Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 12.18.25
File Size 718.54 KB
Date 11.04.25
File Size 57.06 MB
Date 12.02.25
File Size 334.71 KB
Date 07.22.25
File Size 12.75 MB
Camera Connect
Camera Connect
image.canon
image.canon
Lens mount RF mount
Sensor 35mm full-frame CMOS sensor
Number of pixels Total pixels: approx. 26.7 megapixels
Effective pixels: up to approx. 19.0 megapixels
ISO sensitivity 160-25600 (Extended: 100-102400)
BASE ISO 800 / 3200 / 12800 / Auto
(Ex.: Canon Log 2, Canon Log 3, RAW recording)
Sensor mode Full-frame, Super 35mm Crop
ND filter Mechanical ND filter (2 / 4 / 6 / 8* / 10 stops**With extender
Maximum frame rate 6K 29.97P/25.00P (RAW) [internal recording]
4.3K 59.94P/50.00P (RAW) [internal recording]
4K 59.94P/50.00P (XF-AVC/XF-HEVC S/XF-AVC S)
2K 59.94P/50.00P (XF-AVC/XF-HEVC S/XF-AVC S)
Color space Cinema GamutBT.2020 GamutBT.709 Gamut
White balance Auto, sunlight, tungsten, color temperature (2000K to 15000K), settings A/B
Dynamic range 16 stops
AF Dual Pixel CMOS AF II
Recording format Movies: Cinema RAW Light, XF-AVC, XF-HEVC S, XF-AVC S
Photos: JPEG
Slow & Fast Maximum Frame Rate* Full-frame: 6000x3164/30P, 4096x2160/120P. 2048x1080/180P
Super35mm Crop: 4368x2304/60P, 4096x2160/120P, 2048x1080/120P
Recording format (audio) Linear PCM 24-bit/48kHz/4ch
AAC 16-bit/48kHz/2ch (XF-HEVC S / XF-AVC S)
Recording media SD card (2 slots)
LCD monitor 3.5-inch (high brightness type) LCD 2.76 million dots, touch panel
Viewfinder No
Level Yes (Roll / Tilt )
SDI OUT Yes (BNC terminal x1, 12G/6G/3G/HD-SDI)
HDMI Yes (Type-A)
HDMI RAW Output Yes (6K 59.94P/50P)
Audio input Yes (Mini-XLR x2) *AES/EBU not supported
Ethernet Yes
Wi-Fi Yes (internal)
Multi-function shoe (21 pin) Yes (with electrical contacts)
USB Yes (USB Type-C) [HOST not supported/no power supply]
MIC Yes(3.5mm stereo mini jack)
Headphone Yes (stereo)
REMOTE A(2.5mm) Yes (REMOTE terminal)
TC (TIME CODE) Yes (BNC terminal) [doubles as input/output]
DC-IN Yes (round pin jack x1)
Battery BP-A30NBP-A60NBP-A30BP-A60
AC adapter CA-CP300B
Operating temperature Guaranteed performance conditions: Approx. 32o F to 104o F (0 to 40 )85 (relative humidity)
Guaranteed operating conditions: Approx. 23o F to 113o F (-5 to 45 )60 (relative humidity)
Dimensions (W x H x D) Approx. 6.3 x 5.4 x 4.5 in. (160 x 137.4 x 116mm)
Main body weight Approx. 2.8 lbs. (1300 g)
CANON PROFESSIONAL DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY FOR PRODUCTS
PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Digital Video Equipment (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
  1. Loss or damage to the Equipment due to abuse, mishandling, accident improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
  2. If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
  3. If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
  4. If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
  5. Any internal modification to product hardware or firmware;
  6. Any applicable fee for Maintenance of the Equipment;
  7. If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
Title Firmware Notice: EOS C80: Firmware Version 1.0.5.1
Advisory Type Firmware Notice
Date 01.20.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
