Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 11.04.25
File Size 57.06 MB
Date 06.25.26
File Size 9.86 MB
Date 10.20.26
File Size 477.60 KB
Date 06.25.26
File Size 14.56 MB
Date 12.02.25
File Size 334.71 KB
Date 11.26.25
File Size 1.10 MB
Date 11.26.25
File Size 4.69 MB
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Type
Image Processor DIGIC DV 7
Lens Mount Canon RF mount
Lens RF lensincluding RF-S lens, RF cinema lens)
EF lensincluding EF-S lens, EF cinema lens (when equipped the EF-RF Mount Adapter))
PL lenswhen equipped the Mount Adapter PL-RF)
Image Sensor
Sensor Full frame CMOS sensor
Number of Total Pixels Approx. 34.20 megapixels (7144x4790)
Number of Effective Pixels Sensor mode: Full frame 3:2
Approx. 32.373 megapixels (6968x4646): 6960x4640 / 6912x4608 resolution
Approx. 25.628 megapixels (6968x3678): 6960x3672 /4096x2160 / 2048x1080 resolution
Approx. 24.032 megapixels (6534*1x3678): 3840x2160 / 1920x1080 resolution
Sensor mode: Super 35mm (Crop)
Approx. 13.427 megapixels (5044x2662): 5036x2656 /4096x2160 /2048x1080 resolution
Approx. 12.591 megapixels (4730*2x2662): 3840x2160 / 1920x1080 resolution
Sensor mode: Super 16mm (Crop)
Approx. 3.388 megapixels (2532x1338): 2524x1332 /2048x1080 resolution
Approx. 3.176 megapixels (2374*3x1338): 1920x1080 resolution
*1 Converted from 6968 pixels
*2 Converted from 5044 pixels
*3 Converted from 2532 pixels
Unit pixel 5.16 5.16 (m)
Effective Sensor Size Sensor mode: Full frame 3:2
35.9 x 23.9 mm 43.2 mm on the diagonal)6960x4640 resolution
35.7 x 23.8 mm 42.9 mm on the diagonal)6912x4608 resolution
35.9 x 18.9 mm 40.6 mm on the diagonal)6960x3672 /4096x2160 / 2048x1080 resolution
33.6 x 18.9 mm (38.6 mm on the diagonal)3840x2160 / 1920x1080 resolution
26.0 x 13.7 mm (29.4 mm on the diagonal)5036x2656 /4096x2160 /2048x1080 resolution
24.4 x 13.7 mm (28.0 mm on the diagonal)3840x2160 / 1920x1080 resolution
13.0 x 6.9 mm (14.7 mm on the diagonal)2524x1332 /2048x1080 resolution
12.2 x 6.9 mm (14.0 mm on the diagonal)1920x1080 resolution
Color Filter System RGB primary color filter (Bayer array)
Dynamic Range Sensor mode: Full frame
Canon Log 21600% / 15+ stopsBase Sensitivity ISO 800
Sensor mode: Super35mm
Canon Log 21600% / 16 stopsBase Sensitivity ISO 800
LCD Screen
Type Color wide LCD monitor
Screen size 3.0 inch (diagonal 7.5 cm)
Number of dots Approx. 1.62 million dots (900xRGBx600)
Field of view coverage 100%
Adjustment function Brightness, Contrast, Color, Sharpness, Luminance*
* A luminance boost function is also available that makes LCD monitor display easier tosee outdoors and in other bright conditions.
Touch panel Electrostatic capacitance system. Touch/drag operation supported.
Network Specifications Ethernet
- Standards compliance: Follows the specifications of the Ethernet adapter
Wi-Fi
- Supported standards: IEEE802.11b /g /n2.4 GHz
IEEE802.11a / n / ac5 GHz
- Setup: InfrastructureWPS: push button method, WPS: PIN code method, access point, manual configurationCamera access point
- Security: Open, Shared key, WPA/WPA2/WPA3-Personal, WPA/WPA2/WPA3-Enterprise
- Encryption TKIPAES
IP streaming
Compression method MPEG-4 H.264/AVC
Bit rate/Resolution 9 Mbps1920x108059.94P59.94i50.00P50.00i
4 Mbpssame as above
Audio MPEG-2 ACC-LC 2ch
Audio rate 256 kbps
Protocols UDP
Prioritizes transfer speed, with no guarantees of reliability or correct order. Lost or lagging packets ignored.
RTP
Standard system for sending videos and audio online. Lost or lagging packets ignored.
