Canon Support for EOS M100 | Canon U.S.A., Inc.
EOS M100
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
Wireless Connection
Using Wi-Fi
- Performing Remote Shooting with a Smartphone using the Wi-Fi Function
- What Can I Do Using the Wireless LAN Functions?
- Sending Images to a Smartphone using a Wireless Connection
Printing Images Wirelessly
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital single-lens non-reflex AF/AE camera |
Recording Media | SD/SDHC/SDXC memory card * UHS-I compatible |
Compatible Lenses | Canon EF-M, EF* and EF-S* lenses *Canon EF and EF-S lenses require Mount Adapter EF-EOS M. |
Lens Mount | Canon EF-M mount |
Type | CMOS sensor (supporting Dual Pixel CMOS AF) |
Pixels | Approx. 24.2 megapixels |
Total Pixels | Approx. 25.8 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Dust Deletion Feature |
File Format | Design rule for Camera File system 2.0, Exif 2.3 compliant |
Data Type | JPEG, RAW (14-bit, Canon original) RAW+JPEG simultaneous recording possible |
Recording Pixels | Large: Approx. 24.00 Megapixels Medium: Approx. 10.60 Megapixels Small 1: Approx. 5.90 Megapixels Small 2: Approx. 3.80 Megapixels RAW: Approx. 24.00 Megapixels 3:2 Aspect Ratio Large: 6000 x 4000 Medium: 3984 x 2656 Small 1: 2976 x 1984 Small 2: 2400 x 1600 RAW: 6000 x 4000 4:3 Aspect Ratio Large: 5328 x 4000 Medium: 3552 x 2664 Small 1: 2656 x 1992 Small 2: 2112 x 1600 RAW: 5328 x 4000 16:9 Aspect Ratio Large: 6000 x 3368 Medium: 3984 x 2240 Small 1: 2976 x 1680 Small 2: 2400 x 1344 RAW: 6000 x 3368 1:1 Aspect Ratio Large: 4000 x 4000 Medium: 2656 x 2656 Small 1: 1984 x 1984 Small 2: 1600 x 1600 RAW: 4000 x 4000
Folder Setting | Monthly/Daily |
File Numbering | Continuous, Auto Reset |
Picture Style |
Settings |
Noise Reduction | Applicable to:
Automatic Image Brightness Correction | Auto Lighting Optimizer |
Highlight Tone Priority | Provided |
Lens Aberration Correction |
Creative Assist |
Type | Dual Pixel CMOS AF (1-point AF, Face+Tracking priority AF, Smooth Zone AF) |
AF Points | Up to 49 points (Maximum) |
AF Working Range | EV -1-18 (at room temperature, ISO 100, when using EF-M 22mm f/2 STM) |
AF Assist Beam | Built-in LED lamp |
Metering Modes | Real-time metering using the image sensor Evaluative metering Partial metering Spot metering Center-weighted Average |
Brightness Metering Range | Stills: EV 1-20 (at room temperature 73°F/23°C, ISO 100) Video: EV 2-20 (at room temperature 73°F/23°C, ISO 100) |
Exposure Control |
ISO Speed Range | Stills: ISO 100-25600 (in 1/3-stop increments) Video: ISO 100-6400; H: 12800 |
Exposure Compensation | Manual: ±3 stops in 1/3-stop increments |
AE Lock | Manual, Auto |
Type | Electronically controlled focal-plane shutter |
Shutter Speeds | 1/4000 to 30 sec., bulb X-sync at 1/200 sec. |
Built-in Flash | Manual pop-up flash Guide No. approx. 16.4 ft./5m (at ISO 100) Supports angle of view equivalent to focal length of approx. 15mm (35mm film equivalent: approx. 24mm) Recharging time (when battery is fully charged): approx. 5.0 sec. |
Flash Metering System | E-TTL II metering |
FE Lock | Provided |
Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
Drive Modes | Single shooting, Continuous shooting |
Continuous Shooting Speed |
Self-timer Mode | Off, 2-second self-timer, 10-second self-timer, Custom timer |
Aspect Ratio Settings | 3:2, 4:3, 16:9, 1:1 |
Focus Mode | AF, MF, AF+MF (Manual focus after One-Shot AF) Max. in MF: Approx. 5x / Approx. 10x MF peaking provided |
Continuous AF | Provided |
Touch Shutter | Provided |
Grid Display | Two Types |
Depth of Field Preview | Provided |
Recording System | MP4 |
File Format | Video: MPEG-4 AVC / H.264
Recording Size and Frame Rate | 1920 x 1080 (Full HD): 59.94 fps / 29.97 fps / 23.98 fps 1280 x 720 (HD): 59.94 fps 640 x 480 (SD): 29.97 fps |
Metering Mode | Evaluative metering |
Exposure Compensation | ±3 stops in 1/3-stop increments |
ISO Speed (Recommended Exposure Index) | ISO 1006400; H: 12800 |
Miniature Effect Movie | Provided |
Still Image Shooting | Provided |
Grid Display | Two types |
Sound Recording | Built-in stereo microphone, recording level adjustable, wind filter provided, attenuator provided |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0-inch type |
Dots | Approx. 1.04 million dots |
Brightness Control | 5 levels |
Angle Adjustment | Tilt type: Up to approx. 180° upward |
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese) |
Hints and Tips | Displayable |
Image Display Format |
Zoom Magnification | Approx. 2.0x to 10.0x |
Image Browsing Methods |
Image Rotate | Provided |
Rating | Provided |
Video Playback | Provided (with built-in speaker) |
Rating | Provided |
Sideshow |
Creative Filters |
Resize | Provided |
Red-eye Correction | Provided |
Compatible Printers | PictBridge |
Printable Images |
Registration of Custom Functions | Shutter button, Movie button |
Copyright Info | Provided |
Digital Terminal | Mini-B (Hi-Speed USB compliant) |
HDMI OUT Terminal | Type D HDMI output while recording (shooting screen without sound) provided |
Standards Compliance | IEEE 802.11b/g/n |
Transmission Method | DS-SS modulation (IEEE 802.11b), OFDM modulation (IEEE 802.11g/n) |
Transmission Frequency (Central Frequency) | Frequency: 24122462 MHz Channels: 111 ch |
Transfer Images Between Cameras |
Connection to Smartphones |
Print from Wi-Fi® Printers | Images to be printed can be sent to a printer supporting Wi-Fi® |
Send Images to a Web Service | Images in the camera or links to images can be sent to registered Web services |
View Images Using a Media Player | Images can be reviewed using a DLNA-compatible media player |
Battery | Battery Pack LP-E12 |
Battery Life | Number of Still Image Shots CIPA compliant, Room Temperature 73°F/23°C: Approx. 295 shots Eco Mode On: Approx. 410 shots Movie Recording Time CIPA compliant, Room Temperature 73°F/23°C: Approx. 80 min. Continuous Shooting*: Approx. 125 min. * Total shooting time when shooting is performed under the following conditions: using default AUTO Mode, without using zooming and other operations, when max. recording time per movie is reached and recording stops/resumes automatically. |
Dimensions (W x H x D) | Approx. 4.3 x 2.6 x 1.4 in. (108.2 x 67.1 x 35.1mm)
Weight | Approx. 10.7 oz. / 302g (Including battery pack and memory card) Approx. 9.4 oz. / 266g (Body only) |
Working Temperature Range | 32-104°F / 0-40°C |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
