Canon Support for EOS 80D | Canon U.S.A., Inc.
EOS 80D
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type
Digital, AF/AE single-lens reflex camera with built-in flash
Recording Media
SD, SDHC and SDXC Memory Cards
SD speed class compatibility.
UHS speed class compatibility.
High-speed writing is supported when a UHS-I compatible SD card is used.
Compatible with Eye-Fi Cards.
Multimedia cards (MMC) cannot be used (card error will be displayed).
Image Format
Approx. 22.5mm x 15.0mm (APS-C)
Compatible Lenses
Canon EF Lenses (including EF-S lenses, excluding EF-M lenses)
Lens Mount
Canon EF Mount
Type
CMOS Sensor
Pixels
Approx. 24.2 megapixels
Pixel Unit
Approx. 3.72 &micro;m square
Total Pixels
Approx. 25.8 megapixels
Aspect Ratio
3:2 (Horizontal: Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the image sensor
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
    • Removes dust adhering to the low-pass filter.
    • Self-cleaning can be done automatically when the power is turned on or off. Manual cleaning also possible.
  2. Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
    • The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
  3. Manual cleaning
Recording Format
Design Rule for Camera File System 2.0 and EXIF 2.3
Image Format
Still Image: JPEG, RAW (14 bit Canon Original), M-RAW, S-RAW, RAW+JPEG, M-RAW+JPEG, S-RAW+JPEG
Video: MOV (Full HD Movie: MPEG4 AVC/H.264*; Audio: Linear PCM), MP4 (Movie: MPEG4 AVC/H.264*; Audio: AAC)
* Variable (averaged) bit rate
File Size
3:2 Aspect Ratio
Large: 24.0 Megapixels (6000 x 4000)
Medium: Approx. 10.6 Megapixels (3984 x 2656)
Small 1: Approx. 5.9 Megapixels (2976 x 1984)
Small 2: Approx. 2.5 Megapixels (1920 x 1280)
Small 3: Approx. 0.35 Megapixels (720 x 480)
RAW: 24.0 Megapixels (6000 x 4000)
mRAW: 13.5 Megapixels (4500 x 3000)
sRAW: 6.0 Megapixels (3000 x 2000)
4:3 Aspect Ratio
Large: Approx. 21.3 Megapixels (5328 x 4000)
Medium: 9.5 Megapixels (3552 x 2664)
Small 1: Approx. 5.3 Megapixels (2656 x 1992)
Small 2: Approx. 2.2 Megapixels (1696 x 1280)
Small 3: Approx. 0.31 Megapixels (640 x 480)
16:9 Aspect Ratio
Large: Approx. 20.2 Megapixels (6000 x 3368)
Medium: Approx. 8.9 Megapixels (3984 x 2240)
Small 1: Approx. 5.0 Megapixels (2976 x 1680)
Small 2: Approx. 2.1 Megapixels (1920 x 1080)
Small 3: Approx. 0.29 Megapixels (720 x 408)
1:1 Aspect Ratio
Large: Approx. 16.0 Megapixels (4000 x 4000)
Medium: Approx. 7.1 Megapixels (2656 x 2656)
Small 1: Approx. 3.9 Megapixels (1984 x 1984)
Small 2: Approx. 1.6 Megapixels (1280 x 1280)
Small 3: Approx. 0.23 Megapixels (480 x 480)
Values of Pixels recorded are rounded off to the nearest 10,000th or 1,000th.
JPEG images are generated in the aspect ratio that was set.
RAW images are generated in [3:2] and the set aspect ratio is appended.
Backup Recording
N/A
File Numbering
The following three types of file numbers can be set:
  1. Continuous numbering
    • The numbering of captured images continues even after you replace the card.
  2. Auto reset
    • When you replace the card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card.
  3. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
Color Space
sRGB, Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    • In Basic Zone modes, "Auto" is set automatically.
    • In Creative Zone modes, you can select or set the Picture Style.
    • [Auto] is the default setting for [User Def. 1-3].