SRT
Achieves high-quality streaming with minimal video distortion due to low latency and a packet loss playback function.
RTP+FEC
Error correction (FEC)* control during RTP transfer enables recovery of lost or corrupt packets on the receiving side.
RTSP+RTP
Real-time data streaming control via RTSP (Real Time Streaming Protocol) andtransfer via RTP. The receiving side can start or stop streaming.
Network functions and connection methods
FunctionDescription
Ethernet
Wi-Fi
Infrastructure
Camera
access
point
IP Streaming
Streams video to decoder transmission device or computer over the network.
XC Protocol
The EOS C50 can be remotely operated by a controller or application that supports the XC protocol via IP connection.
Supported Canon products are as follows:
Controller
RC-IP100 (Ver 1.20 or later, RC-IP1000
Application
Remote Camera Control Application (Ver
1.3.0 or later, Canon Multi-Camera Control, Multi-Camera Management
Application
Canon App
This function allows you to connect a camera to a mobile device running iOS or Android via Wi-Fi, and use Content Transfer Professional on the device to transfer files from the camera (video files, audio files, News Metadata, still image files),
as well as create and edit News Metadata.
CV Protocol
Output metadata information needed for real- time virtual production in a computer application from a commercially available Ethernet
adapter.
Frame.io
Upload clips from the camera using Adobe's Frame.io Camera to Cloud function.
*IPv4 only
Verified Ethernet Adapters
Model NumberManufacturer
US1GC30WStarTech.com
US2GC30StarTech.com
UG-USBC-25052UGREEN
  • The listed model numbers have been tested and verified for compatibility by Canon.
  • The operation of the listed models is not guaranteed.
Input / Output terminal
Input terminal Camera
MIC Terminal
3.5 mm stereo mini jack (Unbalanced, plugin power supported)
MIC
Input impedance
1.5 k
Sensitivity
-72 dBV (Volume auto, Full scale - 18 dB)
ATT
20 dB
Supply voltage
DC 2.0 V (Bias resistor 2.2 k)
LINE
Input impedance
10 k
Sensitivity
-12 dBVVolume center, Full scale18 dB
REMOTE Terminal
Type E3, 2.5 mm stereo mini jack
Handle unit
INPUT1 Terminal, INPUT2 Terminal
XLR 3 pin jack (Balanced) (1) Shield, (2) Hot, (3) Cold)
MIC
Input impedance
1.2 k
Sensitivity
-60 dBu (Volume center, Full scale - 18 dB)
ATT
20 dB
 LINE
Input impedance
10 k
Sensitivity
+4 dBu (Volume center, Full scale - 18 dB)
Output terminal
HDMI OUT Terminal HDMI connector (Type A)
Time codes can be superimposed (original standards)
 Video/Audio OutputAccording to HDMI specifications.
Headphone Terminal 3.5mm stereo mini jack
 Output impedance50 or lower
 Output signal level-17 dBV32 load, maximum volume)
USB Terminal USB Type-C® jack
Can be used to connect a smartphone or Ethernet adapter. USB Video Class and USB Audio Class (UVC and UAC) are supported.
In-camera charging and power supply are possible with USB Power Adapter PD-E2.
