Canon Support for EOS Rebel T5 | Canon U.S.A., Inc.
EOS Rebel T5
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | High-sensitivity, high-resolution, large single-plate CMOS sensor |
Pixels | Effective pixels: Approx. 18.00 megapixels Total pixels: Approx. 18.70 megapixels |
Pixel Unit | 4.3 µm square |
Aspect Ratio | 3:2 (Horizontal : Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the CMOS sensorFluorine coating on the top surface. |
Dust Deletion Feature | (1) Manual cleaning (2) Dust Delete Data acquisition and appending The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.Self Cleaning Sensor Unit not included. |
Recording Format | Design rule for Camera File System 2.0 and Exif 2.30 |
File Size | (1) Large: Approx. 17.90 Megapixels (5184 x 3456) (2) Medium: Approx. 8.00 Megapixels (3456 x 2304) (3) Small 1: Approx. 4.50 Megapixels (2592 x 1728) (4) S2: Approx. 2.50 Megapixels (1920 x 1280) (5) S3: Approx. 0.35 Megapixels (720 x 480) (6) RAW: Approx. 17.90 Megapixels (5184 x 3456) Exact file sizes depend on the subject, ISO speed, Picture Style, etc. |
File Numbering | Consecutive numbering, auto reset, manual reset |
RAW + JPEG Simultaneous Recording | Provided (RAW + JPEG) |
Color Space | sRGB, Adobe RGB |
Picture Style | Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3 |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | White balance correction: ±9 levels White balance bracketing: ±3 levels in single-level increments Blue/amber direction or magenta/green direction possible |
Color Temperature Information Transmission | Provided |
Type | Eye-level SLR (with fixed pentamirror) |
Coverage | Vertical/Horizontal approx. 95% |
Magnification | Approx. 0.8x / 22.4° (with 50mm lens at infinity, -1 m-1 (dpt)) |
Eye Point | Approx. 21 mm (At -1m-1 from the eyepiece lens center) |
Dioptric Adjustment Correction | Adjustable from approx. -2.5 to +0.5 m-1 (dpt) |
Focusing Screen | Fixed |
Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60) |
Viewfinder Information | 1) AF information (AF points, focus confirmation light) 2) Exposure information (Shutter speed, aperture, ISO speed, AE lock, Exposure level, exposure warning) 3) Flash information (Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light) 4) Image information (Highlight tone priority, Monochrome shooting, maximum burst, white balance correction, SD card information) |
Depth Of Field Preview | No depth-of-field preview button (Enabled with C.Fn 9-4) |
Type | TTL-CT-SIR AF-dedicated CMOS sensor |
AF Points | 9-point AF (f/5.6 cross-type AF point at center) |
AF Working Range | Center AF Point: EV 0 - 18 (at 73°F/23°C, ISO 100) Other AF Points: EV 1 - 18 (at 73°F/23°C, ISO 100) |
Focusing Modes | (1) Autofocus - One-Shot AF - Predictive AI Servo AF - AI Focus AF (Switches between One-Shot AF and AI Servo AF automatically) (2) Manual focus (MF) |
AF Point Selection | (1) Manual selection (2) Auto selection |
Selected AF Point Display | Indicated by superimposed display in the viewfinder and on the LCD monitor |
AF Assist Beam | 1) Intermittent firing of built-in flash. 2) Effective range: Approx. 4 m/13.1 ft at center, approx. 3.5 m/11.5 ft at periphery. With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.Compatible with 320EX, 270EX II and 270EX AF-assist beam (intermittent flash firing). |
Metering Modes | 63-zone SPC TTL metering with selectable modes Evaluative metering (linkable to all AF point)Partial metering (approx. 10% of viewfinder at center)Center-weighted average metering |
Metering Range | EV 1.0 - EV 20.0 (at 73°F/23°C with EF50mm f/1.4 USM lens, ISO 100) |
Exposure Control Systems | Creative Zone modes (1) Program AE (program-shift possible) (2) Shutter-priority AE (3) Aperture-priority AE (4) Manual exposure (including bulb) Basic Zone modes (1) Scene Intelligent Auto (Program AE, non-shiftable) (2) Flash Off (3) Creative Auto (4) Portrait (5) Landscape (6) Close-up (7) Sports (8) Night Portrait |
