Canon Support for EOS 5DS R | Canon U.S.A., Inc.
EOS 5DS R
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
Software Development Kit
SELECT ERROR CODE
Type | Digital, AF/AE single-lens reflex, camera |
Recording Media | CF card * Type I drive (Incompatible with Type II and Microdrive.) * High-speed writing possible with UDMA CF cards. SD, SDHC, and SDXC memory cards * High-speed writing possible with UHS-I SD cards. * MultiMediaCard (MMC) cannot be used. (A card error will be displayed.) |
Image Format | Approx. 36 mm x 24mm (35mm Full-frame) |
Compatible Lenses | Canon EF Lenses (excluding EF-S Lenses) |
Lens Mount | Canon EF mount |
Type | High-sensitivity, high-resolution, large single-plate CMOS sensor |
Pixels | Effective pixels: Approx. 50.60 megapixels Total pixels: 53.00 megapixels |
Pixel Unit | 4.14µm square |
Total Pixels | Total Pixels: 53.00 megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the image sensor |
Dust Deletion Feature | Self Cleaning Sensor Unit * Removes dust adhering to the low-pass filter. * At power ON: Performed for approx. 3 sec. (Operation indicated for 2 sec.) At power Off: Performed for approx. 2 sec. Manual operation: Performed for approx. 8.5 sec. * Magnesium fluoride coating on the low-pass filter surface applied. Dust Delete Data acquisition and appending * The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. * The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots. Manual cleaning |
Recording Format | Design Rule for Camera File System 2.0 and EXIF 2.3 |
Image Format | Still Image: JPEG, RAW (14-bit Canon Original), RAW, M-RAW, S-RAW, RAW+JPEG, M-RAW+JPEG, S-RAW+JPEG Video: MOV (Image data: H.264/MPEG-4 AVC; Audio: Linear PCM) |
File Size | Full Size Large: Approx. 50.3 Megapixels (8688 x 5792)Medium 1: Approx. 39.3 Megapixels (7680 x 5120)Medium 2: Approx. 22.1 Megapixels (5760 x 3840)S1 (Small 1): Approx. 12.40 Megapixels (4320 x 2880)S2 (Small 2): Approx. 2.50 Megapixels (1920 x 1280)S3 (Small 3): Approx. 350,000 Pixels (720 x 480)RAW: Approx. 50.3 Megapixels (8688 x 5792)M-RAW: Approx. 28.50 Megapixels (6480 x 4320)S-RAW: Approx. 12.40 Megapixels (4320 x 2880) Crop - 1.3x Large: Approx. 30.5 Megapixels (6768 x 4512)Medium 1: Approx. 24.1 Megapixels (6016 x 4000)Medium 2: Approx. 13.6 Megapixels (4512 x 3008)S1 (Small 1): Approx. 7.6 Megapixels (3376 x 2256)S2 (Small 2): Approx. 2.5 Megapixels (1920 x 1280)S3 (Small 3): Approx. 0.35 Megapixels (720 x 480) Crop - 1.6x Large: Approx. 19.6 Megapixels (5424 x 3616)Medium 1: Approx. 15.4 Megapixels (4800 x 3200)Medium 2: Approx. 8.7 Megapixels (3616 x 2408)S1 (Small 1): Approx. 4.9 Megapixels (2704 x 1808)S2 (Small 2): Approx. 2.50 Megapixels (1920 x 1280)S3 (Small 3): Approx. 0.35 Megapixels (720 x 480) Aspect Ratio - 1:1Large: Approx. 33.5 Megapixels (5792 x 5792)Medium 1: Approx. 26.2 Megapixels (5120 x 5120)Medium 2: Approx. 14.7 Megapixels (3840 x 3840)S1 (Small 1): Approx. 8.3 Megapixels (2880 x 2880)S2 (Small 2): Approx. 1.6 Megapixels (1280 x 1280)S3 (Small 3): Approx. 0.23 Megapixels (480 x 480) Aspect Ratio: 4:3 Large: Approx. 44.7 Megapixels (7712 x 5792)Medium 1: Approx. 34.9 Megapixels (6816 x 5120)Medium 2: Approx. 19.7 Megapixels (5120 x 3480)S1 (Small 1): Approx. 11.1 Megapixels (3840 x 2880)S2 (Small 2): Approx. 2.2 Megapixels (1712 x 1280)S3 (Small 3): Approx. 0.31 Megapixels (640 x 480) Aspect Ratio: 16:9 Large: Approx. 42.5 Megapixels (8688 x 4888)Medium 1: Approx. 33.2 Megapixels (7680 x 4320)Medium 2: Approx. 18.7 Megapixels (5760 x 3240)S1 (Small 1): Approx. 10.5 Megapixels (4320 x 2432)S2 (Small 2): Approx. 2.1 Megapixels (1920 x 1080)S3 (Small 3): Approx. 0.28 Megapixels (720 x 408) Exact file sizes depend on the subject, ISO speed, Picture Style, etc. |
