Canon Support for EOS 50D | Canon U.S.A., Inc.
EOS 50D
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels
Effective pixels: Approx. 15.10 megapixels
Total Pixels
Total pixels: Approx. 15.50 megapixels
Aspect Ratio
3:2 (Horizontal: Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the CMOS sensor
Dust Deletion Feature
(1) Automatic sensor cleaning
(2) Manual cleaning of sensor
(3) Dust Delete Data appended to the captured image
Recording Format
Design rule for Camera File System 2.0
Image Format
JPEG, RAW (14-bit, Canon original), sRAW, RAW+JPEG
File Size
(1) Large/Fine: Approx. 5.0MB (4752 x 3168 pixels)
(2) Large/Nomal: Approx. 2.5MB (4752 x 3168 pixels)
(3) Medium/Fine: Approx. 3.0MB (3456 x 2304 pixels)
(4) Medium/Normal: Approx. 1.6MB (3456 x 2304 pixels)
(5) Small/Fine: Approx. 1.7MB (2352 x 1568 pixels)
(6) Small/Normal: Approx. 0.9MB (2352 x 1568 pixels)
(7) RAW: Approx. 20.2MB (4752 x 3168 pixels)
(8) RAW+Large/Fine: Approx. 20.2+5.0MB (4752 x 3168 pixels)
(9) sRAW 1: Approx. 12.6MB (3267 x 2178 pixels)
(10) sRAW 1+Large/Fine: Approx. 12.6+5.0MB (3267 x 2178 pixels)
(11) sRAW 2: Approx. 9.2MB (2376 x 1584 pixels)
(12) sRAW 2+Large/Fine: Approx. 9.2+5.0MB (2376 x 1584 pixels)
Exact file sizes depend on the subject, ISO speed, Picture Style, etc.
Recording Functions
With the WFT-E3A attached, image recording to the CF card and to the USB external media connected to the WFT-E3A will be possible as follows:
(1) Standard
(2) Automatic switching of recording media
(3) Separate recordings according to image-recording quality
(4) Recording images having the same size
Backup Recording
Enabled with WFT-E3A attached
File Numbering
Consecutive numbering, auto reset, manual reset. Possible to create new folders and select folders in the CF card
RAW + JPEG Simultaneous Recording
Provided (sRAW+JPEG also possible)
Color Space
sRGB, Adobe RGB
Picture Style
Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3
Settings
Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom, Color Temperature setting
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
White balance correction: &plusmn;9 stops in full-stop increments
White balance bracketing: &plusmn;3 stops in full-stop increments
Blue/amber direction or magenta/green direction possible
Color Temperature Information Transmission
Provided
Type
Eye-level pentaprism
Coverage
Vertical/Horizontal approx. 95%
Magnification
Approx. 0.95x (-1m-1 with 50mm lens at infinity)
Eye Point
Approx. 22mm (from eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0m-1 (diopter)
Focusing Screen
Interchangeable (Ef-D: Grid lines, Ef-S {point of Focus), Ef-A standard focusing screen provided
Mirror
Quick-return half mirror (transmission: reflection ratio of 40:60, no mirror cut-off with EF600mm f/4L IS USM or shorter lenses)
Viewfinder Information
AF information (AF points, focus confirmation light), Exposure information (shutter speed, aperture, ISO speed, AE lock, exposure level, spot metering circle), Flash information (flash ready, flash exposure compensation, High-speed sync, FE lock, Red-eye reduction light), Image information (Highlight tone priority, monochrome shooting, maximum burst, white balance correction, CF card information)
Depth Of Field Preview
Enabled with depth-of-field preview button
Type
TTL-CT-SIR AF-dedicated CMOS sensor
AF Points
9 (Cross-type)
AF Working Range
EV 0.5-18 (at 73&deg;F/23&deg;C, ISO 100)
Focusing Modes
Auto, One-Shot AF, Predictive AI Servo AF, AI Focus AF, Manual focusing (MF)
AF Point Selection
Automatic selection, manual selection
Selected AF Point Display
Superimposed in viewfinder and indicated on LCD panel
AF Assist Beam
Small series of flashes fired by built-in flash
Effective range: Approx. 13.1 ft./4.0m at center, approx. 11.5 ft./3.5m at periphery
Metering Modes
35-zone TTL full-aperture metering Evaluative metering (linkable to any AF point)Partial metering (approx. 9% of viewfinder at center)Spot metering (approx. 3.8% of viewfinder at center)Center-weighted average metering
Metering Range
EV 1-20 (at 73&deg;F/23&deg;C with EF50mm f/1.4 USM lens, ISO 100)
ISO Speed Range
Basic Zone modes: ISO 100-1600 set automatically
Creative Zone modes: ISO 100-3200 (in 1/3-stop increments), Auto, or ISO speed can be expanded to ISO 6400 or ISO 12800
Extension settable (with C.Fn.I-3-1): ISO 12800
High Tone Priority settable: ISO 200-1600
Exposure Compensation
Manual: &plusmn;3 stops in 1/3- or 1/2-stop increments (can be combined with AEB)
AE Lock
Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved
Manual: By AE lock button
Shutter
Vertical-travel, mechanical, Electronically-controlled, focal-plane shutter1/8000 to 1/60 sec., X-sync at 1/250 sec.
