Canon Support for EOS M10 EF-M 15-45mm IS STM Kit | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | CMOS sensor (supporting Hybrid CMOS AF II) |
Pixels | Effective Pixels: Approx. 18.0 Megapixels Total Pixels: Approx. 18.5 Megapixels |
Total Pixels | 18.5 megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Dust Deletion Feature | Self Cleaning Sensor Unit (Ultrasonic vibration keeps the front layer of the CMOS sensor free of dust) Auto / Manual |
Recording Format | Design Rule for Camera File System 2.0, Exif 2.3 compliant JPEG, RAW (14-bit, Canon original) RAW+JPEG simultaneous recording possible |
File Size | L (Large): Approx. 17.9 Megapixels (5184x3456) M (Medium): Approx. 12.4 Megapixels (4320x2880) S1 (Small 1): Approx. 5.5 Megapixels (2880x1920) S2 (Small 2): Approx. 3.5 Megapixels (2304x1536) S3 (Small 3): Approx. 350,000 pixels (720x480) RAW: Approx. 17.9 Megapixels (5184x3456) |
Folders | Monthly and daily can be selected Continuous, Auto reset |
Settings | Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3 Noise Reduction Applicable to long exposures and high ISO speed shots Automatic Image Brightness Correction Auto Lighting Optimizer Highlight Tone Priority Provided Lens Aberration Correction Peripheral illumination correction, Chromatic aberration correction Creative Assist Background (Blurred-Sharp), Brightness (Dark-Light), Contrast (Low-High), Saturation (Neutral-Vivid), Color Tone (Cool-Warm), Monochrome |
Auto White Balance | Auto, Preset (Daylight, Shade, Cloudy, Tungsten light, White fluorescent light, Flash), Custom white balance correction feature available |
Type | Hybrid CMOS AF II method (1-point AF, Face+Tracking priority AF) Focusing Brightness Range EV 1-18 (at room temperature, ISO 100, with EF-M 22mm f/2 STM) AF Operation One-Shot AF, Servo AF |
AF Points | 49 points (Maximum) |
AF Assist Beam | Built-in (LED lamp) |
Metering Modes | Real-time metering using the image sensor Evaluative metering Partial metering Spot metering Center Weighted Avg. |
Metering Range | EV 1-20 (at room temperature, ISO 100) |
Exposure Control Systems | (1) Program AE (modes other than Tv, Av, and M) (2) Shutter-priority AE (3) Aperture-priority AE (4) Manual exposure |
ISO Speed Range | Automatically or manually set in a range of ISO 100-12800 (equivalent to 25600 when expanded) Max. auto ISO speed can be configured when mode dial is set to P, Tv, Av, M, or Movie mode * Flicker detection |
Exposure Compensation | Manual: ±3 stops in 1/3-stop increments |
AE Lock | (1) Auto AE lock in the One-Shot AF mode with evaluative metering, AE is locked as soon as subjects are in focus.(2) Manual AE lock Performed using the AE lock button. |
Type | Electronically controlled focal-plane shutter |
Shutter Speeds | 1/4000 sec. to 30 sec. (total shutter speed range; available range varies by shooting mode), X-sync at 1/200 sec. |
Type | Retracting, manual pop-up flash Guide No. approx. 5m (at ISO 100) Supports angle of view equivalent to focal length of approx. 15mm (35mm film equivalent: approx. 24mm) Recharging time: approx. 3 sec. * Safety FE supported * Recharging time when using a fully charged battery pack Focusing Brightness Range EV 1-18 (at room temperature, ISO 100, with EF-M 22mm f/2 STM) AF Operation One-Shot AF, Servo AF Range of Flash Photography (Approx.) (Approx. ft. [m]) |
Flash Metering System | E-TTL II autoflash |
FE Lock | Provided |
Flash Exposure Compensation | ±stops in 1/3-stop increments |
Drive Modes | Single shooting, Continuous shooting |
Continuous Shooting Speed | (1) One-Shot AF (all lenses): Max. approx. 4.6 fps (2) Servo AF (with EF-M 15-45mm f/3.5-6.3 IS STM at the telephoto end): Max. approx. 2.2 fps * Under default settings, with a shutter speed of 1/500 sec. or higher. * Continuous shooting speed may be lower depending on shutter speed, aperture value, subject conditions, brightness, type of lens, flash use, battery level and other factors. |
Maximum Burst | * Image file size, number of possible shots, and maximum burst during continuous shooting are measured based on Canon's testing standards (3:2 aspect ratio, ISO 200, and Standard Picture Style), using a UHS-I compatible, 16 GB memory card that meets Canon's testing standards. These values vary depending on the shooting conditions. Self-timer Mode Off, 2-second self-timer, 10-second self-timer, Custom timer |
Focusing | AF, MF, AF+MF (MF, and MF in AF+MF mode: approx. 5x/10x magnification and MF peaking supported) Aspect Ratio Settings 3:2, 4:3, 16:9, 1:1 Continuous AF Provided Touch Shutter Provided Depth-of-Field Preview Provided |
Metering Modes | (1) Evaluative metering (384 zones) (2) Partial metering (approx. 10%) (3) Spot metering (approx. 2%) (4) Center Weighted Avg. |
Grid Display | Two types |
File Format | Recording System MP4 MPEG-4 AVC / H.264 Variable (averaged) bit rate |
