Canon Support for EOS Digital Rebel XTi | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type
Type | Digital AF/AE SLR with built-in flash |
Recording Media | CompactFlash (CF) Card Type I & II |
Image Format | 0.87 x 0.58 in./22.2 x 14.8mm (APS-C size sensor) |
Compatible Lenses | Canon EF and EF-S lenses |
Lens Mount | Canon EF mount |
Image Sensor
Type | High-Sensitivity, high-resolution, single-plate, CMOS sensor |
Pixels | Approx. 10.10 megapixels |
Total Pixels | Approx. 10.50 megapixels |
Aspect Ratio | 3:2 (Horizontal : Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the CMOS sensor |
Dust Deletion Feature | (1) Automatic sensor cleaning (2) User-activated sensor cleaning (3) Dust Delete Data appended to image data |
Recording System
Recording Format | JPEG, RAW, and RAW+JPEG simultaneous recording provided. The RAW and JPEG images are saved as separate files in the CF card. |
Image Format | JPEG, RAW (Canon .CR2) |
File Size | (1) Large/Fine: Approx. 3.8MB (3,888 x 2,592) (2) Large/Normal: Approx. 2.0MB (3,888 x 2,592) (3) Medium/Fine: Approx. 2.3MB (2,816 x 1,880) (4) Medium/Normal: Approx. 1.2MB (2,816 x 1,880) (5) Small/Fine: Approx. 1.3MB (1,936 x 1,288) (6) Small/Normal: Approx. 0.7MB (1,936 x 1,288) (7) RAW: Approx. 9.8MB (3,888 x 2,592) |
File Numbering | (1) Continuous numbering (2) Auto reset (3) Manual reset (the image numbering is reset to 0001, a new folder is created where subsequent images are saved) |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style | Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3 |
Interface | USB 2.0 Hi-Speed, mini-B port. NTSC/PAL for video output |
White Balance
Settings | Auto, Preset (Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash), Manual (Custom, or user-set Color Temperature) |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | White balance bracketing: +/- stops in 1-stop increments White balance correction: blue/amber bias +/- 9 levels, magenta/green bias +/- 9 levels |
Color Temperature Information Transmission | Provided |
Viewfinder
Type | Eye-level SLR with pentamirror |
Coverage | Approx. 95% horizontally and vertically |
Magnification | 0.8x (-1 dpt with 50mm lens at infinity) |
Eye Point | Approx. 21mm |
Dioptric Adjustment Correction | -3.0 to +1.0 diopter |
Mirror | Quick-return half mirror (Transmission: reflection ratio of 40:60) |
Viewfinder Information | AF (AF points, focus confirmation light), Exposure (shutter speed, aperture, exposure level, AE lock, exposure compensation, AEB level, bulb), Flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, FEB shooting, flash exposure compensation, insufficient flash warning during FE lock), White balance correction, Maximum burst, CF card full warning, CF card error warning, No CF card warning |
Depth Of Field Preview | Enabled with depth-of-field preview button (with Speedlite 580EX, 430EX, MR-14EX or MT-24EX; pressing the depth-of-field preview button fires a modeling flash) |
Autofocus
Type | TTL-CT-SIR with CMOS sensor |
AF Points | 9 AF points |
AF Working Range | EV -0.5-18 (ISO 100 at 73°F/23°C) |
Focusing Modes | Autofocus: One-Shot AF, Predictive AI Servo AF, AI Focus AF (automatic switching between One-Shot/Predictive AI Servo AF); Manual Focus (MF) |
AF Point Selection | Automatic selection, Manual AF point selection |
Selected AF Point Display | Superimposed on viewfinder and LCD monitor |
AF Assist Beam | Intermittent firing of built-in flash (Emitted automatically when necessary under low light, and linked to all 9 AF points. Not emitted in the Landscape, Sports and Flash OFF modes) |
Exposure Control
Metering Modes | Max. aperture TTL metering with 35-zone SPC (1) Evaluative metering (linked to all AF points) (2) Partial metering (approx. 9% at center of viewfinder) (3) Center-weighted average metering |
Metering Range | EV 1-20 (ISO 100 at 73°F/23°C with EF 50mm f/1.4 USM lens) |
ISO Speed Range | Basic Zone: automatically set by the camera Creative Zone: equivalent to ISO 100-1,600 |
Exposure Compensation | (1) User-set with multi-controller (2) AEB (Auto Exposure Bracketing) Bracketing range: +/- 2 stops in 1/3- or 1/2-stop increments |
AE Lock | Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved User-set: Applied with AE lock button |
Shutter | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/4000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/200 sec.Soft-touch electromagnetic release; shutter "lag time" approx. 100 msec.10 sec. delay, 2 sec. delay with C.Fn-7-1 (mirror lockup)Remote control with Remote Switch RS-60E3 or Wireless Remote Controllers RC-1/RC-5 |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled |
