Canon Support for EOS 80D | Canon U.S.A., Inc.
EOS 80D
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital, AF/AE single-lens reflex camera with built-in flash |
Recording Media | SD, SDHC and SDXC Memory Cards SD speed class compatibility. UHS speed class compatibility. High-speed writing is supported when a UHS-I compatible SD card is used. Compatible with Eye-Fi Cards. Multimedia cards (MMC) cannot be used (card error will be displayed). |
Image Format | Approx. 22.5mm x 15.0mm (APS-C) |
Compatible Lenses | Canon EF Lenses (including EF-S lenses, excluding EF-M lenses) |
Lens Mount | Canon EF Mount |
Type | CMOS Sensor |
Pixels | Approx. 24.2 megapixels |
Pixel Unit | Approx. 3.72 µm square |
Total Pixels | Approx. 25.8 megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the image sensor |
Dust Deletion Feature |
Recording Format | Design Rule for Camera File System 2.0 and EXIF 2.3 |
Image Format | Still Image: JPEG, RAW (14 bit Canon Original), M-RAW, S-RAW, RAW+JPEG, M-RAW+JPEG, S-RAW+JPEG Video: MOV (Full HD Movie: MPEG4 AVC/H.264*; Audio: Linear PCM), MP4 (Movie: MPEG4 AVC/H.264*; Audio: AAC) * Variable (averaged) bit rate |
File Size | 3:2 Aspect Ratio Large: 24.0 Megapixels (6000 x 4000) Medium: Approx. 10.6 Megapixels (3984 x 2656) Small 1: Approx. 5.9 Megapixels (2976 x 1984) Small 2: Approx. 2.5 Megapixels (1920 x 1280) Small 3: Approx. 0.35 Megapixels (720 x 480) RAW: 24.0 Megapixels (6000 x 4000) mRAW: 13.5 Megapixels (4500 x 3000) sRAW: 6.0 Megapixels (3000 x 2000) 4:3 Aspect Ratio Large: Approx. 21.3 Megapixels (5328 x 4000) Medium: 9.5 Megapixels (3552 x 2664) Small 1: Approx. 5.3 Megapixels (2656 x 1992) Small 2: Approx. 2.2 Megapixels (1696 x 1280) Small 3: Approx. 0.31 Megapixels (640 x 480) RAW: 24.0 Megapixels (6000 x 4000) mRAW: 13.5 Megapixels (4500 x 3000) sRAW: 6.0 Megapixels (3000 x 2000) 16:9 Aspect Ratio Large: Approx. 20.2 Megapixels (6000 x 3368) Medium: Approx. 8.9 Megapixels (3984 x 2240) Small 1: Approx. 5.0 Megapixels (2976 x 1680) Small 2: Approx. 2.1 Megapixels (1920 x 1080) Small 3: Approx. 0.29 Megapixels (720 x 408) RAW: 24.0 Megapixels (6000 x 4000) mRAW: 13.5 Megapixels (4500 x 3000) sRAW: 6.0 Megapixels (3000 x 2000) 1:1 Aspect Ratio Large: Approx. 16.0 Megapixels (4000 x 4000) Medium: Approx. 7.1 Megapixels (2656 x 2656) Small 1: Approx. 3.9 Megapixels (1984 x 1984) Small 2: Approx. 1.6 Megapixels (1280 x 1280) Small 3: Approx. 0.23 Megapixels (480 x 480) RAW: 24.0 Megapixels (6000 x 4000) mRAW: 13.5 Megapixels (4500 x 3000) sRAW: 6.0 Megapixels (3000 x 2000) Values of Pixels recorded are rounded off to the nearest 10,000th or 1,000th. JPEG images are generated in the aspect ratio that was set. RAW images are generated in [3:2] and the set aspect ratio is appended. |
Backup Recording | N/A |
File Numbering | The following three types of file numbers can be set:
Color Space | sRGB, Adobe RGB |
Picture Style |
Settings | Auto, Daylight, Shade, Cloudy*, Tungsten Light, White Fluorescent Light, Flash, Custom, Color Temperature setting * Effective in twilight and sunset as well. |
Auto White Balance | Option between ambience priority and white priority settings |
Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels *Corrected in reference to the current WB mode's color temperature. |
Color Temperature Information Transmission | Provided |
Type | Eye-level SLR (with fixed pentaprism) |
Coverage | |
Magnification | Approx. 0.95x (with 50mm lens at infinity, -1m-1) / 28.3° angle of view |
Eye Point | Approx. 22mm (at -1m-1 from eyepiece lens center) |
Dioptric Adjustment Correction | -3.0 to +1.0 m-1 (diopter) |
Focusing Screen | Fixed |
Viewfinder Information | Information display with translucent liquid crystal
