Canon Support for EOS R8 | Canon U.S.A., Inc.
EOS R8
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 02.22.23
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type Digital interchangeable lens, mirrorless camera
Image Processor DIGIC X
Recording Media (One) SD card slot
  • Compatible with UHS-II
  • Eye-Fi cards and Multimedia cards (MMC) are not supported.
Compatible Lenses Canon RF lens group (including RF-S lenses) When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount Canon RF mount
Type Full-frame CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective pixels Approx. 24.2 megapixels
Screen Size Approx. 36.0 x 24.0 mm
Pixel Unit Approx. 6.00 µm square
Total Pixels Approx. 25.6 megapixels
Aspect Ratio 3:2 (Horizontal:Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Installed in front of the image sensor, non-detachable
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
  2. Removes dust adhering to the low-pass filter.
    • Auto cleaning: At power off / Enable / Disable
    • * Automatically performs the sensor cleaning during Power OFF/ON.
    • Clean now
    • * Performs cleaning immediately. After the cleaning ends, the camera automatically restarts (Power OFF to ON).
  3. Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
    • The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
    • Not available with RF-S/EF-S lenses, in cropped shooting, during focus bracket shooting, in RAW burst mode, multiple-exposure shooting, or HDR mode, or when Multi Shot Noise Reduction or the interval timor or digital tele-converter is set.
  4. Manual cleaning (by hand) not supported
Recording Format Compliant to Design rule for Camera File system 2.0 and Exif 2.31*. *Supports time difference information in Exif 2.31.
Image Format JPEG (.JPG), HEIF (.HIF), RAW, C-RAW, Dual Pixel RAW, RAW burst (.CR3) Movies: ALL-I (Time-lapse video only), IPB (.MP4)
File Size Click here to view the full specifications PDF.
*1: Number of shots using a 32 GB card that conforms to Canon testing standards.
*2: When set to [HDR shooting (HDR PQ): Disable].
*3: When set to [HDR shooting (HDR PQ): Enable].
* File sizes are determined based on Canon testing standards.
Maximum Burst Click here to view the full specifications PDF.
*1: Number of shots using a 32 GB UHS-I card that conforms to Canon testing standards.
*2: Number of shots using a 32 GB UHS-II card that conforms to Canon testing standards.
*3: When set to [HDR shooting (HDR PQ): Disable].
*4: When set to [HDR shooting (HDR PQ): Enable].
* Maximum burst as measured under conditions conforming to Canon testing standards (High-speed continuous shooting + in One-Shot AF mode, ISO 100, and Standard Picture Style).
* Number of shots available varies depending on shooting conditions (such as cropping/aspect ratio, subject, memory card brand, ISO speed, Picture Style, and Custom Function).
File Numbering The following file numbers can be set:
  1. File numbering methods
    • Continuous numbering
      • The numbering of captured images continues even after you replace the card.
    • Auto reset
      • When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG / HEIF Simultaneous Recording Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported.
Color Space Selectable between sRGB and Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    • In Scene Intelligent Auto, [Auto] will be set automatically.
    • [Standard] is the default setting for [User Def. 1-3].
Settings
  1. Auto (Ambience priority/White priority)
  2. Day Light
  3. Shade
  4. Cloudy*1
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
  9. Color temperature*2
*1: Effective also in twilight and sunset.
*2: With an EX / EL-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000 K if the flash unit does not have the color temperature communication feature.
Auto White Balance Option between ambience priority and white priority settings, using SET button
White Balance Shift Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
  • Shifted from the color temperatue of the current WB mode.
  • Blue/amber and magenta/green shift can be set at the same time.
