Canon Support for EOS R1 | Canon U.S.A., Inc.
EOS R1
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 09.26.24
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type Digital interchangeable lens, mirrorless camera
Image Processor DIGIC X (with DIGIC Accelerator co-processor)
Recording Media (Two) CFexpress Type B card slots
compatible with CFexpress 2.0 and VPG400
Compatible Lenses Canon RF lens group (including RF-S lenses)
When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount Canon RF mount
Type Canon designed full-frame back-illuminated stacked CMOS sensor (compatible with Dual Pixel CMOS AF and Cross-type AF)
Effective Pixels Approx. 24.2 megapixels
Screen Size Approx. 36.0 x 24.0 mm
Pixel Unit Approx. 6.00 m square
Total Pixels Approx. 26.7 megapixels
Aspect Ratio 3:2 (Horizontal: Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Installed in front of the image sensor, non-detachable
Dust Deletion Feature (1) Self Cleaning Sensor Unit
Removes dust adhering to the low-pass filter.
At power off only / Enable / Disable. Performed automatically (taking about approx. 2 sec. as indicated on the screen) or manually (taking about approx. 8 sec. as indicated on the screen).
After manually activated cleaning, the camera will automatically restart (Power OFF to ON).
When [Multi Shot Noise Reduction], [Multiple exposures], or [HDR mode] is set, [Clean now] and [Clean manually] cannot be selected.
(2) Dust Delete Data acquisition and appending
The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
Not available with RF-S/EF-S lenses, in cropped shooting, during focus bracket shooting, in RAW burst mode, or multiple-exposure shooting.
(3) Manual cleaning (by hand)
Recording Format Compliant to Design rule for Camera File system 2.0 and Exif 2.31*.
*Supports time difference information in Exif 2.31.
Image Format RAW: RAW / C-RAW / JPEG / HEIF: L / M / S1 / S2
Movies: RAW / XF-HEVC S YCC422 10bit / XF-HEVC S YCC420 10bit / XF-AVC S YCC422 10bit / XF-AVC S YCC420 8bit
File Size
Quality
File Size
[Approx. MB]
Possible Shots
[Approx.]*¹
Maximum Burst [Approx.]*
CFexpress
Card*¹
JPEG*2 L 8.3 37930 1000 or more
M 4.4 71490 1000 or more
S1 3.0 102820 1000 or more
S2 1.8 170290 1000 or more
HEIF*3 L 8.4 37720 1000 or more
M 4.9 64760 1000 or more
S1 3.5 89510 1000 or more
S2 2.1 147840 1000 or more
RAW RAW 27.5 11530 1000 or more
C-RAW 12.4 25520 1000 or more
RAW+JPEG*2 RAW + L 27.5 + 8.3 8840 1000 or more
C-RAW + L 12.4 + 8.3 15250 1000 or more
RAW+HEIF*3 RAW + L 27.5 + 8.4 8230 260
C-RAW + L 12.4 + 8.4 13520 560
* 1: Number of shots available and maximum burst apply to 325 GB cards conforming to Canon testing standards.* 2: When [HDR shooting (PQ): Disable] is set.* 3: When [HDR shooting (PQ): HDR PQ] is set.* Maximum burst as measured under conditions conforming to Canon testing standards (One-Shot AF, High-speed continuous shooting +, JPEG/HEIF image quality: 8, ISO 100, Picture Style: Standard, and room temperature: 23°C / 73°F).* File size, number of shots available, and maximum burst vary depending on shooting conditions (including cropping/aspect ratio, JPEG/HEIF image quality, subject, memory card brand, ISO speed, Picture Style, and Custom Functions).
File Numbering The following file numbers can be set:
1. File numbering methods
a. Continuous numbering
i. The numbering of captured images continues even after you replace the card.
b. Auto reset
i. When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
2. Manual reset
a. Resets the file number to 0001, and creates a new folder automatically.
* When manually resetting the file number, folders can also be renamed.
RAW + JPEG / HEIF Simultaneous Recording Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported.
