Canon Support for EOS R50 V | Canon U.S.A., Inc.
EOS R50 V
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 05.07.25
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type Digital interchangeable lens mirrorless camera
Image Processor DIGIC X
Recording Media (One) SD card slot
Compatible with UHS-II/UHS-I/UHS speed class/SD speed class
Eye-Fi cards and Multimedia cards (MMC) are not supported.
Compatible Lenses Canon RF lenses (including RF-S lenses)
Canon RF-S3.9mm F3.5 STM Dual Fisheye lens and RF-S7.8mm F4 STM Dual lens
* When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount Canon RF mount
Type APS-C CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective Pixels Approx. 24.0 megapixels
Aspect Ratio 3:2 (Horizontal: Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Installed in front of the image sensor, non-detachable
Dust Deletion Feature Self Cleaning Sensor Unit not provided.
Manual cleaning (by hand) not supported.
Dust Delete Data acquisition and appending
The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
Not available during focus bracket shooting.
Recording Format Compliant to Design rule for Camera File system 2.0 and Exif 2.31*
*Supports time offset information
Image Format JPEG (.JPG), HEIF (.HIF), RAW, C-RAW (.CR3)
Movies: XF-HEVC S YCC422 10 bit
XF-HEVC S YCC420 10 bit
XF-AVC S YCC422 10 bit
XF-AVC S YCC420 8 bit
*1: When a movie is recorded with [Add CP file: On] set when [Custom Picture] is active, a .CPF file will be created.
Still image resolution RAW, C-RAW -- 24.0 MP (6000 x 4000)
Large (L) -- 24.0 MP (6000 x 4000)
Medium (M) -- Approx. 10.6 MP (3984 x 2656)
S1 -- Approx. 5.9 MP (2976 x 1984)
S2 -- Approx. 3.8 MP (2400 x 1600)
File Size
Quality
File Size
[Approx. MB]
Available Shots
[Approx.]*1
JPEG*2 L (fine) 8.7 14040
L (Normal) 4.6 26460
M (fine) 4.7 25740
M (Normal) 2.6 45600
S1 (Fine) 3.1 39020
S1 (Normal) 1.8 64490
S2 1.8 65020
HEIF*3 L (fine) 9.0 13470
L (Normal) 6.8 17550
M (fine) 5.2 22540
M (Normal) 4.1 28670
S1 (Fine) 3.5 32870
S1 (Normal) 2.9 40400
S2 1.9 56440
RAW*2 RAW 27.0 4570
C-RAW 14.0 8920
RAW+JPEG*2 RAW + L (fine) 27.0 + 8.7 3440
C-RAW + L (fine) 14.0 + 8.7 5450
RAW+HEIF*3 RAW + L (fine) 29.9 + 9.0 3140
C-RAW + L (fine) 16.9 + 9.0 4730
*1: Number of shots using a 128 GB card that conforms to Canon testing standards.
*2: With HDR PQ disabled
*3: With HDR PQ enabled
* File sizes are determined based on Canon testing standards.
* FIle size varies by shooting conditions (such as aspect ratio, subject, ISO speed, Picture Style, and Custom Functions.
Maximum Burst
Quality
Electronic 1st-curtain
(Approx. 12 shots/sec.)
Electronic shutter
(Approx. 15 shots/sec.)
JPEG*2 L (fine) 140 95
M (fine) 140 95
S1 (Fine) 140 95
S2 140 95
HEIF*3 L (fine) 130 91
M (fine) 130 91
S1 (Fine) 130 91
S2 130 91
RAW*2 RAW 59 36
C-RAW 120 79
RAW+JPEG*2 RAW + L (fine) 36 27
C-RAW + L (fine) 110 66
RAW+HEIF*3 RAW + L (fine) 23 22
C-RAW + L (fine) 49 47
*1: Number of shots using a 128 GB UHS-II card that conforms to Canon testing standards.
