Canon Support for EOS Rebel T4i | Canon U.S.A., Inc.
EOS Rebel T4i
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 07.23.12
File Size 6.38 MB
Date 07.23.12
File Size 6.88 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 06.12.12
File Size 1.86 MB
Date 06.12.12
File Size 25.68 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
CMOS Sensor
Pixels
Effective pixels: Approx. 18.0 megapixels
Pixel Unit
4.3 &micro;m square
Total Pixels
Total pixels: Approx. 18.50 megapixels
Aspect Ratio
3:2 (Horizontal : Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the CMOS sensor
Dust Deletion Feature
(1) Self Cleaning Sensor Unit Removes dust adhering to the low-pass filter. Self-cleaning executed automatically (taking approx. 2 sec.) when power is turned on or off. Manual execution also possible (taking approx. 5 sec.).(2) Dust Delete Data acquisition and appending The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.(3) Manual cleaning
Recording Format
Complies with Design rule for Camera File system 2.0 and Exif 2.30
File Size
(1)Large: Approx. 17.90 Megapixels (5,184 x 3,456)
(2)Medium: Approx. 8.00 Megapixels (3,456 x 2,304)
(3)Small 1: Approx. 4.50 Megapixels (2,592 x 1,728)
(4)Small 2: Approx. 2.50 Megapixels (1920 x 1280)
(5)Small 3: Approx. 350,000 Pixels (720 x 480)
(6)RAW: Approx. 17.90 Megapixels (5,184 x 3,456)
Backup Recording
N/A
File Numbering
The following three types of file numbering method can be set:
(1) Continuous numbering
* The numbering of captured images will continue even after you replace the camera's card.
(2) Auto reset
* When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card.
(3) Manual reset
* Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording
Large RAW and JPEG images are recorded simultaneously
Color Space
sRGB, Adobe RGB
Picture Style
Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3
Settings
Auto, Daylight, Shade, Cloudy (Twilight and Sunset), Tungsten Light, White Fluorescent Light, Flash, Custom (Custom White Balance: Approx. 2,000&deg; - 10,000&deg; K)
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
White balance correction:Blue/amber bias: &plusmn;9 levels Magenta/green bias: &plusmn;9 levels* Correction based on the current WB mode's color temperature.
Color Temperature Information Transmission
Provided
Type
Eye-level SLR (with fixed pentamirror)
Coverage
Vertical/Horizontal approx. 95%
Magnification
Approx. 0.85x / 23.8&deg;
Eye Point
Approx. 19 mm (At -1m-1 from the eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0 m-1 (dpt)
Focusing Screen
Fixed
Mirror
Quick-return half mirror (transmission: reflection ratio of 40:60)
Viewfinder Information
1) AF information (AF points and focus confirmation light)
2) Exposure information (Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, spot metering circle, exposure warning)
3) Flash information (Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light)
4) Image information (Highlight tone priority (D+), monochrome shooting, maximum burst (1-digit display), white balance correction, SD card information)
Depth Of Field Preview
Enabled with depth-of-field preview button
Type
TTL-CT-SIR AF-dedicated CMOS sensor
AF Points
9 points (All AF points are cross-type at f/5.6., Center AF point is diagonal cross-type at f/2.8.)
AF Working Range
EV -0.5 - 18 (at 23&deg;C/73&deg;F and ISO 100, based on Canon's testing standards)
Focusing Modes
(1) Autofocus One-Shot AF Predictive AI Servo AFAI Focus AF (*Switches between One-Shot AF and AI Servo AF)(2) Manual focus (MF)
AF Point Selection
(1) Manual selection
(2) Auto selection
* Automatically set in Basic Zone modes.
Selected AF Point Display
Indicated by superimposed display in the viewfinder and on the LCD monitor
AF Assist Beam
(1) Intermittent firing of built-in flash
(2) Effective range: Approx. 13.1 ft./4 m. at center, approx. 11.5 ft /3.5 m. at periphery
* With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
* Compatible with assist-beam (intermittent firing) of 270EX II, 320EX, and 270EX flashes.
Metering Modes
Real-time evaluative metering with image sensor
Evaluative metering, partial metering (center: approx. 9% of viewfinder), spot metering (center: approx. 4% of viewfinder), center-weighted average metering
* AE lock possible. The active metering time can be changed.
Metering Range
EV 1.0 - EV 20.0 (at 73&deg;F/23&deg;C with EF50mm f/1.4 USM lens, ISO 100)
Exposure Control Systems
Creative Zone
(1) Program AE (shiftable)
(2) Shutter-priority AE
(3) Aperture-priority AE
(4) Manual exposure (including bulb)Basic zone
(1) Scene Intelligent Auto (Program AE / non-shiftable)
(2) Flash Off
(3) Creative Auto
(4) Portrait
(5) Landscape
(6) Close-up
(7) Sports
(8) Night Portrait
(9) Handheld Night Scene mode
(10) HDR Backlight Control mode
ISO Speed Range
For Stills:
1.Manual setting range of ISO 100-12800, expansion to ISO 25600
2.Auto, ISO 100-6400 (in whole-stop increments)
- In Creative Zone modes, the maximum ISO speed (ISO 400, 800, 1600, 3200, or 6400) for ISO Auto can be set.
