Canon Support for EOS M5 EF-M 18-150mm IS STM Kit | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Digital single-lens non-reflex AF/AE camera
Recording Media
SD/SDHC/SDXC memory card
* UHS-I compatible
Compatible Lenses
EF-M lens (when using EF-M Mount Adapter: EF/EF-S lens group)
Equivalent to approximately 1.6x the focal length indicated on a mounted lens
Lens Mount
Canon EF-M mount
Type
CMOS sensor
Pixels
Effective pixels: Approx. 24.2 Megapixels
Total pixels: Approx. 25.8 Megapixels
  • Pixels may decrease due to image processing.
Pixel Unit
Square pixel approx. 3.72 &micro;m
Aspect Ratio
3:2
Dust Deletion Feature
Auto / Manual
Recording Format
EXIF 2.3 (DCF2.0)
JPEG/RAW (CR2 a Canon 14-bit RAW format)
File Size
3:2 Aspect Ratio
Large: 6000 x 4000
Medium: 3984 x 2656
Small 1: 2976 x 1984
Small 2: 2400 x 1600
16:9 Aspect Ratio
Large: 6000 x 3368
Medium: 3984 x 2240
Small 1: 2976 x 1680
Small 2: 2400 x 1344
4:3 Aspect Ratio
Large: 5328 x 4000
Medium: 3552 x 2664
Small 1: 2656 x 1992
Small 2: 2112 x 1600
1:1 Aspect Ratio
Large: 4000 x 4000
Medium: 2656 x 2656
Small 1: 1984 x 1984
Small 2: 1600 x 1600
File Numbering
Continuous, Auto Reset
RAW + JPEG Simultaneous Recording
Yes
Picture Style
Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1-3
Settings
  1. Auto
  2. Day Light
  3. Shade
  4. Cloudy
  5. Light bulb
  6. White fluorescent light
  7. Flash
  8. Color temperature
  9. Custom
White Balance Correction Blue/Amber: ±9 levels
Green/Magenta: ±9 levels
Type
Built-in electronic color viewfinder with 0.39-type screen size and approx. 2.36 million dots
Grid Display
3 types
Depth Of Field Preview
Provided
Type
Dual Pixel CMOS AF (Face+Tracking AF, 1-point AF)
AF Points
49 points (Maximum)
AF Working Range
EV -118 (at room temperature, ISO 100, when using EF-M 22mm f/2 STM)
Focusing Modes
  1. Autofocus
    • One-Shot AF
    • Servo AF
  2. Manual focus
  3. AF+MF (Manual focus after One-Shot AF: when shooting still images during movie recording)
AF Assist Beam
Built-in LED lamp
Metering Modes
Real-time metering using the image sensor
  1. Evaluative
  2. Partial metering
  3. Center-weighted evaluative metering
  4. Spot
Metering Range
EV 1-20 (at room temperature, ISO 100)
Exposure Control Systems
  1. Program AE
  2. Shutter-priority AE
  3. Aperture-priority AE
  4. Manual exposure
ISO Speed Range
ISO Auto Range (AUTO mode): ISO 100-6400
Max. ISO Speed (P mode): ISO 25600
Max. Speed Limit Setting in ISO AUTO: ISO 25600
Exposure Compensation
  1. Manual: ±3 stops in 1/3-stop increments
  2. AE Bracketing: ±2 stops in 1/3-stop increments
    AE Bracketing can be used together with manual compensation.
AE Lock
Manual / Auto
Type
Electronic control only
Shutter Speeds
1/4000 sec. to 30 sec. in Auto mode
Highest flash-sync shutter speed: 1/200 sec.
Self Timer
Off, 2 sec. delay, 10 sec. delay, Custom, Remote Control
Camera Start-up Time
Approx. 1.0 sec.
Type
Manual pop-up flash
Guide Number
Gno. approx. 5 (ISO 100/m)
Flash Coverage
Covers approx. 15mm focal length (35mm film size conversion: approx. 24mm)
Flash Exposure Compensation
&plusmn;2 stops in 1/3-stop increments
Flash Metering
E-TTL II autoflash
FE Lock
Provided
External Flash Settings
Flash functions settable with the camera
Drive Modes
Single shooting, Continuous shooting (High-speed continuous shooting, low-speed continuous shooting)
File Format
MP4
Video: MPEG-4 AVC / H.264
Audio: MPEG-4 AAC-LC (stereo)
File Size
Recording Sizes:
1920 x 1080 (Full HD), 1280 x 720 (HD) and 640 x 480 (VGA)
Frame Rates
[1920 x 1080]: 59.94 fps / 29.97 fps / 23.976
[1280 x 720]: 59.94 fps
[640 x 480]: 29.97 fps
Provided (±3 stops in 1/3-stop increments)
Type
TFT color, liquid-crystal monitor
Monitor Size
3.2 type
Pixels
Approx. 1.62 million dots
Brightness Control
Adjustable to one of five brightness levels
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
  1. Single-image display
  2. 1 shot + information display
    • Simple information
    • Detailed information
      • Histogram
      • Lens information
      • Picture Style
      • Noise reduction
      • Correction data
  3. Index display
  4. Image rotate
Highlight Alert
Provided
Quick Control Dial
Provided
Image Protection
Provided
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG, RAW*, MP4 and MOV files are printable.
* Prints JPEG images used for display, which are taken on the same model.
DPOF
DPOF print ordering provided (Complies to DPOF Version 1.1)
Custom Controls (Camera Controls / Buttons Customization)
Functions can be assigned to the following controls (set in Custom Functions):
  • Shutter button
  • Main dial
  • Quick control dial
  • Cross button (up, down, left, right)
  • Control dial
  • M-Fn button
  • Movie button
  • Touchpad AF button
USB Terminal
Micro USB
Video Out Terminal
HDMI OUT Terminal Type D
HDMI output while recording available
Battery
LP-E17
Battery Life
Number of Still Image Shots (CIPA compliant)
Monitor On: Approx. 295 shots
Electronic Color Viewfinder On: Approx. 295 shots
Number of Still Image Shots (Eco Mode On)
Monitor On: Approx. 420 shots
Movie Recording Time (CIPA compliant)
Monitor On: Approx. 85 min.
Electronic Color Viewfinder On: Approx. 90 min.
Playback Time
Approx. 4 hr.
  • Time when playing back a slideshow of still images.
Dimensions (W x H x D)
Approx. 4.6 x 3.5 x 2.4 in. (115.6 x 89.2 x 60.6mm)
  • CIPA compliant.
Weight
Approx. 13.4 oz. / 380.0g (Body only)
Approx. 15.1 oz. / 427.0g (Including battery pack, memory card)
  • CIPA compliant.
Working
14-104°F / -10-40°C
Working Humidity
90% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