* Maximum burst as measured under conditions conforming to Canon testing standards (One- Shot AF mode, High-speed continuous shooting +, ISO 100, Standard Picture Style, and Room temperature: 23°C / 73°F).
File size varies by shooting conditions (such as still photo aspect ratio, subject, ISO speed, Picture Style, and Custom Functions). Number of shots available and maximum burst varies depending on shooting conditions (including still photo aspect ratio, subject, memory card brand, ISO speed, Picture Style, and Custom Functions)
File Numbering The following file numbers can be set:
1. File numbering methods
a. Continuous numbering
i. The numbering of captured images continues even after you replace the card.
b. Auto reset
i. When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
2. Manual reset
a. Resets the file number to 0001, and creates a new folder automatically.
* When manually resetting the file number, folders can also be renamed.
RAW + JPEG / HEIF Simultaneous Recording Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported.
Color Space (sill images) sRGB
(HDR PQ images BT.2020)
Picture Style (Set via Color Mode menu or Color Mode button)
(1) Auto
(2) Standard
(3) Portrait
(4) Landscape
(5) Fine Detail
(6) Neutral
(7) Faithful
(8) Monochrome
(9) User Defined 13
* Picture Style files can be registered to user-defined settings 13.
Settings (1) Auto (Ambience priority/White priority)
(2) Daylight
(3) Shade
(4) Cloudy*1
(5) Tungsten light
(6) White fluorescent light
(7) Flash*2
(8) Manual
(9) Color temperature 1
(10) Color temperature 2 Approx. 2500K-10000K*
(11) Color temperature 2 Set in 100K increments
(12) Color temperature 4
*1: Effective also in twilight and sunset.
*2: With an EX / EL-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000 K if the flash unit does not have the color temperature communication feature.
* Can also be changed during movie recording when Creative (Movie) Zone is set.
* Color temperature 14 can be switched with [Customize buttons for shooting: Switch color temperature]
Auto White Balance Option between ambience priority and white priority settings, using SET button
White Balance Shift Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Shifted from the color temperatue of the current WB mode.
Blue/amber and magenta/green shift can be set at the same time.
(WB Bracketing not supported)
Focus Method Dual Pixel CMOS AF
Number of AF zones available for Automatic Selection AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%
(100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used)
Stills: Max. 651 zones (31 x 21)
Movies: Max. 527 zones (31 x17)
Selectable Positions for AF Point AF area: Horizontal: Approx. 90% x Vertical: Approx. 100%
Stills: Max. 4503 positions (79 x 57)
Movies: Max 3713 positions (79 x 47)
Focusing brightness range (still photo shooting) EV -5.0 to 20 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100)
* Except RF lenses with a Defocus Smoothing (DS) coating.
Focusing brightness range (movie recording) EV -2.5 to 20 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and 29.97 / 25.00 fps.)
Available AF Areas (still images and movies) Spot AF
1-point AF
Expand AF area: Above/below/left/right
Expand AF area: Around
Flexible Zone AF 1
Flexible Zone AF 2
Flexible Zone AF 3
Whole area AF
Available Subject Detection (still images and movies) Auto
People
Animals (dogs / cats / birds/ horses)
Vehicles (motorsports cars / motorcycles / airplanes / trains)
* Certain types of animals or vehicles may not be detected, depending on shape and appearance
Eye Detection Auto:
Selects the eye closer to the camera (as detected from the angle of the face).
At the same distance from the camera, selects the eye closer to the center of the AF area.
Left/right eye detection: Supported (refers to subject's left/right eye)
Available Functions Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials
Customize Buttons Customizable Dials/Control Ring
Item Details Still Photos Movie
Customize buttons for shooting Change assignment of
functions to camera controls
Depends on setting
Shutter button function for movies Half Press   Yes
Full Press
Customize dials / control ring Change assignment of
Depends on setting
Touch Shutter Disable / Enable Yes
Multi-function lock Mail Dial Yes Yes
Control Dial
Touch Control
Control Ring
Focus Ring / Control Ring Use as focus ring /
Use as control ring
Yes Yes
Camera / Remote optical zoom speed Standby Yes Yes
Recording Yes
Lens optical zoom speed Standby Yes Yes
Recording Yes
My Menu Registration Up to six top-tier menu items and Custom Functions can be registered.
