Canon Support for EOS Rebel T8i | Canon U.S.A., Inc.
EOS Rebel T8i
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital AF/AE single-lens reflex camera
Image Processor | DIGIC 8
Recording Media |
SD/SDHC/SDXC memory cards
Image Format | Approx. 22.3 x 14.9mm (APS-C Size)
Compatible Lenses | Canon EF lenses (including EF-S lenses, excluding EF-M lenses)
Lens Mount | Canon EF mount
Type | CMOS sensor (supporting Dual Pixel CMOS AF)
Pixels | Effective pixels: Approx. 24.1* Megapixels
Total pixels: Approx. 25.8* Megapixels * Rounded to the nearest 100,000. |
Pixel Unit | Approx. 3.72µm square
Aspect Ratio | 3:2 (Horizontal:Vertical)
Color Filter System | RGB primary color filters
Low Pass Filter | Installed in front of the image sensor, non-detachable
Dust Deletion Feature | (1) Self Cleaning Sensor Unit
Recording Format | Compliant to Design rule for Camera File system 2.0 and EXIF 2.31
File Size | 3:2 Aspect Ratio
Large: 24 Megapixels (6000 x 4000) Medium: Approx. 10.6 Megapixels (3984 x 2656) Small 1: Approx. 5.9 Megapixels (2976 x 1984) Small 2: Approx. 3.8 Megapixels (2400 x 1600) RAW / C-RAW: Approx. 24 Megapixels (6000 x 4000) 4:3 Aspect Ratio Large: Approx. 21.3 Megapixels (5328 x 4000) Medium: Approx. 9.5 Megapixels (3552 x 2664) Small 1: Approx. 5.3 Megapixels (2656 x 1992) Small 2: Approx. 3.4 Megapixels (2112 x 1600) RAW / C-RAW: Approx. 24 Megapixels (6000 x 4000) 16:9 Aspect Ratio Large: Approx. 20.2 Megapixels (6000 x 3368) Medium: Approx. 8.9 Megapixels (3984 x 2240) Small 1: Approx. 5.0.Megapixels (2976 x 1680) Small 2: Approx. 3.2 Megapixels (2400 x 1344) RAW / C-RAW: Approx. 24 Megapixels (6000 x 4000) 1:1 Aspect Ratio Large: Approx. 16 Megapixels (4000 x 4000) Medium: Approx. 7.1 Megapixels (2656 x 2656) Small 1: Approx. 3.9 Megapixels (1984 x 1984) Small 2: Approx. 2.6 Megapixels (1600 x 1600) RAW / C-RAW: Approx. 24 Megapixels (6000 x 4000) |
File Numbering | The following three types of file numbering method can be set:
(1) File numbering method Continuous numbering
RAW + JPEG Simultaneous Recording | Simultaneous recording of RAW or C-RAW plus Large/Fine JPEG is supported.
