Canon Support for EOS M200 Content Creator Kit | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital single-lens mirrorless AF/AE camera |
Recording Media | SD/SDHC/SDXC memory cards
Image Format | Approx. 22.3 x 14.9mm (APS-C) |
Compatible Lenses | Canon EF-M, EF* and EF-S* lenses * Canon EF and EF-S lenses require Mount Adapter EF-EOS M. |
Lens Mount | Canon EF-M mount |
Type | CMOS sensor (supporting Dual Pixel CMOS AF) |
Effective Pixels | Approx. 24.1 megapixels |
Total Pixels | Approx. 25.8 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
File Format | Design rule for Camera File system 2.0, Exif 2.31 compliant, Supports time difference information |
Data Type | RAW (Canon .CR3, 14-bit); C-RAW (Canon .CR3) and JPEG (12-bit A/D conversion for RAW images in continuous shooting mode) |
Recording Pixels | Large: Approx. 24.00 Megapixels Medium: Approx. 10.60 Megapixels Small 1: Approx. 5.90 Megapixels Small 2: Approx. 3.80 Megapixels RAW / C-RAW: Approx. 24.00 Megapixels 3:2 Aspect Ratio Large: 6000 x 4000 Medium: 3984 x 2656 Small 1: 2976 x 1984 Small 2: 2400 x 1600 RAW / C-RAW: 6000 x 4000 4:3 Aspect Ratio Large: 5328 x 4000 Medium: 3552 x 2664 Small 1: 2656 x 1992 Small 2: 2112 x 1600 RAW / C-RAW: 6000 x 4000 16:9 Aspect Ratio Large: 6000 x 3368 Medium: 3984 x 2240 Small 1: 2976 x 1680 Small 2: 2400 x 1344 RAW / C-RAW: 6000 x 4000 1:1 Aspect Ratio Large: 4000 x 4000 Medium: 2656 x 2656 Small 1: 1984 x 1984 Small 2: 1600 x 1600 RAW / C-RAW: 6000 x 4000 The recording pixels number is rounded to the whole number nearest to 10,000 or 1,000. |
Folder Setting | Creating new folders and selecting folders in the card is possible. |
File Numbering | Continuous, Auto Reset |
Picture Style |
White Balance |
*1 Effective also in twilight and sunset. *2 Custom white balance is not available for monochrome images and images with Creative filters applied. |
Noise Reduction |
Automatic Image Brightness Correction | Auto Lighting Optimizer (Disable, Low, Standard, or High) (Not available if Highlight Tone Priority is active) |
Highlight Tone Priority | Provided: (Disable, Enable, or Enhanced) |
Lens Aberration Correction |
Creative Assist | During shooting (in Scene Intelligent Auto):
Creative Assist during playback (RAW or C-RAW images):
Type | Dual Pixel CMOS AF (1-point AF, Spot AF, Face+Tracking priority AF, Zone AF) |
AF Points | Up to 143 points (Maximum) |
Focusing Brightness Range | EV -4-18 (at Center AF point, room temperature, ISO 100, f/1.4, in One-Shot AF) |
AF Operation | One-Shot AF, Servo AF, or Manual Focus |
AF Assist Beam | Built-in LED lamp |
Metering Modes | Real-time metering using the image sensor Evaluative metering Partial metering (Approx. 5.8% of screen) Spot metering (Approx. 2.9% of screen) Center-weighted Average |
Brightness Metering Range | Stills: EV -1-20 (at room temperature 73°F/23°C, ISO 100) Video: EV 0-20 (at room temperature 73°F/23°C, ISO 100) |
Exposure Control | Via SHOOTING MODE in menu:
ISO Speed Range (Recommended Exposure Index) | Stills: ISO 100-25600 (in 1/3-stop increments) Video: ISO 100-12800; H: 25600 |
Exposure Compensation | Manual: ±3 stops in 1/3-stop increments |
AE Lock | Manual, Auto (exposure locked after focusing, in One-Shot AF with Evaluative metering) |
Type | Vertical-travel mechanical focal-plane shutter, electronically controlled at all speeds |
Shutter Speeds | Creative Zone: 1/4000 to 30 sec., bulb *X-sync at 1/200 sec. Basic Zone: 1/4000 to 1 sec. |
Built-in Flash | Manual pop-up flash (Max. Guide Number approx. 16.4 [ft] / 5.0 [m], at ISO 100) |
Flash Metering Mode | E-TTL II autoflash (evaluative, average), FE lock |
Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
FE Lock | Provided |
External Flash | Not supported |
Drive Mode and Continuous Shooting Speed (Approx.) |
*1 Conditions for maximum continuous shooting speed are as follows: fully charged Battery Pack LP-E12, shutter speed: 1/1000 sec. or faster, maximum aperture (f/3.5), room temperature (73°F/23°C), 12 bit *2 BR-E1: Supported / RC-6: Not supported |
Maximum Burst |
*1 The number of possible shots and maximum burst apply to a 32GB card based on Canon testing standards. |
Self-timer Mode | Off, 2-second self-timer, 10-second self-timer, Continuous timer |
Aspect Ratio Settings | 3:2, 4:3, 16:9, 1:1 (Frame Grab images from 4K movies cannot be cropped) |
Focus Mode | AF, MF, AF+MF (Manual focus after One-Shot AF) MF peaking provided |
Continuous AF | Provided |
Touch Shutter | Provided |
