Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 07.01.24
File Size 4.64 MB
Date 04.26.22
File Size 380.26 KB
Date 10.21.24
File Size 56.98 MB
Date 11.28.23
File Size 938.71 KB
Date 12.19.24
File Size 23.30 MB
Camera Connect
Camera Connect
image.canon
image.canon
Effective Pixels 4096x2160: when 4096 x 2160 or 2048 x 1080 is selected as the resolution (Approx. 8.85 megapixels)
3840 x 2160: when 3840 x 2160 or 1920 x 1080 is selected as the resolution (Approx. 8.29 megapixels)
Total Pixels
4206 x 2280; Approx. 9.6 megapixels
Sensor Type
CMOS
Sensor Size Super 35mm
4K: 26.2 x 13.8 (29.6 mm diagonal)
UHD: 4K: 24.6 x 13.8 (28.2 mm diagonal)
Sensor Modes Super 35mm, Super 16mm(cropped)
Pixel Pitch
6.4 µm
Scanning System
Progressive
Number of Sensors
1
Filter
RGB Primary Color Filter (Bayer Array)
Imaging Processor
DiG!C DV 7
Lens Mount
Default Mount: EF
Optional: EF-C locking, PL
*All mounts are interchangeable
**Supports both EF and EF-S lens
Zoom/Focus Preset
Not Available
Shockless Zoom
Not Available
Digital Teleconverter
1.5x/2.0x/2.5x/3.0x
ND Filter
Mechanical ND filter system with option of clear, 2, 4, and 6 stops; 8 and 10 stops in extended mode
Peripheral Illumination Correction
Available
Exposure Modes
(1) Manual exposure based on shutter setting, iris setting, ISO/gain setting, and ND filter setting
(2) Push auto iris control, auto iris control
Metering Modes
Standard, Spotlight and Backlight
Gain
Normal Setting -6dB to 54dB TBD
Fine Setting -2dB to 54dB in 0.5 dB increments
ISO
100 to 102,400
Auto Gain Control (AGC)
Not Available
Shockless Gain
Not Available
Exposure Compensation/AE Shift
2.0 to +2.0 in 0.25 point intervals
Shutter Modes
3 Modes: OFF; Speed; Angle; Slow Shutter; Clear Scan
Speed Mode is selected in 1/3 or 1/4 stop increments
Shutter Speed Range
59.94Hz/24.00Hz: 1/12 to 1/2000
50.00Hz: 1/12 to 1/2000
Shutter Angle Settings
59.94Hz/50.00Hz/24.00Hz: 360, 240, 180, 120, 90, 60, 45, 30, 22.5, 15, 11.25
Iris Settings (EF)
Can be set to 1/2 stop, 1/3 stop or Fine.
(1) Push auto iris control
(2) Auto iris control (Compatible lens required)
(1/2, 1/3 stop or fine setting can be selected)
Focus Control
Dual Pixel CMOS AF
Focus Modes
Manual focus, continuous AF, one-shot AF, AF-Boosted MF, face detection AF
Only lenses that support AF functions can be used in AF modes
System Frequency
59.94 Hz, 50.00 Hz, 24.00 Hz
59.94 Hz mode: 59.94i/59.94P/29.97P/23.98P
50.00 Hz mode: 50.00i/50.00P/25.00P
24.00 Hz mode: 24.00P
Resolution
Mode Resolution Frame Rates
Cinema RAW Light 4096x2160 59.94p / 29.97p / 23.98p /
50.00p / 25.00p / 24.00p
2048x1080 59.94p / 29.97p / 23.98p /
XF-AVC 4096x2160 / 3840x2160 59.94p / 29.97p / 23.98p /
2048x1080 / 1920x1080 59.94p / 29.97p / 23.98p /
50.00p / 25.00p / 24.00p/59.94i / 50i
1280x720 59.94p / 50p
Color Gamuts*
Cinema Gamut, BT.709, BT.2020
Gamma Curves*
BT.709, Wide DR, Canon Log 2, Canon Log 3, PQ, HLG
*Enabled for recording (including proxy) and output from each terminal, but does not affect recorded Cinema RAW Light files.