Color Space | sRGB/Adobe RGB
Picture Style | (1) Auto
(2) Standard (3) Portrait (4) Landscape (5) Fine Detail (6) Neutral (7) Faithful (8) Monochrome (9) User Def. 13
Settings | (1) Auto (Ambience priority/White priority)
(2) Daylight (3) Shade (4) Cloudy* (5) Tungsten light (6) White fluorescent light (7) Flash (8) Custom (Custom WB) (9) Color temperature (K) (Manually adjustable between 2000 - 10000K) * Effective also in twilight and sunset. |
Auto White Balance | Option between ambience priority and white priority settings
White Balance Shift | Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels Corrected in reference to the current WB modes color temperature. |
Type | Eye-level optical viewfinder (with fixed pentamirror)
Coverage | At approx. 19mm eye-point
Vertical / Horizontal approx. 95% (With 50mm f/1.8 STM lens; Large/Fine JPEG image, 3:2 aspect ratio) |
Magnification | Approx. 0.82x/23.2° (with 50mm lens at infinity, -1m
-1
Eye Point | Approx. 19mm (at -1m
-1
from the eyepiece lens center)
Dioptric Adjustment Correction | Adjustable from approx. -3.0 to +1.0m
-1
(dpt)
Focusing Screen | Fixed
Mirror | Quick-return all-surface half mirror
Viewfinder Information | Displayed with transparent liquid crystal
(1) AF point information
(3) Electronic level (4) Grid (5) Aspect line (6) Flicker detection |
Depth Of Field Preview | Provided with depth of field preview button
Type | TTL secondary image-forming phase-difference detection system with AF-dedicated sensor
AF Points | Up to 45 points (cross-type AF points: max. 45)
AF Working Range | Conditions: One-Shot AF, at 73°F/23°C, ISO 100 (based on Canon's testing standards and environment)
Focusing Modes | (1) Autofocus
AF Area Selection | (1) Single-point AF (Manual selection)
Automatic AF Point Selection: EOS iTR AF | EOS iTR AF (face Priority):
Gives greater priority to people's faces when AF points are selected automatically. With One-Shot AF:
With AI Servo AF:
AF Assist Beam |
Intermittent firing of built-in flash
Effective range
With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
Metering Modes | 220,000-pixel RGB+IR metering sensor
216-zone (18 x 12) metering optical viewfinder (1) Evaluative metering (linked to all AF points) (2) Partial metering (center, approx. 6.5% of viewfinder) (3) Spot metering (center, approx. 2.0% of viewfinder) (4) Center-weighted average metering |
Metering Range | EV 120 (room temperature, ISO 100, evaluative metering)
Exposure Control Systems | (1) Creative Zone
ISO Speed Range |
Manual setting
For [Highlight tone priority], the settable ISO speed range will be ISO 200-25600.
Auto ISO Speed Settings
1
If fill-in flash will cause overexposure, ISO 100 or a higher ISO will be set.
Exposure Compensation |
* Up to ±2 stops, indicated in the viewfinder.
* Up to ±3 stops when [Shooting screen: Guided] is set.
AE Lock | (1) Auto AE lock
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds | 1/4000 to 30 sec., bulb (total shutter speed range. Available range varies by shooting mode.)
X-sync at 1/200 sec. Creative Zone: 1/4000-30 sec., bulb Basic Zone: 1/4000-1 sec. |
Self Timer | 10-sec. delay, 2-sec. delay
Shutter Lag Time | (1) With shutter button half-pressed time between fully pressed and start of exposure: approx. 0.070 sec.
(2) Time lag when shutter button fully pressed without initially being pressed half-way: approx. 0.250 sec.
Flash Metering | E-TTL II autoflash (Evaluative- face priority, Evaluative, Average), FE Lock
Flash Exposure Compensation | ±2 stops in 1/3- or 1/2-stop increments (when set on camera body)
FE Lock | Provided
Continuous Shooting Priority (CSP) Mode | Supported (with accessory Canon Speedlites only)
External Flash Settings | (1) External flash control
Drive Modes and Continuous Shooting Speed during Viewfinder Shooting | (1) Single shooting
(2) High-speed continuous shooting
(5) 2 sec. self-timer / remote control (6) Continuous shooting after 10-sec. self-timer (2 to 10 shots) |
Maximum Burst: Image file sizes, number of shots, burst rates |
The number of shots available and standard maximum burst in viewfinder shooting with a 32GB UHS-I card conforming to Canon testing standards.
The file size, number of possible shots and maximum burst vary depending on shooting conditions (aspect ratio of 3:2, subject, memory card brand, ISO speed, Picture Style, etc.) |
Shooting Modes | Still photo shooting and video shooting
Focusing | (1) Dual Pixel CMOS AF
Metering Modes | 384-zone (24 x 16)
Real-time metering with image sensor
(2) Partial metering (center, approx. 5.8% of viewfinder) (3) Spot metering (center, approx. 2.9% of viewfinder) (4) Center-weighted average metering
Metering Range | EV -220 (room temperature, ISO 100, evaluative metering)
Grid Display | (1) Off
(2) 3x3 (3) 6x4 (4) 3x3+diag |
File Format | MP4
Video: MPEG-4 AVC / H.264
Video Recording Size and Frame Rates |
* The image is cropped around the center of the image sensor.