Grid Display | Off / 3x3 / 6x4 / 3x3+diag |
Depth of Field Preview | Provided |
Recording System | MP4 | ||||||||||||||||||||||||||||||||||
File Format | Video: MPEG-4 AVC / H.264
Recording Size and Frame Rate | 4K (3840 x 2160): 23.98 fps (Time Laps only — 29.97 fps) Full HD (1920 x 1080): 59.94 fps / 29.97 fps HD (1280 x 720): 59.94 fps (Hybrid Auto — 29.97 fps; High Frame Rate movies — 119.88 fps) |
Movie Exposure Modes | Movie Auto Exposure; Movie Manual Exposure | ||||||||||||||||||||||||||||||||||
Metering Mode | Evaluative metering / Center-weighted metering (when no faces are detected) | ||||||||||||||||||||||||||||||||||
Exposure Compensation | ±3 stops in 1/3-stop increments | ||||||||||||||||||||||||||||||||||
ISO Speed (Recommended Exposure Index) | ISO 100-6400; H: 12800 | ||||||||||||||||||||||||||||||||||
Miniature Effect Movie | Provided (Full HD 1920 x 1080, 29.97 fps) | ||||||||||||||||||||||||||||||||||
Still Image Shooting | Provided (Possible with Hybrid Auto setting; HD 1280 x 720 at 29.97 fps) | ||||||||||||||||||||||||||||||||||
Continuous Shooting Time |
* Limitations of video shooting: continuous shooting is possible until the memory card becomes full or the recording length for one video reaches approx. 29 minutes and 59 seconds (or 7 min. 29 sec. for a HD High Frame Rate Movie). * For 4K movies, movie recording stops automatically when the recording time reaches 9 min. 59 sec. * Recording bit rate of movie images only, sound data not included. |
Sound Recording | Built-in stereo microphones, recording level adjustable, wind filter provided, attenuator provided | ||||||||||||||||||||||||||||||||||
Card Performance Requirements |
Type | TFT color, liquid-crystal monitor |
Screen Size | 3.0-inch type |
Dots | Approx. 1.04 million dots |
Brightness Adjustment | Manually adjustable to one of seven brightness levels |
Angle Adjustment | Tilt type: Up to approx. 180° upward |
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese) |
Hints & Tips | Displayable |
Playback Methods | Playback on camera's LCD screen
Playback Display Options |
Zoom Magnification | Approx. 1.5x to 10.0x (Can be activated by double-tapping) |
Image Browsing Methods |
Image Rotate | Provided |
Rating | Provided (Off, 1˜5 stars) |
Video Playback | Provided (with built-in speaker) |
Playback Time | Approx. 4 hr. 55 min. * With a fully charged LP-E12 * Time when playing back a slideshow of still photos |
Slideshow |
Creative Filters |
Cropping | Cropping frame movement: all directions Tilt correction Aspect ratio (3:2, 16:9, 4:3, 1:1, 2:3, 9:16, 3:4) * Frame grab images from 4K movies cannot be cropped. |
Resize | M, S1, S2 * Frame grab images from 4K movies cannot be resized. |
Red-eye Reduction | Provided |
Compatible Printers | PictBridge |
Printable Images |
Custom Functions | 6 Available |
Customizable Buttons | Shutter button, Movie button |
Copyright Info | Provided |
Digital Terminal | Micro-B (Hi-Speed USB 2.0 compliant) |
HDMI OUT Terminal | Type D (resolution switches automatically)
Wireless Remote Control |
Standards Compliance | IEEE 802.11b/g/n |
Transmission Method | DS-SS modulation (IEEE 802.11b), OFDM modulation (IEEE 802.11g/n) |
Transmission Frequency (Central Frequency) | Frequency: 2412-2462 MHz Channels: 1-11 ch |
Connection Method and Security |
Supported Wireless Functions |
Transfer Images Between Cameras | Not Possible |
Connection to Smart phones | Connect with free Canon Camera Connect app (Android and iOS versions available for compatible mobile devices) |
Wireless Connection Types | Wi-Fi® and Bluetooth v. 4.2 (low-energy) |
Battery | Battery Pack LP-E12 |
Battery Life | Number of Still Image Shots CIPA compliant, Room Temperature 73°F/23°C: Approx. 315 shots Eco Mode On: Approx. 485 shots Movie Recording Time CIPA compliant, Room Temperature 73°F/23°C: Approx. 90 min. Continuous Shooting*: Approx. 135 min. * Total shooting time when shooting is performed under the following conditions: using default AUTO Mode, without using zooming and other operations, when max. recording time per movie is reached and recording stops/resumes automatically. |
Dimensions (W x H x D) | Approx. 4.3 x 2.6 x 1.4 in. (108.2 x 67.1 x 35.1mm)
Weight | Approx. 10.55 oz. / 299g (Including battery pack and memory card) Approx. 9.24 oz. / 262g (Body only) |
Working Temperature Range | 32-104°F / 0-40°C |
Working Humidity Range | 85% or less |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
Wireless API | Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
