Canon Support for EOS 77D | Canon U.S.A., Inc.
EOS 77D
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Digital AF/AE single-lens reflex camera with built-in flash
Recording Media
SD/SDHC/SDXC memory cards
  • SD speed class-compatible
  • UHS-I compatible
  • High-speed writing is supported when a UHS-I compatible SD card is used.
  • Compatible with Eye-Fi Cards.
  • Multimedia cards (MMC) cannot be used (card error will be displayed).
Image Format
Approx. 22.3 x 14.9mm (APS-C Size)
Compatible Lenses
Canon EF lenses (including EF-S lenses, excluding EF-M lenses)
Lens Mount
Canon EF mount
Type
CMOS sensor (supporting Dual Pixel CMOS AF)
Pixels
Effective pixels: Approx. 24.2 Megapixels
Total pixels: Approx. 25.8 Megapixels
Pixel Unit
Approx. 3.72 &micro;m square
Aspect Ratio
3:2 (Horizontal: Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Installed in front of the image sensor, non-detachable
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
    • Removes dust adhering to the low-pass filter.
    • Self-cleaning executed automatically (taking approx. 2 sec.) when power is turned on or off. Manual execution also possible (taking approx. 7 sec.).
    • After the cleaning is performed, the camera will automatically restart (power OFF to ON).
  2. Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
    • The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
  3. Manual cleaning
Recording Format
Compliant to Design rule for Camera File system 2.0 and EXIF 2.3
Image Format
Still Image: JPEG, RAW (14 bit Canon Original)
Video: MOV (Full HD Movie: MPEG4 AVC/H.264*; Audio: Linear PCM), MP4 (Movie: MPEG4 AVC/H.264*; Audio: AAC) * Variable (averaged) bit rate
File Size
3:2 Aspect Ratio
Large: 6000 x 4000
Medium: 3984 x 2656
Small 1: 2976 x 1984
Small 2: 2400 x 1600
RAW: 6000 x 4000
4:3 Aspect Ratio
Large: 5328 x 4000*
Medium: 3552 x 2664
Small 1: 2656 x 1992
Small 2: 2112 x 1600*
RAW: 6000 x 4000
16:9 Aspect Ratio
Large: 6000 x 3368*
Medium: 3984 x 2240*
Small 1: 2976 x 1680*
Small 2: 2400 x 1344
RAW: 6000 x 4000
1:1 Aspect Ratio
Large: 4000 x 4000
Medium: 2656 x 2656
Small 1: 1984 x 1984
Small 2: 1600 x 1600
RAW: 6000 x 4000
  • Values for recording pixels are rounded to the nearest 100,000.
  • JPEG images are generated in the set aspect ratio.
  • RAW images are generated in [3:2], and the set aspect ratio is appended.
* Indicate an inexact proportion.
File Numbering
The following three types of file numbering method can be set:
  1. File numbering method
    Continuous numbering
    • The numbering of captured images will continue even after you replace the camera's card.
    Auto reset
    • When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording
Simultaneous recording is possible using a combination of RAW and JPEG (Large).
Color Space
sRGB, Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    • In Basic Zone modes, [Auto] will be set for and of the mode, and [Standard] will be set for other modes.
    • In Creative Zone modes, you can select or set the Picture Style.
    • [Auto] is the default setting for [User Def. 1-3].
Settings
  1. Auto (Ambience priority/White priority)
  2. Daylight
  3. Shade
  4. Cloudy*
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
    * Effective also in twilight and sunset.
Auto White Balance
Option between ambience priority and white priority settings
Color Temperature Compensation
Blue/amber bias: &plusmn;9 levels
Magenta/green bias: &plusmn;9 levels Corrected in reference to the current WB mode&rsquo;s color temperature.