ISO Speed Range | *1: 1 ISO 800 for Bulb exposures. *2: Depends on the maximum ISO speed that has been set.*3: If fill-flash results in overexposure, ISO 100 is set.*4: When the maximum ISO speed is ISO 400, the speed is fixed at ISO 400. *5: If a bounce flash with an external Speedlite flash is used in Basic Zone modes (except Night Portrait) or P mode, the ISO speed is automatically set between ISO 800–1600 in accordance with the brightness. |
Exposure Compensation | (1) Manual: ±5 stops in 1/3- or 1/2-stop increments(2) AEB : ±2 stops in 1/3- or 1/2-stop increments |
AE Lock | Auto AE Lock: Applied in One-Shot AF mode with evaluative metering when focus is achieved. Manual: By AE lock button in P, Tv and Av modes |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled. Electronic 1st curtain. Only 2nd curtain mechanically controlled. |
Shutter Speeds | 1/4000 to 30 sec., Bulb (Total shutter speed range. Available range varies by shooting mode.); X-sync at 1/200 sec.Settable in 1/3- or 1/2-stop increments. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay |
Shutter Lag Time | (1) During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.12 sec. (2) Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.24 sec. Time lag with the aperture stopped down by 3 stops or less. Excludes AF operation time. |
Remote Control | Compatible with Remote Switch RS-60E3. There is no wireless remote control sensor. |
Type | Auto pop-up, retractable, built-in flash in the pentamirror |
Flash Metering System | E-TTL II autoflash (Evaluative, Average), FE lock |
Guide Number | Approx. 9.2/30.2 (at ISO 100 in meters/feet) |
Recycling Time | Approx. 2 sec. |
Flash Ready Indicator | Flash-ready icon lights in viewfinder |
Flash Coverage | Up to 17mm focal length (equivalent to approx. 28mm in 135 format) |
FE Lock | Provided |
Flash Metering | E-TTL II autoflash (evaluative flash metering and average flash metering), FE lock |
Flash Exposure Compensation | ±2 stops in 1/3-stop or 1/2-stop increments |
Drive Modes | (1) Single shooting (2) Continuous shooting (3) 10-sec. self-timer (4) 2-sec. self-timer (5) Continuous shooting after 10-sec. self-timer (2 to 10 shots) |
Continuous Shooting Speed | JPEG & RAW: Max. approx. 3.0 fps |
Maximum Burst | (1) JPEG: 69 shots (2) RAW: 6 shots (3) RAW+JPEG: 4 shots When the image-recording quality is JPEG, continuous shooting is possible until the memory card becomes full. * Based on Canon's testing standards with a 8GB test card (3:2 aspect ratio, ISO 100 and Standard Picture Style) |
Shooting Modes | Still photo shooting and video shooting |
Focusing | 1) Autofocus - FlexiZone-Single - Face Detection Live mode - Quick mode 2) Manual Focus |
Metering Modes | Real-time Evaluative metering with image sensor |
Metering Range | EV 0 to EV 20 (At 23°C/73°F, ISO 100) |
Grid Display | (1) Grid 1: Pair of vertical and horizontal lines (2) Grid 2: 5 vertical and 3 horizontal lines |
Exposure Simulation | Provided |
Silent Shooting | Not provided |
File Format | MOV (image data: H.264; audio: Linear PCM (monaural)) |
File Size | [Full HD] 1920 x 1080 (30 fps/25 fps/24 fps): 330 MB/min. [HD] 1280 x 720 (60 fps/50fps): 330 MB/min. [SD] 640 x 480 (30 fps/25fps): 82.5 MB/min. * If the file size exceeds 4GB, a new file will be automatically created. ** SD Class 6 or higher required. |
Frame Rates | 1920 x 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p 1280 x 720 (HD): 60p (59.94) / 50p 640 x 480 (SD): 30p (29.97) / 25p |
Continuous Shooting Time | Approx. 29 min. 59 sec. |
Focusing | Autofocus: FlexiZone-Single, Quick mode, Face Detection Live mode; manual |
Exposure Control | (1) Program AE for movie shooting * Shutter speed 1/30 - 1/4000 sec. (signal accumulation time), aperture and ISO speed automatically set (2) Manual Exposure The ISO speed, aperture, and shutter speed (signal-accumulation time ranging from 1/30 sec. to 1/4000 sec.) are set manually. |
Exposure Compensation | ± 3 stops in 1/3-stop increments |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0-inch (Screen aspect ratio of 4:3) |
