Software Notice: Multi-Camera Management Application Version 1.0.0
Application Overview:
A computer application that enables centralized setup and management of multiple cameras and controllers
Applicable Models:
Models: CR-N700, CR-N500, CR-N300, CR-N100, CR-X300, EOS C500 Mark II, EOS C300 Mark III, EOS C70, XF605, RC-IP1000
Distribution file:
mcmainstall-v100.zip
Description:
Enables management of large systems
  • Supports setup and management of up to 200 cameras & controllers
  • Group creation tool makes control more efficient
Simplifies initial setup
  • Initial setup can be done at once for multiple cameras
  • Copy camera settings to multiple cameras at once
  • Editing camera registration to a controller
Enables monitoring of video and status
  • Displays list of camera/controller connections and settings
  • Multi-view display of camera images enables visual checks
Reduces control/maintenance work
  • Firmware updates, backup/restore, reboot/initialization, and other settings can be performed on multiple cameras at once
Installation Instructions
Refer to the instructions for installing the Multi-Camera Management Application.
<Application File>
MultiCameraManagementApplication.exe
The application contains software modules developed by third parties. The details are available in the download: ReadMe-E.txt, ThirdPartySoftware-E.txt (Third Party Software) and the license conditions are available in the ThirdPartySoftware folder which is inside the LICENSE folder.
Precaution:
Be sure to read the Readme and User's Guide of the software before using it. Notes and restrictions on use are included. Third party licenses may be required.
PC Recommended Environment:
OS : Windows 11, Windows 10 64-bit
CPU : Intel Core i7-12700 or greater
Memory : 8 GB or more
Display : Resolution 1920×1080 or greater
Setup:
  1. Download the file to any folder.
  2. Right-click the zip file, and then select Extract All to extract the file.
Support