Type
Eye-level SLR (with fixed pentamirror)
Magnification
Approx. 0.82x / 23.2&deg (50mm lens at &infin;, -1m-1 dpt)
Eye Point
Approx. 19mm (At -1m-1 from the eyepiece lens center)
Dioptric Adjustment Correction
Adjustable from approx. -3.0 to +1.0m-1 (dpt)
Focusing Screen
Fixed
Mirror
Quick-return half mirror (transmission: reflection ratio of 40:60)
Viewfinder Information
Displayed with transparent liquid crystal
  1. AF point information
    • Including Area AF frame
  2. Spot metering circle
  3. Electronic level
  4. Grid
  5. Aspect line
  6. Flicker detection
Depth Of Field Preview
Provided with depth of field preview button
Metering Modes
7560-pixel RGB+IR metering sensor
63-zone (9 x 7) metering
(1) Evaluative metering (linked to all AF points)
(2) Partial metering (center, approx. 6.0% of viewfinder)
(3) Spot metering (center, approx. 3.5% of viewfinder)
(4) Center-weighted average metering
Metering Range
EV 1-20 (room temperature, ISO 100, evaluative metering)
Exposure Control Systems
  1. Creative Zone
    1. Program AE (Shiftable)
    2. Shutter-priority AE
    3. Aperture-priority AE
    4. Manual exposure (including bulb)
  2. Basic Zone
    1. Scene Intelligent Auto (Program AE/ non-shiftable)
    2. Flash Off
    3. Creative Auto
    4. Portrait
    5. Landscape
    6. Close-up
    7. Sports
    8. Special Scene
      1. Group Photo
      2. Kids
      3. Food
      4. Candlelight
      5. Night Portrait
      6. Handheld Night Scene
      7. HDR Backlight Control
    9. Creative Filters
      1. Grainy B/W
      2. Soft Focus
      3. Fish-eye Effect
      4. Water Painting Effect
      5. Toy Camera Effect
      6. Miniature Effect
      7. HDR Art Standard
      8. HDR Art Vivid
      9. HDR Art Bold
      10. HDR Art Embossed
AE Lock
  1. Auto AE lock
    • In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
  2. Manual AE lock
    • In the P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
    • Possible with all metering modes.
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds
1/4000 to 30 sec., bulb (total shutter speed range. Available range varies by shooting mode.)
X-sync at 1/200 sec.
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. or 2-sec. delay
Shutter Lag Time
  1. With SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.070 sec.
  2. Time lag between simultaneous SW-1/SW-2 ON and start of exposure: approx. 0.250 sec.
    • Time lag with the aperture stopped down by 3 stops or less from the open aperture. Excludes AF operation time.
Type
Auto pop-up, retractable built-in flash at the pentamirror
Flash Metering System
E-TTL II autoflash with all EX Series Speedlites
Guide Number
Approx. 39.4 / 12 (at ISO 100 in feet / meters)
Flash Coverage
Up to approx. 17mm focal length (equivalent to approx. 28mm in 135 format)
FE Lock
Provided
Flash Exposure Compensation
±2 stops in 1/3 - or 1/2 - stop increments
  • Flash exposure compensation for built-in flash and external Speedlite can be set from the camera.
±2 stops in 1/3- or 1/2-stop increments
FE Lock
Provided
FE Lock
Provided
External Flash Settings
  1. External flash control
    • Flash firing, E-TTL II metering, Flash mode, Wireless functions, Flash zoom, Shutter synchronization, Flash exposure compensation, Flash exposure bracketing and Clear settings.
    • The radio wireless flash functions can be set from the camera.
  2. External flash Custom Function setting
    • The setting options for both (1) and (2) will differ depending on the Speedlite used.
Drive Modes and Continuous Shooting Speed during Viewfinder Shooting
  1. Single shooting
  2. High-speed continuous shooting
    • Max. approx. 6.0 fps.
    • Maximum continuous shooting speed with 1/500 sec. or faster shutter speed, maximum aperture (varies depending on the lens), Anti-flicker shooting set to Disable, with a fully-charged Battery Pack LP-E17 and at room temperature (73°F/23°C).
    • With the AF mode set to One-Shot AF and the Image Stabilizer turned off when using the following lenses: EF 300mm f/4L IS USM, EF 28-135mm f/3.5-5.6 IS USM, EF 75-300mm f/4-5.6 IS USM, EF 100-400mm f/4.5-5.6L IS USM.
  3. Low-speed continuous shooting
    • Max. approx. 3.0 fps
  4. Self-timer: 10 sec./remote control
  5. 2 sec. self-timer
  6. Continuous shooting after 10-sec. self-timer (2 to 10 shots)
Shooting Modes
Still photo shooting and video shooting
Focusing
  1. Dual Pixel CMOS AF
    • Dual Pixel CMOS AF is possible with all EF and EF-S lenses.
    • Contrast AF is not provided.
  2. Manual focus
    • Magnifying the image by 5x or 10x for manual focus possible.
Metering Modes
Real-time metering with image sensor
  • AE lock possible. The metering timer can be changed.