Shutter Speeds | 1/4000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/200 sec. |
Shutter Release | Soft-touch electromagnetic release; shutter "lag time" approx. 100 msec. |
Self Timer | 10 sec. delay, 2 sec. delay with C.Fn-7-1 (mirror lockup) |
Remote Control | Remote control with Remote Switch RS-60E3 or Wireless Remote Controllers RC-1/RC-5 |
Built in Flash
Type | Auto pop-up, retractable, built-in flash in the pentaprism |
Guide Number | 43 ft./13m (ISO 100) |
Recycling Time | Approx. 3 sec. |
Flash Ready Indicator | Flash-ready indicator lights in viewfinder |
Flash Coverage | 17mm lens focal length (equivalent to 27mm in 135 format) |
FE Lock | Provided |
Flash Exposure Compensation | +/-2 stops in 1/3- and 1/2-stop increments |
External Speedlite
EOS Dedicated Speedlite | E-TTL II autoflash with EX Series Speedlites |
Zooming to Match Focal Length | Provided |
PC Terminal | N/A |
Drive System
Drive Modes | Single, Continuous, Self-timer/Remote control |
Continuous Shooting Speed | Approx. 3 fps (at shutter speed of 1/250 sec. or faster) |
Maximum Burst | JPEG: approx. 27 frames (Large/Fine) RAW: approx. 10 frames RAW+JPEG: approx. 8 frames (Large/Fine) |
LCD Monitor
Type | TFT color, liquid-crystal monitor |
Monitor Size | 2.5 in. diagonal with a viewing angle of approx. 160° vertically and horizontally |
Pixels | Approx. 230,000 pixels |
Coverage | Approx. 100% |
Brightness Control | 7 levels provided |
Interface Languages | 18 |
Playback
Display Format | Single image, 9-image index, Magnified zoom (approx. 1.5x to 10x), Auto play, Auto review right after shooting, Histogram, Rotate, Jump |
Highlight Alert | In the single image (INFO) display mode, the highlight portions containing no image information will blink |
Histogram | Brightness, RGB |
Image Protection and Erase
Protection | A single image can be protected or unprotected |
Erase | A single image or all images stored in a CF card can be erased if they are unprotected |
Direct Printing
Compatible Printers | PictBridge, CP Direct, and Bubble Jet Direct-compatible printers |
Printable Images | JPEG images (DPOF printing possible) |
Easy Print feature | Provided |
DPOF: Digital Print Order Format
DPOF | Version 1.1 compatible |
Direct Image Transfer
Compatible Images | JPEG and RAW images *Images to be used for wallpaper on the personal computer screen must be JPEG images |
Customization
Custom Functions | 11 Custom Functions with 29 settings |
Power Source
Battery | Battery Pack NB-2LH, quantity 1 *AC power enabled with AC Adapter ACK-DC20 *With Battery Grip BG-E3, size-AA batteries can be used |
Battery Life | [Number of shots: Approx.] *The above figures apply when a fully-charged Battery Pack NB-2LH is used. *The figures above are based on CIPA (Camera & Imaging Products Association) testing standards |
Battery Check | Automatic |
Power Saving | Provided; power turns off after 30 sec., 1, 2, 4, 8, or 15 min. |
Date/Time Battery | One CR2016 Lithium Battery |
Start-up Time | Approx. 0.2 sec. |
Dimensions and Weight
Dimensions (W x H x D) | 4.98 x 3.71 x 2.56 in./126.5 x 94.2 x 65mm |
Weight | 18 oz./510g (body only) |
Operating Environment
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
Battery Pack
Type | For NB-2LH Rechargeable lithium-ion battery |
Rated Voltage | 7.4 V DC |
Battery Capacity | 720 mAh |
Dimensions (W x H x D) | 33.3 x 16.2 x 45.2mm/1.3 x 0.6 x 1.8 in. |
Weight | Approx. 43 g/1.5 oz. |
Battery Charger
Type | For CB-2LW |
Compatible Battery | Battery Pack NB-2LH |
Recharging Time | Approx. 105 min. |
Rated Input | 100 - 240 V AC, 50/60 Hz |
Rated Output | 8.4 V DC |
Working Temperature Range | 0°C-40°C/32°F - 104°F |
Dimensions (W x H x D) | 91 x 56 x 22.5mm/3.6 x 2.2 x 0.9 in. |
Weight | Approx. 68 g/2.4 oz. |
Kit Lens
Angle of View | For EF-S 18-55mm f/3.5-5.6 II Diagonal extent: 74°20' - 27°50' Horizontal extent: 64°30' - 23°20' Vertical extent: 45°30' - 15°40' |
Lens Construction | 11 elements in 9 groups |
Minimum Aperture | f/22 - 36 |
Closest Focusing Distance | 0.28m/0.92 ft. (from image sensor plane) |
Maximum Magnification and Field of View | 18mm: 0.10x (248 x 161mm/9.8 x 6.3 in.) 55mm: 0.28x (81 x 54mm/3.2 x 2.1 in.) |
Filter Size | 58mm |
Hood | EW-60C |
Diameter x Length | 68.5 x 66mm/2.7 x 2.6 in. |
Weight | Approx. 190 g/6.7 oz. |
Case | LP814 |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
