Canon Support for EOS M50 | Canon U.S.A., Inc.
EOS M50
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
Wireless Setup
Wireless Connection
Using Wi-Fi
- Sending Images to a Smartphone using a Wireless Connection
- Using EOS Utility 3.x to Send Images to a Computer using the Wi-Fi Function
- What Can I Do Using the Wireless LAN Functions?
Bluetooth Connections
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital single-lens non-reflex AF/AE camer |
Recording Media | SD/SDHC/SDXC memory card * UHS-I compatible |
Image Format | Approx. 22.3 x 14.9mm (APS-C Size) |
Compatible Lenses | EF-M lens (and EF/EF-S lenses when using Mount Adapter EF-EOS M) Equivalent to approximately 1.6x the focal length indicated on a mounted lens |
Type | Canon CMOS Sensor |
Pixels | Effective pixels: Approx. 24.1 Megapixels Total pixels: Approx. 25.8 Megapixels
Pixel Unit | Square pixel approx. 3.72 µm |
Aspect Ratio | 3:2 |
Dust Deletion Feature | Auto / Manual |
Recording Format | EXIF 2.31 (DCF2.0) |
Image | JPEG / RAW (CR3 a Canon 14-bit RAW format) |
File Size | 3:2 Aspect Ratio Large: 6000 x 4000 Medium: 3984 x 2656 Small 1: 2976 x 1984 Small 2: 2400 x 1600 RAW: 6000 x 4000 C-RAW: 6000 x 4000 16:9 Aspect Ratio Large: 6000 x 3368 Medium: 3984 x 2240 Small 1: 2976 x 1680 Small 2: 2400 x 1344 RAW: 6000 x 3368 C-RAW: 6000 x 3368 4:3 Aspect Ratio Large: 5328 x 4000 Medium: 3552 x 2664 Small 1: 2656 x 1992 Small 2: 2112 x 1600 RAW: 5328 x 4000 C-RAW: 5328 x 4000 1:1 Aspect Ratio Large: 4000 x 4000 Medium: 2656 x 2656 Small 1: 1984 x 1984 Small 2: 1600 x 1600 RAW: 4000 x 4000 C-RAW: 4000 x 4000 |
File Number | Continuous, Auto Reset, Manual Reset |
RAW + JPEG Simultaneous Recording | Yes |
Picture Style | Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 13 |
Picture Style |
White Balance Correction | Blue/Amber: ±9 levels Green/Magenta: ±9 levels |
Type | Built-in electronic color viewfinder with 0.39-type screen size and approx. 2.36 million dots |
Grid Display | 3 types |
Depth of Field Preview | Provided |
Type | Dual Pixel CMOS AF (Face+Tracking AF, Zone AF, 1-point AF) |
AF Points | 143 / 99 points |
AF Working Range | EV -218 (at room temperature 73°F/23°C, ISO 100, when using EF-M 22mm f/2 STM) |
Focusing Modes |
Continuous AF | Provided |
AF Assist Beam | Built-in LED lamp |
Metering Modes | Real-time metering using the image sensor
Metering Range | EV 020 (at room temperature 73°F/23°C, ISO 100) |
Exposure Control Systems |
ISO Speed Range (Recommended Exposure Index) | ISO Auto Range (AUTO mode): ISO 1006400 Max. ISO Speed (P mode): ISO 25600 Max. Expanded ISO Speed (P mode): ISO 51200 |
Exposure Compensation |
AE Lock | Manual / Auto |
Type | Electronically controlled focal-plane shutter |
Shutter Speeds | 1/4000 sec. to 30 sec. Highest flash-sync shutter speed: 1/200 sec. |
Self Timer | Off, 2 sec. delay, 10 sec. delay, Custom, Remote Shooting |
Camera Start-up Time | Approx. 1.0 sec. |
Type | Manual pop-up flash |
Guide Number | GN approx. 5/16.4 (ISO 100 m/ft.) |
Flash Coverage | Covers approx. 15mm focal length (35mm film size conversion: approx. 24mm) |
Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
Flash Metering | E-TTL II autoflash |
FE Lock | Provided |
External Flash Settings | Flash functions settable with the camera |
Drive Modes | Single shooting, Continuous shooting (High-speed continuous shooting, low-speed continuous shooting) |
File Format | MP4 Video: MPEG-4 AVC / H.264 Audio: MPEG-4 AAC-LC (stereo) |
File Size | Recording Sizes: 3840 x 2160 (4K UHD), 1920 x 1080 (Full HD) and 1280 x 720 (HD) |
Frame Rates | [3840 x 2160]: 23.98 fps [1920 x 1080]: 59.94 fps / 29.97 fps / 23.98 fps [1280 x 720]: 119.9 fps / 59.94 fps |
Metering Mode | Real-time metering using the image sensor
ISO Speed Range (Recommended Exposure Index) | 3840 x 2160 (4K UHD) ISO Auto Range (AUTO and Manual mode): ISO 1006400 1920 x 1080 (Full HD), 1280 x 720 (HD) ISO Auto Range (AUTO and Manual mode): ISO 10012800 Expandable to ISO 25600 |
Exposure Compensation | ±3 stops in 1/3-stop increments |
Type | TFT color liquid crystal monitor |
Monitor Size | 3.0 type |
Pixels | Approx. 1.04 million dots |
Features | Vari-angle |
Touch-screen Panel | Electrostatic capacitance type |
Brightness Control | Electrostatic capacitance type |
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese) |
Display Format |
Highlight Alert | Provided |
Image Protection | Provided |
Compatible | PictBridge-compatible printers |
Resize | Provided |
Red-eye Correction | Provided |
Compatible Printers | PictBridge |
Printable Images | JPEG and RAW* are printable. *Prints JPEG images after RAW processing. |
DPOF | DCF-compliant DPOF compatible (Version 1.1) |
Custom Controls (Camera Controls / Buttons Customization) | Functions can be assigned to the following controls (set in Custom Functions):
USB Terminal | Micro USB |
Audio / Video OUT Terminal | HDMI OUT terminal Type D HDMI output while recording (shooting screen without sound) available HDMI output to HDR compatible TVs* available * Movie playback not supported. JPEG images are not displayed in HDR. |
Battery | LP-E12 |
Battery Life | Number of Still Image Shots (CIPA compliant: room temperature 73°F/23°C) Screen On*: Approx. 235 shots Electronic Color Viewfinder On*: Approx. 235 shots Number of Still Image Shots (Eco Mode On)Screen On**: Approx. 370 shots Movie Recording Time (CIPA compliant: room temperature 73°F/23°C) Screen On: Approx. 85 min. Electronic Color Viewfinder On: Approx. 85 min. Movie Recording Time*** (Continuous Shooting) Screen On: Approx. 130 min. Electronic Color Viewfinder On: Approx. 130 min. * Approx. 290 shots when power saving is enabled. ** Approx. 425 shots when power saving is enabled. *** Total shooting time when shooting is performed under the following conditions: using default AUTO Mode; without using zooming and other operations; when max. recording time per movie is reached and recording stops/resumes automatically. |
Playback Time | Approx. 4 hr.
Dimensions (W x H x D) | Approx. 4.6 x 3.5 x 2.3 in. (116.3 x 88.1 x 58.7mm)
Weight | Black Approx. 12.4 oz. / 351g (body only) Approx. 13.7 oz. / 387g (including battery pack, memory card)
Approx. 12.5 oz. / 354g (body only) Approx. 13.8 oz. / 390g (including battery pack, memory card)
Working Temperature Range | 32-104°F / 0-40°C |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
