Canon Support for EOS M50 Mark II | Canon U.S.A., Inc.
EOS M50 Mark II
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 07.08.21
File Size 6.16 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 11.01.22
File Size 145.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type Digital Single-Lens Non-Reflex AF/AE Camera With Built-In Flash
Image Processor
DIGIC 8
Recording Medium SD/SDHC/SDXC Memory Cards
&Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp; UHS-I Compatible
Compatible Lenses Canon EF-M Lens Group
&Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp; Using Mount Adapter EF-EOS M: Canon EF Or EF-S Lenses.
&Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp; RF Mount Lenses Cannot Be Used.
Lens Mount Canon EF-M Mount
Type CMOS Sensor (Supporting Dual Pixel CMOS AF)
Pixels Effective Pixels: Approx. 24.1 Megapixels
Total Pixels: Approx. 25.8 Megapixels
Aspect Ratio 3:2 (Horizontal:Vertical)
Screen Size
Approx. 22.3 X 14.9mm (APS-C)
Recording Format Design Rule For Camera File System 2.0, Exif 2.31 Compliant, Supports Time Difference Information
Data Type
RAW (Canon .CR3, 14-Bit); C-RAW (Canon .CR3) And JPEG (8-Bit) (12-Bit A/D Conversion For RAW Images In Continuous Shooting Mode)
Recording Pixels
Large: Approx. 24.00 Megapixels
Medium: Approx. 10.60 Megapixels
Small 1: Approx. 5.90 Megapixels
Small 2: Approx. 3.80 Megapixels
RAW / C-RAW: Approx. 24.00 Megapixels
3:2 Aspect Ratio
Large: Approx. 24 MP (6000 X 4000)
Medium: Approx. 10.6 MP (3984 X 2656)
Small 1: Approx. 5.9 MP (2976 X 1984)
Small 2: Approx. 3.8 MP (2400 X 1600)
RAW / C-RAW: Approx. 24 MP (6000 X 4000)
4:3 Aspect Ratio
Large: Approx. 21.3 MP (5328 X 4000)
Medium: Approx. 9.5 MP (3552 X 2664)
Small 1:Approx. 5.3 MP (2656 X 1992)
Small 2: Approx. 3.4 MP(2112 X 1600)
16:9 Aspect Ratio
Large: Approx. 20.2 MP (6000 X 3368)
Medium: Approx. 8.9 MP (3984 X 2240)
Small 1: Approx. 5.0 MP (2976 X 1680)
Small 2: Approx. 3.2 MP (2400 X 1344)
1:1 Aspect Ratio
Large: Approx. 16 MP (4000 X 4000)
Medium: Approx. 7.1 MP (2656 X 2656)
Small 1: Approx. 3.9 MP (1984 X 1984)
Small 2: Approx. 2.6 MP 1600 X 1600)
The Recording Pixels Number Is Rounded To The Whole Number Nearest To 10,000 Or 1,000.
File Numbering Continuous, Auto Reset
Folder Setting
Creating New Folders And Selecting Folders In The Card Is Possible.
Still Photo File Size / Number Of Possible Shots / Maximum Burst For Continuous Shooting
Image Quality Image File Size
(Approx. MB)
Possible Shots (Approx.)*1 Maximum Burst (Approx.)*1
Large (Fine) 8.4 3600 36
Large (Normal) 4.5 6610 35
Medium (Fine) 4.6 6480 34
Medium (Normal) 2.6 11400 34
Small 1 (Fine) 3.1 9690 34
Small 1 (Normal) 1.8 16010 34
Small 2 1.8 16340 34
RAW 27.2 1120 10
C-RAW 15.8 1930 16
RAW + Large (Fine) 27.2 + 8.4 850 10
C-RAW + Large (Fine) 15.8 + 8.4 1250 14
*1 The Number Of Possible Shots And Maximum Burst Apply To A UHS-I Compliant 32GB Card Based On Canon Testing Standards.
* File Size, Number Of Possible Shots, And Maximum Burst Vary Depending On Shooting Conditions (Including Subject, ISO Speed, Picture Style, And Custom Function).