Pixels | Approx. 460,000 dots |
Coverage | Approx. 100% |
Brightness Control | Adjustable to one of seven brightness levels |
Coating | None |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Hungarian, Czech, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean and Japanese) |
Display Format | (1) Single image displaySingle image, basic information, detailed information, histogram display (2) Index display 4-image index and 9-image index. (3) Jump display (Image jump w/ Main Dial) 1/10/100 images, shooting date, by folder, movies, stills, rating |
Highlight Alert | On the detailed information and histogram displays, highlight areas with no image data will blink. |
Items | When you press the Quick Control button under the following conditions, you can set the functions below (The settable functions depend on the shooting mode): (1) With viewfinder shooting: Shutter speed, aperture, ISO speed, exposure compensation, AEB, flash exposure compensation, Picture Style, white balance, Auto Lighting Optimizer, raise built-in flash, AF mode, drive mode, metering mode, and image-recording quality. (2) With Live View shooting: AF mode, drive mode, white balance, Picture Style, Auto Lighting Optimizer, image-recording quality, ISO speed and raise built-in flash (with C.Fn). (3) With movie shooting: AF mode, white balance, Picture Style, and Auto Lighting Optimizer. |
Protection | Erase protection can be applied/canceled for a single image, all images in a folder, or all images in the card. |
Erase | Erase single image, erase selected images, erase all images on folder, erase all images in a card, or erase only unprotected images. |
Compatible Printers | PictBridge-compatible printers |
Printable Images | JPEG images complying to Design rule for Camera File System RAW images printable.Movies cannot be printed. |
DPOF | Version 1.1 compatible |
Custom Functions | 11 Custom Functions with 33 settings settable with the camera |
Custom Controls | Not Provided |
Camera User Settings | Not provided |
My Menu Registration | Up to six top-tier menu options and Custom Function settings can be registered. |
USB Terminal | Hi-Speed USB-standard mini-B terminal for personal computer communications and PictBridge. |
Video Out Terminal | 1) Type C (Switches automatically to suit the resolution) 2) Video output: 1. 1080/60i, 2. 1080/50i, 3. 480/60p, 4. 576/50p * Switches automatically to 1, 2, 3, or 4 to suit the TV. |
Extension System Terminal | Compatible with Remote Switch RS-60E3 |
Gigabit-Ethernet | Compatible (*Canon cameras are not guaranteed to support Eye-Fi card functions, including wireless transfer. In case of an issue with the Eye-Fi card, please consult with the card manufacturer. The use of Eye-Fi cards may not be approved in all regions, or from one region to another; please contact the card manufacturer for status of approval in the country/region of use.) |
Battery | Battery Pack LP-E10 x 1* With the AC Adapter Kit ACK-E10, AC power is possible. |
Battery Life | Number of shots (approx.) |
Battery Check | Automatic battery level check when power is turned ON.Battery level indicated in one of four levels on LCD monitor. |
Power Saving | Provided. Power turns off after 1, 2, 4, 8, 15 min. |
Date/Time Battery | Built-in secondary battery. When fully-charged, the date/time can be maintained for about three months. * Recharge time for backup battery: Approx. 8 hours |
Start-up Time | Approx. 0.1 sec. (Based on CIPA testing standards) |
Dimensions (W x H x D) | Approx. 5.10 (W) x 3.93 (H) x 3.07 (D) in./ Approx. 129.6 (W) x 99.7 (H) x 77.9 (D) mm |
Weight | Approx. 16.93 oz. / 480g (CIPA Standard) Approx. 15.34 oz. / 435g (Body only) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or lessAll data are based on Canon's Standard Test Method. Subject to change without notice. If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker. Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
