Canon Support for EOS Rebel T7 | Canon U.S.A., Inc.
EOS Rebel T7
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
Using Wi-Fi
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital, Af/Ae Single-Lens Reflex Camera With Built-In Flash |
Recording Medium | Sd, Sdhc And Sdxc Memory Cards Compatible With Sd Speed Class Cards. Not Compatible With Uhs Speed Class Cards. Compatible With Eye-Fi Cards. Multimedia Cards (Mmc) Cannot Be Used. (A Card Error Will Be Displayed.) Image Format |
Compatible Lenses | Canon Ef Lenses (Including Ef-S Lenses And Excluding Ef-M Lenses) |
Lens Mount | Canon Ef Mount |
Type | Cmos Sensor |
Pixels | Approx. 24.10 Megapixels (Rounded To The Nearest 100,000) |
Pixel Unit | Approx. 3.72 µm Square |
Total Pixels | Approx. 24.70 Megapixels (Rounded To The Nearest 100,000) |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | Rgb Primary Color Filters |
Low Pass Filter | Installed In Front Of The Image Sensor, Non-Detachable |
Dust Deletion Feature |
Recording Format | Compliant To Design Rule For Camera File System 2.0 And Exif 2.30 Image Format |
File Size | 3:2 Aspect Ratio Large: 6000 X 4000 Medium: 3984 X 2656 Small 1: 2976 X 1984 Small 2: 1920 X 1280 Small 3: 720 X 480 Raw: 6000 X 4000 4:3 Aspect Ratio Large: 5328 X 4000* Medium: 3552 X 2664 Small 1: 2656 X 1992 Small 2: 1696 X 1280* Small 3: 640 X 480 Raw: 6000 X 4000 16:9 Aspect Ratio Large: 6000 X 3368* Medium: 3984 X 2240* Small 1: 2976 X 1680* Small 2: 1920 X 1080 Small 3: 720 X 408* Raw: 6000 X 4000 1:1 Aspect Ratio Large: 4000 X 4000 Medium: 2656 X 2656 Small 1: 1984 X 1984 Small 2: 1280 X 1280 Small 3: 480 X 480 Raw: 6000 X 4000 * The Dimensions Will Not Attain A Perfect Aspect Ratio. Values Are Rounded To The Nearest 100,000. (Nearest 10,000 For S3.) For Jpeg, The Image Will Be Generated According To The Selected Aspect Ratio. Raw Images Are Generated In [3:2], And The Set Aspect Ratio Is Appended. |
File Numbering | The Following Three Types Of File Numbering Methods Can Be Set:
Color Space | Srgb, Adobe Rgb |
Picture Style |
Auto White Balance | Option Between Ambience Priority And White Priority Settings Settings
Color Temperature Compensation | Blue/Amber Bias: ±9 Levels Magenta/Green Bias: ±9 Levels Corrected Based On The Current Wb Mode's Color Temperature. |
Type | Eye-Level Single Lens Reflex (With Fixed Pentamirror) |
Coverage | Approx. 95% Vertically And Horizontally (With Eye Point Approx. 21mm) |
Magnification | Approx. 0.8x / 22.4° (-1m-1 With 50mm Lens At Infinity) |
Eyepoint | Approx. 21mm (At -1m-1 From Eyepiece Lens Center) |
Dioptric Adjustment Correction | Adjustable From Approx. -2.5 To +0.5 M-1 (Dpt) |
Focusing Screen | Fixed |
Mirror | Quick-Return Half Mirror |
Viewfinder Information | Af Point, Af Point Activation Indicator, Iso Speed, White Balance Correction, Focus Indicator, Maximum Burst, Monochrome Shooting, Iso Speed, Highlight Tone Priority, Exposure Level Indicator, Exposure Compensation Amount Aeb Range, Red-Eye Reduction Lamp On, Aperture, Card Full Warning, Card Error Warning, No Card Warning, Shutter Speed, Fe Lock, Busy, Built-In Flash Recycling, Flash Exposure Compensation, High-Speed Sync (Fp Flash), Fe Lock/Feb In-Progress, Flash-Ready, Fe Lock Out Of Range Warning, Ae Lock/Aeb In-Progress, Focusing Screen |
Depth Of Field Preview | Possible (With C.Fn-9 (Assign Set Button) Setting) |
Type | Ttl Secondary Image-Forming Phase-Difference Detection System With Af-Dedicated Sensor |
Af Points | 9 Points All Af Points Support F/5.6 Cross-Type Af With Center Af Point Af Working Range |
Focusing Modes |
Af Point Selection |
Selected Af Point Display | Indicated By Superimposed Display In The Viewfinder And On The Lcd Monitor. |
Af Assist Beam | Intermittent Firing Of Built-In Flash Effective Range: Center: Approx. 13.1 Ft. / 4.0m Periphery: Approx. 11.5 Ft. / 3.5m With An Eos-Dedicated Speedlite Attached, The Speedlite's Af-Assist Beam Is Emitted Instead. |
Metering Modes | Dual-Layer Metering Sensor With The Area Divided Into 63 Zones.