Raw Jpeg Simultaneous Recording Simultaneous Recording Of Any Combination Of RAW/C-RAW/ And JPEG Image Recording Quality Is Supported
Back To TopImage Processing During Shooting
Picture Style
  • Auto
  • Standard
  • Portrait
  • Landscape
  • Fine Detail
  • Neutral
  • Faithful
  • Monochrome
  • User Defined 1-3
White Balance
  • Auto (Ambience Priority/White Priority)
  • Daylight
  • Shade
  • Cloudy*1
  • Tungsten Light
  • White Fluorescent Light
  • Flash
  • Color Temperature
  • Custom (Custom WB)*2
  • White Balance Shift - Blue,Amber And/Or Magenta,Green; ±9 Levels
*1 Effective Also In Twilight And Sunset.
*2 Custom White Balance Is Not Available For Monochrome Images And Images With Creative Filters Applied.
Noise Reduction
  • High ISO Speed NR - Disable, Low, Standard, High, Or Multi-Shot NR Possible
  • (Applies To All ISO Speeds)
    Long Exposure Noise Reduction (At Shutter Speeds 1 Second And Longer) - Disable, Enable, Or Enhanced
Automatic Image Brightness Correction
Auto Lighting Optimizer
(Disable, Low, Standard, Or High)
(Not Available If Highlight Tone Priority Is Active)
Still Photo Shooting(Disable, Enable Or Enhanced)
Movie Recording (Disable, Enable)
Lens Aberration Correction
  • Peripheral Illumination Correction
  • Distortion Correction
  • Digital Lens Optimizer (DLO)
  • Chromatic Aberration Correction
  • Diffraction Correction
Creative Assist
During Shooting (In Scene Intelligent Auto):
Vivid, Soft, Warm, Cool, Green, Shine, Lime, Peach, B&W, Blue, Purple
Image Creation Effects Background Blur, Brightness, Contrast, Saturation, Color Tone 1, Col-Or-Tone 2, Monochrome
Creative Assist During Playback (RAW Or C-RAW Images):
Auto 1, Auto 2, Auto 3, Vivid, Soft, Warm, Cool, Green, Shine, Lime, Peach, B&W, Blue, Purple, Normal
Image Creation Effects Brightness, Contrast, Saturation, Color Tone 1, Color Tone 2, Monochrome
Type Dual Pixel CMOS AF (1-Point AF, Spot AF, Face+Tracking Priority AF, Zone AF)
Af Points Still Photo Shooting: Up To 143 Zones (Maximum)
Video Shooting: Up To 117 Zones (Maximum)
Focusing Brightness Range
Still Photo Shooting: EV -418 (At Center AF Point, Room Temperature, ISO 100, F/1.4, In One-Shot AF)
Video Shooting: EV -218 ( When Set To Face+Tracking. Except For Miniature Effect Movie).
AF Operation
One-Shot AF, Servo AF, Or Manual Focus
Touch & Drag AF
Supported (When [Tap To Select Subject] Is Disabled)
Face+Tracking Tap To Select Subject Enable / Disable
Active Touch Area Right, Left, Top, Bottom, Top Right, Bottom Right, Top Left, Bottom Left
* Can Be Set When [Touch & Drag AF] Is Disabled.
Af Assist Beam Built-In LED Lamp
Metering Modes 384-Zone (24x16) Metering Using The Image Sensor.
Metering Range Stills: EV -220 (At Room Temperature 73&Deg;F/23&Deg;C, ISO 100)
Video: EV 020 (At Room Temperature 73&Deg;F/23&Deg;C, ISO 100)
Exposure Control Systems Via SHOOTING MODE In Menu:
Program AE, Shutter-Priority AE, Aperture-Priority AE, Or Manual
(B Is Selected As Shutter Speed Setting In Manual Mode)
Iso Speed Range Stills: ISO 10025600 (In 1/3-Stop Increments)
Video: ISO 100-12800; H: 25600
Exposure Compensation Manual: &Plusmn;3 Stops In 1/3-Stop Increments
Ae Lock Manual, Auto (Exposure Locked After Focusing, In One-Shot AF With Evaluative Metering)
Type Electronically Controlled Focal-Plane Shutter
* Electronic 1st / Mechanical 2nd Curtain
* Except When Silent Mode Is Set
Rolling Shutter, Using The Image Sensor
* Electronic Shutter
* When Silent Mode Is Set
Shutter Speeds Creative Zone: 1/4000 To 30 Sec., Bulb
* X-Sync At 1/200 Sec.