Up to five My Menu tabs can be added.
My Menu tab overall operations Adding a tab
Deleting tabs in a batch
Deleting all tab items
Setting the menu display
My Menu tab detailed operations Selecting a registered item
Sorting registered items
Deleting selected registered items
Deleting registered items in a batch
Deleting tabs
Rename tab (16 ASCII characters)
Metering Modes Real-time metering from CMOS image sensor (384 [24x16] metering zones)
(1) Evaluative metering (AF point-linked)
(2) Partial metering (approx. 5.8% of the area at the center of the screen)
(3) Spot metering (approx. 2.9% of the area at the center of the screen)
(4) Center-weighted average metering
* Movie recording: Evaluative metering only
Metering Range Still Photo Shooting: EV -5 to 20
Movie Recording: EV -2.5 to 20 (4K) / EV -3.0 to 20 (Full HD)
Exposure Modes Still photo shooting:
Full Auto (A+), P, Tv, Av, M
Self-portrait, Portrait, Smooth skin, Panoramic shot, Food, Handheld Night Scene
Movie recording:
Movie auto exposure, Shutter-priority (Tv), Aperture-priority (Av), Movie Manual exposure
ISO Speed Range Manually Set
Normal ISO 10032000 (in 1/3- or 1-stop increments)
Expanded H: (equivalent to ISO 51200)
When set to [Highlight tone priority], the available manual setting range is ISO 20032000.
Expanded ISO speeds cannot be set in HDR mode or for HDR shooting (HDR PQ).
ISO Auto setting range for still photo shooting: User-set Auto ISO maximum: 400 32000
ISO Auto details for still photo shooting
Shooting mode No Flash Using Flash
Compatible Lens Incompatible Lens
Creative Zone P / Tv / Av /
M (other than bulb)
ISO 100*1*232000*2 ISO 1006400*2 ISO 100*1*21600*2
M (bulb) ISO 400*3 ISO 400*3
Basic Zone Scene Intelligent Auto / Hybrid Auto ISO 1006400 ISO 1006400 ISO 1003200*4
Special Scene Varies by shooting mode
Creative Filters Varies by shooting mode
*1: ISO 200 minimum when set to [Highlight tone priority: Enable/Enhanced].
*2: Varies depending on the [Max for Auto] settings.
*3: If outside the setting range, changed to the value closest to ISO 400.
*4: When using the built-in flash. ISO 1600 when using an external flash unit.
Exposure Compensation
User-set ±3 stops (in 1/3-stop increments)
AEB ±3 stops (in 1/3-stop increments)
AE Lock (1) Automatic AE lock
In One-Shot AF mode, AE is locked as soon as subjects are in focus.
(2) User-applied AE lock
By using the AE Lock button in P, Tv, Av, and M mode.
Toggling: Press again to cancel and once more to refresh.
Enabled in all metering modes.
Type Electronically controlled focal-plane shutter.
Rolling shutter, using the image sensor.
(1) Electronic first curtain
(2) Electronic shutter
* When set to [Electronic], the camera makes no mechanical shutter sound. (An electronic shutter sound can be configured in [Beep] and [Volume: Shutter volume]). Note that the camera may make sounds other than the shutter release sound, such as sounds for aperture adjustment or the lens focus drive, or beeps. Moreover, using long exposure noise reduction with shutter speeds of 1 sec. or longer involves a mechanical second-curtain shutter, which produces a mechanical sound.
* Bands of light may be displayed and captured images may be affected by light and dark banding when shooting under fluorescent lighting or other flickering light sources with the camera set to [Anti-flicker shoot.: Disable].
