Canon Support for EOS R100 | Canon U.S.A., Inc.
EOS R100
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 06.01.23
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type Digital interchangeable lens, mirrorless camera
Image Processor DIGIC 8
Recording Media (One) SD card slot
Compatible with UHS-I
Eye-Fi cards and Multimedia cards (MMC) are not supported.
Lens Mount Canon RF mount
Compatible Lenses Canon RF lens group (including RF-S lenses)
* When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
* Note that control ring of the Control Ring Mount Adaptor EF-EOS R does not function.
* EXTENDER RF1.4x / RF2x is not compatible.
(EXTENDER EF1.4x / EF2x is compatible when used with the Mount Adaptor.)
* RF5.2mm F2.8 L DUAL FISHEYE and RF85mm F1.2 L USM DS are not compatible.
Type APS-C CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective pixels Approx. 24.1 megapixels
Screen Size Approx. 22.3×14.9 mm
Pixel Unit Approx. 3.72 µm square
Total Pixels Approx. 25.8 megapixels
Aspect Ratio 3:2 (Horizontal: Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Not provided
Dust Deletion Feature Self Cleaning Sensor Unit not provided.
Manual cleaning (by hand) not supported.
Dust Delete Data acquisition and appending
The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
Recording Format Compliant to Design rule for Camera File system 2.0 and Exif 2.31*
*Supports time offset information
Image Format JPEG (.JPG), RAW, C-RAW (.CR3)
* HEIF not supported.
Movies: ALL-I (Time-lapse video only), IPB (Standard) (.MP4)
* IPB (Light) not supported.
File Size Please click here for full specifications.
Maximum Burst Please click here for full specifications.
File Numbering The following file numbers can be set:
  1. File numbering methods
    • Continuous numbering
      • The numbering of captured images continues even after you replace the card.
    • Auto reset
      • When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
      * When manually resetting the file number, folders can also be renamed.
RAW + JPEG / HEIF Simultaneous Recording Simultaneous recording of any combination of RAW/C-RAW images and JPEG images is supported.
Color Space Selectable between sRGB and Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    * Picture Style files can be registered to user-defined settings 1-3.
Settings
  1. Auto (Ambience priority/White priority)
  2. Day Light
  3. Shade
  4. Cloudy*1
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
  9. Color temperature*2
*1: Effective also in twilight and sunset.
*2: With an EX / EL-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000 K if the flash unit does not have the color tem-perature communication feature.
Auto White Balance Option between ambience priority and white priority settings, using SET button
White Balance Shift Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Shifted from the color temperatue of the current WB mode.
Blue/amber and magenta/green shift can be set at the same time.
Type OLED color electronic viewfinder; 0.39-inch, approx. 2.36 million dots
Coverage Approx. 100% (at JPEG Large image quality, 3:2 aspect ratio, approx. 22 mm eyepoint)
Magnification / Angle of View Approx. 0.95×/28.0° (3:2 aspect ratio, with 50mm lens at infinity, 1 m1)
Eye Point Approx. 22 mm (at 1 m1 from eyepiece lens end)
Dioptric Adjustment Range Approx. 3.0 to +1.0 m1 (dpt)
Viewfinder Information Users can customize and select whether to use the following three display elements.
Live View + basic information display
Live View + detailed information display
Live View + detailed information display + histogram
Focus Method Still photo shooting: Dual Pixel CMOS AF
Number of AF zones available for Automatic Selection AF area: Horizontal: Approx. 88% x Vertical: Approx. 100%
Stills: Max. 143 zones (13×11)
Movies: Max. 117 zones (13×9)
Selectable Positions for AF Point AF area: Horizontal: Approx. 88% x Vertical: Approx. 100%
Stills: Max. 3975 positions (75 × 53)
Movies: Max. 3375 positions (75 × 45)
Focusing brightness range (still photo shooting) EV 4.0 to 20
(With an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100)
* Except RF lenses with a Defocus Smoothing (DS) coating
Focusing brightness range (movie recording) EV 2.0 to 20
(With an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100) * Except RF lenses with a Defocus Smoothing (DS) coating
* During Full HD (29.97/25.00 fps) recording
Available AF Areas Face+Tracking AF*1
Spot AF*1*2
1-point AF
Zone AF*2
*1: Not available in Panning mode.