Basic Zone: 1/4000 To 1 Sec.
* Varies Depending On Shooting Mode
Type Manual Pop-Up Flash (Max. Guide Number Approx. 16.4 [Ft] / 5.0 [M], At ISO 100)
Flash Metering System Evaluative (Face Priority) / Evaluative / Average
Fe Lock Provided
Flash Exposure Compensation &Plusmn;2 Stops In 1/3-Stop Increments
Continuous Shooting Priority (CSP) Mode
Supported
* EL-100 Mode Dial Set To ON
* Flash Mode Set To CSP
* ISO Speed Is Automatically Set To ISO Auto
External Flash
Not Supported
Continuous Shooting Speed
Single Shooting Single Shooting
Continuous Shooting When Set To ONE SHOT AF: Max. Approx. 10 Shots/Sec.*1 When Set To SERVO: Max. Approx. 7.4 Shots/Sec.*1
Self-Timer: 10 Sec. / Remote Control Single Shooting With A Remote Control*2
Self-Timer: 2 Sec. Shoots 2 Sec. After The Shutter Button Is Pressed
Self-Timer: Continuous Takes The Specified Number Of Shots 10 Sec. After The Shutter Button Is Pressed
*1 Conditions For Maximum Continuous Shooting Speed Are As Follows: Fully Charged Battery Pack LP-E12, Shutter Speed: 1/1000 Sec. Or Faster, Room Temperature (73°F/23°C), 12 Bit
*2 BR-E1: Supported / RC-6: Not Supported
Self-Timer Mode
Off, 2-Second Self-Timer, 10-Second Self-Timer, Continuous Timer
Back To TopLive View Functions
Aspect Ratio Settings
3:2, 4:3, 16:9, 1:1 (Frame Grab Images From 4K Movies Cannot Be Cropped)
Focus Mode
AF, MF, AF+MF (Manual Focus After One-Shot AF)
MF Peaking Provided
Continuous AF
Provided
Touch Shutter
Provided
Grid Display
Off / 3x3 / 6x4 / 3x3+Diag
Depth Of Field Preview
Provided
File Format Video: MPEG-4 AVC / H.264
Variable (Averaged) Bit Rate
Audio: AAC
Recording System
MP4
Live Streaming
Supported
Recording Size And Frame Rate
Movie Recording Resolution Frame
Rate (Fps)1
Compression
Format
Audio Recording
Format
4K (UHD)*¹ 3840 X 2160 23.98 IPB (Standard) AAC MP4
Full HD 1920 X 1080 59.94
29.97
23.98
HD 1280 X 720 59.94
Hybrid Auto Full HD 1920 X 1080 59.94
29.97
23.98
HD 1280 X 720 59.94
Video Snapshot Full HD 1920 X 1080 29.97
23.98
Miniature Effect Movies*² Full HD 1920 X 1080 29.97
23.98
High Frame Rate Movies*²*³ HD 1280 X 720 119.88
Time-Lapse
Movies*²*³
4K*¹ 3840 X 2160 29.97 ALL-I
*1The Image Is Cropped Around The Center Of The Image Sensor.
*2 Sound Recording, Movie Servo AF, Movie Digital IS, And Movie Auto Level Are Disabled.
*3 AF Disabled During Shooting.
Continuous Shooting Time
Video Recording Size 32GB 128GB File Size (Approx.)
4K
(3840 X 2160)
23.98 Fps IPB
(Standard)
35 Min. 2 Hr. 21 Min. 120 Mbps
861 MB/Min.
Full HD
(1920 X 1080)
59.94 Fps 1 Hr. 10 Min. 4 Hr. 43 Min. 60 Mbps
432 MB/Min.
29.97 Fps
23.98 Fps
2 Hr. 20 Min. 9 Hr. 23 Min. 30 Mbps
217 MB/Min.
HD
(1280 X 720)
59.94 Fps 2 Hr. 42 Min. 10 Hr. 49 Min. 26 Mbps
188 MB/Min.
119.88 Fps 1 Hr. 22 Min. 5 Hr. 28 Min. 52 Mbps
372 MB/Min.
* Limitations Of Video Shooting: Continuous Shooting Is Possible Until The Memory Card Becomes Full Or The Recording Length For One Video Reaches Approx. 29 Minutes And 59 Seconds (Or 7 Min. 29 Sec. For A HD High Frame Rate Movie).