Color Space Selectable between sRGB and Adobe RGB
Picture Style (1) Auto
(2) Standard
(3) Portrait
(4) Landscape
(5) Fine Detail
(6) Neutral
(7) Faithful
(8) Monochrome
(9) User Defined 13
In Scene Intelligent Auto, [Auto] will be set automatically.
[Standard] is the default setting for [User Def. 13].
A Picture Style file can be registered to User Def. 1/2/3.
Settings (1) Auto (Ambience priority/White priority)
(2) Daylight
(3) Shade
(4) Cloudy*1
(5) Tungsten light
(6) White fluorescent light
(7) Flash
(8) Custom (Custom WB)
(9) Color temperature*2
*1: Effective also in twilight and sunset.
* White balance can be adjusted during movie recording.
Auto White Balance Option between ambience priority and white priority settings, using SET button
White Balance Shift Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Shifted from the color temperatue of the current WB mode.
Blue/amber and magenta/green shift can be set at the same time.
WB Bracketing available, up to ±3 levels Blue/amber or magenta/green, via Quick Control Dial
Type OLED color electronic viewfinder; 0.5-inch, approx. 9.44 million dots
Coverage Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 25mm eyepoint).
Magnification / Angle of View Approx. 0.90x / Approx. 41.4 degrees (with 50mm lens at infinity, -1 m-1)
Eye Point Approx. 25mm (at -1 m-1 from the eyepiece lens end)
Dioptric Adjustment Range Approx. -4.0 to + 2.0 m-1 (dpt)*
*1: Dioptric adjustment lock mechanism
Viewfinder Information (1) Maximum burst
(2) Possible shots/Sec. until self-timer shoots
(3) Focus Bracketing/ Multiple-exposure/HDR shooting/Multi Shot Noise Reduction/Bulb timer/Interval timer
(4) Shooting mode
(5) AF method
(6) AF operation
(7) Image quality
(8) Card
(9) Drive mode
(10) Metering mode
(11) No. of remaining shots for focus braketing, multiple exposures, or interval timer
(12) Electronic level
(13) Movie recording time available
(14) Battery level
(15) Image Stabilizer (IS mode)
(16) Histogram (Brightness/RGB)
(17) Quick Control button
(18) Anti-flicker shooting
(19) White balance/White balance correction
(20) Picture style
(21) Auto Lighting Optimizer
(22) Still photo cropping / Aspect ratio
(23) AF point (1-point AF)
(24) AEB/FEB
(25) View Assist
(26) HDR PQ
(27) Flash ready / FE lock / High-speed sync
(28) Electronic shutter
(29) Touch shutter / Create folder
(30) AE lock
(31) Shutter speed / Multi-function lock warning
(32) Aperture value
(33) Wi-Fi® function
(34) Wi-Fi® signal strength
(35) Bluetooth® function
(36) Exposure simulation
(37) Magnify button
(38) ISO speed
(39) Highlight tone priority
(40) Exposure compensation
(41) Exposure level indicator
Focus Method Dual Pixel CMOS AF
Cross-type AF Supported
* Dual Pixel CMOS AF has been vertical-line detection only with previous models, but the EOS R1 can perform not only vertical-line detection but also horizontal-line detection by rotating the pupil division direction of the Gb pixels of the CMOS sensor by 90 degrees.
* Cross-type AF functions under the conditions indicated by Yes in the table below during still photo shooting (not supported during movie recording).
* Cross-type can be performed in the whole focusing area.
* Cross-type does not function (vertical-line detection only) during movie recording, when using Preview AF, when using Focus guide, when the image flickers under fluorescent lighting, LED lighting, or other flickering light sources, and when operating the SA control ring of RF100mm F2.8 L MACRO IS USM.
Number of AF zones available for Automatic Selection AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%
(100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used)
Stills: Max. 1053 zones (39 x 27)
Movies: Max. 975 zones (39 x25)
Selectable Positions for AF Point AF area: Horizontal: Approx. 90% x Vertical: Approx. 100%
Stills: Max. 4897 positions (83 x 59)
Movies: Max 4067 positions (83 x 49)
Focusing brightness range (still photo shooting) EV 7.5 to 21 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100)
* Except RF lenses with a Defocus Smoothing (DS) coating.