Settings
Auto, Daylight, Shade, Cloudy*, Tungsten Light, White Fluorescent Light, Flash, Custom, Color Temperature setting
* Effective in twilight and sunset as well.
Auto White Balance
Option between ambience priority and white priority settings
Color Temperature Compensation
Blue/amber bias: &plusmn;9 levels
Magenta/green bias: &plusmn;9 levels
*Corrected in reference to the current WB mode's color temperature.
Color Temperature Information Transmission
Provided
Type
Eye-level SLR (with fixed pentaprism)
Coverage
Magnification
Approx. 0.95x (with 50mm lens at infinity, -1m-1) / 28.3° angle of view
Eye Point
Approx. 22mm (at -1m-1 from eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0 m-1 (diopter)
Focusing Screen
Fixed
Viewfinder Information
Information display with translucent liquid crystal
  • AF area selection mode
  • AF point information
  • Area AF frame
  • Spot metering circle
  • Electronic level
  • Grid display
  • Aspect line (4:3, 16:9, 1:1)
  • Flicker detection
  • Warning symbol
You can set whether to display or hide [Electronic level], [Grid display] and [Flicker detection].
Depth Of Field Preview
Provided
Type
TTL secondary image-forming phase-difference detection system with AF-dedicated CMOS sensor
AF Points
Up to 45 points (Cross-type AF points: Max. 45)The number of AF points, cross-type AF points and dual cross-type AF points vary depending on the lens used.
Note that, with aspect ratio of 1:1, the maximum number of AF points becomes 35. (Each left and right end line of AF points in total of ten are not usable.)
AF Working Range
One-shot AF, room temperature, ISO 100
(Based on Canon&#8217;s testing standards and environment)
Focusing Modes
  1. Autofocus
    • One-Shot AF
    • Predictive Al Servo AF (Al Servo AF III+)
    • AI Focus AF
      • Switches between One-Shot AF and AI Servo AF automatically.
  2. Manual focus
AF Point Selection
  1. Manual Selection: 1 pt AF
    • The checkmark cannot be removed from this option.
  2. Manual Selection of Zone: Zone AF
    • All AF points divided into nine focusing zones.
  3. Manual Selection of Zone: Large Zone AF
    • All AF points divided into three focusing zones
  4. Auto Selection: 45 point AF
Selected AF Point Display
AF Assist Beam
Intermittent firing of built-in flash
Effective range:
Center: Approx. 13.1 ft. / 4.0m
Periphery: Approx. 11.5 ft. / 3.5m
With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
Metering Modes
63-zone (18 x 12) metering with approx. 7,560-pixel RGB+IR metering sensor and TTL full-aperture. The following metering modes selectable:
(1) Evaluative metering (linked to all AF points)
(2) Partial metering on the center part of the viewfinder (approx. 6.0% of viewfinder)
(3) Spot metering (approx. 3.8% of viewfinder)
(4) Center-weighted average metering
Metering Range
EV 1-20 (room temperature, ISO 100, with evaluative metering)
Exposure Control Systems
Creative Zone
  1. Program AE (Shiftable)
  2. Shutter-priority AE
  3. Aperture-priority AE
  4. Manual exposure
  5. Bulb
  6. Custom shooting mode C1 or C2
Basic Zone
  1. Scene Intelligent Auto (Program AE/non-shiftable)
  2. Flash Off
  3. Creative Auto
  4. Special Scene
    • Food
    • Kids
    • Candlelight
    • Night Portrait
    • Handheld Night Scene
    • HDR Backlight Control
    • Portrait
    • Landscape
    • Close-up
    • Sports
  5. Creative Filters
    • Grainy B/W
    • Soft Focus
    • Fish-eye Effect
    • Toy Camera Effect
    • Miniature Effect
    • Water Painting Effect
    • HDR Art Standard
    • HDR Art Vivid
    • HDR Art Bold
    • HDR Art Embossed
Exposure Compensation
Manual: &plusmn;5 stops in 1/3- or 1/2-stop increments AEB: &plusmn;3 stops in 1/3- or 1/2-stop increments* Indicated up to &plusmn;3 stops on the LCD panel and in the viewfinder.