With an Ethernet adapter: equivalent to SuperSpeed USB (USB 3.2 Gen 1)
In other cases: equivalent to SuperSpeedPlus USB (USB 3.2 Gen 2)
TIME CODE Terminal DIN1.0/2.3 jack terminal
 InputInput impedance: 100k
Signal level: 0.5-4.5 Vp-p
 OutputOutput impedance: 50
Signal level: 1.3 Vp-p
Other Terminals
Multi-Accessory Shoe Terminal Canon original specifications
Power Source
Terminal Battery terminal: DC 7.2 V (battery pack
Compatible battery LP-E6Pprovided with camera/LP-E6NH*
*Lenses that do not operate when powered by LP-E6NH or DR-E6C only in VIDEO mode
EF28-70mm F3.5-4.5EF50mm 1.0L USMEF28-80mm F2.8-4L USM
EF1200mm F5.6L USMEF24mm F2.8EF100mm F2 USM
EF 200mm F2.8 LEF200mm F2.8L II USMEF100-200mm F4.5A
EF35-80mm F4-5.6 PZEF35-80mm F4-5.6EF80-200mm F4.5-5.6
EF75-300mm F4-5.6 IS USMEF80-200mm F4.5-5.6 IIEF75-300mm F4-5.6 II
EF28-80mm F3.5-5.6EF35-135mm F4-5.6 USMEF100-300mm 4.5-5.6 USM
EF70-210mm F3.5-4.5 USMEF35-105mm F4.5-5.6EF75-300mm 4-5.6
EF35-350mm 3.5-5.6L USMEF28-70mm 2.8L USMEF20-35mm 3.5-4.5 USM
EF70-200mm F2.8L USMEF24-85mm 3.5-4.5 USMEF20mm F2.8 USM
EF85mm F1.8 USMEF400mm F5.6L USMEF135mm F2L USM
EF300mm F4L IS USMEF35-80mm F4-5.6 USMEF75-300mm F4-5.6 USM
EF75-300mm F4-5.6 II USMEF28-80mm F3.5-5.6 III USMEF28-80mm F3.5-5.6 USM
EF55-200mm F4.5-5.6 USMEF28-80mm F3.5-5.6 V USMEF75-300mm F4-5.6 III USM
EF28-80mm F3.5-5.6 IIEF28-90mm F4-5.6 USMEF28-90 F4-5.6
EF28-105mm F4-5.6 USMEF90-300mm 4.5-5.6EF28-90mm F4-5.6 USM
EF70-300mm F4-5.6 IS USMEF35mm 1.4L USMEF400mm F2.8L IS USM
EF85mm F1.2L II USMEF28-135mm 3.5-5.6 IS USMEF100-400mm F4.5-5.6L IS USM
EF70-200mm F4L USMEF16-35mm F2.8L USMEF24-70mm F2.8L USM
EF17-40mm F4L USMEF70-300mm 4.5-5.6 DO IS USMEF70-200mm F4L IS USM
EF16-35mm 2.8L II USMEF8-15mm F4L FISHEYE USM
Dimensions and Weight
Dimensions (W x H x D) Camera (Width x height x depth)
Approx. 142 x 88 x 95 mm (5.6 x 3.5 x 3.7 in.) (camera body only)
Approx. 222 x 239 x 186 mm (8.7 x 9.4 x 7.3 in.) (attached handle unit and Microphone holder)
* For dimension details, refer to the six-sided view.
Weight (1) Camera
Approx. 670 g (1.47 lb.)
(2) Camera+Battery Pack LP-E6P+CFexpresscard+SD card
Approx. 765g (1.7 lb.)
(3) Camera+Handle unit+Microphone holder+Battery Pack LP-E6P+CFexpresscard+SD card
Approx. 1120 g (2.5 lb.)
(4) Supplied accessories
Handle unit: Approx. 300 g (10.6 oz.)
Microphone holder and two bolts: Approx. 60 g (2.1 oz.)
LP-E6P Battery Pack: Approx. 82 g (2.89 oz.)
LC-E6 Battery Charger: Approx. 110 g (3.9 oz.)
LC-E6E Battery Charger: Approx. 100 g (3.5 oz.) (excluding power cord)
Operating Environment
Temperature and humidity requirements for performance Approx. 0 to 40°C (32 to 104 ), 85% (relative humidity)
Temperature and humidity requirements for operation Approx. -5 to 45°C (23 to 113 ), 60% (relative humidity)
Video
Sensor Mode
Sensor modeMain Rec FormatMain Resolution
Full frame 3:2RAW6960x4640
XF-HEVC S6912x4608
Full frameRAW6960x3672
XF-AVC, XF-HEVC S, XF-AVC S4096x2160, 3840x2160, 2048x1080, 1920x1080
Super 35mm (Crop)RAW5036x2656
Super 16mm (Crop)RAW2524x1332
XF-AVC, XF-HEVC S, XF-AVC S2048x1080, 1920x1080
Base ISO
Gamma/Color Space GammaMENU > [Camera Setup] > [ISO/Gain]
[ISO][Gain]
Canon Log 2, Canon Log 3Auto Selection, Base ISO 800, Base ISO 6400Auto Selection, Base ISO 800 (12dB), Base ISO 6400 (12dB)
PQ, HLG, Canon 709, BT.709 Wide DRAuto Selection, Base ISO 400, Base ISO 3200Auto Selection, Base ISO 400 (6dB), Base ISO 3200 (6dB)
BT.709 StandardAuto Selection, Base ISO 160, Base ISO 1250Auto Selection, Base ISO 160 (-2dB), Base ISO 1250 (-2dB)
Media Overview
 SD CardCfexpress Card
TypeSD, SDHC, SDXCCFexpress 2.0
Type B
Number of slots11
Speed class / VPGSpeed classC6, C10 VPG 400
UHS speed class U1, U3
Video speed class V30, V60, V90
File systemSD card (2GB) FAT12, 16CFexpress(,8TB): exFAT
SDHC card (up to 32GB): FAT32
SDXC card (exceeds 32GB to 2TB): exFAT
File division units: FAT32 is 4GB
exFAT is none Maximum of 9 file divisions per clip
(FAT32 only)
Maximum number of clips per mediaRAW / XF-AVC / XF-HEVC SXF-AVC S: 999
Recorded dataMovie: XF-AVC, XF-AVC S, XF-HEVC SMovie: RAW, XF-AVC, XF- HEVC S, XF-AVC S
Audio: WAV
Other: custom pictures and metadata
(CFexpress card may be used only by recording format, etc.)
