Canon Support for EOS Rebel XSi | Canon U.S.A., Inc.
EOS Rebel XSi
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.20.10
File Size 11.20 MB
Date 10.14.10
File Size 8.08 MB
Date 04.13.09
File Size 7.50 MB
Date 03.26.08
File Size 13.29 MB
Date 07.22.12
File Size 6.88 MB
Date 06.09.08
File Size 6.00 MB
Date 06.09.08
File Size 10.99 MB
Date 04.15.09
File Size 6.96 MB
Date 01.24.12
File Size 10.69 MB
Date 04.01.25
File Size 142.00 B
Date 03.04.10
File Size 12.70 MB
Date 03.26.08
File Size 3.67 MB
Date 07.22.12
File Size 6.38 MB
Date 04.01.25
File Size 142.00 B
Date 06.09.08
File Size 6.67 MB
Date 10.14.10
File Size 8.41 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels
Effective pixels: Approx. 12.20 megapixels
Total Pixels
Total pixels: Approx. 12.40 megapixels
Aspect Ratio
3:2 (Horizontal : Vertical)
Color Filter System
RGB primary color filter
Low Pass Filter
Located in front of the image sensor, non-removable
Dust Deletion Feature
(1) Automatic sensor cleaning
(2) Manual cleaning of sensor
(3) Dust Delete Data appended to the captured image
Recording Format
Design rule for Camera File System 2.0
Image Format
JPEG, RAW (14-bit Canon original)RAW+JPEG
File Size
(1) Large/Fine : Approx. 4.3MB (4272 x 2848 pixels)
(2) Large/Normal : Approx. 2.2MB (4272 x 2848 pixels)
(3) Medium/Fine : Approx. 2.5MB (3088 x 2056 pixels)
(4) Medium/Normal: Approx. 1.3MB (3088 x 2056 pixels)
(5) Small/Fine : Approx. 1.6MB (2256 x 1504 pixels)
(6) Small/Normal : Approx. 0.8MB (2256 x 1504 pixels)
(7) RAW : Approx. 15.3 MB (4272 x 2848 pixels)
Exact file sizes depend on the subject, ISO speed, Picture Style, etc.
File Numbering
Consecutive numbering, auto reset, manual reset
RAW + JPEG Simultaneous Recording
Provided
Color Space
sRGB, Adobe RGB
Picture Style
Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3
Settings
Auto, Daylight, Shade, Cloudy, Tungsten, White Fluorescent Light, Flash, Custom
Color Temperature Compensation
White balance correction: &plusmn;9 stops in full-stop incrementsWhite balance bracketing: &plusmn;3 stops in full-stop increments
Blue/amber direction or magenta/green direction possible
Color Temperature Information Transmission
Provided
Type
Eye-level pentamirror
Coverage
Vertical/Horizontal approx. 95%
Magnification
Approx. 0.87x (-1m with 50mm lens at infinity)
Eye Point
Approx. 19mm (from eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0 diopter
Focusing Screen
Fixed, Precision Matte
Mirror
Quick-return half mirror (Transmission: reflection ratio of 40:60, no mirror cut-off with EF600mm f/4L IS USM or shorter lenses)
Viewfinder Information
AF information (AF points, focus confirmation light), exposure information (shutter speed, aperture, AE lock, exposure level, ISO speed, exposure warning), flash information (flash ready, high-speed sync, FE lock, flash exposure compensation), monochrome shooting, white balance correction, maximum burst, SD memory card information
Depth Of Field Preview
Enabled with depth-of-field preview button
Type
TTL secondary image-registration, phase detection
AF Points
9 AF points
AF Working Range
EV -0.5-18 (at 73&deg;F/23&deg;C, ISO 100)
Focusing Modes
One-Shot AF, AI Servo AF, AI Focus AF, Manual focusing (MF)
AF Point Selection
Automatic selection, manual selection
Selected AF Point Display
Superimposed in viewfinder and indicated on LCD monitor
AF Assist Beam
Small series of flashes fired by built-in flash
Effective range: Approx. 4.0m/13.1 ft. at center, approx. 3.5m/11.5 ft. at periphery
Metering Modes
35-zone TTL full-aperture meteringEvaluative metering (linkable to any AF point)Partial metering (approx. 9% of viewfinder at center)Spot metering (approx. 4% of viewfinder at center)Center-weighted average metering
Metering Range
EV 1-20 (at 73&deg;F/23&deg;C with EF50mm f/1.4 USM lens, ISO 100)
ISO Speed Range
Basic Zone modes: ISO 100-800 set automatically
Creative Zone modes: ISO 100-1600 (in 1-stop increments), Auto
Exposure Compensation
Manual: &plusmn;2 stops in 1/3- or 1/2-stop increments (can be combined with AEB)
AEB: &plusmn;2 stops in 1/3- or 1/2-stop increments
AE Lock
Automatic: When focus achieved with evaluative metering and One-Shot AF
Manual: By AE lock button
Type
Electronically-controlled, focal-plane shutter
Shutter Speeds
1/4000 sec. to 1/60 sec., X-sync at 1/200 sec.