*2: Not available for 4K movies.
* Some lenses and camera settings may reduce the number of AF areas and zones used.
Available Subject Detection People / Eye
Eye Detection Auto:
The eye closer to the camera is selected (as detected from the angle of the face).
Changed Manually:
Other eyes can be selected with the left and right cross keys after pressing the AF point selection button.
Faces are selected when another subjects eyes cannot be detected.
Metering Modes 384-zone (24×16) metering using image sensor output signals
(1) Evaluative metering (AF point-linked)
(2) Partial metering (approx. 5.8% of the area at the center of the screen)
(3) Spot metering (approx. 2.9% of the area at the center of the screen)
(4) Center-weighted average metering
Metering Range Still Photo Shooting: EV -2 to 20
Movie Recording: EV 0 to 20
Exposure Modes Still Photo Shooting:
  1. Scene Intelligent Auto
  2. Hybrid Auto
  3. Special Scenes
  4. Creative Filters
  5. Program AE
  6. Shutter-priority AE
  7. Aperture-priority AE
  8. Manual Exposure
  9. Bulb Exposure
Movie Recording:
  1. Movie auto exposure
  2. Movie manual exposure
ISO Speed Range Please click here for full specifications.
Exposure Compensation
User-set ±3 stops (in 1/3-stop increments)
AEB ±3 stops (in 1/3-stop increments)
AE Lock
  1. Automatic AE lock
    • In One-Shot AF mode, AE is locked as soon as subjects are in focus.
    • Manual AE lock
      • By using the AE Lock button in P, Tv, Av, and M mode.
        Toggling: Press again to cancel and once more to refresh.
      • Enabled in all metering modes.
Type Electronically controlled focal-plane shutter
* Electronic 1st / mechanical 2nd curtain
* Except in silent shutter mode
Rolling shutter, using the image sensor
* Electronic shutter
* In silent shutter mode
Shutter Speed / X-sync Speed Creative Zone: 1/400030 sec.,*1 Bulb*2
Basic Zone: 1/40001 sec.*3
Maximum flash sync speed: 1/250 sec.
*1: In 1/3-stop increments
*2: In manual shooting mode only
*3: Varies by mode.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay, 2-sec. delay, Continuous
Still Photo IS In-body IS not provided.
Still Photo IS not suppored.
Accessory Shoe Conventional accessory shoe
* Not compatible with accessories designed for multi-function shoes
E-TTL balance Not supported
Flash Exposure Compensation ±2 stops (in 1/3-stop increments)
* When set from the camera menu
Continuous flash control Not supported
* Set to [E-TTL each shot] and cannot be changed
Drive Modes and Continuous Shooting Speed Please click here for full specifications.
File Format Please click here for full specifications.
Estimated Recording time, Movie Bit Rate and File Size Please click here for full specifications.
Estimated Recording Time, Continued. HDR PQ: ON
Card Performance Requirements Please click here for full specifications.
Video AF Full HD or HD movie recording: Dual Pixel CMOS AF
4K movie recording: Contrast AF
* With Contrast AF as used when recording 4K movies, focusing may take longer than when recording Full HD or HD movies, and focusing with certain lenses may be difficult.
Time Code Not supported
Movie Pre-recording (On/Off) Not supported
Time-lapse Movie Setting Please click here for full specifications.
Time-lapse Playback Frame Rate 29.97 (set to NTSC); 25.00fps (set to PAL)
Type TFT color, liquid-crystal monitor
Monitor Size 3.0-inch (screen aspect ratio of 3:2)
2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
Dots Approx. 1.04 million dots
Coverage Approx. 100% vertically/horizontally
Brightness Control Manually adjustable in a range of 17
Touch-screen Operation Not provided
Coating Anti-smudge coating not provided.
Anti-reflection coating not provided.
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format Please click here for full specifications.
