Canon Support for EOS R50 | Canon U.S.A., Inc.
EOS R50
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital interchangeable lens, mirrorless camera |
Image Processor | DIGIC X |
Recording Media | (One) SD card slot
Compatible Lenses | Canon RF lens group (including RF-S lenses) When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses) |
Lens Mount | Canon RF mount |
Type | APS-C CMOS sensor (compatible with Dual Pixel CMOS AF) |
Effective pixels | Approx. 24.2 megapixels |
Sensor Size | Approx. 22.3 x 14.9 mm |
Pixel Unit | Approx. 3.72 µm square |
Total Pixels | Approx. 25.5 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Installed in front of the image sensor, non-detachable |
Dust Deletion Feature | Self Cleaning Sensor Unit not provided. Manual cleaning (by hand) not supported.
Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif 2.31*. *Supports time offset information |
Image Format | JPEG (.JPG), HEIF (.HIF), RAW, C-RAW (.CR3) Movies: ALL-I (Time-lapse video only), IPB (Light) |
File Size | Click here to view the full specifications PDF. |
Maximum Burst | Click here to view the full specifications PDF. |
File Numbering | The following file numbers can be set:
RAW + JPEG / HEIF Simultaneous Recording | Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported. |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style |
Settings |
*2: With an EX / EL-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000 K if the flash unit does not have the color tem-perature communication feature. |
Auto White Balance | Option between ambience priority and white priority settings, using SET button |
White Balance Shift | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels •Shifted from the color temperatue of the current WB mode. •Blue/amber and magenta/green shift can be set at the same time. WB Bracketing available, up to ±3 levels Blue/amber or magenta/green, via Quick Control Dial |
Type | OLED color electronic viewfinder; 0.5-inch, approx. 3.69 million dots |
Coverage | Approx. 100% (at JPEG Large image quality, 3:2 aspect ratio, approx. 22 mm eyepoint) |
Magnification / Angle of View | Approx. 0.96x / Approx. 28.0° (3:2 aspect ratio, with 50mm lens at infinity,-1 m-1) |
Eye Point | Approx. 22mm (at -1 m-1 from the eyepiece lens end) |
Dioptric Adjustment Range | Approx. -3.0 to + 1.0 m-1 (dpt) |
Viewfinder Information |
Focus Method | Dual Pixel CMOS AF |
Number of AF zones available for Automatic Selection | AF area: Horizontal: Approx. 100% x Vertical: Approx. 100% (100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used) Stills: Max. 651 zones (31 x 21) Movies: Max. 527 zones (31 x17) |
Selectable Positions for AF Point | AF area: Horizontal: Approx. 90% x Vertical: Approx. 100% Stills: Max. 4503 positions (79 x 57) Movies: Max 3713 positions (79 x 47) |
Focusing brightness range (still photo shooting) | EV -4.0 to 20 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100) * Except RF lenses with a Defocus Smoothing (DS) coating. |
Focusing brightness range (movie recording) | EV -3.5 to 20 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and29.97 / 25.00
fps.)*
Available AF Areas |
Available Subject Detection |
Eye Detection | Auto:
Metering Modes | Real-time metering from CMOS image sensor (384 [24x16] metering zones)
Metering Range | Still Photo Shooting: EV -2 to 20 Movie Recording: EV 0 to 20 |
Exposure Modes | Still Photo Shooting:
ISO Speed Range |
Expanded ISO speeds cannot be set in HDR mode or for HDR shooting (HDR PQ). ISO Auto setting range for still photo shooting: Not suppored ISO Auto setting range for still photo shooting: Not suppored
*2: Varies depending on the [Max for Auto] settings. *3: If outside the setting range, changed to the value closest to ISO 400. *4: When using the built-in flash. ISO 1600 when using an external flash unit. |
Exposure Compensation |
AE Lock |
Type | Electronically controlled focal-plane shutter. Rolling shutter, using the image sensor.