  1. Evaluative metering (315-zone)
  2. Partial metering (center, approx. 6.0% of viewfinder)
  3. Spot metering (center, approx. 2.6% of viewfinder)
  4. Center-weighted average metering
    • AE lock possible. The active metering timer can be changed.
Metering Range
EV 0-20 (room temperature, ISO 100, evaluative metering)
Grid Display
  1. Off
  2. 3x3
  3. 6x4
  4. 3x3+diag
Exposure Simulation
&plusmn;3 stop increments
File Format
MP4
Video: MPEG-4 AVC / H.264
  • Variable (averaged) bit rate
Audio: AAC
MOV: LL-I (FHD 29.98, time-lapse movies only)
Focusing
  2. Manual focus
    • Magnifying the image by 5x or 10x for manual focus possible (not possible during movie shooting).
Range
Full range (0-255)
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0-inch (screen aspect ratio of 3:2)
Approx. 3.03 in./7.70cm diagonal (approx. 2.51 in./6.37cm width, approx. 1.67 in/4.25cm height)
Pixels
Approx. 1.04 million dots
Coverage
Approx. 95%*
* When the aspect ratio is 16:9, vertical viewfinder coverage is approx. 93%.
Brightness Control
Adjustable to one of seven brightness levels
Coating
Clear View LCD II
  • Anti-smudge coating applied.
  • Anti-reflection coating not applied.
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
  1. Single-image display
    • No information display
    • Basic information display
    • Detailed shooting information display
      • Basic shooting information
      • Lens information and RGB histogram
      • White balance
      • Picture Style and sharpness
      • Contrast, color saturation and color tone
      • Color space and noise reduction
      • Lens aberration correction
      • GPS information (when GPS Receiver is used)
  2. Index display
    • 4-image
    • 9-image
    • 36-image
    • 100-image
Highlight Alert
With detailed information display, overexposed highlight areas with no image data will blink
Histogram
Brightness and RGB
Items
Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback.
After selecting an item, you can select contents by operating the Main Dial.
Protection
  1. Single image (select image)
  2. Select range
  3. All images in a folder
  4. All images in a card
  5. All found images (only during image search)
Erase
Except protected images
  1. Select image to erase
  2. Select range
Compatible Printers
PictBridge-compatible printers (wireless LAN only)
Printable Images
JPEG images compliant to Design rule for Camera File System
  • RAW images can be printed.
  • Movies cannot be printed.
DPOF
Complies to DPOF Version 1.1
Custom Functions
14 Custom Functions with 34 settings settable with the camera
Custom Controls
Functions can be assigned to the following control parts:
  • Shutter button (halfway pressing)
  • AE start button
  • AE lock button
  • SET button
USB Terminal
Hi-Speed USB (USB 2.0)
  • For PC communication
  • For GP-E2 connection
  • For Connect Station connection
Video Out Terminal
Type C (resolution switches automatically)
  • Video is not displayed unless the video format appropriate for the connected TV set, [NTSC] or [PAL], is set.
Extension System Terminal
3.5mm diameter stereo mini jack
  • Directional Stereo Microphone DM-E1 connection
Battery
Battery Pack LP-E17 x 1
  • With the AC Adapter AC-E6N and DC Coupler DR-E18, AC power operation is possible.
Battery Check
Automatic battery check when the power switch is turned ON. Displayed in 4 levels.
Power Saving
Power turns off after the set time (10/30* or 30 sec., 1, 2, 4, 8 or 15 min.) of non-operation elapses
* Normally 10 sec. is set. 30 sec. will be set for function setting, Live View shooting, image playback, etc.
Date/Time Battery
Built-in secondary battery
When fully-charged, the date/time can be maintained for approx. 3 months
  • Recharge time: approx. 8 hrs.
    • To become capable to maintain the right date/time for 3 months after main battery power depletion.
Start-up Time
Approx. 0.2 sec. (based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 5.16 x 3.93 x 3.00 in. (131.0 x 99.9 x 76.2mm)
  • CIPA compliant.
Weight
Approx. 19.05 oz. / 540g (including battery pack and SD memory card)
Approx. 17.39 oz. / 493g (body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Canon Support | Firmware Notice: EOS 77D: Firmware Version 1.0.3
Advisory Type
Date 02.12.20
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: EOS 77D: Firmware Version 1.1.0
Advisory Type
Date 10.18.20
Title Canon Support | Service Notice: Photo Culling App Version 2.0 for iOS
Advisory Type
Date 11.16.21
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
