Exposure Control
Metering Modes | TTL full aperture metering with 21-zone SPC (1) Evaluative metering (linkable to any AF point)(2) Partial metering (approx. 13.5% of viewfinder at center)(3) Spot metering a. Center spot metering (approx. 3.8% of viewfinder at center) b. AF point-linked spot metering (approx. 3.8% of viewfinder at center) c. Multi-spot metering (Max. 8 spot metering entries)(4) Center weighted average metering |
Metering Range | EV 0-20 (at 20 °C/68 °F with 50mm f/1.4 lens, ISO 100) |
ISO Speed Range | Equivalent to ISO 200-1600 (in 1/3 stop increments), ISO speed can be expanded to ISO 100 and 3200 |
Exposure Compensation | Auto exposure bracketing (AEB): +/- 3 stops in 1/3 stop increments |
AE Lock | Auto: Operates in One-shot AF mode with evaluative metering when focus is achieved Manual: By AE lock button in all metering modes |
Shutter | Electronic shutter with the CCD sensor and vertical-travel, local-plane shutter with all speeds electronically-controlled1/16,000 to 30 sec. (1/3 stop increments), bulb, X-synch at 1/500th sec.Soft-touch electromagnetic release10-sec. or 20-sec. delayRemote switch N3-type terminal provided |
Type | Electronic shutter with the CCD sensor and vertical-travel, local-plane shutter with all speeds electronically-controlled |
Shutter Speeds | 1/16,000 to 30 sec. (1/3 stop increments), bulb, X-synch at 1/500th sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 20-sec. delay |
Remote Control | Remote switch N3-type terminal provided |
External Speedlite
EOS Dedicated Speedlite | Speedlite EX series E-TTL autoflash |
PC Terminal | Provided; operates regardless of sync polarity |
Drive System
Drive Modes | Single-frame, low-speed continuous, high-speed continuous |
Continuous Shooting Speed | Low-speed continuous: 3 fps. High-speed continuous: 8 fps |
Maximum Burst | 21 shots in Large/Fine, Large/Normal, Small/Fine modes16 shots in RAW, RAW+Large/Fine, RAW+Large/Normal,RAW+Small/Fine modes*Maximum shots per burst depends on the subject shooting mode, and ISO speed. |
LCD Monitor
Type | TFT color LCD monitor |
Monitor Size | 2.0 inches |
Pixels | Approx. 120,000 |
Coverage | Approx. 100% with respect to the effective pixels |
Brightness Control | Adjustable to one of five levels |
Playback
Display Format | (1)Single image with information(2) Single image(3) 4-image index(4) 9-image index |
Highlight Alert | In display formats (1) and (2) above, any overexposed highlight areas will blink in the image display |
AF Point Display | Displayed in the single image with information display format |
Image Protection and Erase
Protection | Erase protection of one image, all images in folder, or all images in the CF card can be applied or cancelled at one time. |
Erase | One image, all images in folder, or all images in the CF card can be erased (except protected images) at one time |
Sound Recording
Recording Methods | The voice narration recorded with the built-in microphone is attached to the image |
File Format | WAV |
Recording Time | Max. 30 sec. per recording |
Menus
Menu Categories | (1) Shooting menu(2) Image reviewing menu(3) Setup menu(4) Custom/Personal functions |
LCD Monitor Language | Japanese, English, French, German, Spanish |
Firmware Update | Update possible by the user |
Power Source
Battery | One Ni-MH Pack NP-E3*AC power can be supplied via the AC adapter and DC coupler |
Number of Shots | At 20°C/68°F: approx. 500. At 0°C/32°F: approx. 350 When a fully-charged Ni-MH Pack NP-E3 battery and EF 50mm f/1.4 USM lens are used; the photo image confirmation function is "on"; the confirmation display time is 2 sec.; and the file format is RAW + Large/Fine) |
Battery Check | Automatic |
Power Saving | Provided, Power turn off after 1, 2, 4, 8, 15, or 30 min. |
Back-up Battery | One CR2025 lithium battery |
Dimensions and Weight
Dimensions (W x H x D) | 156 x 157.6 x 79.9 mm/6.1 x 6.2 x 3.1 in. |
Weight | 1250 g/44.1 oz. (Body only. Battery: 335 g/11.8 oz.) |
Operating Environment
Working Temperature Range | 0 - 45°C/32 - 113°F |
Working Humidity Range | 85% or lower |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