AE Lock
  1. Auto AE lock
    • In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
  2. Manual AE lock
    • In P, Av, Tv and M mode, enabled with the AE lock button. (Press again to update)
    • Enabled in all metering modes.
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds
1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.)X-sync at 1/250 sec. Shutter speed's control range can be set.
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. delay, 2-sec. delay
Shutter Lag Time
1. During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.06 sec.
2. Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.14 sec.
* Shutter-release time lag may become longer during silent shooting, and Live View shooting.
Type
Auto pop-up, retractable, built-in flash at the pentamirror
Flash Metering System
E-TTL II autoflash with all EX Series Speedlites
Guide Number
Approx. 39.4 ft./12m (at ISO 100)Up to approx. 17mm focal length (equivalent to approx. 28mm in 135 format)
Flash Coverage
FE Lock
Provided
Flash Exposure Compensation
EOS Dedicated Speedlite
Zooming to Match Focal Length
Provided
Flash Metering
E-TTL II autoflash
FE Lock
Provided
External Flash Settings
  1. External flash control
    • Flash firing
    • E-TTL II Flash metering
    • Flash mode
    • Radio transmission wireless flash shooting
    • Optical transmission wireless flash shooting
    • Zoom
    • Sync setting
    • Flash exposure compensation
    • FEB
    • Clear settings
  2. Flash Custom Function setting
Drive Modes
  1. Single shooting
  2. High-speed continuous shooting
  3. Low-speed continuous shooting
  4. Silent single shooting
  5. Silent continuous shooting
  6. 10-sec. self-timer/remote control
  7. 2-sec. self-timer/remote control
Continuous Shooting Speed
High-speed continuous shooting: Max. approx. 7.0 fps
* With 1/500 sec. or faster shutter speed, maximum aperture (varies depending on the lens), Anti-flicker shooting set to Disable, with a fully-charged Battery Pack LP-E6N and at room temperature (73&deg;F/23&deg;C).
* With the AF mode set to One-Shot AF and the Image Stabilizer turned off when using the following lenses: EF 300mm f/4L IS USM, EF 28-135mm f/3.5-5.6
Low-speed continuous shooting: Max. approx. 3.0 fps
Silent continuous shooting: Max. approx. 3.0 fps
Shooting Modes
Still photo and video recording
Focusing
  1. Dual Pixel CMOS AF
  2. * Dual Pixel CMOS AF is possible with all EF lenses.
    * Contrast AF is not provided
  3. Manual focus
  4. * Magnify the image by 5x or 10x and focus manually.
Metering Modes
  1. Evaluative metering (315-zone)
  2. Partial metering (approx. 6.1% of viewfinder)
  3. Spot metering (approx. 2.6% of viewfinder)
  4. Center-weighted average metering
  5. * AE lock possible. The active metering timer can be changed.
Metering Range
EV 0-20 (room temperature, ISO 100, with evaluative metering)
Grid Display
  1. 3x3
  2. 6x4
  3. 3x3+diag
Exposure Simulation
Possible
Silent Shooting
Provided (Mode 1 and Mode 2)
File Format
MOV:
Movie: MPEG-4 AVC/H.264
*Variable (average) bit rate
Audio: Linear PCM
MP4:
Audio: AAC
File Size
MOV:
MP4:
Frame Rates
MOV:
1920 x 1080 (Full HD): 30 fps (29.97 fps) / 24 fps (23.98 fps)
MP4:
1920 x 1080 (Full HD): 60 fps (59.94 fps) / 30 fps (29.97 fps) / 24 fps (23.98 fps)
1280 x 720 (HD): 60 fps (59.94 fps) / 30 fps (29.97 fps)
Continuous Shooting Time
Continuous Shooting Time MOV
MP4Bit rate indicates video output only, audio is not included.