Focusing brightness range (movie recording) 4K 30p: EV 5.5 to 21
Full HD 30p: EV 5.5 to 21
(with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and 29.97 / 25.00 fps.)
Available AF Areas Spot AF
1-point AF
Expand AF area: Above/below/left/right
Expand AF area: Around
Flexible Zone AF 1
Flexible Zone AF 2
Flexible Zone AF 3
Whole area AF
Whole area tracking OFF Spot AF
Whole area tracking OFF 1-point AF
Whole area tracking OFF Expand AF area: Above/below/left/right
Whole area tracking OFF Expand AF area: Around
Available Subject Detection Auto
People
Animals (dogs / cats / birds / horses)
Vehicles (motorsports cars or motorcycles / aircraft / trains)
* Certain types of animals or vehicles may not be detected, depending on shape and appearance
Eye Detection Auto:
Selects the eye closer to the camera (as detected from the angle of the face).
At the same distance from the camera, selects the eye closer to the center of the image.
Right Eye:
Prioritizes the subjects right eye.
Left Eye:
Prioritizes the subjects left eye.
Metering Modes Real-time metering from CMOS image sensor (6144 [96x64] metering zones)
(1) Evaluative metering (AF point-linked)
(2) Partial metering (approx. 5.9% of the area at the center of the screen)
(3) Spot metering (approx. 3.0% of the area at the center of the screen)
(4) Center-weighted average metering
Metering Range EV -3 20 (at 73°F/23°C, ISO 100) (Still Photo Shooting)
Exposure Modes
Shooting Mode Name
Fv Flexible-priority AE
P Program AE
Av Aperture-priority AE
M Manual exposure
Tv Shutter-priority AE
BULB Bulb exposure
C1/C2/C3 Custom shooting
ISO Speed Range Manually Set
Normal ISO 100102400 (in 1/3- or 1-stop increments)
Expanded L (equivalent to ISO 50), H1 (equivalent to ISO 204800) and
H2 (equivalent to ISO 409600)
* When set to [Highlight tone priority], the available manual setting range is ISO 200102400.
* Expanded ISO speeds are not available when [HDR shooting (PQ): HDR PQ] is set.
ISO Auto range settings in still photo shooting
Auto Range ISO Speed
Minimum ISO 10051200 (in 1-stop increments)
Maximum ISO 200102400 (in 1-stop increments)
ISO Auto details in still photo shooting
No Flash Using Flash
Compatible Lens Incompatible Lens
ISO 100*1*2102400*2 ISO 100*1*26400*2 ISO 100*1*21600*2
ISO 400*3 ISO 400*3
*1: ISO 200 when set to [Highlight tone priority: Enable/Enhanced].
*2: Varies depending on the [Maximum] and [Minimum] settings for [Auto range].
*3: If outside the setting range, changed to the value closest to ISO 400.
Exposure Compensation
User-set ±3 stops in 1/3- or 1/2-stop increments
AEB ±3 stops in 1/3- or 1/2-stop increments
AE Lock (1) Auto AE lock
AE is locked as soon as subjects are in focus using One-Shot AF when set to selected metering mode in [C.Fn2: AE lock meter. mode after focus].
(2) User-set AE lock
Use the AE lock button (update by pressing the button again) in Fv, P, Tv, Av, and M mode.
Enabled in all metering modes.
Type Electronically controlled focal-plane shutter
(1) Electronic first curtain
(2) Mechanical shutter
(3) Electronic shutter*
* Cannot be used in conjunction with the following functions: flash photography, HDR shooting, multiple exposures, Multi Shot Noise Reduction, AEB, HDR PQ, anti-flicker shooting, Dual Pixel RAW shooting, Digital Lens Optimizer [High].
* A shutter release sound is not generated. However, note that the sounds other than the shutter release sound (aperture, focusing lens drive sound/electronic sound, etc.) may be generated.
* In electronic shutter shooting, fast shutter speeds of 1/10000 sec. or faster are only available in Tv or M mode (up to 1/8000 sec. in P, Av, or Fv mode).