Highlight Alert Yes
* Detailed information display only
Histogram Brightness / RGB
Function The Quick Control screen can be accessed by pressing the Quick Control button during still photo shooting, movie recording, or playback.
Quick Control Screen Displayable
* Only the conventional Quick Control screen
Protection Select images / Select range / All images in folder / Unprotect all images in folder / All images on card / Unprotect all images on card / All found images / Unprotect all found images
Erase Select and erase images / Select range / All images in folder / All images on card / All found images
Wireless Connections Images can be sent via Wi-Fi to a PictBridge-compatible (wireless LAN) printer and printed.
DPOF Compliant to DPOF Version 1.1
Supporting Standards Equivalent to IEEE 802.11b/g/n Standards
Transmission Method DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n)
Transition Frequency (Central Frequency) 2.4 GHz band
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 channels
5.0 GHz band
Not supported
Connection Method (1) Camera access point mode
(2) Infrastructure mode
Security Please click here for full specifications.
Communication with a Smartphone Images can be viewed, controlled, and received using a smartphone
Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications.
Images can be sent to a smartphone.
NFC connection: Not supported
Supported images: JPEG, RAW/C-RAW, MP4 video files
Transcoding while sending: Size to send (original / reduced size); Quality to send (original / compressed)
Remote Operation Using EOS Utility The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer.
Print from Wi-Fi® Printers Supported.
Send Images to a Web Service image.canon: Video files (MP4) and JPEG, RAW or C-RAW still images can be uploaded to image.canon servers.
From image.canon, images can be sent to specific social media and 3rd-party cloud image services.
Standards Compliance Bluetooth Specification Version 4.2 compliant (Bluetooth Low Energy technology)
Transmission Method GFSK modulation
Bluetooth Pairing Smartphone up to 10 devices; BR-E1 remote controller 1 unit
Available Functions Customize buttons
Customize Buttons Functions can be assigned to the following camera controls.
Shutter button (half-press)
Exposure compensation button
AE lock button
ISO speed setting button
Flash button
Movie shooting button
Drive mode button
Customizable Dials Customize control ring supported.
My Menu Registration Please click here for full specifications.
USB Video Class (UVC) Not supported.
USB Terminal Equivalent to Hi-Speed USB (USB 2.0)
For PC communication
Terminal type: USB Type-C
* Cannot be connected to a printer
* Not for communication with smartphones
* Charging and powering the camera via USB are not supported
HDMI Out Terminal HDMI micro OUT terminal (Type D)
* Resolution switches automatically
* HDMI CEC not supported
* Images not displayed unless [For NTSC] or [For PAL] is set correctly for the TV video system
Clean HDMI Output Provided
Microphone terminal 3.5mm diameter stereo mini jack
Headphone terminal Not provided.
Battery Canon LP-E17 battery pack
With the AC Adapter AC-E6N + DC Coupler DR-E18, AC power is possible (AC Adapter Kit ACK-E18 can also be used).
Optional Battery Grip Not supported
Battery Check Automatic battery check with 4-level display when the power switch is turned ON.
Start-up Time Approx. 0.9 sec.
  • Based on CIPA testing standards.
Dimensions (W x H x D) Approx. 4.58 × 3.37 × 2.71 in. / 116.3 x 85.5 x 68.8mm
Based on CIPA standards.
Weight Please click here for full specifications.
Working Temperature Range 32-104°F / 0-+40°C
Working Humidity
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
What is the Stop Motion Animation Service?
We have released a new upgrade service for various EOS R series cameras.
This upgrade enables you to capture Stop Motion Animation.
For more details of the service and compatible camera’s click Learn More.
Pricing
Model Price*
Various EOS R cameras $100
*Tax and shipping fees are NOT included
*All pricing is subject to change Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-800-OK-CANON (toll free), 1-800-652-2666
For additional support options: https://www.usa.canon.com/support
Title Firmware Notice: EOS R100: Firmware Version 1.1.0
Advisory Type Firmware Notice
Date 09.26.24
Title Service Notice: EOS Webcam Utility Pro v2.3
Advisory Type Service Notice
Date 11.13.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
