Canon Support for EOS C400 | Canon U.S.A., Inc.
EOS C400
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Sensor | 6K Full-Frame Back-illuminated stacked CMOS sensor | ||||
| Number of Pixels | Total pixels: approx. 26.7 megapixels Effective pixels: up to approx. 19.2 megapixels |
| ISO Sensitivity | 160-25600 (Extended: 100-102400) | ||||
| Base ISO | 800 / 3200 / 12800 / Auto-change (Ex.: Canon Log 2, Canon Log 3, RAW recording) | ||||
| Sensor Mode | Full-frame, Super 35mm Crop, Super 16mm Crop | ||||
| ND Filter | Mechanical ND filter (2 / 4 / 6 / 8* / 10* stops) *With extender | ||||
| Gamma | Canon Log 2, Canon Log 3, Canon 709, BT.709 Wide DR, BT.709 Standard, PQ, HLG | ||||
| Frame Rate | 6K 59.94P/50.00P (RAW) 4.3K 59.94P/50.00P(RAW) 4K 59.94P/50.00P (RAW/XF-AVC/XF-HEVC S/XF-AVC S) 2K 59.94P/50.00P (RAW/XF-AVC/XF-HEVC S/XF-AVC S) |
| Color Space | Cinema Gamut, BT.2020 Gamut, BT.709 Gamut | ||||
| White Balance | Auto, sunlight, tungsten, color temperature (2000K to 15000K), settings A/B | ||||
| Dynamic Range | 16 Stops | ||||
| AF | Dual Pixel CMOS AF II | ||||
| Recording Format |
| Maximum Frame Rate* (Slow & Fast, etc.) | Full-frame 6000x3164/60P Super35mm Crop 4368x2304/100P, 4096x2160/120P Super16mm Crop 2184x1152/180P |
| Recording Format (audio) | Linear PCM 24-bit/48kHz/4ch AAC 16-bit/48kHz/2ch (XF-HEVC S / XF-AVC S) |
| Recording Media | CFexpress card SD card |
| LCD Monitor | 3.5-inch LCD 2.76 million dots, touch panel | ||||
| Viewfinder | No | ||||
| Multi-function Shoe | Yes (with power contacts) | ||||
| Wi-Fi | Internal |
| Lens | Yes |
| SDI Out | Yes (BNC terminal x1, 12G/6G/3G/HD-SDI) |
| Mon. | Yes (BNC terminal x1, 3G/HD-SDI) |
| HDMI | Type-A |
| Input | Mini-XLR x2 (AES/EBU not supported) |
| Ethernet | Yes |
| USB | USB Type-C, for smartphone connection |
| Video | USB Type-C1Footnote1, for LCD connection |
| Grip | USB Type-C1Footnote1, for grip connection |
| Mic | 3.5mm stereo mini jack |
| Headphone | Yes (stereo) |
| Remote A | Yes (REMOTE terminal)( 2.5mm) |
| Remote B (RS-422) | No |
| Time Code | Yes (DIN terminal) |
| G-Lock | Yes (DIN terminal)Footnote2 |
| Sync | Yes (DIN terminal)Footnote2 |
| Ret. | Yes (DIN terminal)Footnote2 |
| DC-IN 12V | XLR (4-pin) |
| Battery | BP-A30N, BP-A60N |
| Operating Temperature | Guaranteed performance conditions: Approx. 320, 1040 F (00, 400 C), 85% (relative humidity) Guaranteed operating conditions: Approx. 230 , 1130 F (-50, 450 C), 60% (relative humidity) |
| Dimensions (W x H x D) | Approx. 5.6" x 5.3" x 5.3" (142 x 135 x 135mm) |
| Main Body Weight | Approx. 3.4 lbs. (1550g) |
CANON PROFESSIONAL DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY FOR PRODUCTS
PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Digital Video Equipment (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
- Loss or damage to the Equipment due to abuse, mishandling, accident improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
- If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
- If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
- If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
- Any internal modification to product hardware or firmware;
- Any applicable fee for Maintenance of the Equipment;
- If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
next to your download