  • WB Bracketing available, up to ±3 levels Blue/amber or magenta/green, via Quick Control Dial
Type OLED color electronic viewfinder; 0.39-inch, approx. 2.36 million dots
Coverage Approx. 100% (at JPEG Large image quality, 3:2 aspect ratio, approx. 22 mm eyepoint)
Magnification / Angle of View Approx. 0.70x / Approx. 33.0 degrees (3:2 aspect ratio, with 50mm lens at infinity, 1 m1)
Eye Point Approx. 22mm (at -1 m-1 from the eyepiece lens end)
Dioptric Adjustment Range Approx. -4.0 to + 1.0 m-1 (dpt)
Viewfinder Information
  1. Maximum burst
  2. Possible shots/Sec. until self-timer shoots
  3. Focus Bracketing/ Multiple-exposure/HDR shooting/Multi Shot Noise Reduction/Bulb time/Interval timer
  4. Shooting mode
  5. AF method
  6. AF operation
  7. Image quality
  8. Card
  9. Drive mode
  10. Metering mode
  11. No. of remaining shots for focus braketing, multiple exposures, or interval timer
  12. Electronic level
  13. Movie recording time available
  14. Battery level
  15. Image Stabilizer (IS mode)
  16. Histogram (Brightness/RGB)
  17. Quick Control button
  18. Anti-flicker shooting
  19. White balance/White balance correction
  20. Picture style
  21. Auto Lighting Optimizer
  22. Still photo cropping / Aspect ratio
  23. AF point (1-point AF)
  24. AEB/FEB
  25. View Assist
  26. HDR PQ
  27. Flash ready / FE lock / High-speed sync
  28. Electronic shutter
  29. Touch shutter / Create folder
  30. AE lock
  31. Shutter speed / Multi-function lock warning
  32. Aperture value
  33. Wi-Fi® function
  34. Wi-Fi® signal strength
  35. Bluetooth® function
  36. Exposure simulation
  37. Magnify button
  38. ISO speed
  39. Highlight tone priority
  40. Exposure compensation
  41. Exposure level indicator
Focus Method Dual Pixel CMOS AF
Number of AF zones available for Automatic Selection AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%
(100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used)
Stills: Max. 1053 zones (39 x 27)
Movies: Max. 1053 zones (39 x27)
Selectable Positions for AF Point AF area: Horizontal: Approx. 90% x Vertical: Approx. 100% Stills: Max. 4897 positions (83 x 59) Movies: Max 4067 positions (83 x 49)
Focusing brightness range (still photo shooting) EV 6.5 to 21 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100) * Except RF lenses with a Defocus Smoothing (DS) coating.
Focusing brightness range (in movie recording) 4K: EV 4.0 to 21
Full HD: EV 4.5 to 21
(with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and 29.97 / 25.00 fps.)
Available AF Areas
  • Spot AF
  • 1-point AF
  • Expand AF area: Above/below/left/right
  • Expand AF area: Around
  • Flexible Zone AF 1
  • Flexible Zone AF 2
  • Flexible Zone AF 3
  • Whole area AF
Available Subject Detection
  • Auto
  • People
  • Animals (dogs / cats / birds / horses)
  • Vehicles (motorsports cars or motorcycles / aircraft / trains)
    * Certain types of animals or vehicles may not be detected, depending on shape and appearance
Eye Detection Auto:
  • Selects the eye closer to the camera (as detected from the angle of the face).
  • At the same distance from the camera, selects the eye closer to the center of the image.
Right Eye:
  • Prioritizes the subjects right eye.
Left Eye:
  • Prioritizes the subjects left eye.
Disable
Metering Modes Real-time metering from CMOS image sensor (384 [24x16] metering zones)
  1. Evaluative metering (AF point-linked)
  2. Partial metering (approx. 5.9% of the area at the center of the screen)
  3. Spot metering (approx. 3.0% of the area at the center of the screen)
  4. Center-weighted average metering
Metering Range EV -3 - 20 (at 73°F/23°C, ISO 100)(Still Photo Shooting)
Exposure Modes
  1. Scene Intelligent Auto
  2. Hybrid Auto
  3. Special Scenes
  4. Creative Filters
  5. Flexible-priority AE
  6. Program AE
  7. Shutter-priority AE
  8. Aperture-priority AE
  9. Manual Exposure
  10. Bulb Exposure
  11. Custom Shooting Modes C1, C2, C3
ISO Speed Range Click here to view the full specifications PDF.
*1: ISO 200 when set to [Highlight tone priority: Enable/Enhanced].
