Canon Support for EOS 7D Mark II | Canon U.S.A., Inc.
EOS 7D Mark II
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | Digital AF/AE single-lens reflex camera with built-in flash |
Recording Media | CF Cards (Type I); Compatible with UDMA CD cards; SD, SDHC, and SDXC Memory Cards |
Image Format | Approx. 22.4 x 15.0 mm (APS-C size) |
Compatible Lenses | Canon EF lenses including EF-S lenses (35mm-equivalent focal length is approx. 1.6x the lens focal length) |
Lens Mount | Canon EF mount |
Type | High-sensitivity, high-resolution, large single-plate CMOS sensor |
Pixels | Effective pixels: Approx. 20.2 megapixels |
Pixel Unit | 4.1 µm square |
Total Pixels | Approx. 20.9 megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the CMOS sensor |
Dust Deletion Feature | Self Cleaning Sensor Unit * Removes dust adhering to the low-pass filter. * Self-cleaning executed automatically (taking approx. 3 sec.) when power is turned on or off. Manual execution also possible (taking approx. 7 sec.). * Low-pass filter has a fluorine coating. Dust Delete Data acquisition and appending * The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. * The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots. Manual cleaning |
Recording Format | Design Rule for Camera File System 2.0 and Exif 2.3 |
Image Format | Still: JPEG, RAW (14-bit, Canon original), sRAW, mRAW, RAW+JPEG Video: MOV (Image data: H.264, Audio: Linear PCM), MP4 (Image data: H.264, Audio: AAC) |
File Size | Large: Approx. 20.00 Megapixels (5472 x 3648)Medium: Approx. 8.90 Megapixels (3648 x 2432)S1 (Small 1): Approx. 5.00 Megapixels (2736 x 1824)S2 (Small 2): Approx. 2.50 Megapixels (1920 x 1280)S3 (Small 3): Approx. 350,000 pixels (720 x 480)RAW: Approx. 20.00 Megapixels (5472 x 3648)M-RAW: Approx. 11.20 Megapixels (4104 x 2736)S-RAW: Approx. 5.00 Megapixels (2736 x 1824) |
Recording Functions | Standard *Records to either the CF card or SD card. Auto switch card *When the current card becomes full, the camera switches to the other card automatically. Record separately *The CF card and SD card record the same image at a different image recording quality. Record to multiple * Both the CF card and SD card record the same image at the same image recording quality (Also applies to RAW+JPEG, M-RAW+JPEG, and S-RAW+JPEG). |
Backup Recording | Images recorded in a card can be copied to the other card |
File Numbering | The following three types of file numbers can be set:Continuous numbering * The numbering of captured images will continue even after you replace the camera's card. (The numbering continues even when the folder changes.)Auto reset * When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card. Manual reset * Resets the file number to 0001, and creates a new folder automatically. |
Image Copy | Select individual images to copy Select folder(s) to copy Select all the images to copy |
RAW + JPEG Simultaneous Recording | The image-recording quality can be selected in any combination of the three RAW and eight JPEG recording quality settings |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style | Auto Standard Portrait Landscape Neutral Faithful Monochrome User Defined 1-3 Scene Intelligent Auto will set [Auto] automatically. * [Standard] is the default setting for [User Def. 1-3] |
Interface | Auto (AWB)Daylight Shade Cloudy, Twilight, Sunset Tungsten Light White Fluorescent Light Flash Custom (Custom WB)Color temperature *With an EX-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000K if the flash unit does not have the color temperature communication feature. |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels Correction based on the current WB mode's color temperature. |
Color Temperature Information Transmission | Provided |
Type | Eye-level SLR with fixed pentaprism |
Coverage | Approx. 100% vertically and horizontally (with eye point approx. 22mm eyepoint) |
Magnification | Approx. 1.00x / 29.6° (with 50mm lens at infinity, -1m-1 (dpt)) Without distortion correction |