Photo: JPEG Audio: WAV
Other: custom pictures, metadata, and menu settings
Available Combinations for Second Card Recording
 2nd Card Rec
OffProxy RecSub RecAudio RecRelay RecordingDouble Slot RecordingCrop RecChunk Rec
Recording ModeNormal Recording*2
Slow & Fast Motion*1*1----
S&F / Audio(WAV)-------
Pre-Recording*2-
Continuous Recording*2*3-------
Frame Recording-----
Interval Recording-----
Simultaneous recording is available only with normal recording while connected to a network with IP streaming activated.
*1 Only when the main recording format is RAW.
*2 Not available when recording in RAW format.
*3 Not available when recording in XF-AVC format.
Slow & Fast Motion Recording
Frame rateAvailable frame rate for Slow & Fast Motion Recording *1
59.94P1, 2, 3, 6, 15, 30, 44, 48, 52, 56, 60, 90, 120, 150, 180
29.97P1, 2, 3, 6, 15, 22, 24, 26, 28, 30, 32, 36, 40, 44, 48, 52, 56, 60, 90, 120, 150, 180
50.00P1, 5, 15, 25, 34, 38, 42, 46, 50, 54, 58, 60, 75, 100, 120, 125, 150, 175, 180
25.00P1, 5, 15, 17, 19, 21, 23, 25, 26, 28, 30, 34, 38, 42, 46, 50, 54, 58, 60, 75, 100, 120, 125,
150, 175, 180
23.98P, 24.00P1, 2, 3, 6, 12, 16, 18, 20, 22, 24, 26, 28, 30, 32, 36, 40, 44, 48, 52, 56, 60, 72, 96, 120, 144, 150*2, 168, 180
*1 Maximum frame rate varies by sensor mode.
Full Frame 3:2: up to 30P Full Frame: up to 180P
Super 35mm (Cropped): up to 60P
Super 16mm (Cropped): up to 150P
*2 Only in Super 16mm (Cropped) sensor mode.
Available Shooting Frame Rates
Configurable frame rate (RAW)
Main Rec FormatMain resolutionFrame rate
59.94P29.97P23.98P50.00P25.00P24.00P
RAW ST, RAW LT6960x4640-1,1501,30-1,301,30
RAW HQ6960x3672
5036x2656
-1,301,30-1,301,30
RAW ST, RAW LT1,601,601,601,601,601,60
RAW HQ, RAW ST, RAW LT2524x13321,1501,1501,1501,1501,1501,150
Configurable frame rate (XF-AVC)
Main Rec FormatMain resolutionFrame rateBit rateFrame rate for Slow & Fast Motion Recording *1*2 Up To
XF-AVC YCC422 10bit4096x2160Intra-frame
3840x2160Intra-frame
59.94P1200 Mbps1,60
900 Mbps600 Mbps1,120
50.00P1000 Mbps1,60
750 Mbps500 Mbps1,120
29.97P600 Mbps1,60
450 Mbps300 Mbps1,120
25.00P500 Mbps1,60
375 Mbps250 Mbps1,120
24.00P, 23.98P
480 Mbps
1,60
360 Mbps240 Mbps1,120
4096x2160LongGOP
3840x2160LongGOP
59.94P, 50.00P250 Mbps1,120
29.97P, 25.00P, 24.00P, 23.98P150 Mbps1,120
2048x1080Intra-frame
1920x1080Intra-frame
59.94P300 Mbps1,180
50.00P250 Mbps1,180
29.97P150 Mbps1,180
25.00P125 Mbps1,180
24.00P, 23.98P120 Mbps1,180
2048x1080LongGOP
1920x1080LongGOP
59.94P, 50.00P, 29.97P, 25.00P, 24.00P, 23.98P50 Mbps1,180
*1 Up to 60P when the sensor mode is [Super 35mm (Cropped)]
*2 Up to 150P when the sensor mode is [Super 16mm (Cropped)]
Configurable frame rate (XF-HEVC S) Recording media: CFexpress card
XF-HEVC S YCC422 10bit6912x4608
Intra-frame
29.97P1620 Mbps
1080 Mbps
130
25.00P1350 Mbps
900 Mbps
130
24.00P, 23.98P1730 Mbps124
1300 Mbps
864 Mbps
130
6912x4608