Recording Functions | Standard * Records to either the CF card or SD card. Auto switch card * When the current card becomes full, the camera switches to the other card automatically. Record separately * The CF card and SD card record the same image at a different image recording quality (L, M, S1, S2, S3, RAW, M-RAW, S-RAW)Record to multiple * Both the CF card and SD card record the same image at the same image recording quality. (Also applies to RAW+JPEG, M+JPEG, and SRAW+JPEG) |
Backup Recording | Images recorded in a card can be copied to the other card |
File Numbering | The following three types of file numbers can be set: (1) Continuous numbering * The continuous numbering of captured images will continue even after you replace the camera's card. (The numbering continues even when the folder changes.) (2) Auto reset * When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card. (3) Manual reset * Resets the file number to 0001, and creates a new folder automatically. |
RAW + JPEG Simultaneous Recording | The image-recording quality can be selected in any combination of the three RAW and eight JPEG recording quality settings. |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style | Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3 * Scene Intelligent Auto will set [Auto] automatically. * [Standard] is the default setting for [User Def. 1-3] |
Settings | Auto (AWB)Daylight Shade Cloudy, Twilight, Sunset Tungsten light White fluorescent light Flash Custom (Custom WB)Color temperature * With an EX-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000K if the flash unit does not have the color temperature communication feature. |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels *Corrected in reference to the current WB mode's color temperature. |
Color Temperature Information Transmission | Provided |
Type | Eye-level pentaprism |
Coverage | Approx. 100% vertically and horizontally (At approx. 21mm eyepoint) |
Magnification | Approx. 0.71x / Angle of view 34.1° (with 50mm lens at infinity, -1 m-1 (dpt)) |
Eye Point | Approx. 21mm (At -1m-1 from the eyepiece lens center) |
Dioptric Adjustment Correction | -3.0 to +1.0m-1 (diopter) |
Focusing Screen | Fixed |
Mirror | Quick-return half mirror (transmission: reflectance ratio of 40:60) |
Viewfinder Information | AF information AF point, focus confirmation, AF status indicator Exposure information Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, exposure warning Flash information Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light Image information Highlight tone priority (D+), maximum burst (2-digit display), card information Battery check Composition information Grid, electronic level Warning symbol Displayed if any of the following is set: Monochrome, white balance correction, One-touch recording quality switch, expanded ISO speed, or spot metering. |
Depth Of Field Preview | Enabled with Depth-of-field preview button |
Type | TTL Secondary image registration, phase detection with AF-dedicated CMOS sensor |
AF Points | 61-point High-Density Reticle AF |
AF Working Range | EV -2 - 18 (at 73°F/23°C and ISO 100) |
Focusing Modes | (1) Autofocus One-Shot AF Predictive AI Servo AF For automatic AF point selection, the AF point to start the AI Servo AF operation can be selected. For automatic AF point selection, the active AF point can be displayed.AI Focus AF (Switches between One-Shot AF and AI SERVO AF automatically)Automatically set in A+ (Auto) Mode(2) Manual focus (MF) |
AF Point Selection | Single-point Spot AF (Manual selection)Single-point AF (Manual selection) *The checkmark cannot be removed from this option.AF point expansion (Manual selection, 4 points: Up, down, left, and right)AF point expansion (Manual selection, surrounding 8 points)Zone AF (Manual zone selection Auto selection 61-Point AF) |