* Recording Bit Rate Of Movie Images Only, Sound Data Not Included.
Exposure Compensation &Plusmn;3 Stops In 1/3-Stop Increments
Movie Exposure Modes
Movie Auto Exposure; Movie Manual Exposure
Metering Mode
Evaluative Metering / Center-Weighted Metering (When No Faces Are Detected)
ISO Speed (Recommended Exposure Index)
ISO 100- Maximum 6400/12800 H:25600
Provided (Full HD 1920 X 1080, 29.97 Fps)
Still Image Shooting
Provided (Possible With Hybrid Auto Setting; HD 1280 X 720 At 29.97 Fps)
Sound Recording
Built-In Stereo Microphones, Recording Level Adjustable, Wind Filter Provided, Attenuator Provided
Card Performance Requirements
Video Recording Size SD Card
4K
(3840 X 2160)
IPB (Standard) 23.98 Fps
UHS-I, UHS Speed Class 3 Or Higher
Full HD
(1920 X 1080)
IPB (Standard) 59.94 Fps SD Speed Class 10 Or Higher
HD
(1280 X 720)
IPB (Standard) 29.97 Fps SD Speed Class 6 Or Higher
Time-Lapse Movie 4K (UHD) (3840 X 2160) IPB (Standard) 59.94 Fps SD Speed Class 4 Or Higher
119.88 Fps SD Speed Class 10 Or Higher
Time-Lapse Movie Full HD (1920 X 1080) ALL-I 29.97 Fps Read Speed Of 40 MB/S Or Higher
29.97 Fps Read Speed Of 20 MB/S Or Higher
Type TFT Color Liquid Crystal Monitor
Menu Magnification
Double-Tap-Based Supported
* You Can Double-Tap With Two Fingers To Zoom In On The Area Centered Between The Two Double-Tapped Points.
Brightness Adjust-Ment
Manually Adjustable To One Of Seven Brightness Levels
Angle Of View
Approx. 170° Vertically And Horizontally
Hints & Tips
Displayable
Screen Monitor Size 3.0-Inch Type
Pixels Approx. 1.04 Million Dots
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese)
Image Display Format Single Image, Or 4, 9, 36, Or 100-Image Index
Viewing Options Via INFO Button: Full Image, Full Image With Basic Info, Thumbnail Image With Histogram And Detailed Shooting Info, RGB And Brightness Histograms With Lens Info
Playback Methods
Playback On Camera's LCD Screen
HDMI Playback To Compatible TVs - (AV Cables Not Supported)
Playback On Computer Screen - (Requires Compatible Software)
Zoom Magnification
Approx. 1.5x To 10.0x
(Can Be Activated By Double-Tapping)
Image Browsing Methods
  • Single Image
  • 10 Images
  • Specified Number (1-100 Images)
  • Date
  • Folder
  • Movies
  • Still Images
  • Protected Images
  • Ratings
Image Rotate
Provided
Rating
Provided
(Off, 1,5 Stars)
Video Playback
Provided (With Built-In Speaker)
Playback Time
Approx. 4 Hr. 55 Min.
* With A Fully Charged LP-E12
* Time When Playing Back A Slideshow Of Still Photos
Slideshow
  • All Images
  • Repeat: Enable / Disable
  • Slideshow Of Images After Selection From The Search List
  • Background Music: Off / On
Back To TopPost-Processing Of Images
Creative Filters
  • Grainy B/W
  • Soft Focus
  • Fish-Eye Effect
  • Art Bold Effect
  • Water Painting Effect
  • Toy Camera Effect
  • Miniature Effect
Cropping
Cropping Frame Movement: Vertical / Horizontal
Cropping Range: Up To 42 Sizes
Tilt Correction
Aspect Ratio (3:2, 16:9, 4:3, 1:1, 2:3, 9:16, 3:4)
* Frame Grab Images From 4K Movies Cannot Be Cropped.