* Bands of light may be displayed and captured images may be affected by light and dark banding when shooting under fluorescent lighting or other flickering light sources with the camera set to [Anti-flicker shoot.: Disable]. |
Shutter Speeds | Electronic 1st-curtain shutter: 1/4000th sec - 30 seconds, in 1/3-step increments Electronic shutter: 1/8000th sec - 30 seconds, in 1/3-step increments |
X-sync Speed | Elec. 1st-curtain: 1/250 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay, 2-sec. delay, Continuous |
Still Photo IS | In-body IS not provided. Still Photo IS not suppored. |
Accessory Shoe | Canon Multi-function accessory shoe •Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories |
E-TTL balance | Ambience priority, standard, flash priority |
Flash Exposure Compensation | ±3 (in 1/3-stop increments) |
Continuous flash control | E-TTL each shot / E-TTL 1st shot |
Drive Modes and Continuous Shooting Speed |
*2: Slower maximum continuous shooting speed when set to Servo AF with lenses other than those in the lens list attached. For details on lenses that support the indicated continuous shooting speed, refer to the separate lens list. * With electronic first-curtain, maximum continuous shooting speed is (or may be) reduced in flash photography or anti-flicker shooting. * With certain lenses, zooming during continuous shooting with electronic shutter may cause changes in exposure even at the same f/number. Refer to the separate lens list for the applicable lenses. (Note that even with a zoom lens that is not listed in the list may result in exposure changes or flickering if sudden zooming is performed.) |
HDR Shooting (HDR PQ) | Disable / Enable * Can be used in conjunction with Auto Lighting Optimizer. |
Still Photo HDR PQ |
Movie HDR PQ |
Continuous HDR Shooting (still images) | 1 shot only / Every shot |
File Format | Normal Movies
Estimated Recording time, Movie Bit Rate and File Size | HDR PQ: Off) Click here to view the full specifications PDF. |
Estimated Recording Time, Continued. | HDR PQ: ON Click here to view the full specifications PDF. |
Card Performance Requirements |
Video AF | Dual Pixel CMOS AF; Movie Servo AF available in AF Menu | |||||||||||||||||||||||||||||||||||||||||||||
Exposure Compensation | ±3 stops (in 1/3-stop increments) | |||||||||||||||||||||||||||||||||||||||||||||
Time Code | Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable) | |||||||||||||||||||||||||||||||||||||||||||||
Movie Pre-recording (On/Off) | Not supported | |||||||||||||||||||||||||||||||||||||||||||||
Time-lapse Movie Setting |
*1: Can be set in 1-sec. increments. *2: Can be set in 30-shot increments. *3: Can be set in 1-shot increments. |
Time-lapse Playback Frame Rate | 29.97 (set to NTSC); 25.00fps (set to PAL) |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0-inch (screen aspect ratio of 3:2) 2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height) |
Dots | Approx. 1.62 million dots |
Coverage | Approx. 100% vertically/horizontally |
Brightness Control | Manually adjustable to one of seven brightness levels |
Touch-screen Operation | Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified View; Volume Touch Sounds: 0 (silent) to 5 |
Coating | Anti-smudge coating not provided. Anti-reflection coating not provided. |
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese) |
Display Format |
Highlight Alert | Not supported | ||||||||||||||||||||||||||||||
Histogram | Brightness and RGB |
Function | The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback. |
Quick Control Screen | Users can customize setting items shown on the Quick Control screen.
* Customizable from the [Customize Quick Controls] menu item or by pressing and holding the button with the Quick Control screen displayed. |
Protection |
Erase | Except protected images
Compatible Printers | Images can be sent via Wi-Fi to a PictBridge-compatible (wireless LAN) printer and printed. |
DPOF | Compliant to DPOF Version 1.1 |
Supporting Standards | Equivalent to IEEE 802.11b/g/n Standards | |||||||||||||||||||||||||
Transmission Method | DS-SS modulation (IEEE 802.11b) OFDM modulation (IEEE 802.11g/n) |
Transition Frequency (Central Frequency) | 2.4 GHz band Frequency: 2412 to 2462 MHz Channels: 1 to 11 channels 5.0 GHz band Not supported |
Connection Method | (1) Camera access point mode (2) Infrastructure mode |
Security |
Communication with a Smartphone |
Remote Operation Using EOS Utility | The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer. | |||||||||||||||||||||||||
Print from Wi-Fi® Printers | Supported. | |||||||||||||||||||||||||
Send Images to a Web Service | image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers. From image.canon, images can be sent to specific social media and 3rd-party cloud image services. |
Standards Compliance | Bluetooth Specification Version 4.2 compliant (Bluetooth Low Energy technology) |
Transmission Method | GFSK modulation |
Bluetooth Pairing | Smartphone up to 10 devices; BR-E1 remote controller 1 unit |
Available Functions | Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials | ||||
Customize Buttons | Functions can be assigned to the following camera controls.
Customizable Dials | Customize control ring supported. | ||||
My Menu Registration |
• Up to six top-tier menu options and Custom Function settings can be registered.
• Up to five My Menu tabs can be added.
USB Video Class (UVC) | Available * The camera is accessible to software (such as Zoom, MS Teams, Skype, etc.) on a computer once connected via USB. |
USB Terminal | Equivalent to Hi-Speed USB (USB 2.0)
HDMI Out Terminal | HDMI micro OUT terminal Type D * Resolution switches automatically * HDMI CEC not supported * Images not displayed unless [For NTSC] or [For PAL] is set correctly for the TV video system |
Clean HDMI Output | Provided |
Microphone terminal | 3.5mm diameter stereo mini jack |
Headphone terminal | Compatible with 3.5mm diameter stereo mini-plug |
Battery | Canon LP-E17 battery pack
Optional Battery Grip | Not supported |
Battery Check | Automatic battery check with 4-level display when the power switch is turned ON. |
Start-up Time | Approx. 0.4 sec.
Dimensions (W x H x D) | Approx. 4.58 x 3.37 x 2.71 in. / 116.3 x 85.5 x 68.8mm Based on CIPA standards. |
Weight |
Working Temperature Range | 32-104°F / 0-+40°C |
Working Humidity | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