1/4000 sec. to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.)
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. or 2-sec. delay or 10-sec. delay plus continuous shooting
Remote Control
Remote Switch RS-60E3
Remote Controller RC-1/RC-5
Type
Retractable, auto pop-up flash
Guide Number
13/43 (ISO 100, in meters/feet)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready icon lights in viewfinder
Flash Coverage
17mm lens angle of view
FE Lock
Provided
Flash Exposure Compensation
EOS Dedicated Speedlite
E-TTL II autoflash with EX Series Speedlites
Zooming to Match Focal Length
Provided
Flash Metering
E-TTL II autoflash
FE Lock
Provided
External Flash Settings
Flash function settings, Flash C.Fn settings
PC Terminal
N/A
Continuous Shooting Speed
Max. approx. 3.5 shots/sec. (single shots possible)
Maximum Burst
JPEG (Large/Fine): Approx. 53, RAW: Approx. 6
RAW+JPEG (Large/Fine): Approx. 4
Based on Canon's testing standards with a 2GB SD memory card, ISO 100, and Standard Picture Style
Varies depending on the subject, SD memory card brand, image-recording quality, etc.
Shooting Modes
(1) Live View shooting
(2) Remote Live View shooting (w/a personal computer installed with EOS Utility)
Focusing
Manual focus
Autofocus (Quick mode, Live mode)
Metering Modes
Evaluative metering with the image sensor
Metering Range
EV 0 - 20 (at 23&deg;C/73&deg;F with EF50mm f/1.4 USM lens, ISO 100)
Grid Display
Provided
Exposure Simulation
Simulated exposure displayed in real-time
Type
TFT color liquid-crystal monitor
Monitor Size
3.0 in.
Pixels
Approx. 230,000 pixels
Coverage
Approx. 100%
Brightness Control
7 levels provided
Interface Languages
20
Display Format
Single image, Single image + Image-recording quality, shooting information, histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image, image jump (by 1/10/100 images, or shooting date)
Highlight Alert
Provided (Overexposed highlights blink)
Protection
Single images can be erase-protected or not
Erase
Single image, check-marked images, or all images in the card can be erased (except protected images) at one time
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG image compliant to Design rule for Camera file System (DPOF printing possible)
Easy Print feature
Provided
DPOF
Version 1.1 compatible
Compatible Images
JPEG and RAW images
*Only JPEG images can be transferred as wallpaper on the personal computer screen
Custom Functions
Total 13
My Menu Registration
Provided
Battery
Battery Pack LP-E5 (Quantity 1)
AC power can be supplied via AC Adapter Kit ACK-E5
With Battery Grip BG-E5, size-AA batteries can be used
Number of Shots
Battery Life
The above figures apply with a fully-charged Battery Pack LP-E5
The figures above are based on CIPA (Camera & Imaging Products Association) testing standards
Battery Check
Automatic
Power Saving
Provided. Power turns off after 30 sec., 1, 2, 4, 8, or 15 min.
Back-up Battery
Built-in secondary battery
Start-up Time
Approx. 0.1 sec. (based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 5.1 x 3.8 x 2.4 in./128.8 x 97.5 x 61.9mm
Weight
Approx. 16.8 oz./ 475g (body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
Type
LP-E5
Rechargeable lithium-ion battery
Rated Voltage
7.4 V DC
Battery Capacity
1080 mHh
36 x 14.7 x 53.1mm/1.4 x 0.6 x 2.1 in.)
Weight
Approx. 50g/1.8 oz. (excluding protective cover)
Type
LC-E5
Compatible Battery
Battery Pack LP-E5
Recharging Time
Approx. 2 hours
Rated Input
100 - 240 V AC (50/60 Hz)
Rated Output
8.4 V DC/700 mA
0&deg;C - 40&deg;C/32&deg;F - 104&deg;F
85% or less
67 x 26 x 87.5mm/2.6 x 1.0 x 3.4 in.
Weight
Approx. 80g/2.8 oz.
Angle of View
For EF-S 18-55mm f/3.5-5.6 IS
Diagonal extent: 74&deg;20' - 27&deg;50'
Horizontal extent: 65&deg;30' - 23&deg;20'
Vertical extent: 45&deg;30' - 15&deg;40'
Lens Construction
11 elements in 9 groups
Minimum Aperture
f/22 - 36
Closest Focusing Distance
0.25m/0.82 ft. (from image sensor plane)
Maximum Magnification and Field of View
0.34x (at 55mm)
Filter Size
58mm
Hood
EW-60C
Diameter x Length
Approx. 68.5 x 70mm/2.7 x 2.8 in.
Weight
Approx. 200g/7.1 oz.
Case
LP814
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Use of Eye-Fi Cards and SD card removal timing
Advisory Type
Date 03.04.12
Title Canon Support | Service Notice: Information on Original Data Security and Original Data Verification Kits
Advisory Type
Date 01.24.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