Resize
M, S1, S2
* Frame Grab Images From 4K Movies Cannot Be Resized.
Red-Eye Reduction
Provided
Compatible Printers PictBridge
Printable Images JPEG
RAW / C-RAW
Custom Controls Stills :Shutter Button, AE Lock Button, Multi-Function Button, Movie Button, Exposure Comp. Button, AF/MF Button, Flash Button, Erase Button.
Movie:AE Lock Button, Multi-Function Button, Exposure Comp. Button, AF/MF Button, Flash Button, Erase Button
Custom Functions
5 Available
Copyright Info
Provided
Usb Terminal USB Micro-B (Hi-Speed USB 2.0 Compliant)
Video Out Terminal HDMI Type D (Resolution Switches Automatically)
HDMI Output While Recording (Shooting Screen Without Sound) Provided
CEC Not Supported
Wireless Remote Control
Compatible With Wireless Remote Control BR-E1
Not Compatible With Accessories Using The Infrared Transmission System Of Remote Controller RC-6
Back To TopWi-Fi® (Wireless LAN)
Standards Compliance
IEEE 802.11b/G/N
Transmission Method
DS-SS Modulation (IEEE 802.11b), OFDM Modulation (IEEE 802.11g/N)
Transmission Frequency (Central Frequency)
Frequency: 24122462 MHz
Channels: 111 Ch
Connection Method And Security
(1) Infrastructure Mode
  1. WPA2-PSK
    1. AES
    2. TKIP
  2. WPA-PSK
    1. AES
    2. TKIP
  3. Open
    1. WEP
    2. None
  4. Wi-Fi® Protected Setup Compliant
(2) Camera Access Point Mode
  1. WPA2-PSK
    1. AES
  2. Open
    1. WEP
    2. None
Back To TopNetwork Functions
Supported Wireless Functions
Connect To Compatible Smart Phone Or Tablet
Remote-Control Camera From Compatible Mobile Device
Remote-Control Camera With Optional Canon BR-E1 Remote Controller
Send Still Images Or Video Files To Mobile Device
Upload Images To Web Service
Send Images To Compatible Computer
Print To Compatible Wi-Fi Enabled Printer
Geo-Tag In-Camera Images With GPS Data From Compatible Smart Phone (Bluetooth Required)
Transfer Images Between Cameras
Not Possible
Connection To Smart Phones
Connect With Free Canon Camera Connect App
(Android And IOS Versions Available For Compatible Mobile Devices)
Wireless Connection Types
Wi-Fi® And Bluetooth V. 4.2 (Low-Energy)
Battery Battery Pack LP-E12
Battery Life
&Nbsp; Shooting
Method
Temperature Shooting Conditions
AE: 100%
(Flash Off)
Flash 50%
Possible Shots
For Sill Photo
Shooting
Viewfinder
Shooting
73°F / 23°C Approx. 275 Shots Approx. 250 Shots*¹
32°F / 0°C Approx. 245 Shots Approx. 230 Shots
On-Screen
Shooting
73°F / 23°C Approx. 320 Shots Approx. 305 Shots*¹
32°F / 0°C Approx. 305 Shots Approx. 280 Shots
* With A Fully Charged LP-E12 Battery.
* With [Display Performance: Power Saving] (Default Setting).
* ¹ CIPA Testing Standards Complliant.
Dimensions W X H X D Approx. 4.58 X 3.47 X 2.31 In. (116.3 X 88.1 X 58.7mm)
CIPA Compliant.
Weight Black:
Approx. 13.65 Oz. / 387g (Including Battery Pack And Memory Card)
Approx. 12.35 Oz. / 350g (Body Only)
White:
Approx. 13.69 Oz. / 388g (Including Battery Pack And Memory Card)
Approx. 12.38 Oz. / 351g (Body Only)
* Without Body Cap
* 1: Based On CIPA Guidelines
Operating Temperature Range 32-104&Deg;F / 0-40&Deg;C
Operating Humidity Range 85% Or Less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: EOS M50 Mark II: Firmware Version 1.0.1
Advisory Type
Date 12.12.21
Title Firmware Notice: EOS M50 Mark II: Firmware Version 1.0.3
Advisory Type
Date 06.07.22
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