Shutter Speeds Electronic 1st-curtain shutter:
1/4000th sec 30 seconds, in 1/3-step increments
Electronic shutter:
1/8000th sec 30 seconds, in 1/3-step increments
X-sync Speed Elec. 1st-curtain: 1/250 sec. (flash not possible with Electronic shutter)
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay, 2-sec. delay, Continuous
Still Photo IS In-body IS not provided.
(lens optical Image Stabilization supported)
E-TTL flash metering Evaluative (Face Priority) / Evaluative / Average
Accessory Shoe Canon Multi-function accessory shoe
Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories
No traditional flash contacts on accessory shoe
E-TTL balance Ambience priority, standard, flash priority
Flash Exposure Compensation ±3 stops (in 1/3-stop increments)
Continuous flash control E-TTL each shot / E-TTL 1st shot
Drive Modes and Continuous Shooting Speed (all maximum Drive speeds approximate)
Drive Modes Operating Modes Electronic 1st curtain Electronic shutter
Single Shooting Yes Yes
High-speed
Continuous
Shooting +
One-Shot AF / Servo AF 12 shots/sec.*1*2 15 shots/sec.*2
High-speed
Continuous
Shooting
One-Shot AF / Servo AF 7.6 shots/sec.*2 15 shots/sec.*2
Low-speed
Continuous Shooting
One-Shot AF / Servo AF 3.0 shots/sec. 5.0 shots/sec.
Self-timer 10 sec. Yes Yes
2 sec. Yes Yes
Continuous shooting Yes Yes
*1: AE, flash metering, and WB do not change after the first shot in flash photography.
*2: Slower maximum continuous shooting speed when set to Servo AF with lenses other than those in the lens list attached. For details on lenses that support the indicated continuous shooting speed, refer to the separate lens list.
* With electronic first-curtain, maximum continuous shooting speed is (or may be) reduced in flash photography or anti-flicker shooting.
* With certain lenses, zooming during continuous shooting with electronic shutter may cause changes in exposure even at the same f/number. Refer to the separate lens list for the applicable lenses. (Note that even with a zoom lens that is not listed in the list may result in exposure changes or flickering if sudden zooming is performed.)
Still-image HDR shooting HDR PQ (HEIF images)
HDR mode (final image composited from three initial images)
HDR PQ and HDR can be combined
Disable / Enable
* Can be used in conjunction with Auto Lighting Optimizer.
Still Photo HDR PQ
Recording format Bit depth Color sampling method HDR specification
HEIF 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Movie HDR PQ According to setting of movie recording format
* Cannot be set for XF-AVC S YCC420 8 bit
Continuous HDR Shooting (still images) 1 shot only / Every shot (HDR mode shooting only)
Video resolution 4K (UHD only; 3840 x 2160 (16:9) oversampled from 6K recording
4K Crop (3840 x 2160; not oversampled)
Full HD (1920 x 1080)
RAW video recording Not Available
Video compression LongGOP (equivalent to IPB); Intra (= All-I) for Time Lapse video recording
Video Gamma, Color Space options (in CP/Custom Picture menu) Canon 709
Canon Log 3
PQ (HDR PQ; BT.2020
HLG (BT.2020)
BT.709 Standard
Vertical video recording Available (video shooting info display can be rotated, for shooting & playback)
Vertical tripod socket on grip side of camera
Auto Level display available during video recording
Audio recording Built-in microphone; separate Left & Right Stereo inputs
Noise detection microphone (for AF focus drive noise, white/floor noise)
16-bit/2 CH or 24-bit/4 CH recording possible (2 channel for built-in mic)
48 kHz sampling frequency
3.5mm stereo mini-jack (3-pin) for external mics
Digital mic input at Multi-function Shoe (Canon DM-E1D Stereo MIcrophone, etc.)