You can set whether to display or hide [Electronic level], [Grid display] and [Flicker detection]. |
Depth Of Field Preview | Provided |
Type | TTL secondary image-forming phase-difference detection system with AF-dedicated CMOS sensor |
AF Points | Up to 45 points (Cross-type AF points: Max. 45)The number of AF points, cross-type AF points and dual cross-type AF points vary depending on the lens used. Note that, with aspect ratio of 1:1, the maximum number of AF points becomes 35. (Each left and right end line of AF points in total of ten are not usable.) |
AF Working Range | One-shot AF, room temperature, ISO 100 (Based on Canon’s testing standards and environment) |
Focusing Modes |
AF Point Selection |
Selected AF Point Display | |
AF Assist Beam | Intermittent firing of built-in flash Effective range: Center: Approx. 13.1 ft. / 4.0m Periphery: Approx. 11.5 ft. / 3.5m With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead. |
Metering Modes | 63-zone (18 x 12) metering with approx. 7,560-pixel RGB+IR metering sensor and TTL full-aperture. The following metering modes selectable: (1) Evaluative metering (linked to all AF points) (2) Partial metering on the center part of the viewfinder (approx. 6.0% of viewfinder) (3) Spot metering (approx. 3.8% of viewfinder) (4) Center-weighted average metering |
Metering Range | EV 1-20 (room temperature, ISO 100, with evaluative metering) |
Exposure Control Systems | Creative Zone
Basic Zone
Exposure Compensation | Manual: ±5 stops in 1/3- or 1/2-stop increments AEB: ±3 stops in 1/3- or 1/2-stop increments* Indicated up to ±3 stops on the LCD panel and in the viewfinder. |
AE Lock |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
Shutter Speeds | 1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.)X-sync at 1/250 sec. Shutter speed's control range can be set. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay, 2-sec. delay |
Shutter Lag Time | 1. During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.06 sec. 2. Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.14 sec. * Shutter-release time lag may become longer during silent shooting, and Live View shooting. |
Type | Auto pop-up, retractable, built-in flash at the pentamirror |
Flash Metering System | E-TTL II autoflash with all EX Series Speedlites |
Guide Number | Approx. 39.4 ft./12m (at ISO 100)Up to approx. 17mm focal length (equivalent to approx. 28mm in 135 format) |
Flash Coverage | Up to approx. 17mm focal length (equivalent to approx. 28mm in 135 format) |
FE Lock | Provided |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
EOS Dedicated Speedlite | E-TTL II autoflash with all EX Series Speedlites |
Zooming to Match Focal Length | Provided |
Flash Metering | E-TTL II autoflash |
External Flash Settings |
Drive Modes |
Continuous Shooting Speed | High-speed continuous shooting: Max. approx. 7.0 fps * With 1/500 sec. or faster shutter speed, maximum aperture (varies depending on the lens), Anti-flicker shooting set to Disable, with a fully-charged Battery Pack LP-E6N and at room temperature (73°F/23°C). * With the AF mode set to One-Shot AF and the Image Stabilizer turned off when using the following lenses: EF 300mm f/4L IS USM, EF 28-135mm f/3.5-5.6 Low-speed continuous shooting: Max. approx. 3.0 fps Silent continuous shooting: Max. approx. 3.0 fps |
Shooting Modes | Still photo and video recording |
Focusing |
* Contrast AF is not provided |
Metering Modes |
Metering Range | EV 0-20 (room temperature, ISO 100, with evaluative metering) |
Grid Display |
Exposure Simulation | Possible |
Silent Shooting | Provided (Mode 1 and Mode 2) |
File Format | MOV: Movie: MPEG-4 AVC/H.264 *Variable (average) bit rate Audio: Linear PCM MP4: Movie: MPEG-4 AVC/H.264 *Variable (average) bit rate Audio: AAC |