Eye Point | Approx. 22mm (At -1m-1 from the eyepiece lens center) |
Dioptric Adjustment Correction | Adjustable from approx. -3.0 to +1.0m-1 (dpt) |
Focusing Screen | Eh-A Standard Focusing Screen Eh-S Super Precision Matte |
Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60) |
Viewfinder Information | AF Point Information, Spot Metering Circle, Electronic Level, Grid, Shooting Mode, White Balance, Drive Mode, Focusing Modes, Metering Modes, JPEG/RAW, Flicker Detection, AF Status Indicator, Warning Symbol |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Type | TTL secondary image-forming phase-difference detection system with AF-dedicated CMOS sensor |
AF Points | 65-point all cross-type AF * The number of AF points and cross-type AF points vary depending on the lens used. * The center AF point is a dual cross-type AF point at f/2.8. |
AF Working Range | Conditions: One-Shot AF, at 73°F/23°C, ISO 100 |
Focusing Modes | Autofocus One-Shot AF Predictive AI Servo AF (AI Servo AF III)AI Focus AF Switches between One-Shot AF and AI Servo AF automatically Manual Focus |
AF Point Selection | Single-point Spot AF (Manual selection)Single-point AF (Manual selection)AF point expansion (Manual selection, 4 points: Up, down, left, and right)AF point expansion (Manual selection, surrounding 8 points) *All AF points divided into nine focusing zones. Zone AF (Manual zone selection)Large Zone AF (Manual zone selection) *All AF points divided into three focusing zones. Auto Selection 65-point AF |
Selected AF Point Display | Displayed in viewfinder with transparent LCD and on LCD panel |
Active AF Point Indicator | Displayed in viewfinder area Displayed outside viewfinder area |
AF Assist Beam | Enable Disable Enable external flash only IR AF assist beam only |
Metering Modes | Approx. 150,000-pixel RGB+IR metering sensor EOS iSA System with 252-zone metering Evaluative metering (linked to all AF points)Partial metering (center, approx. 6% of viewfinder)Spot metering (center, approx. 1.8% of viewfinder) *AF point-linked spot metering not provided. Center-weighted average metering * The selectable metering modes can be restricted with a Custom Function. |
Metering Range | EV 0-20 (at 73°F/23°C, ISO 100) |
Exposure Control Systems | Scene Intelligent Auto Program AE (shiftable)Shutter-priority AE (Safety shift possible)Aperture-priority AE (Safety shift possible)Manual exposure Bulb Custom shooting mode C1, C2, C3 |
ISO Speed Range | *1: It depends on [Minimum] and [Maximum] of [Auto ISO range] *2: If overexposure would occur with fill flash, the minimum ISO speed set is ISO 100. *3: For bounced flash, ISO 400–1600 is set automatically depending on the ambient brightness. *4: Except in the A mode. *5: Auto set for ISO 400-1600 in the P mode with external Speedlite set for bounce flash. ISO Speed upper and lower limits:Manual setting range*ISO speed expansion is set with this option Auto ISO range*ISO speed expansion not settable Shutter speed and automatic ISO speed control in P and Av modes:The minimum shutter speed can be set so that a slower shutter speed is not set automatically while AUTO ISO is set. Auto setting: Slower/Faster settable to one of seven settings Manual setting: Set the shutter speed: 1/8000, 1/4000, 1/2000, 1/1000, 1/500, 1/250, 1/125, 1/60, 1/30, 1/15, 1/8, 1/4, 0.5", 1" |
Exposure Compensation | Manual: ±5 stops in 1/3-or 1/2-stop increments AEB: ±3 stops in 1/3-or 1/2-stop increments *Indicated up to ±3 stops on the LCD panel and in the viewfinder ISO speed for still photos during movie shooting: *1: ISO 100 – ISO 6400 *2: ISO 100 – ISO 16000 *3: Same as the ISO speed used for movie shooting. |
AE Lock | Auto AE lock *In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved. Manual AE lock *With AE lock button. (AE lock is updated each time you press the button.) Enabled in all metering modes. |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
Shutter Speeds | 1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.) X-sync at 1/250 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay |
Shutter Lag Time | During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.055 sec. *During silent shooting, approx. 0.105 sec. *With flash, approx. 0.095 sec. *During silent shooting with flash, approx. 0.145 sec. Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.17 sec. *During silent shooting, approx. 0.22 sec. *With flash, approx. 0.215 sec. * During silent shooting with flash, approx. 0.265 sec. |
Type | Retractable, auto pop-up flash |
Flash Metering System | E-TTL II auto flash |
Guide Number | Approx. 11/36.1 (ISO 100, in meters/feet) |
Recycling Time | Approx. 3 sec. |
Flash Ready Indicator | Indicator |
Flash Coverage | 15mm lens angle of view (equivalent to approx. 24mm in 135mm format) |
FE Lock | Provided |
Flash Exposure Compensation | ±3 stops in 1/3-or 1/2-stop increments |
EOS Dedicated Speedlite | E-TTL II autoflash with all EX Series Speedlites |
Zooming to Match Focal Length | TBD |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
External Flash Settings | The camera can set the following with Speedlite 600EX-RT, 600EX, 430EX II, 320EX, 270EX II, 90EX, ST-E3-RT, or MR-14EX:External flash control *Flash firing, E-TTL II Flash metering, Flash mode, Wireless functions, Zoom, Sync setting, Flash exposure compensation, FEB and Clear settings. Flash Custom Function setting *The actual setting options for 1 and 2 will differ depending on the Speedlite used. |
PC Terminal | Provided (no polarity) |
Drive Modes | Single, High-speed continuous, Low-speed continuous shooting, Silent single shooting, Silent continuous shooting, 10-sec self-timer/remote control, 2-sec. self-timer/remote control |
Continuous Shooting Speed | High-speed: Maximum approx. 10.0 fps (Maximum approx. 9.5 fps with EOS iTR AF) *At 1/1000 sec. or faster shutter speed, and at the maximum aperture (varies depending on the lens) Low-speed: Approx. 3 fps (default setting) Silent continuous shooting: Maximum approx. 4.0 fps |
Maximum Burst | JPEG Large/Fine: Approx. 130 shots (approx. 1090 shots) RAW: Approx. 24 shots (approx. 31 shots) RAW + JPEG Large / Fine: Approx. 18 shots (approx. 19 shots) * Figures are based on Canon's testing standards (Aspect ratio: 3 x 2, ISO 100 and Standard Picture Style) and an 8 GB CF card. * Figures in parentheses apply to an UDMA mode 7, CF card based on Canon's testing standards. |
Shooting Modes | Still photo shooting and video shooting |
Focusing | (1) AF operation with Dual Pixel CMOS AF, One-shot AF Face Detection plus Tracking AF FlexiZone - Multi* 31 zones * AF at the touched zone FlexiZone - Single(2) TTL secondary image-forming, phase-difference detection with AF operation, One-shot AF Manual selection: Single point AF Manual selection: Zone AF Auto selection: 19-point AF* Automatically set in Basic Zone modes(3) Manual focus* Manual focusing by enlarging images by approx. 5 to 10 times |
Metering Modes | Real-time evaluative metering with image sensor |
Metering Range | Evaluative metering (315-zone)Partial metering (approx. 10% of Live View screen)Spot metering (approx. 2.6% of Live View screen)Center-weighted average metering *Metering range: EV 0-20 (at 73°F/23°C and ISO 100) *AE lock possible. *The active metering timer can be changed. |
Grid Display | 9 sections24 sections9 sections + Diagonal Lines |
Exposure Simulation | Possible |
Silent Shooting | Provided (Mode 1 and Mode 2) |
File Format | MOV Movie: MPEG-4 AVC / H.264 Audio: Linear PCMMP4 Movie: MPEG-4 AVC / H.264 *Variable (averaged) bit rate Audio: AAC |
File Size | Recording Sizes: 1920 x 1080 (Full HD), 1280 x 720 and 640 x 480 |
Frame Rates | MOV Format: [1920 x 1080]: 59.94 fps / 29.97 fps / 24.00 fps / 23.98 fps [1280 x 720]: 59.94 fps [640 x 480]: 29.97 fps MP4 Format: [1920 x 1080]: 59.94 fps / 29.97 fps / 24.00 fps / 23.98 fps [1280 x 720]: 59.94 fps / 29.97 fps [640 x 480]: 29.97 fps |
Continuous Shooting Time | * With MOV and MP4, if the recording time reaches 29 min. 59 sec., the movie shooting stops automatically. * With MOV and MP4, movie shooting does not stop automatically even if the file size reaches 4 GB. |