LongGOP
29.97P, 25.00P,
24.00P, 23.98P
486 Mbps130
4096x2160LongGOP
3840x2160LongGOP
59.94P, 50.00P225 Mbps1120
29.97P, 25.00P,
24.00P, 23.98P
135 Mbps1120
2048x1080LongGOP
1920x1080LongGOP
59.94P, 50.00P,
29.97P, 25.00P,
24.00P, 23.98P
50 Mbps1180
XF-HEVC S YCC420 10bit6912x4608
LongGOP
29.97P, 25.00P,
24.00P, 23.98P
360 Mbps130
4096x2160LongGOP
3840x2160LongGOP
59.94P, 50.00P150 Mbps1120
29.97P, 25.00P,
24.00P, 23.98P
100 Mbps1120
2048x1080LongGOP
1920x1080LongGOP
59.94P, 50.00P,
29.97P, 25.00P,
24.00P, 23.98P
35 Mbps1180
*1 Up to 60P when the sensor mode is [Super 35mm (Cropped)].
*2 Up to 150P when the sensor mode is [Super 16mm (Cropped)].
Configurable frame rate (XF-AVC S) Recording media: CFexpress card
XF-AVC S YCC422 10bit4096x2160Intra-frame
59.94P1200 Mbps160
900 Mbps600 Mbps1120
50.00P1000 Mbps160
750 Mbps500 Mbps1120
29.97P600 Mbps160
450 Mbps300 Mbps1120
25.00P500 Mbps160
375 Mbps250 Mbps1120
24.00P, 23.98P480 Mbps160
360 Mbps240 Mbps1120
4096x2160LongGOP
3840x2160LongGOP
59.94P, 50.00P250 Mbps1120
29.97P, 25.00P
24.00P, 23.98P
150 Mbps1120
59.94P300 Mbps1180
50.00P250 Mbps1180
29.97P150 Mbps1180
25.00P125 Mbps1180
24.00P, 23.98P120 Mbps1180
2048x1080LongGOP
1920x1080LongGOP
59.94P, 50.00P,
29.97P, 25.00P,
24.00P, 23.98P
50 Mbps1180
XF-AVC S YCC420 8bit4096x2160LongGOP
3840x2160LongGOP
29.97P, 25.00P,
24.00P, 23.98P
100 Mbps1120
2048x1080LongGOP
1920x1080LongGOP
59.94P, 50.00P,
29.97P, 25.00P,
24.00P, 23.98P
35 Mbps1180
Crop Recording
Available configurations
Primary clip  Crop recording
Recording format / Color sampling / Resolution / Scanning method
XF-HEVC SXF-AVC S
YCC 422
10bit
YCC 420
10bit
YCC 422
10bit
YCC 420
10bit
YCC 422
10bit
YCC 420
10bit
YCC 422
10bit
YCC 420
8bit
YCC 422
10bit
YCC 420
8bit
YCC 422
10bit
YCC 420
8bit
Recording formatResolutionScanning method1080x20481080x19201080x10801080x20481080x19201080x1080
RAWAll-------------
XF-AVC YCC422
10bit
4096x
2160
P--------
3840x
1920
P--------
All except the above------------
XF-HEVC S YCC422
10bit
4096x
2160
P--------
3840x
1920
P--------
XF-HEVC S YCC420
10bit
4096x
2160
P----------
3840x
1920
P------ ---
XF-AVC S YCC422
10bit
4096x
2160
P--------
3840x
1920
P--------
XF-AVC S YCC420
8bit
4096x
2160
P----------
3840x
1920
P----------
Available values
Recording formatResolutionBit rateSystem Frequency / Frame rate
59.94 Hz50.00 Hz24.00 Hz
XF-HEVC S YCC422 10bit1080x2048
1080x1920
50 Mbps L.GOP
1080x108027 Mbps L.GOP
XF-HEVC S YCC420 10bit1080x2048
1080x1920
35 Mbps L.GOP
1080x108019 Mbps L.GOP
XF-AVC S YCC422 10bit1080x2048
1080x1920
300 Mbps Intra-----
250 Mbps Intra-----
150 Mbps Intra------
125 Mbps Intra-----
120 Mbps Intra----
500 Mbps Intra
1080x1080159 Mbps Intra-----
133 Mbps Intra-----
80 Mbps Intra-----
67 Mbps Intra-----
64 Mbps Intra----
27 Mbps Intra
XF-HEVC S1080x2048
1080x1920
35 Mbps L.GOP
Cropped recording is not available in these situations.
