Canon Support for EOS Digital Rebel XT | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type
| Type | Digital AF/AE SLR |
| Recording Media | CF card Type I and II |
| Image Format | 0.87 x 0.58 in./22.2 x 14.8mm |
| Compatible Lenses | Canon EF Lenses including EF-S Lenses (Focal length conversion factor: Equivalent to approx. 1.6x indicated focal length compared to 35mm format) |
| Lens Mount | Canon EF mount |
Image Sensor
| Type | High-sensitivity, high-resolution, single-plate color CMOS sensor |
| Pixels | Approx. 8.0 Megapixels |
| Total Pixels | Approx. 8.2 Megapixels |
| Aspect Ratio | 2:3 (Vertical:Horizontal) |
| Color Filter System | RGB primary color filter |
| Low Pass Filter | Fixed position in front of the image sensor |
Recording System
| Recording Format | Design rule for Camera File System 2.0 |
| Image Format | JPEG, RAW (12bit) Simultaneous Recording: Possible |
| File Size | JPEG: (1) Large/Fine: Approx. 3.3 MB (3456 x 2304), (2) Large/Normal: Approx. 1.7 MB (3456 x 2304), (3) Medium/Fine: Approx. 2.0 MB (2496 x 1664), (4) Medium/Normal Approx. 1.0 MB (2496 x 1664), (5) Small/Fine: Approx. 1.2 MB (1728 x 1152), (6) Small/Normal: Approx. 0.6 MB (1728 x 1152); RAW: Approx. 8.3 MB (3456 x 2304) |
| Folders | Automatic setting |
| File Numbering | (1) Continuous numbering, (2) Auto reset |
| Interface | USB 2.0 Hi-Speed |
White Balance
| Settings | Auto, Preset (Daylight, Shade, Cloudy/Twilight/Sunset, Tungsten light, White fluorescent light, Flash), Manual (Custom: read off photo quality gray card or white subject) |
Viewfinder
| Type | Eye-level SLR (with fixed pentamirror) |
| Coverage | Approx. 95% vertically and horizontally (against JPEG Large) |
| Magnification | 0.8x (-1 diopter with 50mm lens at infinity) |
| Eye Point | 21mm |
| Dioptric Adjustment Correction | -3.0 - +1.0 diopters |
| Focusing Screen | Fixed |
| Mirror | Quick-return half mirror (Transmittance: reflection ratio of 40:60, no mirror cut-off with lenses up to EF 600mm f/4) |
| Viewfinder Information | AF points, AE lock, FE lock, AEB in progress, Flash ready, Improper FE lock warning, High-speed Sync, Flash exposure compensation, Red-Eye reduction, Shutter speed, Bulb, FE lock, Processing data, Built-in flash recycling, Aperture, Exposure level display (Exposure compensation, Manual exposure level, AEB level, Flash exposure compensation, Red-Eye Reduction lamp on time display), Max burst during continuous shooting, AF/MF focus confirmation, CF card full, CF card error, no CF card |
| Depth Of Field Preview | Enabled with depth-of-field preview button |
| Eyepiece Shutter | None (provided on strap) |
Autofocus
| Type | TTL-CT-SIR with AF-dedicated CMOS sensor |
| AF Points | 7 |
| AF Working Range | EV 0.5 - 18 (at ISO 100) |
| Focusing Modes | One-Shot AF, Predictive AI Servo AF, AI Focus AF (Automatically selects One-Shot AF or AI Servo AF selected according to shooting mode), Manual Focusing (MF) |
| AF Point Selection | Automatic selection, manual selection |
| Selected AF Point Display | Superimposed in viewfinder and indicated on LCD panel |
| AF Assist Beam | Intermittent firing of built-in flash, effective range: approx. 13.1 ft./4m at center, approx. 11.5 ft./3.5m at periphery |
Exposure Control
| Metering Modes | Max. aperture TTL metering with 35-zone SPC. (1) Evaluative metering, (2) Partial metering at center (approx. 9% of viewfinder), (3) Center-weighted average metering |
| Metering Range | EV 1-20 (at 68° F/20° C with 50mm f/1.4 lens at ISO 100) |
| ISO Speed Range | Equivalent to ISO 100-1600 |
| Exposure Compensation | Up to +/-2 stops in 1/2- or 1/3-stop increments (1) Manual exposure compensation (2) AEB (Auto Exposure Bracketing) |
| AE Lock | Auto: Operates in One-Shot AF mode evaluative metering when focus is achieved; Manual: Enabled with AE lock button (No AE lock in Basic Zone modes) |
| Shutter | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled1/4000 to 30 sec. in 1/2- or 1/3-stop increments, bulb, X-Sync at 1/200 sec.Soft-touch electromagnetic release10-sec. delayRemote control with RS-60E3 Terminal or Wireless remote controllers RC-1/RC-5 |
| Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
| Shutter Speeds | 1/4000 to 30 sec. in 1/2- or 1/3-stop increments, bulb, X-Sync at 1/200 sec. |
| Shutter Release | Soft-touch electromagnetic release |
| Self Timer | 10-sec. delay |
| Remote Control | Remote control with RS-60E3 Terminal or Wireless remote controllers RC-1/RC-5 |
Built in Flash
| Type | Auto pop-up, retractable, built-in flash in the pentaprism |
| Guide Number | 13 (at ISO 100 in meters) |
| Recycling Time | Approx. 3 sec. |
| Flash Ready Indicator | Flash-ready indicator lights on in viewfinder |
| Flash Coverage | Up to 17mm focal length (equivalent to 27mm in 35mm format) |
External Speedlite
| EOS Dedicated Speedlite | E-TTL II autoflash |
Drive System
| Drive Modes | (1) Single, (2) Continuous, (3) Self-timer/Remote Control |
| Continuous Shooting Speed | Approx. 3.0 fps (with Battery Pack NB-2LH, at Tv=1/250 sec. for all recording qualities) |
| Maximum Burst | 14 shots (Large/Fine) |
LCD Monitor
| Type | TFT color LCD monitor |
| Monitor Size | 1.8 inches |
| Pixels | Approx. 115,000 pixels (Displayed pixels) |
| Coverage | Approx. 100% (for JPEG images) |
| Brightness Control | 5 levels (settable with menu's "LCD brightness") |
Playback
| Display Format | (1) Single image, (2) 9-image Index, (3) Magnified Zoom, (4) Auto Play, (5) Auto Play right after shooting |
| Highlight Alert | In the single image with information display mode, the highlighted portions containing no image information with blink |
Image Protection and Erase
| Protection | A single image can be protected or unprotected |
| Erase | A single image or all images stored in a CompactFlash card can be erased if they are unprotected |
Menus
| Menu Categories | (1) Shooting 1 [6 items], (2) Shooting 2 [7 items], (3) Playback [5 items], (4) Setup 1 [7 items], (5) Setup 2 [7 items] |
| LCD Monitor Language | Any of the following 15 languages can be selected: English, German, French, Dutch, Danish, Italian, Finnish, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Korean, Russian, and Japanese |
| Firmware Update | Enabled by the user |
Power Source
| Battery | Battery Pack NB-2LH (x1) |
Dimensions and Weight
| Dimensions (W x H x D) | 4.98 x 3.71 x 2.63 in./126.5 x 94.2 x 64mm |
| Weight | 17.1 oz./485g |
Operating Environment
| Working Temperature Range | 32-104° F/0-40° C |
| Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
 in the top right of the browser in the top right of the browser
 in the top right of the browser next to your download
