Canon Support for EOS R5 | Canon U.S.A., Inc.
EOS R5
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital Single-Lens Non-Reflex Af/Ae Camera |
Recording Medium | Cfexpress Card Type B: Card Slot Sd Card Speed Class-Compatible Sd Card Compatible With Uhs-Ii Eye-Fi Cards And Multimedia Cards (Mmc) Are Not Supported. |
Compatible Lenses | Canon Rf Lens Group (Excluding Ef, Ef-S And Ef-M Lenses) When Using Mount Adapter Ef-Eos R: Canon Ef Or Ef-S Lenses (Excluding Ef-M Lenses) |
Lens Mount | Canon Rf Mount |
Type | Cmos Sensor (Compatible With Dual Pixel Cmos Af) |
Pixels | Effective Pixels: Approx. 45.0 Megapixels |
Pixel Unit | Approx. 4.40 µm Square |
Total Pixels | Approx. 47.1 Megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | Rgb Primary Color Filters |
Low Pass Filter | Installed In Front Of The Image Sensor, Non-Detachable |
Dust Deletion Feature |
Recording Format | Compliant To Design Rule For Camera File System 2.0 And Exif 2.3*. * Supports Time Difference Information In Exif 2.31. |
File Size | 3:2 Aspect Ratio Large/Raw/C-Raw: 8192 X 5464 Medium: 5808 X 3872 Small 1: 4176 X 2784 Small 1: 2976 X 1984 Small 2: 2400 X 1600 1.6x (Crop)* Large/Raw/C-Raw: 5088 X 3392 Small 2: 2400 X 1600 4:3 Aspect Ratio Large: 7280 X 5464 Medium: 5152 X 3872 Small 1: 3712 X 2784 Small 2: 2112 X 1600 Raw/C-Raw: 8192 X 5464 16:9 Aspect Ratio Large: 8192 X 4608 Medium: 5808 X 3264 Small 1: 4176 X 2344 Small 2: 2400 X 1344 Raw/C-Raw: 8192 X 5464 1:1 Aspect Ratio Large: 5456 X 5456 Medium: 3872 X 3872 Small 1: 2784 X 2784 Small 2: 1600 X 1600 Raw/C-Raw: 8192 X 5464
* Indicate An Inexact Proportion. |
File Numbering | The Following File Numbers Can Be Set:
Raw Jpeg Simultaneous Recording | Simultaneous Recording Of Any Combination Of Raw/C-Raw And Jpeg/Heif Image-Recording Quality Is Supported. |
Color Space | Selectable Between Srgb And Adobe Rgb |
Picture Style |
Settings |
Auto White Balance | Option Between Ambience Priority And White Priority Settings. |
Color Temperature Compensation | Blue/Amber Bias: ±9 Levels Magenta/Green Bias: ±9 Levels Corrected In Reference To The Current Wb Mode's Color Temperature. |
Type | Oled Color Electronic Viewfinder; Approx. 5.76 Million Dots Resolution |
Coverage | Approx. 100% Vertically And Horizontally Relative To The Shooting Image Area (With Image Quality L, At Approx. 23mm Eyepoint). |
Magnification | Approx. 0.76x / Approx. 35.5 Degrees (With 50mm Lens At Infinity, -1 M-1) |
Eyepoint | Approx. 23mm (At -1 M-1 From The Eyepiece Lens End) |
Viewfinder Information |
Type | Dual Pixel Cmos Af | |||||||
Af Working Range | Ev -6 To 20 (F/1.2 Lens*, Center Af Point, One-Shot Af, At 73°F/23°C, Iso 100, One-Shot Af) * Except Rf Lenses With A Defocus Smoothing (Ds) Coating. |
Af Point Selection |
Metering Modes | Real-Time Metering With Image Sensor (384 [24x16 Zone Metering])
Metering Range | Ev -3 - 20 (At 73°F/23°C, Iso 100) (Still Photo Shooting) | |||||||||||||||||||||||||||||||
Exposure Control Systems |
Iso Speed Range | Available Iso Speeds; User-Set
User-Defined Iso Range - Still Photo Shooting
User-Defined Auto Iso Range - Still Photo Shooting
Iso Auto Details In Still Photo Shooting
*2 Varies Depending On [Maximum] And [Minimum] Of [Auto Range]. *3 If Outside The Setting Range, Changed To The Value Most Close To Iso 400. *4 Iso 1600 When Using A Lens That Is Not Compatible With "Variable Control Of Maximum Iso Auto Limit For E-Ttl". |