- Full Frame 3:2 or Super 16mm (Cropped) sensor mode
- Slow & Fast Motion, Frame Recording, or Interval Recording recording mode
Anamorphic desqueeze is not available for clips recorded cropped.
Cropped video output to an external monitor during recording is not supported.
Auto Focus
Auto Focus Subject detection (Subject to Detect, Subject Detection AF*, Eye Detection, Face Detection AE, and Tracking) is available in Slow & Fast Motion recording at frame rates of 24P or higher. At frame rates in a range of 1P150P, other AF-relatedfunctions are also available.
* At frame rates of 150P or lower.
Focusing systems Dual Pixel CMOS AF(CMOS AF)
CMOS AF detection range
When detecting the entire area and subject, approx. 100% (Vertical) x approx. 100% (Horizontal).
Otherwise approx. 100% (Vertical) x approx. 90% (Horizontal)
May be approx. 100 (Vertical) x approx. 80% (Horizontal), approx. 75% (Vertical) x approx. 40% (Horizontal) depending on the lens
AF Modes Applies when the AF/MF switch of an RF lens is set to AF.
Continuous AF
Used to keep continuously focused on a subject.
One-Shot AF
AF is performed only while the assignable button assigned to One-Shot AF is pressed. No further lens movement is permitted after focusing.
Releasing the assignable button resumes continuous AF if it is enabled. When [Lens action if cannot AF] is set to [Stop] in Continuous AF mode, stop the search when distance measurement is not possible.
AF Area Small Zone: Video display range approx. 14.7Verticalx12.2Horizontal
Flexible Zone 1Video display range approx. 38Verticalx 26Horizontal
Flexible Zone 2Video display range approx. 85Verticalx 26Horizontal
Flexible Zone 3Video display range approx. 38Verticalx 77 (Horizontal
Full: approx. 100% (Vertical) x approx. 100% (Horizontal)
The area frame can be moved,* and thickness is adjustable.
* Only with options other than [Whole Area] and when digital zoom is off.
Area frame resizing is available for Flexible Zone options 13.
Values above are based on these conditions: [Sensor Mode]: [Full Frame];
[Main Resolution]: 4096x2160 or 2048x1080; [Electronic IS]: [Off].
AF Lock Available
AF Speed With compatible lenses, the lens drive speed is configurable.
Subject to Detect Detects the eyes, face, head, or body of people or the eyes, face, or body of animals, as set in the menu.
Setting to [People] targets human subjects for detection. Momentary inability to detect eyes / face / head will cause the camera to prioritize bodies (and when these parts can be detected again, they take precedence). Setting to [Animals] targets both animals and people for detection, and if both are detected, animals are given precedence. In scenes that include multiple subjects for detection, the most fitting main subject for detection results and how the shot is composed is automatically selected.
Setting to [People] with autofocus active displays a white frame on the main subject and gray frames on all other subjects detected. Setting to [Animals] only displays a white frame on the main subject out of all animals and people detected.
Subject Detection AF Controls how AF operation changes, based on the menu setting, if targeted subjects are not detected.
Setting to [Detect. Priority] performs AF for any detected main subjects set in [Subject to Detect], or if none are detected, in the specified AF area.
Setting to [Detect. Only] performs continuous AF restricted to main subjects set in [Subject to Detect]. The camera keeps focusing on the last detected position of any subjects that become undetectable. Continuous AF resumes when subjects are once again detected.
Subject-Switching Sensitivity Enables adjustment of how readily the camera switches focus from one main subject to another. Set in a range of 15. [1] makes the camera less likely to switch subjects, and [5] makes switching easier.