Selected AF Point Display | Displayed in viewfinder with transparent LCD and on LCD panel |
Active AF Point Indicator | AF area used in horizontal/vertical (grip up or down) shooting and the manually-selected AF point position can be set separately |
AF Assist Beam | Enable With an EOS-dedicated Speedlite, AF-assist beam is emitted automatically when necessary. Disable IR AF assist beam only * No AF-assist beam with flash bursts. |
Metering Modes | Approx. 150,000-pixel RGB+IR metering sensor EOS iSA System with 252-zone (18 x 14) metering Evaluative metering (linked to all AF points)Partial metering (center, approx. 6.1% of viewfinder)Spot metering (center, approx. 1.3% of viewfinder) •AF point-linked spot metering not provided. Center-weighted average metering a.The selectable metering modes can be restricted with a Custom Function. |
Metering Range | EV 0-20 (at 73°F / 23°C at ISO 100) |
Exposure Control Systems | (1) Scene Intelligent Auto (2) Program AE (shiftable) (3) Shutter-priority AE (Safety shift possible) (4) Aperture-priority AE (Safety shift possible) (5) Manual exposure * The metering mode can be specified with a Custom Function. (6) Bulb (7) Custom shooting mode, C1, C2, C3 * Evaluative metering, Averaged metering |
ISO Speed Range | * For (Highlight tone priority), the settable ISO speed range will be ISO 200–6400. * ISO speed safety shift possible with Custom Function. * For movie shooting, the maximum expanded ISO speed is also ISO 12800. ISO 100-6400 (in 1/3-stop or whole-stop increments)ISO speed expansion possible to ISO 50, 51200, and 102400.For [Highlight tone priority], the settable ISO speed range will be 200-25600.-->ISO speed expansion possible to ISO 50 and 12,800ISO speed safety shift possible with Custom Function. *1: It depends on (Minimum) and (Maximum) of (Auto ISO range). *2: If overexposure would occur with fill flash, the minimum ISO speed is set to ISO 100 (except for M and B). *3: Auto set for ISO 400–1600 in the P mode with external Speedlite set for bounce flash. ISO Speed upper and lower limits: (1) Manual setting range * ISO speed expansion is set with this option. (2) Auto ISO ranger * ISO speed expansion not settable. |
Exposure Compensation | Manual: ±5 stops in 1/3 or 1/2-stop increments AEB: ±3 stops in 1/3 or 1/2-stop increments * Indicated up to ±3 stops on the LCD panel and in the viewfinder. |
AE Lock | (1) Auto AE lock ·In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved. (2) Manual AE lock ·With AE lock button. (AE lock is updated each time you press the button.) Enabled in all metering modes. |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
Shutter Speeds | X-sync at 1/200 sec. 1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.) * Shutter speed's control range can be set with a Custom Function. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay |
Shutter Lag Time | During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.059 sec. * During silent shooting, approx. 0.108 sec. * With flash, approx. 0.086 sec. * During silent shooting with flash, approx. 0.108 sec. Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.186 sec. * During silent shooting, approx. 0.230 sec. * With flash, approx. 0.236 sec. * During silent shooting with flash, approx. 0.255 sec. |
EOS Dedicated Speedlite | E-TTL II autoflash with all EX Series Speedlites |
Zooming to Match Focal Length | Provided |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings | The camera can set the following with Speedlite 600EX-RT, 580EX II, 430EX II, 320EX, 270EX II, or 270EX: (1) External flash control * Flash mode, sync setting, FEB (not possible with 270EX II/270EX), flash exposure compensation, E-TTL II, zoom, wireless master flash (not possible with 430EX II/ 270EX), and clear settings. * With the Speedlite 600EX-RT, radio wireless control is possible. (2) Flash Custom Function setting |