1/8000 to 30 sec., bulb (Total shutter speed range.
Available range varies by shooting mode)Soft-touch electromagnetic release10-sec. or 2-sec. delayRemote control with N3-type terminal
Type
Shutter Speeds
Shutter Release
Self Timer
Remote Control
Type
Retractable, auto pop-up flash
Guide Number
13/43 (ISO 100, in meters/feet)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready icon lights in viewfinder
Flash Coverage
17mm lens angle of view
FE Lock
Provided
Flash Exposure Compensation
Up to &plusmn;2 stops in 1/3- or 1/2-stop increments
Zooming to Match Focal Length
Provided
Flash Metering
E-TTL II autoflash
FE Lock
Provided
External Flash Settings
Flash function settings, Flash C.Fn settings
Drive Modes
Single, High-speed continuous, Low-speed continuous, and Self-timer (10 sec. or 2 sec. delay)
Continuous Shooting Speed
High-speed: Max. 6.3 shots/sec.
Low-speed: Max. 3 shots/sec.
Maximum Burst
JPEG (Large/Fine): approx. 60 (CF)/approx. 90 (UDMA CF)
RAW: approx. 16
RAW+JPEG (Large/Fine): approx. 11
Based on Canon's testing standards with a 2GB CF card, high-speed continuous shooting, ISO 100 and Standard Picture Style
Varies depending on the subject, CF card brand, image-recording quality, ISO speed, drive mode, Picture Style, etc.
Shooting Modes
(1) Live View shooting
(2) Remote Live View shooting (with a personal computer installed with EOS Utility)
Focusing
Manual focus
Autofocus (Live View image interrupted for AF): Quick mode, Live mode, Live Face Detection mode
Metering Modes
Evaluative metering with the image sensor
Metering Range
EV 0-20 (at 73&deg;F/23&deg;C with EF 50mm f/1.4 USM lens, ISO 100)
Magnified View
By 5x or 10x at AF point
Grid Display
Provided
Exposure Simulation
Provided
Silent Shooting
Provided (Mode 1 and 2)
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0 in.
Pixels
Approx. 920,000 (VGA)
Coverage
Approx. 100% (viewing angle: approx. 160&deg;)
Brightness Control
7 levels provided
Interface Languages
25
Display Format
Single image, Single image + Image-recording quality/shooting information, histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image (auto/manual), image jump (by 10/100 images, index screen, by shooting date, by folder), slide show (all images/selected by date/folder)
Highlight Alert
Provided (Overexposed highlights blink)
Protection
Single images can be erase-protected or not
Erase
Single image, check-marked images or all images in the CF card can be erased (except protected images)
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG images compliant to Design rule for Camera File System (DPOF printing possible) and RAW/sRAW images captured with the EOS 50D
Easy Print feature
Provided
DPOF
Version 1.1 compatible
Compatible Images
JPEG and RAW images
Only JPEG images can be transferred as wallpaper on the personal computer screen
Custom Functions
Total 25
Camera User Settings
Register under Mode Dial's C1 and C2 positions
My Menu Registration
Provided
Battery
One Battery Pack BP-511A
AC power can be supplied via optional AC Adapter Kit ACK-E2(with optional Battery Grip BG-E2N or BG-E2 attached, AA-size batteries can be used)
Number of Shots
Number of shots (approx.)
Battery Check
Auto
Power Saving
Provided. Power turns off after 1, 2, 4, 8, 15 or 30 min.
Date/Time Battery
One CR2016 lithium-ion battery
Start-up Time
Approx. 0.1 sec. (Based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 5.7 x 4.2 x 2.9 in./145.5 x 107.8 x 73.5mm
Weight
Approx. 25.7 oz./730g (body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: EOS Utility
Advisory Type
Date 12.12.19
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Service Notice: EOS 7D, EOS 40D, EOS 50D, and EOS 60D: Peripheral AF points do not function as cross-type AF points
Advisory Type
Date 02.20.11
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