File Size | 1920 x 1080 (Full HD): 29.97 fps / 23.98 fps* 1280 x 720 (HD): 59.94 fps 640 x 480 (SD): 29.97 fps * Actual frame rate: 23.976 fps. |
Continuous Shooting Time | *1 Recording bit rate of movie images only, sound data not included. *2 Continuous shooting is possible until the memory card becomes full or the recording length for one movie reaches approx. 29 minutes 59 seconds. *3 Actual frame rate is 23.976 fps. |
Focusing | Hybrid CMOS AF II system (1-point AF, Face+Tracking priority AF) Focus Mode AF, MF, AF+MF (Manual focus after One-Shot AF) (MF, and MF in AF+MF mode: MF peaking supported) Servo AF Can be paused and resumed. Brightness Metering Range EV 1-20 (at room temperature, ISO 100) Metering Mode Evaluative metering Miniature Effect Movie Provided Still Image Shooting Provided Grid Display Grid Display Sound Recording Built-in stereo microphone, recording level adjustable, wind filter provided, attenuator provided |
Range | EV 1-18 (at room temperature, ISO 100) |
Exposure Control | Movie auto exposure mode, miniature effect movie mode, still image mode: Shutter speed of 1/30 to 1/4000 sec.*, with aperture and ISO speed set automatically. Movie manual exposure mode: Shutter speed of 1/30 to 1/4000 sec.*, with aperture and ISO speed (auto or a specific value) set manually.* The minimum shutter speed is limited to 1/30 sec. at 24/25/30 fps or 1/60 sec. at 50/60 fps. |
Exposure Compensation | ±3 stops in 1/3-stop increments |
Type | TFT color, liquid-crystal monitor Angle Adjustment Tilt type: Approx. 180° upward |
Monitor Size | Wide 3.0-inches (Screen aspect ratio 3:2) |
Pixels | Approx. 1.04 million dots |
Brightness Control | Manual (5 levels) |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
Display Format | Single image display, single image + info display (basic info, shooting info, histogram, lens info, Picture Style, noise reduction, correction data), image index (6/12/42/110), image rotate possible Zoom Magnification Approx. 1.5x to 10x Highlight Alert Overexposed highlights blink Image Browsing Single image, jump by 10 or 100 images, filter images (by shooting date, by people, by movies, by stills, by rating), Scroll Display Image Rotate Rating Rating Provided Image Search Rating, Shot Date, People, Stills, Movie Digest Movie Playback Enabled Protect Images Provided Slideshow All images * Playback is also possible after filtering the images using Image Search. |
Compatible Printers | PictBridge (USB and Wireless LAN) |
Printable Images | JPEG and RAW images (can print RAW images displayed as JPEG only with images taken with the same model), MP4 |
Custom Functions | 6 types Copyright Info Entry and inclusion possible |
USB Terminal | For communications with a computer and PictBridge (Hi-Speed USB equivalent) |
Video Out Terminal | Type C (Switches resolution automatically) Wi-Fi® (Wireless LAN) IEEE 802.11b/g/n Transmission Method DS-SS modulation (IEEE 802.11b), OFDM modulation (IEEE 802.11g/n) Transmission Range Approx. 15m (49 ft.) When connected to a smartphone or tablet With no obstructions between transmitting and receiving antennas, and there is no radio interference Transmission Frequency (Central Frequency) Frequency: 2412-2462 MHz, Channels: 1-11 ch Connection Method Infrastructure mode*, Camera access point mode, Ad hoc mode* Wi-Fi® Protected Setup supported Security Authentication method: Open system, WPA-PSK, WPA2-PSKEncryption: WEP, TKIP, AES Transfer Images Between Cameras Transferring one image, transferring selected images, transferring resized images Connection to Smartphones Viewing, controlling, receiving images using a smartphone Sending images to smartphone connected via NFC Remote control of the camera using a smartphone Print from Wi-Fi® Printers Images to be printed can be sent to a printer supporting Wi-Fi® Send Images to a Web Service Images in the camera or links to images can be sent to registered Web services View Images Using a Media Player Images can be viewed using a DLNA-compatible media player |
Battery | One Battery Pack LP-E12 *AC power can be supplied with the AC Adapter Kit ACK-E12 |
Battery Life | Still images: * Based on CIPA measurement methods. * With fully charged battery pack LP-E12. * When EF-M 15–45mm f/3.5–6.3 IS STM is used. Movies: * With fully charged battery pack LP-E12. * When EF-M 15–45mm f/3.5–6.3 IS STM is used. *1 Maximum recordable time under default movie mode settings with repeated capture after the maximum recording time for one movie has been reached. *2 Maximum recordable time under default movie mode settings with operation of record, pause, power on/off, zoom, and other controls. |
Dimensions (W x H x D) | Approx. 4.25 x 2.62 x 1.38 in. (108.0 x 66.6 x 35.0mm) |
Weight | Approx. 10.6 oz. / 301g (Including body + battery pack + card) Approx. 9.35 oz./ 265g (Body only, excluding lens cap) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
Working Temperature Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