*2: Varies depending on the [Maximum] and [Minimum] settings for [Auto range].
*3: If outside the setting range, changed to the value closest to ISO 400.
Exposure Compensation Click here to view the full specifications PDF.
AE Lock
  1. Auto AE lock
    • AE is locked as soon as subjects are in focus using One-Shot AF when set to selected metering mode in [C.Fn2: AE lock meter. mode after focus].
    • User-set AE lock.
      • Use the AE lock button (update by pressing the button again) in Fv, P, Tv, Av, and M mode.
      • Enabled in all metering modes.9
Type Electronically controlled focal-plane shutter
  1. Electronic first curtain
  2. Electronic shutter
* Not equipped with a mechanical first curtain.
* When set to [Electronic], the camera makes no mechanical shutter sound. (An electronic shutter sound can be configured in [Beep] and [Volume: Shutter volume]). Note that the camera may make sounds other than the shutter release sound, such as sounds for aperture adjustment or the lens focus drive, or beeps. Moreover, using long exposure noise reduction with shutter speeds of 1 sec. or longer involves a mechanical second-curtain shutter, which produces a mechanical sound.
* Bands of light may be displayed and captured images may be affected by light and dark banding when shooting under fluorescent lighting or other flickering light sources with the camera set to [Anti-flicker shoot.: Disable].
Shutter Speeds Mechanical / 1st-curtain Electronic shutter: 1/4000th sec 30 seconds, in 1/3 or 12-step increments
Electronic shutter: 1/8000th sec 30 seconds, in 1/3 or 12-step increments (1/16,000th possible, if user-set in Tv or M shooting modes)
X-sync Speed Elec. 1st-curtain: 1/200 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay, 2-sec. delay, Continuous
Image Stabilization Click here to view the full specifications PDF.
* Only during movie recording (OFF during still photo shooting)
Accessory Shoe Canon Multi-function accessory shoe Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories
E-TTL balance Ambience priority, standard, flash priority
Flash Exposure Compensation ±3 stops in 1/3- or 1/2-stop increments
Continuous flash control E-TTL each shot / E-TTL 1st shot
Drive Modes and Continuous Shooting Speed Click here to view the full specifications PDF.
*1: Not available when set to [Dual Pixel RAW: Enable] (low-speed continuous shooting is used).
*2: With electronic first-curtain, continuous shooting speed is the same for Highspeed continuous + and High-speed continuous shooting.
*3: Slower maximum continuous shooting speed when set to Servo AF with lenses other than those in the lens list attached. For details on lenses that support the indicated continuous shooting speed, refer to the separate lens list.
* With electronic first-curtain, maximum continuous shooting speed is (or may be) reduced in flash photography, anti-flicker shooting, or Dual Pixel RAW shooting.
* With certain lenses, zooming during continuous shooting with electronic shutter may cause changes in exposure even at the same f/number. For detail on relevant lenses, refer to the separate lens list (and note that even with zoom lenses not listed, sudden zooming may cause flickering or changes in exposure).
HDR Shooting (HDR PQ) Disable / Enable
* Can be used in conjunction with Auto Lighting Optimizer.
Still Photo HDR PQ Click here to view the full specifications PDF.
Movie HDR PQ Click here to view the full specifications PDF.
HDR Mode Off / Moving sub. / Dynamic range
* [Dynamic range]: For each shot, three images are captured consecutively at different exposures (standard exposure, underexposure, and overexposure).
* [Moving sub.]: Output of a wide gradation without causing motion blur due to image composition by one exposure is possible.
* [Moving sub.]: Minimum ISO speed is ISO 800.
* When [HDR mode] is set, [Picture Style] options are limited to [Standard] and [Monochrome], and maximum shutter speed is 1/8000 sec.
* [Moving sub.]: [Electronic] shutter mode may increase subject distortion (due to rolling shutter).
* Shooting JPEG or HEIF images is supported.
* Can be set in conjunction with HDR shooting (HDR PQ), which enables shooting with a wide dynamic range ([Dynamic range]: up to approx. 3000 nits; [Moving sub.]: up to approx. 3000 nits).