Shutter Speeds Mechanical / 1st-curtain Electronic shutter:
1/8000th sec 30 seconds, in 1/3 or ½-step increments
Electronic shutter:
1/64000th sec 30 seconds, in 1/3 or ½-step increments (1/16,000th possible, if user-set in Tv or M shooting modes)
X-sync Speed Mechanical Shutter: 1/200 sec.
Elec. 1st-curtain: 1/320 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay, 2-sec. delay, Continuous
Still Photo IS In-body IS operation can be selected when using a non-IS lens.
Always on
Only for shot (no stabilization in viewfinder/LCD screen between shots)
Coordinated IS when used with Canon RF or RF-S lenses having optical Image Stabilization
Accessory Shoe Canon Multi-function accessory shoe
Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories
E-TTL balance Ambience priority, standard, flash priority
Flash Exposure Compensation ±3 stops in 1/3- or 1/2-stop increments
Continuous flash control E-TTL each shot / E-TTL 1st shot
Drive Modes and Continuous Shooting Speed
Drive Modes Operating Modes Mechanical Shutter Electronic 1st curtain Electronic shutter
Single Shooting±3 stops in 1/3- or 1/2-stop increments Yes Yes Yes
High-speed
Continuous
Shooting + *¹
Mode A Approx. 12 shots/sec.*², Approx. 40 shots/sec
Mode B Approx. 9.2 shots/sec.*²
Mode C Approx. 6.6 shots/sec.
High-speed
Continuous
Shooting *¹
Mode A Approx. 5.5 shots/sec.*² Approx. 7.0 shots/sec.*² Approx. 20 shots/sec
Mode B Approx. 5.2 shots/sec.*² Approx. 6.6 shots/sec.*²
Mode C Approx. 3.5 shots/sec. Approx. 4.3 shots/sec.
Low-speed Continuous Shooting Approx. 3.0 shots/sec.*² Approx. 5 shots/sec
Self-timer: 10-sec / remote control Yes
Self-timer: 2-sec / remote control Yes
Self-timer: Continuous Yes
1. Continuous shooting speed is lower under certain shooting and measurement conditions: shutter speed, aperture value subject conditions, brightness, type of lens, timing when internal memory becomes full (temporarily disables shooting)
- Mechanical / electronic 1st curtain: use of flash, anti-flicker shooting: Enable, Dual Pixel RAW shooting- Enable, type of battery, battery level, temperature, use of a battery grip, use of WFT, use of built-in Wi-Fi.
- Electronic shutter: State of aperture in continuous shooting
* With Certain lenses, zooming during continuous shooting with electronic shutter may cause changes in exposure even at the same f/number.
2. Automatically switches among modes A (drive mode icon lit in green), B (drive mode icon lit in white), and C (drive mode icon flashing in white). Operating Mode is for reference only automatically set by camera, is dependent on factors such as battery power level, battery type, and lens in use, and cannot be set by user.
* For flash shooting, values for AE, flash metering, and WB do not change after the first shot.
HDR Shooting (HDR PQ) Disable / Enable
Still Photo HDR PQ
Recording format Bit depth Color sampling method HDR specification
HEIF 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Movie HDR PQ
mp4 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Continuous HDR Shooting (still images) 1 shot only / Every shot
Shooting Times
Resolution and
Frame Rate
Mode Approx. Continuous Shooting Time*1,2,3
4K 59.94p
(without crop)
100% sensor width
(6K oversampling)
40 min. or longer
4K 59.94p (crop) APS-C Crop 50 min. or longer
4K 29.97p
(without crop)
100% sensor width
(6K oversampling)
No limit with heating
Full HD 179.82p 100% sensor width 60 min. or longer
*¹ Time available for continuous shooting in 23°C / 73°F environment, from a cold start. If the camera is in LV mode standby before shooting or the ambient temperature is high, the shooting time may be shorter.
*² According to Canon measurement conditions when using UHS-II cards conforming to Canon testing standards.
*³ The maximum duration of shooting may be shorter under some circumstances even if recording begins from "cold start," due to a rise in temperature inside the camera caused by pre-shooting camera setting operations or by prolonged use of the Live View mode. When the card is full, movie recording stops automatically. In this case, duration time when you erase the data and restart shooting.