Estimated Recording Time, Movie Bit Rate, and File Size |
If the recording time reaches 29 min. 59 sec., the movie shooting stops automatically.
Bit rate indicates video output only, auido is not included. File size and time indicates video output + audio With [Digital IS: Disable] set. |
Range | Full range (0255) | |||||||||||||||||||||||||||||||||||||||||||
Exposure Control |
Exposure modes in movie shooting:
* 1/30 when [Movie Auto slow shutter] is set to [Enable]
Exposure Compensation | Up to ±3 stops in 1/3- or 1/2-stop increments |
Type | TFT color, liquid-crystal monitor
Monitor Size | 3.0-inch (screen aspect ratio of 3:2)
Approx. 3.0 in./7.5cm diagonal (approx. 2.5 in./6.2cm width, approx. 1.6 in/4.2cm height) |
Dots | Approx. 1.04 million dots
Angle of view | Approx. 170° vertically and horizontally
Brightness Control | Adjustable to one of seven brightness levels
Coating | Clear View LCD II
Interface Languages | 29 (English, Japanese; Arabic, Chinese [Simplified/Traditional], Czech, Danish, Dutch, Finnish, French, German, Greek, Hindi, Hungarian, Indonesian, Italian, Korean, Malay, Norwegian, Polish, Portuguese, Romanian, Russian, Spanish, Swedish, Thai, Turkish, Ukrainian, Vietnamese)
Display Format | (1) Single-image display
Highlight Alert | With detailed information display, overexposed highlight areas with no image data will blink.
Histogram | Brightness and RGB
Items | Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback.
After selecting an item, you can select contents by operating the Main Dial. |
Protection | (1) Single image (select image)
(2) Select range (3) All images in a folder (4) All images in a card (5) All found images (only during image search) |
Erase | Except protected images
(1) Select image to erase (2) Select range (3) All images in a folder (4) All images in a card (5) All found images (only during image search) |
Compatible Printers | Images can be sent via Wi-Fi to a PictBridge-compatible (Wireless LAN) printer and printed.
Printable Images | JPEG images compliant to Design rule for Camera File System
DPOF | Compliant to DPOF Version 1.1
Select Image | Supported
* RAW/C-RAW images and movies cannot be specified for printing. |
Custom Functions | 14 Custom Functions can be configured
Custom Controls | Functions can be assigned to the following control parts:
My Menu Registration |
Up to six top-tier menu options and Custom Function settings can be registered.
Up to five My Menu tabs can be added.
USB Terminal | Hi-Speed USB (USB 2.0; Micro-B connection type)
HDMI Video/audio Output | HDMI mini OUT terminal (Type C), CEC not compatible
* images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set. |
HDMI HDR Output | OFF / ON
External microphone input terminal | 3.5mm diameter stereo mini jack
Battery | Battery Pack LP-E17 x 1
Battery Life |
Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 4 levels. | |||||||||||||||||
Power Saving | Power turns off after the set time (10/30* or 30 sec., 1, 2, 4, 8 or 15 min.) of non-operation elapses
* Normally 10 sec. is set. 30 sec. will be set for function setting, Live View shooting, image playback, etc. |
Date/Time Battery | Built-in secondary battery
When fully-charged, the date/time can be maintained for approx. 3 months
Start-up Time | Approx. 0.3 sec. (based on CIPA testing standards) |
Dimensions (W x H x D) | Approx. 5.16 x 4.04 x 3.00 in. (131.0 x 102.6 x 76.2mm)
Weight | Approx. 18.17 oz. / 515g (including battery pack and SD memory card)
Approx. 16.61 oz. / 471g (body only) |
Working Temperature Range | 32-104°F / 0-+40°C |
Working Humidity Range | 85% or less |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
Wireless API | Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