PC Terminal | Provided (no polarity) |
Drive Modes | Single, High-speed continuous, Low-speed continuous, Silent Single Shooting, Silent continuous shooting, and Self-timer (10 sec. self-timer/remote control, or 2-sec. self-timer/remote control) |
Continuous Shooting Speed | High-speed: Maximum approx. 5.0 shots/sec. Low-speed: Maximum approx. 3.0shots/sec. Silent continuous shooting: Maximum approx. 3.0 shots/sec. |
Maximum Burst | * The number of possible shots and maximum burst apply to an 8 GB card based on Canon's testing standards. * The image file size, number of possible shots, and maximum burst will vary depending on the shooting conditions (aspect ratio 3:2, subject, memory card brand, ISO speed, Picture Style, etc.). * The "F" after the number indicates that continuous shooting is possible until the card becomes full. |
Shooting Modes | Still photo and video recording |
Focusing | Contrast AF Manual Focus |
Metering Modes | Evaluative metering (315-zone)Partial metering (approx. 6.4% of Live View screen)Spot metering (approx. 2.8% of Live View screen)Center-weighted average metering *AE lock possible. *The active metering timer can be changed. |
Metering Range | Metering range: EV 0 - EV 20 (At 73°F / 23°C, ISO 100) |
Grid Display | Three grid display provided9 sections24 sections9 sections + diagonal lines |
Exposure Simulation | Provided |
Silent Shooting | Provided (Mode 1 and Mode 2) |
File Format | MOV MPEG-4 AVC / H.264 Variable (averaged) bit rate |
File Size | Recording Sizes: 1920 x 1080 (Full HD), 1280 x 720 and 640 x 480 |
Frame Rates | [1920 x 1080]: 30 fps / 25 fps / 24 fps [1280 x 720]: 60 fps / 50 fps [640 x 480]: 30 fps / 25 fps |
Continuous Shooting Time | * If the recording time reaches 29 min. 59 sec., the movie shooting will stop automatically. * There is no 4 GB file size limit for when the shooting stops automatically. |
Focusing | Same as focusing with Live View shooting * During movie shooting or if movie cropping has been set, the image cannot be magnified for manual focusing. |
Range | Manual Settings: Normal ISO Speeds: ISO 100-6400 (in 1/3-stop or whole-stop increments) Expanded ISO Speeds: L: equivalent to ISO 50, H: equivalent to ISO 12800 * For [Highlight tone priority], the settable ISO speed range will be ISO 200-6400. * ISO speed safety shift possible with Custom Function. * For movie shooting, the maximum expanded ISO speed is also ISO 12800. Auto Settings: A+: ISO 100-3200 (No Flash) / ISO 100-6400 (With Flash) P/Tv/Av/M: ISO 100-6400*1 (No Flash) / ISO 400 Fixed*1,*2, *3 B: ISO 400 Fixed (No Flash) / ISO 400 Fixed*1,*2, *3 *1: It depends on [Minimum] and [Maximum] of [Auto ISO range]. *2: If overexposure would occur with fill flash, the minimum ISO speed is set to ISO 100 (except for M and B). *3: Auto set for ISO 400-1600 in the P mode with external Speedlite set for bounce flash. |
Exposure Control | ISO speed for still photos during movie shooting: *1: ISO 100 – ISO 3200 *2: ISO 100 – ISO 6400 *3: Same as the ISO speed used for movie shooting. |
Exposure Compensation | Up to ±3 stops in 1/3-stop increments * For movies, even if exposure compensation has been set beyond ±3 stops, exposure compensation up to only ±3 stops will be applied. * For still photos, exposure compensation up to ±5 stops can be applied. |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.2-inches (Screen aspect ratio 3:2) Approx. 8.11cm (7.13cm width, 5.19cm height) |
Pixels | Approx. 1.04 million dots |
Coverage | Approx. 100% Approx. 170° vertically and horizontally |