File Format Normal Movies
Canon Log OFF ON (Canon Log 3)
HDR PQ OFF ON OFF
Container format MP4
Bit depth 8 bit 10 bit
Compression H.264 / MPEG-4 AVC H.265 / HEVC
Video signal recording
range
Full range (0-255) Full range (0-1023) Full range (128-1020)
Color sampling method YCbCr 4:2:0 YCbCr 4:2:2
Standards compliance Rec.ITU-R BT.709 Rec. ITU-R BT.2100
Color gamut Rec.709 Rec.2020 Rec.709 / Rec.2020 / Cinema Gamut
Audio IPB
(Standard)*
AAC / Linear PCM
IPB (Light) AAC
* Recording in AAC when [Audio compression] (C.Fn4) is set to [Enable] or Linear PCM when set to [Disable].
Estimated Recording time, Movie Bit Rate and File Size RAW, 4K-DCI Fine / 4K-UHD Fine
Recording format compression method/RAW type Frame Rate (fps) Total Recording Time (approx.) Video bit rate/(approx.Mbps) File Size (approx. MB/min.)
64 GB 256 GB 1 TB
RAW1 Standard
RAW
59.94 3 min. 13 min. 51 min. 2600 18631
50.00 3 min. 13 min. 51 min. 2600 18631
29.97 4 min. 17 min. 1 hr. 6 min. 2600 14339
25.00 5 min. 20 min. 1 hr. 19 min. 1670 11979
24.00 5 min. 21 min. 1 hr. 23 min. 1600 11478
23.98
Light
RAW
59.94 4 min. 18 min. 1 hr. 13 min. 1800 12909
50.00 5 min. 22 min. 1 hr. 28 min. 1500 10763
29.97 9 min. 37 min. 2 hr. 27 min. 900 6472
25.00 11 min. 45 min. 2 hr. 56 min. 750 5399
24.00 11 min. 47 min. 3 hr. 3 min. 720 5399
23.98
XF-HEVC S
YCC422
10-bit
Standard LGOP 59.94 37 min. 2 hr. 31 min. 9 hr. 51 min. 225 1612
50.00
29.97 1 hr. 3 min. 4 hr. 12 min. 16 hr. 25 min. 135 968
25.00
24.00
23.98
XF-HEVC S
YCC420
10-bit
Standard LGOP 59.94 56 min. 3 hr. 47 min. 14 hr. 47 min. 150 1075
50.00
29.97 1 hr. 25 min. 5 hr. 40 min. 22 hr. 9 min. 100 718
25.00
24.00
23.98
XF-HEVC S
YCC420
8-bit
50.00
25.00
24.00
23.98
1. Requires CFexpress 2.0 Type-B [400MB/sec. or more]
* Video bit rate indicates video only; audio and metadata are not included.
* When [Audio format: AAC / 16bit / 2CH] is set (when set to RAW, LPCM / 24bit / 4CH).
* When [Add News Metadata: Off] is set.
* Movie recording stops when the maximum recording time per movie is reached.
* When set to 4K-UHD, 24.00 fps is not available.
Estimated Recording Time, Continued. H.265/HEVC (Canon Log: On or HDR PQ: On)
64 GB 256 GB 1 TB
XF-AVC S
YCC422
10-bit
High
quality Intra
59.941 7 min. 28 min. 1 hr. 51 min. 1200 8585
50.001 8 min. 34 min. 2 hr. 13 min. 1000 7155
29.97 14 min. 56 min. 3 hr. 42 min. 600 4294
25.00 17 min. 1 hr. 8 min. 4 hr. 26 min. 500 3579
24.00 17 min. 1 hr. 11 min. 4 hr. 37 min. 480 3436
23.98
Standard
Intra
59.941 9 min. 37 min. 2 hr. 28 min. 900 6440
50.00 11 min. 45 min. 2 hr. 57 min. 750 5367
29.97 18 min. 1 hr. 15 min. 4 hr. 56 min. 450 3221
25.00 22 min. 1 hr. 30 min. 5 hr. 55 min. 375 2685
24.00 23 min. 1 hr. 34 min. 6 hr. 10 min. 360 2577
23.98
Light Intra 59.94 14 min. 56 min. 3 hr. 42 min. 600 4294
50.00 17 min. 1 hr. 8 min. 4 hr. 26 min. 500 3579
29.97 28 min. 1 hr. 53 min. 7 hr. 24 min. 300 2148
25.00 34 min. 2 hr. 16 min. 8 hr. 52 min. 250 1791
24.00 35 min. 2 hr. 22 min. 9 hr. 14 min. 240 1719
23.98
Standard LGOP 59.94 34 min. 2 hr. 16 min. 8 hr. 52 min. 250 1791
50.00
29.97 56 min. 3 hr. 47 min. 14 hr. 47 min. 150 1075
25.00
24.00
23.98
* When [Audio format: AAC / 16bit / 2CH] is set.