Eye Detection Determines which eye is given precedence when two eyes are detected, as set in the menu.Setting to [Auto] targets the eye closest to the camera. If both eyes are the same distance away, the camera targets the eye closer to the center of the configured AF area. Setting to [Right Eye Priority] gives the subjects right eye precedence. Setting to [Left Eye Priority] gives the subjects left eye precedence.
Tracking The main subject can be selected for tracking with the joystick or touch panel.Setting the AF area to [Whole Area] AF enables main subject tracking by pressing the joystick in when the camera detects the target subject set in [Subject to Detect]. The joystick can also be pressed left or right to track specific subjects if multiple subjects are detected. Subjects other than those targeted for detection can also be tracked by tapping them.Additionally, regardless of the configured AF area, any preferred subject can be tracked by tapping it or pressing the joystick after using it to move the marker, once the camera is set to tracking selection mode by pressing the assignable button assigned to tracking.
Tracking by Touch Priority Enables touch-based tracking of any subject regardless of the configured AF area.
Track after Focusing Enables main subjects targeted for AF to be switched with the focusing ring, when Continuous AF is enabled and this function is set to [On (Tracking Frame)] in the menu. As the focusing ring is turned, based on the focus position, an orange tracking frame is displayed on a potential subject that users can switch to, and when manual focusing stops, the potential subject by the tracking frame is tracked as the main subject. Whether or not to display tracking frames for potential subjects can be set from the menu.Without a subject in focus, no tracking frame is displayed, and the camera does not switch subjects after manual focusing.Disabling the function in the menu disables this tracking after focusing.
Exposure Control
Exposure Control Modes Manual
Manual setting using shutter, iris, ISO/Gain, and ND filter.
Push Auto Iris*
While the Push Auto Iris button is pressed, the aperture is controlled to achieve proper exposure. If deviation from the proper exposure occurs, it takes control again.
Auto Iris*
Constantly adjusts automatically for proper exposure using iris.
Auto ISO/Gain*
Constantly adjusts automatically for proper exposure using ISO/Gain.
Auto Shutter*
Constantly adjusts automatically for proper exposure using Shutter.
Other
AE Response can be changed in the menu.
Auto ISO/Gain can be used in combination with Auto Iris or Push Auto Iris.
* Not available at recording frame rates higher than 150P in Slow & Fast Motion recording.
Metering Modes Standard (center-weighted metering), Spotlight, Backlight
*If [EOS Standard] or [EOS Neutral] is selected in [CP File Selection], the setting value will be grayed out and cannot be selected as photometry is performed in the same way as the EOS R series. Editing the CP File (Gamma adjustment, registering another LUT as a Look File), makes it selectable.
Exposure Compensation AE shift is available (±8 levels relative to center). Levels (EV values) are indicated numerically.
Shutter
Shutter mode Electronic shutter
Shutter Speeds 1/16000*1*2 30 sec., bulb
*1 Up to 1/8000 sec. when set to HDR mode, focus bracketing, or same exposure for new aperture (ISO speed/Shutter speed, Shutter speed).
*2 1/10000 and 1/12800 sec. can also be selected.
X-Sync Not Provided
Shutter
Shutter manual modeSystem frequency/Frame rate
59.94 Hz24.00
Hz
50.00 Hz
59.94P / 59.94i29.97P23.98P24.00P50.00P/50.00i25.00P
Speed*11/3-stop
increments
1/1 1/200034 setting options in total
1/4-stop increments1/1 1/200059.94 Hz/24.00 Hz47 setting options in total, 50.00 Hz45 setting options in total
Angle*1360°, 240°, 180°, 120°, 90°, 60°, 45°, 30°, 22.5°, 15°, 11.25°
Also angle values equivalent to the following shutter speeds: 1/120, 1/100, 1/60, 1/50, 1/40, 3/100, 1/30, 1/25
Clear Scan*1Approx. 242000 Hz
Within the above range, the frequency can be set with the minimum available resolution depending on the sensor mode and frame rate.
Slow*21/4, 1/8, 1/15, 1/301/4, 1/8, 1/151/3, 1/6, 1/121/3, 1/6, 1/12, 1/251/3, 1/6, 1/12
Off*11/601/301/241/241/501/25
*1 When slow & fast motion recording is activated, available setting options will vary depending on the selected shooting frame rate.
*2 Not available when slow & fast motion recording is activated.