Codecs
XF-AVC (10 bit 4:2:2 (CFexpress) or 8 bit 4:2:0 (SD card))
Cinema RAW Light (CFexpress)
Recording Media
CFexpress 2.0 (Type B) x 2 slots
Media Capacity (GB)
SanDisk Extreme Pro 512
Sony TOUGH 512
ProGrade Digital COBALT 650
SD Card (Still Images (JPEG), Custom Picture Data, Clip Metadata, and menu settings); SD/SDHC/SDXC Supported
Recording Time
  Cinema RAW Light
CFexpressTM 1 Gbps 250 Mbps
512 GB 64 Minutes 256 Minutes
  XF-AVC Intraframe
CFexpressTM 810 Mbps 410 Mbps 310 Mbps 160 Mbps
512 GB 79 Minutes 156 Minutes 207 Minutes 401 Minutes
  XF-AVC Long GOP
CFexpressTM 260 Mbps 160 Mbps 50 Mbps 24 Mbps
512 GB 246 Minutes 401 Minutes 1284 Minutes 2675 Minutes
  XF-AVC Long GOP
SD 35 Mbps 24 Mbps 17 Mbps
512 GB 1945 Minutes 2840 Minutes 4010 Minutes
File Format
XF-AVC: MXF (OP-1a)
RAW: CRM
File System
CFexpress: exFat
SDHC card: (up to 32 GB): FAT32
SDXC card (more than 32 GB): exFAT
File division unit: 4 GB for FAT32, none for exFAT
Maximum Clip Number
999 (per media)
Recording Format
Linear PCM; 4-Channel; 24-Bit; 48 kHz
Built-in Microphone
Monaural
External Audio Inputs
2 XLR inputs (Auto and Manual level settings)
External microphone terminal: (3.5 mm diameter)
Recording Chanel Selection
Up to 4 channel audio recording is supported.
XLR Mic Trimming
Available; -12dB, -6 dB, 0dB or +12 dB
Limiter
Available
Recording Level Adjustment Range
- Infinity to +18dB
Phantom Power
Available; +48V
Headphone Adjustment
16 Settings; Volume is muted at lowest setting
Built-in Speaker
Available; Volume Adjustable
1KHz Tone
Available (off, -12, -18, or -20 dB)
Playback
Clip Display: 3x4 Index Display.
Clip Playback: Forward Search (x5, x15, x60), Reverse Search (x5, x15, x60), Forward frame Advance, Reverse Frame Advance, Record Review, Skip to next clip, skip to previous clip
Clip information Display: Clip Metadata display, custom picture settings
Playback Functions: Clip Delete
Photo Playback: index, single playback, delete, protect
Slow and Fast Motion Recording
Available; Records at a different frame rate then the playback rate allowing for fast and slow motion effects:
Sensor Mode Recording Mode Available Frame Rates
Super35 Cinema RAW Light
 23.98P/24P: 12-120
 29.97P: 15-120
 25P/50P: 15-120
 59.94P: 15-120
Super16(Crop) Cinema RAW Light
 23.98P/24P: 12-180
 29.97P: 15-180
 25P/50P: 15-180
 59.94P: 15-180
Super35 XF-AVC
 23.98P/24P: 12-120
 23.98P/24P: 12-120
 25P/50P: 15-120
 59.94P: 15-120
Super16(Crop) XF-AVC
 23.98P/24P: 12-120
 29.97P: 15-180
 25P/50P: 15-180
 59.94P: 15-180
Special Recording Functions
Relay Recording*; Double-Slot Recording**
* Not available during Slow Motion recording
** Not available in combination with Slow and fast motion recording or relay recording
Photo Recording Mode
Available; Images captured to SD Card
Waveform Monitor
Available (HDR Compatible);
(a) Line display
(b) Line + spot: Line display over a red waveform in a red frame.
(c) Line select display
(d) RGB (parade)
(e) YPrPb (parade)
Output gain can be selected as either 1x or 2x. With gain set to 2x, the vertical axis (Y-position) offset value can be chosen.
When gamma is set to PQ, an PQ index (nits index) can be displayed. When gamma is set to HLG, an HLG index (0.01.0 relative index) can be displayed.