Card Performance Requirements 4K-DCI Normal / 4K-UHD Normal
64 GB 256 GB 1 TB
XF-HEVC S
YCC422
10-bit
Standard LGOP 119.88 18 min. 1 hr. 15 min. 4 hr. 56 min. 450 3221
100.00
50.00
25.00
24.00
23.98
XF-HEVC S
YCC420
10-bit
Standard LGOP 119.88 28 min. 1 hr. 53 min. 7 hr. 24 min. 300 2148
100.00
50.00
25.00
24.00
23.98
XF-HEVC S
YCC420
8-bit
100.00
50.00
25.00
24.00
23.98
Video AF Dual Pixel CMOS AF; Movie Servo AF available in AF Menu
Time Code Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable)
Movie Pre-recording (On/Off) 3 or 5 seconds; user-selectable
Time-lapse Movie Setting Interval 2 sec 99:59:59; Number of frames 23,600; Movie recording size 4K/Full HD; Auto exposure fixed @ first frame/auto for each frame; Beep per frame recorded (volume setting 0/silent 5)
Time-lapse Playback Frame Rate 29.97 (set to NTSC); 25.00fps (set to PAL)
Type TFT color, liquid-crystal monitor
Monitor Size 3.0-inch (screen aspect ratio of 3:2)
2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
Dots Approx. 2.1 million dots
Coverage Approx. 100% vertically/horizontally
Brightness Control Manually adjustable to one of seven brightness levels
Touch-screen Operation Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified view
Coating Clear View LCD II
Anti-smudge coating applied.
Anti-reflection coating not applied.
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format
Item Still Photo Movie
Magnify zoom display 1.5x10x (15 levels) -
AF point display Yes -
Grid display Off / 3×3 / 6×4 / 3×3+diag -
Zebra display - Yes
False Color display - Yes
Rating OFF / 1 to 5 Stars
Select images / Select range / All images in folder / All images on card / All
found images
Image Search Search conditions
Rating / Date / Folder / Protection / Type of file
Protect Select images / Select range / All images in folder / Unprotect all images in
folder / All images on card / Unprotect all images on card / All found images
Shooting information display No information display / Basic information display / Detailed shooting
information display
Highlight Alert White areas without image data blink in single-image display.
Histogram Brightness / RGB
Function The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback.
Quick Control Screen The following settings are available for the [Quick Control screen] during movie recording.
View 1: Conventional Quick Control screen
View 2: Cinema EOS-style Quick Control screen
Protection (1) Single image (select image)
(2) Select range
(3) All images in a folder
(4) All images on card
Image browsing and image search can be based on ratings.
Ratings-based image selections also possible with DPP.