File Size | MOV: MP4: |
Frame Rates | MOV: 1920 x 1080 (Full HD): 30 fps (29.97 fps) / 24 fps (23.98 fps) MP4: 1920 x 1080 (Full HD): 60 fps (59.94 fps) / 30 fps (29.97 fps) / 24 fps (23.98 fps) 1280 x 720 (HD): 60 fps (59.94 fps) / 30 fps (29.97 fps) |
Continuous Shooting Time | Continuous Shooting Time MOV MP4Bit rate indicates video output only, audio is not included. With MOV and MP4, if the recording time reaches 29 min. 59 sec., the movie shooting stops automatically. With MOV and MP4, movie shooting does not stop automatically even if the file size reaches 4GB. |
Focusing | Dual Pixel CMOS AF *Contrast AF is not possible. Manual focus* Magnify the image by 5x or 10x and focus manually (not possible during movie shooting). |
Exposure Control | Exposure Control |
Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments Likewise ±3 stops for still photo shooting. |
Type | TFT color, liquid-crystal monitor |
Monitor Size | Wide 3.0-inch (Screen aspect ratio of 3:2) Approx. 3.03 in. diagonal (approx. 2.51 in. wide, approx. 1.67 in. high) |
Pixels | Approx. 1.04 million dots |
Coverage | Approx. 100% Viewing angle: Approx. 170° vertically and horizontally |
Brightness Control | Adjustable to one of seven levels |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
Display Format | |
Highlight Alert | With single image display, overexposed highlight areas will blink. |
Protection | Erase protection can be applied or canceled for a single image, all images in a folder or all images in the card. |
Erase | Erase a single image, selected images, all images in a folder, all images in a card or erase only unprotected images. |
Compatible Printers | PictBridge-compatible printers (wireless LAN) |
Printable Images | RAW and JPEG images compliant to Design rule for Camera File System. Movies cannot be printed. |
DPOF | Compliant to DPOF Version 1.1 |
Compatible Images | Not provided |
Custom Functions | 26 Custom Functions are settable. |
Custom Controls | Functions can be assigned to the following buttons:
My Menu Registration | Up to six top-tier menu options and Custom Function settings can be registered. Up to five My Menu tabs can be added. |
USB Terminal | SuperSpeed USB (USB 2.0)
Video Out Terminal | HDMI Type C (Resolution switches automatically) * Video is not displayed unless the video format appropriate for the connected TV set, [NTSC] or [PAL], is set. |
Battery | Battery Pack LP-E6N (or LP-E6) x1When the battery grip is used, two battery packs (LP-E6N or LP-E6) can be installed. Also usable with six AA/R6 batteries. |
Number of Shots | Number of Shots The capacity of the Ni-MH battery is 1900 mAh. |
Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 6 levels. Battery level displayed on LCD panel and in viewfinder. Displayed in four levels with the battery grip with AA/R6 batteries. |
Power Saving | Power turns off after the set time (1, 2, 4, 8, 15 or 30 min.) of non-operation elapses. |
Date/Time Battery | Built-in secondary battery Maintains date/time for about 3 months when fully charged. Recharge time: approx. 8 hr. To become capable to maintain the right date/time for one month after main battery power exhaustion. |
Start-up Time | Approx. 0.16 sec. (Based on CIPA testing standards) * Excluding the recognition time for genuineness (genuine Canon battery) at the installation of the battery. |
Dimensions (W x H x D) | Approx. 5.47 x 4.14 x 3.09 in. / 139.0 x 105.2 x 78.5mm |
Weight | Approx. 25.75 oz. / 730g (Based on CIPA guidelines) Approx. 22.93 oz. / 650g (Body only; excluding the battery, card, body cap and eye cup) |
Working Temperature Range | 32-113°F/0-45°C |
Working Humidity Range | 85% or less |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