Brightness Control | Auto: Brightness adjusted automatically by the light sensor * Adjustable to one of three levels: Darker, Standard, Brighter Manual: Adjustable to one of seven brightness levels |
Coating | Clear View LCD II * Glass surface has an anti-reflective AR coating. |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
Display Format | Single image, Single image + Image-recording quality/shooting information, histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image (auto/manual), image jump (by 10/100 images, index screen, by shooting date, by folder), two-image comparative display, slide show (all images/selected by date/folder), star rating |
Highlight Alert | With single-image display (Info.) and single-image display, overexposed highlight areas will |
Items | The following functions can be set: Shutter speed, aperture, ISO speed, exposure compensation, AEB, flash exposure compensation, AF point selection (including AF area selection modes), Picture Style, White Balance, WB Correction, metering mode, Auto Lighting Optimizer, recording function switching, image-recording quality, AF mode, drive mode, and Custom Controls (camera controls/buttons customization). |
Protection | Erase protection can be applied or canceled for a single image, all images in a folder or all images in the card |
Erase | Erase a single image, selected images, all images in a folder, all images in a card or erase only unprotected images |
Compatible Printers | PictBridge-compatible printers |
Printable Images | RAW and JPEG images complying to Design rule for Camera File System ·Movies cannot be printed |
DPOF | Version 1.1 compatible |
Compatible Images | JPEG and RAW images and movie For RAW+JPEG, only the RAW or JPEG image or both images can be transferred |
Custom Functions | 16 Custom Functions settable with the camera |
Custom Controls | The following camera controls can be customized by assigning the desired function: Shutter button halfway pressing, AF-ON button, AE lock button, Depth-of-field preview button, lens AF Stop button, Multifunction button, SET button, Main Dial, Quick Control Dial, and Multi-controller |
Camera User Settings | Current camera settings can be registered to C1, C2 and C3 on the Mode Dial (Automatic registration update is possible) |
My Menu Registration | Up to six top-tier menu options and Custom Function settings can be registered |
USB Terminal | For personal computer communication and direct printing (USB 3.0) |
Video Out Terminal | (1) Video OUT terminal: NTSC/PAL selectable (2) mini-HDMI OUT terminal |
Extension System Terminal | For connection to WFT-E7A (Version 2) and GPS Receiver GP-E2 |
Gigabit-Ethernet | The RJ-45 jack is not built-in and is only available via the Wireless File Transmitter WFT-E7A (version 2) |
Battery | One Battery Pack LP-E6 AC power can be supplied with the AC Adapter Kit ACK-E6 |
Battery Life | 1) Camera body only:1) With Battery Grip:* Based on CIPA testing standards |
Battery Check | Automatic battery check when the power switch is turned on: Displayed in 6 levels: ·Battery level displayed on LCD panel and in viewfinder. ·Battery information can be checked with the [Battery info.] menu ·If Battery Grip BG-E11 is used with size AA/LR6 batteries; the battery level is displayed in four levels instead. |
Power Saving | Power turns off after the set time (1, 2, 4, 8, 15 or 30 minutes) of non-operation elapses. |
Date/Time Battery | CR1616 lithium battery |
Start-up Time | Approx. 0.1 sec |
Dimensions (W x H x D) | Approx. 5.98 x 4.58 x 3.01 in. (152.0 x 116.4 x 76.4mm) |
Weight | Approx. 32.80 oz. / 930g (Based on CIPA standards) Approx. 29.80 oz./ 845g (Body only) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
