Canon Support for EOS Rebel T1i | Canon U.S.A., Inc.
EOS Rebel T1i
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | High-sensitivity, high-resolution, large single-plate CMOS sensor |
Pixels | Effective pixels: Approx. 15.10 megapixels |
Total Pixels | Total pixels: Approx. 15.50 megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the CMOS sensor |
Dust Deletion Feature | (1) Self Cleaning Sensor Unit (2) Dust Delete Data appended to the captured image (3) Manual cleaning of sensor |
Recording Format | Design rule for Camera File System 2.0 and Exif 2.21 |
Image Format | Still: JPEG, RAW (14-bit, Canon original), RAW+JPEG Video: MOV (Image data: H.264, Audio: Linear PCM) |
File Size | (1) Large/Fine: Approx. 5.0MB (4752 x 3168 pixels) (2) Large/Normal: Approx. 2.5MB (4752 x 3168 pixels) (3) Medium/Fine: Approx. 3.0MB (3456 x 2304 pixels) (4) Medium/Normal: Approx. 1.6MB (3456 x 2304 pixels) (5) Small/Fine: Approx. 1.7MB (2352 x 1568 pixels) (6) Small/Normal: Approx. 0.9MB (2352 x 1568 pixels) (7) RAW: Approx. 20.2MB (4752 x 3168 pixels) Exact file sizes depend on the subject, ISO speed, Picture Style, etc. |
File Numbering | Consecutive numbering, auto reset, manual reset |
RAW + JPEG Simultaneous Recording | Provided (RAW, RAW+JPEG) |
Color Space | sRGB, Adobe RGB selectable |
Picture Style | Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3 |
Settings | Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom |
Color Temperature Compensation | White balance correction: ±9 stops in full-stop increments White balance bracketing: ±3 stops in full-stop increments Blue/amber direction or magenta/green direction possible |
Color Temperature Information Transmission | Provided |
Type | Eye-level pentamirror |
Coverage | Vertical/Horizontal approx. 95% |
Magnification | Approx. 0.87x (-1m-1 with 50mm lens at infinity) |
Eye Point | Approx. 19mm (from eyepiece lens center) |
Dioptric Adjustment Correction | -3.0 to +1.0m-1 (diopter) |
Focusing Screen | Fixed, Precision Matte |
Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60, no mirror cut-off with EF600mm f/4L IS USM or shorter lenses) |
Viewfinder Information | AF information (AF points, focus confirmation light), exposure information (shutter speed, aperture, AE lock, exposure level, ISO speed, exposure warning), flash information (flash ready, high-speed sync, FE lock, flash exposure compensation), monochrome shooting, white balance correction, maximum burst, SD memory card information |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Type | TTL-CT-SIR AF-dedicated CMOS sensor |
AF Points | 9 AF points (center AF point is cross-type) |
AF Working Range | EV -0.5-18 (at 73°F/23°C, ISO 100) |
Focusing Modes | Auto, One-Shot AF, Predictive AI Servo AF, AI Focus AF, Manual Focusing (MF) |
AF Point Selection | Automatic selection, manual selection |
Selected AF Point Display | Superimposed in viewfinder and indicated on LCD monitor |
AF Assist Beam | Intermittent firing of built-in flash Effective range: Approx. 4.0m/13.1 ft. at center, approx. 3.5m/11.5 ft. at periphery. When EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead. |
Metering Modes | 35-zone TTL full-aperture metering Evaluative metering (linkable to any AF point)Partial metering (approx. 9% of viewfinder at center)Spot metering (approx. 4% of viewfinder at center)Center-weighted average metering |
Metering Range | EV 1-20 (at 73°F/23°C with EF50mm f/1.4 USM lens, ISO 100) |
ISO Speed Range | ISO 100-3200 (in 1-stop increments), H1: 6400 H2: 12800; Basic Zone modes: ISO 100-3200 set automatically |
Exposure Compensation | Manual: ±2 stops in 1/3- or 1/2-stop increments (can be combined with AEB) |
AE Lock | Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved; Manual: By AE lock button |
