Canon Support for EOS M5 | Canon U.S.A., Inc.
EOS M5
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
CMOS sensor
Pixels
Effective pixels: Approx. 24.2 Megapixels
Total pixels: Approx. 25.8 Mega pixels Pixels may decrease due to image processing.
Pixel Unit
Square pixel approx. 3.72 &micro;m
Aspect Ratio
3:2
Dust Deletion Feature
Auto / Manual
Recording Format
EXIF 2.3 (DCF2.0)
File Size
3:2 Aspect Ratio
Large: 6000 x 4000
Medium: 3984 x 2656
Small 1: 2976 x 1984
Small 2: 2400 x 1600
16:9 Aspect Ratio
Large: 6000 x 3368
Medium: 3984 x 2240
Small 1: 2976 x 1680
Small 2: 2400 x 1344
4:3 Aspect Ratio
Large: 5328 x 4000
Medium: 3552 x 2664
Small 1: 2656 x 1992
Small 2: 2112 x 1600
1:1 Aspect Ratio
Large: 4000 x 4000
Medium: 2656 x 2656
Small 1: 1984 x 1984
Small 2: 1600 x 1600
File Numbering
Continuous, Auto Reset
RAW + JPEG Simultaneous Recording
Yes
Picture Style
Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1-3
Settings
Auto Day Light Shade Cloudy Light bulb White fluorescent light Flash Color temperature Custom
Type
Built-in electronic color viewfinder with 0.39-type screen size and approx. 2.36 million dots
Depth Of Field Preview
Provided
Type
Dual Pixel CMOS AF (Face+Tracking AF, 1-point AF)
AF Points
49 points (Maximum)
AF Working Range
EV -1-18 (at room temperature, ISO 100, when using EF-M 22mm f/2 STM)
Focusing Modes
Auto focus One-Shot AF Servo AF Manual focus AF+MF (Manual focus after One-Shot AF: when shooting still images during movie recording)
AF Assist Beam
Built-in LED lamp
Metering Modes
Real-time metering using the image sensor Evaluative Partial metering Center-weighted evaluative metering Spot
Metering Range
EV 1-20 (at room temperature, ISO 100)
Exposure Control Systems
Program AE Shutter-priority AE Aperture-priority AEManual exposure
ISO Speed Range
ISO Auto Range (AUTO mode): ISO 100-6400
Max. ISO Speed (P mode): ISO 25600
Max. Speed Limit Setting in ISO AUTO: ISO 25600
Exposure Compensation
Manual: &plusmn;3 stops in 1/3-stop increments AE Bracketing: &plusmn;2 stops in 1/3-stop increments
AE Bracketing can be used together with manual compensation.
AE Lock
Manual / Auto
Type
Electronic control only
Shutter Speeds
1/4000 sec. to 30 sec. in Auto mode
Highest flash-sync shutter speed: 1/200 sec.
Self Timer
Approx. 1.0 sec.
Type
Manual pop-up flash
Guide Number
Gno. approx. 5 (ISO 100/m)
Flash Coverage
Covers approx. 15mm focal length (35mm film size conversion: approx. 24mm)
Flash Exposure Compensation
Flash Metering
E-TTL II autoflash
±2 stops in 1/3-stop increments
FE Lock
Provided
External Flash Settings
Flash functions settable with the camera
Drive Modes
Single shooting, Continuous shooting (High-speed continuous shooting, low-speed continuous shooting)
Continuous Shooting Speed
Continuous Shooting Speed (Approx.)JPEG
* Under Servo AF, may further decrease depending on the subject conditions and lens used.
Continuous Shooting Speed (Approx.)RAW
Continuous shooting speed may become slower due to the following factors: Tv value/Av value/Subject conditions/Lighting conditions/Lens type/Use of flash/Battery Level.
File Format
MP4
Video: MPEG-4 AVC / H.264
Audio: MPEG-4 AAC-LC (stereo)
File Size
Recording Sizes:
1920 x 1080 (Full HD), 1280 x 720 (HD) and 640 x 480 (VGA)
Frame Rates
[1920 x 1080]: 59.94 fps / 29.97 fps / 23.976
[1280 x 720]: 59.94 fps
[640 x 480]: 29.97 fps
Continuous Shooting Time
Continuous Shooting Time Based on 16GB Memory Card
&#8224; Recording bit rate of movie images only, sound data not included.
* Limit on movie recording: continuous shooting is possible until the memory card becomes full or the recording length for one movie reaches approx. 29 minutes 59 seconds.
Provided (±3 stops in 1/3-stop increments)
Type
TFT color, liquid-crystal monitor
Monitor Size
3.2 type
Pixels
Approx. 1.62 million dots
Brightness Control
Adjustable to one of five brightness levels
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
Single-image display1 shot + information display Simple information Detailed information Histogram Lens information Picture Style Noise reduction Correction data Index display Image rotate
Highlight Alert
Provided
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG, RAW*, MP4 and MOV files are printable.
* Prints JPEG images used for display, which are taken on the same model.
DPOF
DPOF print ordering provided (Complies to DPOF Version 1.1)
Custom Functions
6 functions with 15 settings can be performed on the camera.
Custom Controls
Not Provided
Camera User Settings
Functions can be assigned to the following controls (set in Custom Functions):Shutter button Main dial Quick control dial Cross button (up, down, left, right)Control dial M-Fn button Movie button Touch pad AF button
USB Terminal
Micro USB
Video Out Terminal
HDMI OUT Terminal Type D
HDMI output while recording available
Battery
LP-E17
Battery Life
Number of Still Image Shots (CIPA compliant)
Monitor On: Approx. 295 shots
Electronic Color Viewfinder On: Approx. 295 shots
Number of Still Image Shots (Eco Mode On)
Monitor On: Approx. 420 shots
Movie Recording Time (CIPA compliant)
Monitor On: Approx. 85 min.
Electronic Color Viewfinder On: Approx. 90 min.
Dimensions (W x H x D)
Approx. 4.6 x 3.5 x 2.4 in. (115.6 x 89.2 x 60.6mm)CIPA compliant.
Weight
Approx. 13.4 oz. / 380.0g (Body only)
Approx. 15.1 oz. / 427.0g (Including battery pack, memory card)CIPA compliant.
Working Temperature Range
90% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: EOS M5: Firmware Version 1.0.2
Advisory Type
Date 02.12.20
Title Canon Support | Firmware Notice: EOS M5: Firmware Version 1.0.1
Advisory Type
Date 05.08.17
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