Continuous HDR Shooting (still images) 1 shot only / Every shot
* Not available when set to [Moving sub.].
Shooting Times Click here to view the full specifications PDF.
*1: Time available for continuous shooting in 23°C / 73°F environment, from a cold start. If the camera is in LV mode standby before shooting or the ambient temperature is high, the shooting time may be shorter.
*2: According to Canon measurement conditions when using UHS-II cards conforming to Canon testing standards.
*3: The maximum duration of shooting may be shorter under some circumstances even if recording begins from "cold start," due to a rise in temperature inside the camera caused by pre-shooting camera setting operations or by prolonged use of the Live View mode. When the card is full, movie recording stops automatically. In this case, duration time when you erase the data and restart shooting.
File Format Normal Movies Click here to view the full specifications PDF.
* Recording in AAC when [Audio compression] (C.Fn4) is set to [Enable] or Linear PCM when set to [Disable].
Estimated Recording time, Movie Bit Rate and File Size H.264/AVC (Canon Log: Off, HDR PQ: Off)
* Bit rate only applies to video output, not audio or metadata.
* Audio is recorded when [C.Fn4 audio compression:Enable] (Audio: AAC) is set.
* Movie recording stops when the maximum recording time per movie is reached.
* No audio is recorded for approx. the last two frames with the compression method for movie recording quality set to IPB (Standard) or IPB (Light) and the camera set to [C.Fn4 Audio compression: Enable]. Moreover, the video and sound may be slightly out of sync when movies are played back in Windows.
* Mbps megabits per second (8 megabits = 1 megabyte)
Estimated Recording Time, Continued. H.265/HEVC (Canon Log: On or HDR PQ: On)
Card Performance Requirements Click here to view the full specifications PDF.
Video AF Dual Pixel CMOS AF; Movie Servo AF available in AF Menu
Time Code Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable)
Movie Pre-recording (On/Off) 3 or 5 seconds; user-selectable
* Pre-recording does not apply to High Frame Rate or time-lapse movie recording.
Time-lapse Movie Setting Interval 2 sec 99:59:59; Number of frames 23,600; Movie recording size 4K/Full HD; Auto exposure fixed @ first frame/auto for each frame; Beep per frame recorded (volume setting 0/silent 5)
Time-lapse Playback Frame Rate 29.97 (set to NTSC); 25.00fps (set to PAL)
Type TFT color, liquid-crystal monitor
Monitor Size 3.0-inch (screen aspect ratio of 3:2) 2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
Dots Approx. 1.62 million dots
Coverage Approx. 100% vertically/horizontally
Brightness Control Manually adjustable to one of seven brightness levels
Touch-screen Operation Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified View; Volume Touch Sounds: 0 (silent) to 5
Coating Anti-smudge coating not provided.
Anti-reflection coating not provided.
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format Click here to view the full specifications PDF.
Highlight Alert White areas without image data blink in single-image display.
Histogram Brightness and RGB
Function The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback.
Quick Control Screen Users can customize setting items shown on the Quick Control screen.
  • Items shown: Up to 11
  • Edit layout / Reset settings / Clear all items
* Separate Quick Control screens can be set up for use in still photo shooting and movie recording. (Users can select and rearrange the items shown.)
* Customizable from the [Customize Quick Controls] menu item or by pressing and holding the button with the Quick Control screen displayed.
Protection
  1. Single image (select image)
  2. Select range
  3. All images in folder
  4. All images on card
    • Image browsing and image search can be based on ratings.
    • Ratings-based image selections also possible with DPP.
  5. All found images (only during image search)
Erase Except protected images
  1. Select images to erase
  2. Select range
Compatible Printers Direct printing from camera not supported
DPOF Compliant to DPOF Version 1.1
Supporting Standards Equivalent to IEEE 802.11b/g/n Standards
Transmission Method DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n)
Transition Frequency (Central Frequency) 2.4 GHz band
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 channels
5.0 GHz band
Not supported
Connection Method (1) Camera access point mode (2) Infrastructure mode
Security Click here to view the full specifications PDF.
Communication with a Smartphone
  • Images can be viewed, controlled, and received using a smartphone.
  • Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications.
  • Images can be sent to a smartphone.
  • NFC connection: Not supported
  • Supported images: JPEG, HEIF, RAW/C-RAW, MP4 video files
  • Transcoding while sending: Size to send (original / reduced size); Quality to send (original / compressed)
Remote Operation Using EOS Utility The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer.
Print from Wi-Fi® Printers Not supported.
Send Images to a Web Service image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers.
From image.canon, images can be sent to specific social media and 3rd-party cloud image services.
Standards Compliance Bluetooth Specification Version 4.2 compliant (Bluetooth Low Energy technology)
Transmission Method GFSK modulation
Bluetooth Pairing Smartphone up to 10 devices; BR-E1 remote controller 1 unit
Available Functions Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials
Customize Buttons Functions can be assigned to the following camera controls.
  • Shutter button (half-press)
  • Movie shooting button
  • Multi-function button
  • AF-ON button
  • AE Lock button
  • AF point button
  • Up key
  • Left key
  • Right key
  • Down key
  • SET button
  • Lens function button
  • Speedlite menu direct button
Customizable Dials Functions can be assigned to the following camera controls.
  • Main dial
  • Quick control dial
  • Control ring
My Menu Registration
• Up to six top-tier menu options and Custom Function settings can be registered.
• Up to five My Menu tabs can be added.
USB Video Class (UVC) Available
* The camera is accessible to software (such as Zoom, MS Teams, Skype, etc.) on a computer once connected via USB.
USB Terminal Equivalent to SuperSpeed Plus USB (USB 3.2 Gen 2)
  • For PC communication
  • Terminal type: USB Type-C
  • Shared with terminal for in-camera charging with USB Power Adapter PD-E1.
HDMI Out Terminal HDMI micro OUT terminal (Type D)
* Supports 4K 60p output, and (to HDR TVs) HDR PQ video output.
* HDMI CEC not supported
* Images may not be displayed unless [For NTSC] or [For PAL] is set correctly for the TV video system.
Clean HDMI Output Provided
Microphone terminal 3.5mm diameter stereo mini jack
Headphone terminal Compatible with 3.5mm diameter stereo mini-plug
Battery Canon LP-E17 battery pack
  • With the AC Adapter AC-E6N + DC Coupler DR-E18, AC power is possible (AC Adapter Kit ACK-E18 can also be used).
  • USB Power Adapter PD-E1 supports in-camera charging of Battery Pack LP-E17 when the camera is turned off and can supply power when the camera is turned on.
Optional Battery Grip Not supported
Battery Check Automatic battery check with 4-level display when the power switch is turned ON.
* Can be checked on the screen and in the viewfinder.
Start-up Time Approx. 0.4 sec.
  • Based on CIPA testing standards.
Dimensions (W x H x D) Approx. 5.22 x 3.39 x 2.76 in. / 132.5 x 86.1 x 70.0mm
Based on CIPA standards.
Weight Approx. 1.01 lbs. / 461g (including battery, SD memory card; without body cap)
Approx. 0.91 lbs. / 414g (body only; without battery, card or body cap)
Working Temperature Range 32-104° F / 0-+40° C
Working Humidity
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
What is the Stop Motion Animation Service?
We have released a new upgrade service for various EOS R series cameras.
This upgrade enables you to capture Stop Motion Animation.
For more details of the service and compatible camera’s click Learn More.
Pricing
Model Price*
Various EOS R cameras $100
*Tax and shipping fees are NOT included
*All pricing is subject to change Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-800-OK-CANON (toll free), 1-800-652-2666
For additional support options: https://www.usa.canon.com/support
Title Firmware Notice: EOS R8: Firmware Version 1.1.0
Advisory Type Firmware Notice
Date 09.26.23
Title Firmware Notice: EOS R8: Firmware Version 1.2.0
Date 12.05.23
Title Firmware Notice: EOS R8: Firmware Version 1.3.0
Date 06.06.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Advisory Type Service Notice
Date 05.01.24
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Firmware Notice: EOS R8: Firmware Version 1.4.0
Date 09.26.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