Exposure Compensation |
Ae Lock |
Type | Electronically Controlled Focal-Plane Shutter
* A Shutter Release Sound Is Not Generated. However, Note That The Sounds Other Than The Shutter Release Sound (Aperture, Focusing Lens Drive Sound/Electronic Sound, Etc.) May Be Generated. * In Electronic Shutter Shooting Under Conditions Such As Flash Firing By Other Cameras Or With Fluores-Cent Lighting Or Other Flickering Light Sources, A Strip Of Light Or Banding Due To The Brightness Difference May Be Recorded In The Image. |
Shutter Speeds | When [Mechanical] Or [Elec. 1st- Curtain] Is Set: 1/8000-30 Sec, Bulb When [Electronic] Is Set: 1/8000-0.5 Sec. |
Shutter Release | Soft-Touch Electromagnetic Release | ||||||||||||||
Self Timer | 10-Sec. Delay, 2-Sec. Delay | ||||||||||||||
Shutter Lag Time |
Flash Metering | E-Ttl Ii Flash Metering
Flash Exposure Compensation | ±3 Stops In 1/3- Or 1/2-Stop Increments E-Ttl Balance Compatible E-Ttl Speedlites |
Fe Lock | Provided |
External Flash Settings | The Camera Can Set The Following With Ex Series Speedlites:
Focusing | Dual Pixel Cmos Af | |||||||||||||||||||||||||||||||||||||||||||
Exposure Compensation | ±3 Stops In 1/3- Or 1/2-Stop Increments Shooting Times
*1 Time Available For Continuous Shooting In 23°C / 73°F Environment, From A Cold Start. If The Camera Is In Lv Mode Standby Before Shooting Or The Ambient Temperature Is High, The Shooting Time May Be Shorter. Estimated Camera Recovery Time
Type | Tft Color, Liquid-Crystal Monitor |
Screen Monitor Size | 3.2-Inch (Screen Aspect Ratio Of 3:2) 3.15 In./8.01cm Diagonal (2.63 In./6.67cm Width, 1.75 In./4.44cm Height) |
Pixels | Approx. 2.1 Million Dots |
Coverage | Approx. 100% Vertically/Horizontally |
Brightness Control | Manually Adjustable To One Of Seven Brightness Levels |
Coating | Clear View Lcd Ii
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese) |
Protection |
Erase | Except Protected Images
Compatible Printers | Not Supported |
Dpof | Compliant To Dpof Version 1.1 |
Custom Controls | Customizable Buttons
Customizable Dials
My Menu Registration |
Usb Terminal | Equivalent To Hi-Speed Usb (Usb 3.1 Gen 2)
Video Out Terminal | Hdmi Micro Out Terminal Type D (Resolution Switches Automatically) / Cec Not Compatible
Microphone Input Terminal/Headphone Terminal |
Battery | Lp-E6nh/Lp-E6n/Lp-E6
Battery Check | Automatic Battery Check When The Power Switch Is Turned On. Displayed In 6 Levels On Top Lcd Panel.
Start Up Time | Approx. 0.4 Sec.
Dimensions W X H X D | Approx. 5.45 X 3.84 X 3.46 In. / 138 X 97.5 X 88.0mm
Weight | Approx. 1.63 Lbs. / 738g (Including Battery, Cfexpress Card; Without Body Cap) Approx. 1.43 Lbs. / 650g (Body Only; Without Battery, Card Or Body Cap) |
Operating Humidity Range | 85° Or Less |
Working Temperature Range | 32-104° F / 0-+40° C |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
What is the Stop Motion Animation Service?
We have released a new upgrade service for various EOS R series cameras.
This upgrade enables you to capture Stop Motion Animation.
For more details of the service and compatible camera’s click Learn More.
Pricing
Model | Price* |
Various EOS R cameras | $100 |
*Tax and shipping fees are NOT included
*All pricing is subject to change Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-800-OK-CANON (toll free), 1-800-652-2666
For additional support options: https://www.usa.canon.com/support