- With C.Fn-6-1 (Highlight tone priority), ISO 200 or higher will be set.
*1: When the built-in flash is retracted, the ISO speed will be set automatically within ISO 100&#8211;6400.*2: Fixed at ISO 400 for Bulb exposures.*3: Depends on the maximum ISO speed that has been set.*4: If fill-flash will result in overexposure, the lowest ISO 100 is set.*5: If you use bounce flash with an external Speedlite in the Creative Auto, Portrait, Landscape, Close-up, Sports, and P modes, the ISO speed is set automatically within ISO 400&#8211;1600 (or up to the maximum limit) to match the brightness.
Exposure Compensation
Manual: &plusmn;5 stops in 1/3- or 1/2-stop increments (AEB &plusmn;2 stops)
AEB : &plusmn;2 stops in 1/3- or 1/2-stop increments
* If the exposure compensation exceeds &plusmn;2 stops, the left or right icon appears in the viewfinder.
* Manual exposure compensation and AEB can be set in combination.
* AEB is set in the following sequence: Standard exposure, decreased exposure, and increased exposure.
* If AEB is used with the self-timer, the three bracketed shots will be taken in succession after the 10-sec. or 2-sec. delay.
AE Lock
(1) Auto AE lock
* In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
(2) Manual AE lock
* In the P, Tv, Av, and M modes, enabled with the AE lock button. (Press again to update.)
* Enabled in all metering modes.
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds
1/4000 to 1/60 sec., X-sync at 1/200 sec. (Scene Intelligent Auto)
1/4000 to 30 sec., bulb, X-sync at 1/200 sec. (Total shutter speed range. Available range varies by shooting mode.)
* Settable in 1/3- or 1/2-stop increments.
Shutter Release
Soft-touch electromagnetic release
Self Timer
Shutter Lag Time
(1) During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.075 sec.
(2) Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.150 sec.
* Time lag with the aperture stopped down by 3 stops or less. Excludes AF operation time.
Remote Control
Compatible with Remote Controller RC-6, RC-1, and RC-5
Remote control mode (via menu) for video shooting provided
* You can start or stop video shooting immediately with the wireless remote control's 2-sec. delay mode (operates as immediate start/stop).
* Still photo shooting is possible with the wireless remote control's immediate shutter-release mode.
Type
Auto pop-up, retractable, built-in flash in the pentamirror
Flash Metering System
E-TTL II autoflash (evaluative flash metering and average flash metering), FE lock
Guide Number
Approx. 13/43 (at ISO 100 in meters/feet)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready icon lights in viewfinder
Flash Coverage
Up to 17mm focal length (equivalent to approx. 28mm in 135 format)
FE Lock
Provided
Flash Exposure Compensation
Up to &plusmn;2 stops in 1/3- or 1/2-stop increments
Flash exposure compensation for built-in flash and Speedlite can be set with the camera.
Flash Metering
E-TTL II autoflash (evaluative flash metering and average flash metering), FE Lock
&plusmn;2 stops in 1/3-stop or 1/2-stop increments
FE Lock
Provided
PC Terminal
Not Provided
Drive Modes
Single, Continuous, 10-sec. self-timer/Remote control, 2-sec. self-timer, Continuous shooting after 10-sec. self-timer (2 to 10 shots)
Continuous Shooting Speed
Max. approx. 5.0 fps (with One-Shot AF or AI SERVO AF)
* Same as with Battery Grip BG-E8 loaded with size-AA/LR6 alkaline batteries.
Maximum Burst
Based on 8GB memory Card:
JPEG Large/Fine: Approx. 22 Shots
RAW: Approx. 6 Shots
RAW+JPEG Large/Fine: 3 Shots
Based on UHS-I memory card:
JPEG Large/Fine: Approx. 30 Shots
RAW + JPEG Large/Fine: 3 Shots
Shooting Modes
Still photo shooting and video shooting
Focusing
(1) Autofocus
- Face Detection + Tracking AF
- FlexiZone - Multi (31 zones, AF at the touched Zone)
- FlexiZone - Single
- Quick Mode AF
(2) Manual focusing
*Magnify the image by 5x or 10x and focus manually.
Metering Modes
Evaluative metering, partial metering, spot metering, center-weighted average metering
Metering Range
EV 0 to EV 20 (At 23&deg;C/73&deg;F, 50mm f/1.4 lens, ISO 100)
Grid Display
Provided (Two-type grid displays)
Exposure Simulation
Provided
Silent Shooting
Not provided
File Format
MOV (Image data: H.264; audio: Linear PCM (Stereo))
File Size
Recording Size:Recording Size:[Full HD]
1920 x 1080: 330 MB/min.
[HD]
1280 x 720: 330 MB/min.
[SD]
640 x 480: 82.5 MB/min.
Frame Rates
1920 x 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p
1280 x 720 (HD): 60p (59.94) / 50p
640 x 480 (SD): 30p (29.97) / 25p
Continuous Shooting Time
[1920 x 1080]
30 fps: Approx. 22 min.