Focusing | Autofocus One-Shot AF Predictive AI Servo AF (AI Servo AF III)AI Focus AF *Switches between One-Shot AF and AI SERVO AF automatically Manual focus |
Range | EV 0 - 18 (With Dual Pixel CMOS AF detection, at 23°C/73°F, ISO 1000) |
Exposure Control | ISO speed for still photos during movie shooting: *1: ISO 100 – ISO 6400 *2: ISO 100 – ISO 16000 *3: Same as the ISO speed used for movie shooting. |
Exposure Compensation | Up to ±3 stops in 1/3-stop increments *For movies, even if exposure compensation has been set beyond ±3 stops, exposure compensation up to only ±3 stops will be applied. |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0-inch |
Pixels | Approx. 1.04 million dots |
Coverage | Approx. 100% |
Brightness Control | Auto: Brightness adjusted automatically by the light sensor (Darker/ Standard/Brighter) Manual: 7 |
Coating | Clear View II LCD monitor |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean and Japanese) |
On LCD Monitor | Electronic level indicates up to 360° roll and ±10° pitch in 1° increments |
In Viewfinder | Horizontal: 7.5° left/right Vertical: 4° top/bottom |
Display Format | |
Highlight Alert | With single-image display (Info.) and single-image display, overexposed highlight areas will blink |
Items | Pressing the button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting, and playback |
Protection | Single image (select image)All images in folder All images in a card |
Erase | Single image (playback and erase image)Select images to erase All images in a folder All images in a card |
Compatible Printers | PictBridge-compatible printers |
Printable Images | RAW and JPEG images complying to Design rule for Camera File System * Movies cannot be printed. |
DPOF | DPOF Print ordering provided |
Compatible Images | Transferable Images:JPEG RAW Movies For RAW+JPEG images: RAW only, JPEG only, or both RAW and JPEG can be selected for transfer Image Transfer:All images Selected folder Selected images |
Custom Functions | 18 Custom Functions settable with the camera |
Custom Controls | Functions can be assigned to the following Shutter button halfway pressing AF-ON button AE lock button Depth-of-field preview button Lens AF stop button Multi-function button SET button Main Dial Quick Control Dial Multi controller AF area selection lever |
Camera User Settings | Current camera settings can be registered to C1, C2, and C3 on the Mode Dial (Automatic registration update is possible) |
My Menu Registration | Up to six top-tier menu items and Custom Functions can be registered. Up to five My Menu tabs can be added. |
USB Terminal | Super Speed USB (USB 3.0): for computer communication and direct printing |
Video Out Terminal | Video OUT terminal: NTSC/PAL selectable mini-HDMI OUT Terminal |
Extension System Terminal | For connecting WFT-E7 (Ver. 2) (Interface Cable IFC-40AB II and IFC-150AB II provided) |
Gigabit-Ethernet | Not applicable |
Battery | 1 Battery Pack LP-E6N (or LP-E6) With AC Adapter Kit ACK-E6, AC power is possible, With Battery Grip BG-E16, two battery packs (LP-E6N or LP-E6) can be used. Or six AA-/LR6 batteries can be used |
Battery Life | |
Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 6 levels. *Battery level displayed on LCD panel and in viewfinder. *Displayed in four levels with the battery grip using size-AA/LR6 batteries. |
Power Saving | Power turns off after the set time (1, 2, 4, 8, 15, or 30 min.) of non-operation elapses |
Date/Time Battery | Built-in secondary battery; when fully-charged, the date/time can be maintained for approx. three months |
Start-up Time | Approx. 0.1 sec. (Based on CIPA testing standards) |
Dimensions (W x H x D) | Approx. 5.85 (W) x 4.43 (H) x 3.08 (D) in. Approx. 148.6 (W) x 112.4 (H) x 78.2 (D) mm |
Weight | Based on CIPA standard: Approx. 32.10 oz. / Approx. 910 g Body Only: Approx. 28.92 oz. / Approx. 820 g |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