Custom Picture
ItemCorreCharacteristics
CP FileC1: Canon 709
Gamma provides a wide dynamic range with contrast and is suitable for use without postprocessing. Output to a BT. 709 compliant monitor.
C2: Canon Log 2
Gradations best suited to post-processing. Has characteristics similar to film, making it easy to work with in log space grading.
C3: Canon Log 3
Gradations best suited to post-processing. This is a gamma feature for simple grading that sticks to tightening shading and adjusting tones.
C4: BT. 709 Widde DR
Video-based gamma setting with wide dynamic range. Outputs to TV monitor.
C5: BT. 709 Standard
Gamma according to the ITU-R BT. 709 standard.
C6: PQ
Gamma compliant with ITU-R BT.2100-0 PQ specifications.
C7: HLG
Gamma compliant with ITU-R BT.2100-0 HLG specifications.
C8: EOS Standard
C9: EOS Neutral
C10: User10 , User20
Recording pixel count
Image sizeResolution (Pixels)
Still photo cropping / aspect ratio
3:21.6x (crop)*11:14:316:9
JPEG / HEIFLApprox. 32.3
megapixels
(6960×4640)
Approx. 12.4
megapixels
(4320×2880)
Approx. 21.5
megapixels
(4640×4640)
Approx. 28.6
megapixels*2
(6160×4640)
Approx. 27.2
megapixels*2
(6960×3904)
MApprox. 15.4
megapixels
(4800×3200)
 Approx. 10.2
megapixels
(3200×3200)
Approx. 13.6
megapixels*2
(4256×3200)
Approx. 12.9
megapixels*2
(4800×2688)
51Approx. 8.1
megapixels*2
(3472×2320)
 Approx. 5.4
megapixels
(2320×2320)
Approx. 7.1
megapixels*2
(3072×2320)
Approx. 6.8
megapixels*2
(3472×1952)
52Approx. 3.8
megapixels
(2400×1600)
Approx. 3.8
megapixels
(2400×1600)
Approx. 2.6
megapixels
(1600×1600)
Approx. 3.4
megapixels*2
(2112×1600)
Approx. 3.2
megapixels*2
(2400×1344)
RAWRAW / C RAWApprox. 32.3
megapixels
(6960×4640)
Approx. 12.4
megapixels
(4320×2880)
Approx. 32.3 megapixels
(6960×4640)
* Values for recorded pixels are rounded off to the nearest 100,000th.
* RAW/C-RAW images are generated in [3:2], and the set aspect ratio information is appended to the images.
* JPEG/HEIF images are generated in the set aspect ratio.
* These aspect ratios and pixel counts also apply to resizing.
*1: Angle of view of approx. 1.6 times the indicated focal length.
*2: Indicate an inexact proportion.
Drive System
Drive Modes and Continuous Shooting Speed
Drive ModeAF OperationElectronic Shutter
[Max. approx.]
Single shooting Yes
High-speed continuous shooting + One-Shot AF AI Focus AF Servo AF40 shots/sec.*1
High-speed continuous shootingOne-Shot AF AI Focus AF Servo AF20 shots/sec.*1,*2
Low-speed continuous shootingOne-Shot AF AI Focus AF Servo AF5.0 shots/sec.
Self-timer: 10 sec. Yes
Self-timer: 2 sec. Yes
Self-timer: Continuous Yes
* For details on the measurement conditions, see 22.3.1 Continuous shooting speed measurement conditions for High-speed continuous shooting + and High-speed continuous shooting.
* For details on factors that reduce maximum continuous shooting speed, see 22.3.2 Factors that reduce maximum continuous shooting speed.
* Expressed to two significant digits.
* Zooming during continuous shooting with electronic shutter may, depending on the lens, cause changes inexposure even at the same f/number. For details on relevant lenses, refer to the OTH_03 lens list (even withzoom lenses that are not listed, sudden zooming may cause changes in exposure or flickering).
*1: Operates in mode C with a lens attached that is not in the OTH_08 lens list.
*2: Continuous shooting speed decreases when flicker is detected.
CANON PROFESSIONAL DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY FOR PRODUCTS
PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Digital Video Equipment (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
  1. Loss or damage to the Equipment due to abuse, mishandling, accident improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
  2. If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
  3. If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
  4. If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
  5. Any internal modification to product hardware or firmware;
  6. Any applicable fee for Maintenance of the Equipment;
  7. If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
Title Firmware Notice: EOS C50: Firmware Version 1.0.6.1
Advisory Type Firmware Notice
Date 10.20.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