Metering Range | Ev 1-20 (Room Temperature, Iso 100, Evaluative Metering) | ||||||||||||
Exposure Control Systems | Creative Zone
Iso Speed Range | Manual Iso Setting: Iso 1006400 (In Whole-Stop Increments), Expandable Equivalent To Iso 12800.
Ae Lock |
Type | Vertical-Travel Shutter With Electronic First-Curtain Control And Mechanical Second-Curtain Control |
Shutter Speeds | 1/4000 To 30 Sec., Bulb (Total Shutter Speed Range) X-Sync At 1/200 Sec. Settable In 1/3- Or 1/2-Stop Increments. |
Shutter Release | Soft-Touch Electromagnetic Release |
Self Timer | 10-Sec. Or 2-Sec. Delay |
Shutter Lag Time |
Remote Control | Possible By Using Remote Switch Rs-60e3 |
Type | Auto Pop-Up, Retractable, Built-In Flash In The Pentamirror |
Flash Metering System | E-Ttl Ii Autoflash (Evaluative, Average), Fe Lock |
Guide Number | Approx. 30.2 Ft./9.2m (At Iso 100) |
Recycling Time | Approx. 2 Sec. |
Flash Coverage | Up To Approx. 17mm Focal Length (Equivalent To Approx. 28mm In 35mm Format) |
Fe Lock | Possible |
Flash Exposure Compensation | Up To ±2 Stops In 1/3- Or 1/2-Stop Increments Flash Exposure Compensation For Built-In Flash And External Speedlite Can Be Set With The Camera. |
Flash Exposure Compensation | ±2 Stops In 1/3-Stop Or 1/2-Stop Increments |
Drive Modes |
Continuous Shooting Speed | Max. Approx. 3.0 Fps |
Shooting Modes | Still Photo And Video Recording |
Focusing |
Metering Modes | Evaluative Metering (315-Zone)
Metering Range | Ev 0-20 (Room Temperature, Iso 100) |
Grid Display | One Of Two Types Of Grids Can Be Selected And Displayed On The Screen.
File Format | Mov: Movie: Mpeg4 Avc/H.264 * Variable (Average) Bit Rate Audio: Linear Pcm |
File Size | [Full Hd] 1920 X 1080 (30 Fps/24 Fps): 340 Mb/Min. [Hd] 1280 X 720 (60 Fps): 340 Mb/Min. [Sd] 640 X 480 (30 Fps): 90 Mb/Min. |
Frame Rates | 1920 X 1080 (Full Hd): 30 Fps (29.97 Fps) / 24 Fps (23.98 Fps) 1280 X 720 (Hd): 60 Fps (59.94 Fps) 640 X 480 (Sd): 30 Fps (29.97 Fps) |
Focusing |
Exposure Control |
Exposure Compensation | Possible (±3 Stops In 1/3-Stop Increments) |
Type | Tft Color, Liquid-Crystal Monitor |
Screen Monitor Size | 3.0-Inch (Screen Aspect Ratio Of 4:3) Approx. 7.5cm Diagonal (Width: Approx. 6.0cm, Height: Approx. 4.5cm) |
Pixels | Approx. 920,000 Dots |
Coverage | Approx. 170° Vertically And Horizontally |
Brightness Control | Adjustable To One Of Seven Brightness Levels |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Hungarian, Czech, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
Protection | Erase Protection Can Be Applied/Canceled For A Single Image, All Images In A Folder Or All Images In The Card. |
Erase | Erase Unprotected Image(S) With Selection From Single Image, Selected Images, All Images On Folder Or All Images In A Card. |
Compatible Printers | Pictbridge-Compatible Printers |
Printable Images | Raw And Jpeg Images Compliant To Design Rule For Camera File System (Dcf) Movies Cannot Be Printed. |
Dpof | Dpof Print Ordering Provided (Complies To Dpof Version 1.1) |
Custom Functions | 11 Custom Functions With 33 Settings Settable With The Camera |
Custom Controls | Not Provided |
Camera User Settings | Not Provided |
My Menu Registration | Menu Functions, Custom Functions Up To Six Kinds Of Function Settings Can Be Selected And Registered From The Top-Tier Menu Functions. |
Battery | Battery Pack Lp-E10 X 1
Battery Check | Automatic Battery Check When The Power Switch Is Turned On. Battery Level Indicated In One Of The Four Levels On Lcd Monitor. |
Power Saving | Power Turns Off Automatically After The Set Time Of Non-Operation Elapses.
Date Time Battery | Built-In Secondary Battery Maintains Date/Time For About 3 Months When Fully Charged |
Start Up Time | Approx. 0.1 Sec. (Cipa Standards) |
Dimensions W X H X D | Approx. 5.08 X 3.99 X 3.06 In. / 129.0 X 101.3 X 77.6mm
Weight | Approx. 16.75 Oz. / 475g (Including Battery And Card) Approx. 15.06 Oz. / 427g (Body Only) |
Operating Temperature Range | 32-104°F / 0-40°C |
Operating Humidity Range | 85% Or Less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