Auto or Manual sound recording levels (64 manual levels available)
3.5mm Headphone terminal (stereo mini-jack)
File Format Normal Movies
HDR PQ Off On
Container format MP4
Bit depth 8 bit 10 bit
Compression H.264 / MPEG-4 AVC H.265 / HEVC
Video signal recording
range
Full range (0-255) Full range (0-1023)
Color sampling method YCbCr 4:2:0 YCbCr 4:2:2
Standards compliance Rec. ITU-R BT.709 Rec. ITU-R BT.2100
Color gamut Rec.709 Rec.2020
Audio AAC 48 kHz / 16 bit / 2CH
* 4 channel input: Not supported
Estimated Recording time, Movie Bit Rate and File Size for 4K (Up to 29.97)
Movie Recording Size Total Recording Time (approx.) Bit Rate /
File Size
(approx.)
Card
Performance requirements
Movie
Recording
Frame Rate Compression
method
64 GB 128 GB 512 GB
XF-HEVC S
YCC422 10 bit
29.97 fps
25.00 fps
23.98 fps
Standard
LGOP
1 hr. 3 min. 2 hr. 6 min. 8 hr. 24 min. 135 Mbps
968 MB/min.
UHS Speed Class 3 or higher
XF-HEVC S
YCC420 10 bit
29.97 fps
25.00 fps
23.98 fps
Standard
LGOP
1 hr. 25 min. 2 hr. 50 min. 11 hr. 20 min. 100 Mbps
718 MB/min.
XF-AVC S
YCC422 10 bit
29.97 fps
25.00 fps
23.98 fps
Standard
LGOP
56 min. 1 hr. 53 min. 7 hr. 34 min. 150 Mbps
1075 MB/min.
XF-AVC S
YCC420 8 bit
29.97 fps
25.00 fps
23.98 fps
Standard
LGOP
718 MB/min.
* Video bit rate indicates video only; audio and metadata are not included.
* When [Audio format: AAC / 16bit / 2CH] is set.
* Movie recording stops when the maximum recording time per movie is reached.
Estimated Recording time, Movie Bit Rate and File Size for 4K Crop (50.00/59.94 fps)
File Size
(approx.)
Card
Movie
Recording
method
64 GB 128 GB 512 GB
XF-HEVC S
YCC422 10 bit
59.94 fps
50.00 fps
Standard
LGOP
37 min. 1 hr. 15 min. 5 hr. 3 min. 225 Mbps
1612 MB/min.
Video Speed Class V60 or higher
XF-HEVC S
YCC420 10 bit
59.94 fps
50.00 fps
Standard
LGOP
1075 MB/min.
XF-AVC S
YCC422 10 bit
59.94 fps
50.00 fps
Standard
LGOP
34 min. 1 hr. 8 min. 4 hr. 32 min. 250 Mbps
1791 MB/min.
XF-AVC S
YCC420 8 bit
59.94 fps
50.00 fps
Standard
LGOP
1075 MB/min.
Estimated Recording time, Movie Bit Rate and File Size for Full HD
File Size
(approx.)