Vectorscope
Available
False Color
Available
Exposure / Focus Aids
Peaking (2 types), Zebra Pattern, Magnify, Black and White Mode, Focus Guide
Frame Record
Not Available
Pre-Record
Yes, 3 seconds cache (Audio and Video)
Time code
Drop Frame (DF) and Non-Drop Frame (NDF)
Time Code Modes
Regeneration, Record Run, Free Run and External Source
Auto White Balance (AWB)
Available
White Balance
Kelvin Setting:
2,000K to 15,000K in 100K increment
-20CC to +20CC in 1 CC increments
White Balance Presets
Daylight (5,600K); Tungsten (3,200K), Custom A, Custom B
Auto Black Balance Available
Custom Picture Settings
20 Custom Picture settings
Custom pictures can be adjusted using the following settings and saved for later recall:
Gamma, Black, Black Gamma, Low Key Saturation, Knee, Sharpness, Noise Reduction, Skin Detail, Selective Noise Reduction, Color Matrix, White Balance, Color Correction, Setup Level
Custom Pictures can be saved to an SD card for later use or transferring between cameras
Custom Display
Yes; LCD panel and EVF information display can be customized
On Screen Markers
Available marker options include center, horizontal, grid, aspect, safety zone, and user marker.
With user markers, user can set their preferred size and position.
Markers can be displayed in yellow, blue, green, red, black, gray, or white.
Assign Buttons
18 total assignable button (15 assign buttons provided on camera body, 1 on the grip and 2 buttons on the monitor unit)
Color Bars
Color bars compliant with SMPTE, EBU, or ARIB standards can be selected depending on system frequency selected
Sensitivity
59.94 Hz: f/10 (2048x1080/59.94P) or f/14 (1920x1080/29.97P)
50.00 Hz: f/11 (2048x1080/50.00P) or f/16 (1920x1080/25.00P)
All values for ISO 800, 2000 lux, and reflectance rate of 89.9%
Dynamic Range
Canon Log 2: 1600% / 16+ stops (ISO 800)
Canon Log 3: 1600% / 14 stops (ISO 800)
Type
4.3-inch (10.9 cm diagonal) color wide-screen LCD
Approx. 2,760,000 dots (1280 x RGB x 720),
Aspect Ratio
16:9
Field of View Coverage
100%
Display Adjustments
Brightness, Contrast, Color, Sharpness, and Luminance
SDI Out
HD: SMPTE 292
3G: SMPTE 424, SMPTE 425
6G: SMPTE ST 2081
12G: SMPTE ST 2082
Audio: SMPTE ST 299
BNC Connector, output only
Monitor Out
Available
Resolution: 2048x1080 / 1920x1080
Frame Rates:
23.98p/24.00p/25.00p/29.97p/30p/59.94p/50p/60p
Time code In/Out
Yes; BNC Connector (Input and Output)
Genlock
Supported when optional expansion unit EU-V1 or EU-V2 in attached (Shares function with Synch Out)
Adjustment range: -1023 to +1023
Synch Out
Supported when optional expansion unit EU-V1 or EU-V2 in attached (Shares function with Genlock)
HD tri-level signal (HD Sync) 1920x1080: 59.94i/50i/23.98/24.00, 1280x720: 59.94p/50p/23.98, 24.00
HDMI
Yes (Type A)
[4096x2160/3840x2160]/1920x1080/1280x720
Audio Input Terminal
2 Balanced 3-pin XLR (Mic Level, Mic Level with phantom power and Line Level)
3.5mm Microphone terminal
Headphone Jack
Available; 3.5mm stereo mini-jack
Remote Terminals
Remote A (Standard LANC Compatible or RC-V100)
Remote B available In conjunction with expansion unit EU-V1 and EU-V2
Remote control through WFT-E9
USB
Available
CCU
Optional RC-V100
Supply
14.4V DC (Battery Pack)
Power Terminal
DC IN 12V jack: DC 11.5V - 20V
DC 1220V (using V-mount battery with EU-V2)
Battery
BP-A Series
Compact Power Adapter
CA-CP200B
Tripod Adapter
Canon TA-100
Wi-Fi Adapter
WFT-E9 (optional accessory)
Expansion Units
EU-V1, EU-V2, EU-V3
EVF
EVF-V50, EVF-V70
Mounts
PL Mount Kit PM-V1, EF Cinema Lock Mount Kit CM-V1
Adapter
MO-4E (EF to B4), MO-4P (PL to B4)
Dimensions
(Width x height x depth, excluding cable and grip belt)
Body Only: Approx. 153 x 148 x 168 mm (6.0 x 5.8 x 6.6 in.)
Body and Grip: Approx. 183 x 148 x 189 mm (7.2 x 5.8 x 7.4 in.)