(5) All found images (only during image search)
Erase Except protected images
(1) Select images to erase
(2) Select range
(3) All images in folder
Compatible Printers Direct printing from camera not supported
DPOF Compliant to DPOF Version 1.1
Standards Compliance IEEE 802.11b/g/n/a/ac/ax
Transmission Method DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n/a/ac/ax)
OFDMA modulation (IEEE 802.11ax)
Transition Frequency (Central Frequency) 2.4 GHz band
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 channels
5.0 GHz band
Frequency: 5180 to 5825 MHz
Channels: 36 to 165 channels
6.0 GHz band
Frequency: 5955 to 7095 MHz
Channels: 1 to 229 channels
Connection Method (1) Camera access point mode
(2) Infrastructure mode
Security 2.4 GHz band / 5 GHz band
Connection Method Authentication Encryption
Encryption Key Format and Length
Camera Access Point WPA2 / WPA3-Personal AES ASCII 8 characters
Open Disable
Infrastructure Open Disable
Enhanced open AES ASCII 8 characters
WPA / WPA2 / WPA3-Personal AES 1127 characters
WPA / WPA2 / WPA3-Enterprise AES
WPA3-Enterprise 192 bit AES
6 GHz band
Infrastructure Enhanced open AES
WPA3-Enterprise AES
Communication with a Smartphone Images can be viewed, controlled, and received using a smartphone.
Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications.
Images can be sent to a smartphone.
NFC connection: Not supported
Supported images: JPEG, HEIF, RAW/C-RAW, MP4 video files
Transcoding while sending: Size to send (original / reduced size); Quality to send (original / compressed)
Remote Operation Using EOS Utility The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer.
Print from Wi-Fi® Printers Not supported.
Send Images to a Web Service image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers.From image.canon, images can be sent to specific social media and 3rd-party cloud image services.
Standards Compliance Bluetooth Specification Version 5.3 compliant (Bluetooth Low Energy technology)
Transmission Method GFSK modulation
Bluetooth Pairing Smartphone up to 25 devices; BR-E1 remote controller 1 unit
Available Functions Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials
USB Video Class (UVC) Available
* The camera is accessible to software (such as Zoom, MS Teams, Skype, etc.) on a computer once connected via USB.
Customizable Dials Main dial
Quick control dial 1 & 2
Lens Control ring
My Menu Registration Up to six top-tier menu items and Custom Functions can be registered.
Up to five My Menu tabs can be added.
My Menu tab overall operations Adding a tab
Deleting tabs in a batch
Deleting all tab items
Setting the menu display
My Menu tab detailed operations Selecting a registered item
Sorting registered items
Deleting selected registered items
Deleting registered items in a batch
Deleting tabs
Changing a tab name (16 ASCII characters)
USB Terminal Equivalent to SuperSpeed Plus USB (USB 3.2 Gen 2)
For PC communication; video calls/streaming
Terminal type: USB Type-C
Shared with terminal for in-camera charging with USB Power Adapter PD-E1.
HDMI Out Terminal HDMI output terminal (Type A)
HDMI CEC not supported
Images may not be displayed unless [For NTSC] or [For PAL] is set correctly
for the TV video system.
Clean HDMI Output Provided
Microphone terminal 3.5mm diameter stereo mini jack
Headphone terminal Compatible with 3.5mm diameter stereo mini-plug
Battery LP-E19
* LP-E4N / LP-E4 cannot be used. Unauthenticated batteries can also be used,but safety cannot be guaranteed.
Optional Battery Grip Not supported
Battery Check Automatic battery check with 6-level display when the power switch is turned ON.
Displayed in 6 levels in viewfinder, and on LCD screen.
Battery info display in Set-up Menu:
Remaining capacity percentage
Shutter count, on current battery charge
Recharge performance (battery's ability to hold charge; displayed in 3 levels)
Start-up Time Approx. 0.4 sec.
Based on CIPA testing standards.
Dimensions (W x H x D) Approx. 6.2 x 5.89 x 3.44 in. / 157.6 x 149.5 x 87.3mm
Based on CIPA standards.
Weight Approx. 2.5 lbs. / 1115g (including battery and memory card)
Approx. 2.0 lbs. / 920g (body only; without battery, card or body cap)
Working Temperature Range 32113°F / 045°C
Working Humidity Range 85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Firmware Notice: EOS R1: Firmware Version 1.0.1
Advisory Type Firmware Notice
Date 12.05.24
Title Service Notice: EOS Webcam Utility Pro v2.3
Advisory Type Service Notice
Date 11.13.24
Title Firmware Notice: EOS R1: Firmware Version 1.0.2
Date 03.18.25
Title Firmware Notice: EOS R1: Firmware Version 1.1.2
Date 07.24.25
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