Card
Movie
Recording
method
64 GB 128 GB 512 GB
XF-HEVC S
YCC422 10 bit
119.88 fps
100.00 fps
Standard
LGOP
718 MB/min.
59.94 fps
50.00 fps
29.97 fps
25.00 fps
23.98 fps
2 hr. 49 min. 5 hr. 39 min. 22 hr. 38 min. 50 Mbps
360 MB/min.
SD Speed Class 10 or higher
XF-HEVC S
YCC420 10 bit
119.88 fps
100.00 fps
Standard
LGOP
2 hr. 1 min. 4 hr. 2 min. 16 hr. 11 min. 70 Mbps
503 MB/min.
59.94 fps
50.00 fps
29.97 fps
25.00 fps
23.98 fps
4 hr. 2 min. 8 hr. 4 min. 32 hr. 15 min. 35 Mbps
253 MB/min.
SD Speed Class 6 or higher
XF-AVC S c
YCC422 10 bit
119.88 fps
100.00 fps
Standard
LGOP
718 MB/min.
59.94 fps
50.00 fps
29.97 fps
25.00 fps
23.98 fps
2hr. 49 min. 5 hr. 39 min. 22 hr. 38 min. 50 Mbps
360 MB/min.
XF-AVC S
YCC420 8 bit
119.88 fps
100.00 fps
Standard
LGOP
2 hr. 1min. 4 hr. 2 min. 16 hr. 11 min. 70 Mbps
503 MB/min.
59.94 fps
50.00 fps
29.97 fps
25.00 fps
23.98 fps
253 MB/min.
Video AF One Shot AF; Movie Servo AF available in AF Menu
Time Code Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable)
Movie Pre-recording Not supported
Special frame rates High Frame Rate recording (FHD only) up to 119.98 fps
S & F (Slow & Fast recording mode): 120p, 60p, 30p, 12p, 6p, 3p
User-selectable playback speed: 23.98p, 29.97p, or 59.94p
Full HD only
Audio not recorded
Time-lapse Movie Setting
  Interval*1 No. of shots Time required (max.)
Scene 1 24 sec. 30900*2 Approx. 1 hr.
Scene 2 510 sec. 30720*2
Approx.
Approx. 2 hr.
Scene 3 1130 sec. 30240*2 Approx. 2 hr.
Custom 2 sec. to 60 min. 23600*3 Approx. 150 days
*1: Can be set in 1-sec. increments.
*2: Can be set in 30-shot increments.
*3: Can be set in 1-shot increments.
Time-lapse Playback Frame Rate 29.97 (set to NTSC); 25.00fps (set to PAL)
Type TFT color, liquid-crystal monitor
Monitor Size 3.0-inch (screen aspect ratio of 3:2)
2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
Dots Approx. 1.04 million dots
Coverage Approx. 100% vertically/horizontally
Brightness Control Manually adjustable to one of seven brightness levels
Touch-screen Operation Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified View; Volume Touch Sounds: 0 (silent) to 5
Coating Anti-smudge coating not provided.
Anti-reflection coating not provided.
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format
Item Still Photo Movie
Magnify zoom display 1.5×10× (15 levels)
Electronic Level Size Large/Small Large/Small
Card Free (%) Display Off / On
Grid display Off / 3×3 / 6×4 / 3×3+diag
Zebra display   Yes
False Color display   Supported (six colors based on brightness level)
Rating OFF / 1 to 5 Stars
Select images / Select range / All images in folder / All images on card / All
found images
Image Search Search conditions
Rating / Date / Folder / Protection / Type of file
Protect Select images / Select range / All images in folder / Unprotect all images in
folder / All images on card / Unprotect all images on card / All found images
Shooting information display No information display / Basic information display / Detailed shooting
information display
Highlight Alert Blinking highlights during single image with info playback only
cannot be user-enabled or disabled
Histogram Brightness / RGB
Waveform monitor Not available
Function The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback.
Quick Control Screen The following settings can be set in the [Quick Ctrl screen] menu during movie recording.
Three options during video recording:
Q1; Q2; Q3
Display position selectable in Q1
User-selectable in red Shooting Menu* When [Q]1 is set, [Lock disp. position: Enable/Disable], [Disp. position: Align right/Align left], and [Vertical position: Align top/Align bottom] in [Quick Ctrl disp position] are settable.
Protection (1) Single image (select image)
(2) Select range
(3) All images in a folder
(4) All images on card
Image browsing and image search can be based on ratings.
Ratings-based image selections also possible with DPP.
(5) All found images (only during image search)
Erase Except protected images
(1) Select images to erase
(2) Select range
(3) All images in folder
Compatible Printers Not compatible with Direct printing / Pictbridge
DPOF Compliant to DPOF Version 1.1
Supporting Standards Equivalent to IEEE 802.11b/g/n/a/ac Standards
Transmission Method DS-SS modulation (IEEE 802.11b)
OFDM modulation - CSMA / CA (IEEE 802.11g/n/a/ac)
Transition Frequency (Central Frequency) 2.4 GHz band
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 channels
5.0 GHz band
Frequency: 5180 to 5825 MHz
Channels: 36 to 165 channels
Connection Method (1) Camera access point mode
(2) Infrastructure mode
Security
Connection Method Authentication Encryption
Encryption Key Format and Length
Camera Access Point WPA2 / WPA3-Personal AES ASCII 8 characters
Open Disable
Infrastructure Open WEP Hexadecimal 10 digits
Hexadecimal 26 digits
ASCII 5 characters
ASCII 13 characters
Disable
Shared key WEP Same as WEP above
WPA / WPA2 / WPA3-Personal TKIP
AES
1127 characters
Communication with a Smartphone Images can be viewed, controlled, and received using a smartphone.
Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications.
Images can be sent to a smartphone.
NFC connection: Not supported
Supported images: JPEG, HEIF, RAW/C-RAW, MP4 video files
Transcoding while sending: Size to send (original / reduced size); Quality to send (original / compressed)
Remote Operation Using EOS Utility The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer.
Print from Wi-Fi® Printers Supported
Send Images to a Web Service image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers.
From image.canon, images can be sent to specific social media and 3rd-party cloud image services.
Standards Compliance Bluetooth Specification Version 4.2 compliant (Bluetooth Low Energy technology)
Transmission Method GFSK modulation
Bluetooth Pairing Smartphone up to 10 devices; BR-E1 remote controller 1 unit
USB Video Class (UVC) Available
* The camera is accessible to software (such as Zoom, MS Teams, Skype, etc.) on a computer once connected via USB
Live Switcher Mobile streaming Available.
* Connect devices (smartphone) to multiple cameras via Wi-Fi, the actual video to be streamed can be selected/switched using the app while streaming. Streaming is possible with YouTube, Facebook, etc.
HDMI Streaming Available.
* Connect devices (PC, external screen, video switcher) and the camera with an HDMI cable. Using apps such as OBS Studio, streaming is possible with Teams, Skype, YouTube, Facebook, etc.
Camera Connect streaming Available.
* Connect devices (smartphone) and the camera with Bluetooth, set up streaming, then stream via Wi-Fi. Streaming is possible with YouTube, Facebook, Twitch, etc.
USB Terminal Equivalent to Super-Speed Plus USB (USB 3.2 Gen 2)
For PC communication / smartphone communication (Live streaming not possible through USB)
Terminal type: USB Type-C
Shared with terminal for in-camera charging with USB Power Adapter PD-E1.
HDMI Out Terminal HDMI micro OUT terminal (Type D)
* HDMI CEC not supported
* Images not displayed unless [For NTSC] or [For PAL] is set correctly for the TV video system
Clean HDMI Output Provided
Microphone terminal 3-Pin Microhpone IN
Headphone terminal 3.5mm diameter stereo mini-plug
Remote Control terminal Canon E3 type (single pin socket)
Battery Canon LP-E17 battery pack
Battery charger: Canon LC-E17 charger; supplied with camera
With the AC Adapter AC-E6N + DC Coupler DR-E18, AC power is possible (AC Adapter Kit ACK-E18 can also be used).
USB Power Adapter PD-E1 or PD-E2 supports in-camera charging of Battery Pack LP-E17 when the camera is turned off and can supply power when the camera is turned on.
Optional Battery Grip Not supported
Battery Check Automatic battery check with 4-level display when the power switch is turned ON.
Start-up Time Approx. 0.4 sec.
Based on CIPA testing standards.
Dimensions (W x H x D) Approx. 4.7 x 2.9 x 1.8 in. / 119.3 x 73.7 x 45.2mm
Based on CIPA standards.
Weight
Body (including battery and card)*1 Approx. 0.82 lbs. (13 oz.) Approx. 370 g
Body only Approx. 0.71 lbs (11.4 oz.) Approx. 323 g
Temperature Range 32104°F / 040°C working range
Humidity Range 85% or less working range
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Firmware Notice: EOS R50 V: Firmware Version 1.1.1
Advisory Type Firmware Notice
Date 07.17.25
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