Body, Grip, Handle, Mic Holder, LCD Monitor LM-V2 and Expansion Unit EU-V2: Approx. 343 x 277 x 333 mm (13.5 x 10.9 x 13.1 in)
Weight
EF Camera body (without Camera Grip GR-V1 or thumb rest) Approx. 1.75 kg ( 3.9 lb)*
*Body with PL Mount body; Approx. 2030g (4.5 lb.)
*Body with EF Cinema lock Mount body; Approx. 1860g (4.1 lb.)
Camera Grip GR-V1: Approx. 260 g (9.2 oz.)
LCD Monitor LM-V2: Approx. 204 g (7.2 oz.)
Handle unit: Approx. 227 g (8.0 oz.)
Battery Pack BP-A60: Approx. 434 g (15.3 oz.)
Compact Power Adapter CA-CP200B: Approx. 290 g (10.2 oz.) *Not including AC cable
Battery Charger CG-A20: Approx. 145 g (5.10 oz.)
Eyecap: Approx. 26 g ( 0.92 oz.)
Mic holder unit:Approx. 56 g ( 2.0 oz.)
LCD Attachment Unit LA-V2: Approx. 265 g (9.3 oz.)
Thumb rest: Approx. 9 g ( 0.32 oz.)
Extension System Attachment Bracket: Approx. 11 g (0.39 oz.)
Unit Cable UN-5: Approx. 80 g (2.8 oz.)
Body cap: Approx. 17 g (0.60 oz.)
Temperature and Humidity
Performance requirements: 0ºC to 40ºC, 85% (relative humidity)
Operating requirements: -5ºC to 45ºC, 60% (relative humidity)
Language Support
English, Japanese, Chinese, German, Spanish, French, Italian, Korean, Russian
Time and Date
Automatic Calendar range January 1st, 2020 through December 31, 2050
World Clock
World Clock support UTC time setting: Setting range from +14:00 to -12:00
CANON PROFESSIONAL DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY FOR PRODUCTS
PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Digital Video Equipment (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
  1. Loss or damage to the Equipment due to abuse, mishandling, accident improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
  2. If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
  3. If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
  4. If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
  5. Any internal modification to product hardware or firmware;
  6. Any applicable fee for Maintenance of the Equipment;
  7. If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
Title Canon Support | Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.2.1
Advisory Type
Date 12.06.21
Title Canon Support | Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.1.1
Advisory Type
Date 07.28.21
Title Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.3.1
Advisory Type
Date 05.26.22
Title Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.4.1
Advisory Type Firmware Notice
Date 10.12.22
Title Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.5.1
Date 04.12.23
Title Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.6.1
Advisory Type , Firmware Notice
Date 07.06.23
Title Software Notice: Remote Camera Control Application for Windows Version 1.5.0
Advisory Type Software Notice
Date 11.28.23
Title Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.7.1
Date 12.06.23
Title Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.8.1
Date 07.03.24
Title Firmware Notice: EOS C300 Mark III: Firmware Version 1.0.9.1
Date 12.18.24
Title Software Notice: Multi-Camera Management Application Version 1.0.0
Date 11.28.23
Title Software Notice: Remote Camera Control Application for macOS Version 1.2.0
Date
Title Software Notice: EOS C300 Mark III: Remote Camera Control Application for macOS Version 1.1.0
Date 06.20.23
Color Calibration Service
Canon USA is now offering a comprehensive display color calibration service. Whether you operate in the film, post-production, broadcast, corporate or educational world, our goal is the same: to help ensure image fidelity.
Benefits
Calibration Services
This service supports both standard and high dynamic range (HDR) workflows, and ensures your device meets industry standard specifications (SMPTE, DCI, and ITU).*
calibration screen
What to Expect
Our Imaging Science Foundation (ISF) certified professionals will travel to your site to ensure that any calibration is tailored specifically to your viewing environment. During a calibration session, several key image quality elements will be measured including: white point, grayscale, primary and secondary color chromaticity, luminance and gamma.
calibration gamma result screen
Customized Service
For added flexibility, our team can perform calibrations on virtually any type of display technology. Whether it be a consumer grade PC monitor or professional reference display, our service helps ensure your panel is operating to the best of its ability.
Additionally, to remove any ambiguity of your display’s performance, clients will also be provided with detailed pre and post calibration reports.
color calibration screen
Canon’s Color Calibration Service offers one-time calibrations, recurring service contracts, and customized training. For more information or to request a free consultation, please fill out the form below.
Request a quote
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