25 fps: Approx. 22 min.
24 fps: Approx. 22 min.[1280 x 720]
60 fps: 22 min.
50 fps: 22 min.[640 x 480]
30 fps: 1 hr. 32 min.
25 fps: 1 hr. 32 min.
Focusing
(1) Autofocus
1. Face Detection + Tracking AF
2. FlexiZone - Multi (31 zones, AF at the touched zone)
3. FlexiZone - Single
(2) Manual focus
1. Magnify the image by approx. 5x or approx. 10x and focus manually.
2. Magnified view is not possible during video shooting.
Range
Auto ISO range: ISO 100-6400
Manual ISO range: ISO 100-6400, H12800
*If highlight tone priority is set, automatically set within ISO 200 or higher.
Exposure Control
(1) Program AE for video shooting
* In Basic Zone modes, P, Av, and Tv modes
* Shutter speed 1/30 - 1/4000 sec. (Signal accumulation time), aperture, and ISO speed automatically set.
(2) Manual exposure
* For manual exposure.
* Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps.
Provided (&plusmn;3 stops in 1/3-stop increments)
* For video, exposure compensation will not be applied beyond &plusmn;3 stops even if the exposure compensation has been set beyond &plusmn;3 stops.
Type
TFT color, liquid-crystal monitor with Touch Panel LCD (capacitive type)
Monitor Size
3.0 in. (Screen aspect ratio of 3:2)
Pixels
Approx. 1,040,000 dots
Coverage
Viewing Angle: 170&deg; (vertically and horizontally)
Brightness Control
Auto: Brightness adjusted automatically by the light sensor, Manual: 7 levels provided
Coating
Anti-smudge coating
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
(1) Single image display Single image, basic information, detailed information, histogram display(2) Index display4-image index and 9-image index.(3) Jump display (Image jump w/ Main Dial)1/10/100 images, shooting date, by folder, movies, stills, rating
Highlight Alert
On the detailed information and histogram displays, highlight areas with no image data will blink.
Items
When you press the Quick Control function button under the following conditions, you can set the functions below:
*The settable functions depend on the shooting mode(1)With viewfinder shooting:
Shutter speed, aperture, ISO speed, exposure compensation, AEB, flash exposure compensation, Picture Style, white balance, Auto Lighting Optimizer, built-in flash func. setting, AF mode, drive mode, metering mode, and image recording quality.(2)With Live View shooting:
AF mode, drive mode, white balance, Picture Style, Auto Lighting Optimizer, image-recording quality, and built-in flash func. setting.(3)With video shooting:
AF mode, white balance, Picture Style, Auto Lighting Optimizer, image recording quality (stills), video-recording size, and video snapshot.
Protection
Erase protection can be applied/canceled for a single image, all images in a folder, or all images in the card.
Erase
Erase single image, erase selected images, erase all images on folder, erase all images in a card, or erase only unprotected images.
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG images complying to Design rule for Camera File System RAW images printable. Video cannot be printed.
DPOF
DPOF print ordering provided (Complies to DPOF Version 1.1)
* If both Standard and Index are set, only Standard will take effect for printing.
Compatible Images
Not Provided
Custom Functions
Eight Custom Functions with 24 settings settable with the camera
Custom Controls
Not Provided
My Menu Registration
Up to six top-tier menu options and Custom Function settings can be registered
USB Terminal
For personal computer communication and direct printing (USB 2.0 Hi-Speed)
Video Out Terminal
(1) Video OUT terminal: NTSC/PAL selectable
(2) mini-HDMI OUT terminal
Extension System Terminal
Not Provided
Battery
One Battery Pack LP-E8
* With the AC Adapter Kit ACK-E8, AC power is possible.
* With BG-E8, two battery packs (LP-E8) can be used. Or six size-AA/LR6 batteries can be used.
Battery Life
1)Camera body only
2)With Battery Grip BG-E8
Battery Check
Automatic battery level check when power is turned ON.
Battery level indicated in one of four levels on LCD monitor.
Power Saving
Power turns off after the set time of non-operation elapses
* [Auto power off] settable to 30 sec., 1 min., 2 min., 4 min., 8 min., 15 min. or disable
Date/Time Battery
Built-in secondary battery. When fully-charged, the date/time can be maintained for about three months.
Start-up Time
Approx. 0.1 sec. (Based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 5.2 x 3.9 x 3.1 in./ 133.1 x 99.8 x 78.8 mm
Weight
Approx. 18.3 oz. / 520 g (body only)
Approx. 20.3 oz. / 575 g (CIPA Guidelines)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
All data are based on Canon's Standard Test Method. Subject to change without notice.
If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker.
Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Safety Notice: EOS Rebel T4i Rubber grip changing color
Advisory Type
Date 08.14.12
Title Canon Support | Service Notice: Rebel T4i: Incorrect model name in EXIF data for captured images
Advisory Type
Date 07.02.12
Advisory Type
Date 09.15.12
Title Canon Support | Firmware Notice: EOS Rebel T4i: Firmware Version 1.0.5
Advisory Type
Date 11.27.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