With MOV and MP4, if the recording time reaches 29 min. 59 sec., the movie shooting stops automatically.
With MOV and MP4, movie shooting does not stop automatically even if the file size reaches 4GB.
Focusing
Dual Pixel CMOS AF
*Contrast AF is not possible. Manual focus* Magnify the image by 5x or 10x and focus manually (not possible during movie shooting).
Exposure Control
Exposure Control
Likewise &plusmn;3 stops for still photo shooting.
Type
TFT color, liquid-crystal monitor
Monitor Size
Wide 3.0-inch (Screen aspect ratio of 3:2)
Approx. 3.03 in. diagonal (approx. 2.51 in. wide, approx. 1.67 in. high)
Pixels
Approx. 1.04 million dots
Coverage
Approx. 100%
Viewing angle: Approx. 170&deg; vertically and horizontally
Brightness Control
Adjustable to one of seven levels
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
Highlight Alert
With single image display, overexposed highlight areas will blink.
Protection
Erase protection can be applied or canceled for a single image, all images in a folder or all images in the card.
Erase
Erase a single image, selected images, all images in a folder, all images in a card or erase only unprotected images.
Compatible Printers
PictBridge-compatible printers (wireless LAN)
Printable Images
RAW and JPEG images compliant to Design rule for Camera File System.
Movies cannot be printed.
DPOF
Compliant to DPOF Version 1.1
Compatible Images
Not provided
Custom Functions
26 Custom Functions are settable.
Custom Controls
Functions can be assigned to the following buttons:
  • Shutter button halfway pressing
  • AF-ON button
  • AE lock button
  • Depth-of-field preview button
  • Lens AF stop button
  • SET button
  • Main Dial
  • Quick Control Dial
  • Multi controller
My Menu Registration
Up to six top-tier menu options and Custom Function settings can be registered.
Up to five My Menu tabs can be added.
USB Terminal
SuperSpeed USB (USB 2.0)
  • For PC communication
  • For GP-E2 connection
  • For Connect Station connection
Video Out Terminal
HDMI Type C (Resolution switches automatically)
* Video is not displayed unless the video format appropriate for the connected TV set, [NTSC] or [PAL], is set.
Battery
Battery Pack LP-E6N (or LP-E6) x1When the battery grip is used, two battery packs (LP-E6N or LP-E6) can be installed. Also usable with six AA/R6 batteries.
Number of Shots
Number of Shots The capacity of the Ni-MH battery is 1900 mAh.
Battery Check
Automatic battery check when the power switch is turned ON. Displayed in 6 levels. Battery level displayed on LCD panel and in viewfinder. Displayed in four levels with the battery grip with AA/R6 batteries.
Power Saving
Power turns off after the set time (1, 2, 4, 8, 15 or 30 min.) of non-operation elapses.
Date/Time Battery
Built-in secondary battery
Maintains date/time for about 3 months when fully charged. Recharge time: approx. 8 hr. To become capable to maintain the right date/time for one month after main battery power exhaustion.
Start-up Time
Approx. 0.16 sec. (Based on CIPA testing standards)
* Excluding the recognition time for genuineness (genuine Canon battery) at the installation of the battery.
Dimensions (W x H x D)
Approx. 5.47 x 4.14 x 3.09 in. / 139.0 x 105.2 x 78.5mm
Weight
Approx. 25.75 oz. / 730g (Based on CIPA guidelines)
Approx. 22.93 oz. / 650g (Body only; excluding the battery, card, body cap and eye cup)
Working Temperature Range
32-113&deg;F/0-45&deg;C
Working Humidity Range
85% or less
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Canon Support | Firmware Notice: EOS 80D: Firmware Version 1.0.2
Advisory Type
Date 02.12.17
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: EOS 80D: Firmware Version 1.0.3
Advisory Type
Date 08.04.19
Title Canon Support | Service Notice: Photo Culling App Version 2.0 for iOS
Advisory Type
Date 11.16.21
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