Shutter | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/4000 sec. to 1/60 sec., X-sync at 1/200 sec. 1/4000 sec. to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode)Soft-touch electromagnetic release10-sec. or 2-sec. delay or 10-sec. delay plus continuous shootingRemote Switch RS-60E3 Remote Controller RC-1/RC-5 |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled |
Shutter Speeds | 1/4000 sec. to 1/60 sec., X-sync at 1/200 sec. 1/4000 sec. to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode) |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay or 10-sec. delay plus continuous shooting |
Remote Control | Remote Switch RS-60E3 Remote Controller RC-1/RC-5 |
Type | Retractable, auto pop-up flash |
Guide Number | 13/43 (ISO 100, in meters/feet) |
Recycling Time | Approx. 3 sec. |
Flash Ready Indicator | Flash-ready icon lights in viewfinder |
Flash Coverage | 17mm lens angle of view |
FE Lock | Provided |
Flash Exposure Compensation | ±2 stops in 1/3- or 1/2-stop increments |
Drive Modes | Single, continuous, self-timer (10 sec. or 2 sec. delay)/remote control |
Continuous Shooting Speed | Max. 3.4 shots/sec. (with One-Shot AF or AI Servo AF) |
Maximum Burst | JPEG (Large/Fine): Approx. 170, RAW: Approx. 9 Based on Canon's testing standards with a 2GB SD memory card, ISO 100 and Standard Picture Style Varies depending on the subject, SD memory card brand, image-recording quality, etc. |
Shooting Modes | Still photo shooting and video shooting |
Focusing | Autofocus (One-Shot AF): Live mode, Face Detection Live mode, Quick mode; Manual focus (5x or 10x manually) |
Metering Modes | Real-time evaluative metering with image sensor |
Metering Range | EV 0-20 (at 73°F/23°C with EF 50mm f/1.4 USM lens, ISO 100) |
Grid Display | Provided (Two grid displays) |
Exposure Simulation | Provided |
Silent Shooting | Not provided |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0 in. |
Pixels | Approx. 920,000 dots (VGA) |
Coverage | Approx. 100% Viewing angle: 170° |
Brightness Control | 7 levels provided |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
Display Format | Single image, Single image + Image-recording quality, shooting information, histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image, image jump (by 1/10/100 images or shooting date) |
Highlight Alert | Provided (Overexposed highlights blink) |
Protection | Erase protect (or cancel) each image individually |
Erase | Single image, selected images or all images in the SD card can be erased (except protected images) |
Compatible Printers | PictBridge-compatible printers |
Printable Images | JPEG images compliant to Design rule for Camera File System (DPOF printing possible) and RAW images captured with the EOS Rebel T1i |
Easy Print feature | Provided |
DPOF | Version 1.1 compatible |
Compatible Images | JPEG and RAW images *Only JPEG images can be transferred as wallpaper on the personal computer screen |
Custom Functions | Total 13 |
My Menu Registration | Up to 6 menus, Custom functions and other top-tier options can be registered |
Battery | One Battery Pack LP-E5 AC power can be supplied via AC Adapter Kit ACK-E5 With Battery Grip BG-E5, AA-size batteries can be used |
Number of Shots | |
Battery Life | The above figures apply with a fully-charged Battery Pack LP-E5 The figures above are based on CIPA (Camera & Imaging Products Association) testing standards |
Battery Check | Automatic |
Power Saving | Provided. Power turns off after 30 sec., 1, 2, 4, 8, 15 min. |
Back-up Battery | Built-in secondary battery |
Start-up Time | Approx. 0.1 sec. (based on CIPA testing standards) |
Dimensions (W x H x D) | Approx. 5.1 x 3.8 x 2.4 in./128.8 x 97.5 x 61.9mm |
Weight | Approx. 16.9oz./480g (body only) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
