Canon Support for EOS M6 EF-M 15-45mm IS STM Kit | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Type | Digital single-lens non-reflex AF/AE camera |
| Recording Media | SD/SDHC/SDXC memory card
| Image Format | Approx. 22.3 x 14.9mm (APS-C Size) |
| Compatible Lenses | EF-M lens (when using EF-M Mount Adapter: EF/EF-S lens group) Equivalent to approximately 1.6x the focal length indicated on a mounted lens |
| Type | CMOS sensor |
| Pixels | Effective pixels: Approx. 24.2 Megapixels Total pixels: Approx. 25.8 Megapixels
| Pixel Unit | Square pixel approx. 3.72 µm |
| Aspect Ratio | 3:2 |
| Dust Deletion Feature | Auto / Manual |
| Recording Format | EXIF 2.3 (DCF2.0) |
| File Size | 3:2 Aspect Ratio Large: 6000 x 4000 Medium: 3984 x 2656 Small 1: 2976 x 1984 Small 2: 2400 x 1600 16:9 Aspect Ratio Large: 6000 x 3368 Medium: 3984 x 2240 Small 1: 2976 x 1680 Small 2: 2400 x 1344 4:3 Aspect Ratio Large: 5328 x 4000 Small 1: 2656 x 1992 Small 2: 2112 x 1600 1:1 Aspect Ratio Large: 4000 x 4000 Medium: 2656 x 2656 Small 1: 1984 x 1984 Small 2: 1600 x 1600 |
| File Numbering | Continuous, Auto Reset |
| RAW + JPEG Simultaneous Recording | Yes |
| Picture Style | Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1-3 |
| Settings |
| White Balance Correction | Blue/Amber: ±9 levels Green/Magenta: ±9 levels |
| Viewfinder Information | Attachment EVF-DC2 and EVF-DC1 connect to the hot shoe (communication is performed through the use of a dedicated terminal attached to the shoe). |
| Type | Dual Pixel CMOS AF (Face+Tracking AF, Smooth Zone AF, 1-point AF) |
| AF Points | 49 points (Maximum) |
| AF Working Range | EV -1-18 (at room temperature, ISO 100, when using EF-M 22mm f/2 STM) |
| Focusing Modes |
| AF Assist Beam | Built-in LED lamp |
| Metering Modes | Real-time metering using the image sensor
| Metering Range | EV 1-20 (at room temperature, ISO 100) |
| Exposure Control Systems |
| ISO Speed Range | ISO Auto Range (AUTO mode): ISO 100-6400 Max. ISO Speed (P mode): ISO 25600 |
| Exposure Compensation |
| AE Lock | Manual / Auto |
| Type | Electronic controlled focal-plane shutter |
| Shutter Speeds | 1/4000 sec. to 30 sec. in Auto mode Highest flash-sync shutter speed: 1/200 sec. |
| Self Timer | Off, 2 sec. delay, 10 sec. delay, Custom, Remote Shooting |
| Camera Start-up Time | Approx. 1.0 sec. |
| Type | Manual pop-up flash |
| Guide Number | Gno. approx. 5 (ISO 100/m) |
| Flash Coverage | Covers approx. 15mm focal length (35mm film size conversion: approx. 24mm) |
| Flash Exposure Compensation | ±2 stops in 1/3-stop increments |
| Flash Metering | E-TTL II autoflash |
| FE Lock | Provided |
| External Flash Settings | Flash functions settable with the camera |
| Drive Modes | Single shooting, Continuous shooting (High-speed continuous shooting, low-speed continuous shooting) |
| File Format | MP4 Video: MPEG-4 AVC / H.264 Audio: MPEG-4 AAC-LC (stereo) |
| File Size | Recording Sizes: 1920 x 1080 (Full HD), 1280 x 720 (HD) and 640 x 480 (VGA) |
| Frame Rates | [1920 x 1080]: 59.94 fps / 29.97 fps / 23.976 [1280 x 720]: 59.94 fps [640 x 480]: 29.97 fps |
| ISO Speed Range (Recommended Exposure Index) | ISO Auto Range (AUTO and Manual mode): ISO 1006400 Expandable to ISO 12800 |
| Exposure Compensation | Provided (±3 stops in 1/3-stop increments) |
| Type | TFT color liquid-crystal monitor |
| Monitor Size | 3.0 type |
| Pixels | Approx. 1.04 million dots |
| Features | Tilt (upwards approx. 180° + downwards approx. 45°) |
| Touch-screen Panel | Electrostatic capacitance type |
| Brightness Control | Adjustable to one of five brightness levels |
| Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
| Display Format |
| Highlight Alert | Provided |
| Quick Control | Provided |
| Image Protection | Provided |
| Compatible Printers | PictBridge-compatible printers |
| Printable Images | JPEG, RAW*, MP4 and MOV files are printable. * Prints JPEG images used for display, which are taken on the same model. |
| DPOF | DPOF print ordering provided (Complies to DPOF Version 1.1) |
| Custom Controls | Functions can be assigned to the following controls (set in Custom Functions):
| USB Terminal | Micro USB |
| Video Out Terminal | HDMI OUT Terminal Type D HDMI output while recording available |
| Battery | LP-E17 |
| Battery Life | Number of Still Image Shots (CIPA compliant) Monitor On: Approx. 295 shots Electronic Color Viewfinder On: Approx. 295 shots Number of Still Image Shots (Eco Mode On) Monitor On: Approx. 425 shots Movie Recording Time (CIPA compliant) Monitor On: Approx. 85 min. Electronic Color Viewfinder On: Approx. 85 min. |
| Playback Time | Approx. 5 hr.
| Dimensions (W x H x D) | Approx. 4.4 x 2.7 x 1.8 in. (112.0 x 68.0 x 44.5mm)
| Weight | Approx. 12.1 oz. / 343g (body only) Approx. 13.8 oz. / 390g (including battery pack, memory card)
| Working Temperature Range | 32-104° F / 0-40° C |
| Working Humidity | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
next to your download
