Canon Support for imageCLASS MF249dw | Canon U.S.A., Inc.
imageCLASS MF249dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Printer Specifications
Printer Type | Monochrome Laser |
Print Speed | Up to 16ppm (2-sided plain paper letter) / 28ppm (1-sided plain paper letter)1 |
First Print Time | 6 seconds or less (letter)2 |
Printer Language | UFR II LT (Host-based), PCL (5e, 6) |
Print Resolution | Up to 600 x 600 dpi |
Maximum Print Size | Up to Legal (8.5 x 14 inches) |
Duplex Print | Yes |
Print Modes | Watermark, Page Composer, Toner Saver |
Print Memory | 512 MB (Shared) |
Copier Specifications
Copy Speed | Up to 28ppm (letter, 1-sided), Up to 16ppm (letter, 2-sided) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Text, Photo |
Halftones | 256 Levels |
Warm-up Time | 14 seconds or less from power on |
First Copy Time | Approximately 9 seconds3 |
Recovery Time | Approximately 2 seconds |
Maximum Number of Copies | Up to 999 copies |
Reduction/Enlargement | 25-400% in 1% increments |
Copy Size | Platen: Up to 8.5 x 11, Feeder: Up to 8.5 x 14 |
Copy Features | Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Copy Memory | 512 MB (Shared) |
Fax Specifications
Modem Speed | Up to 33.6 Kbps (Super G3)4 |
Fax Resolution | Up to 200 x 400 dpi (ultra fine) |
Transmission Time | Approx. 3 seconds per page |
Memory Capacity | Up to 256 pages5 |
Speed Dials | Up to 4 one-touch speed dials, up to 100 coded dials |
Group Dialing | 103 destinations |
Sequential Broadcasting | 114 destinations |
Duplex Fax | Yes |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | Fax forwarding, Dual Access, Remote Reception, PC Fax (sending only), Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Fax Activity / Result Reports, Fax Activity Management Reports |
Memory Backup | Yes |
pC Fax | Sending only |
Fax Forwarding | SMB, E-mail |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical) |
Scan Size | Platen: Up to Letter, Feeder: Up to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA, ICA |
Output File Formats | TIFF, JPEG, PDF, Compact PDF, Searchable PDF |
Scan Features | Push Scan, Pull Scan: USB and Network |
Send Specifications
Scan to Email | Yes - TIFF, JPEG, PDF, Compact PDF, Searchable PDF |
Scan to SMB | Yes - TIFF, JPEG, PDF, Compact PDF, Searchable PDF |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette plus 1-sheet multipurpose tray, 16-43 lb. (bond, plain paper)6 |
Document Feeder | 50-sheet Duplex Auto Document Feeder6 |
Paper Output | 100 sheets (face down) |
Media Sizes | Letter, Legal, Executive, Statement |
Media Types | Plain, Color, Recycled, Heavy, Bond, Label, Envelope |
Envelope Capacity | 1 (Multipurpose Tray) |
Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (Network), 802.11 b/g/n Wireless7, Wi-Fi Direct Connection8 |
WiFi Access Mode | Infrastructure Mode, WPS Easy Set Up |
WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | Canon PRINT Business9, Apple® AirPrint®10, Mopria™ Print Service11, Google Cloud Print™12 |
Network Functions | Print, PC Fax, Scan, Send |
Web Browser Support for Remote UI | IE 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6), IPP, IPPS |
TCP/IP Set of Application Services | Bonjour(mDNS),DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1/SNMPv3 (IPv4,IPv6), HTTP/HTTPS, SNTP |
OS Compatibility | Windows® 10, 8.1, 8, 7, Windows Vista®,Windows Server® 2012, 2012 R2, 2008, 2008 R2, 2003, 2003 R2, Mac OS 10.6.8 or later |
Cable Included | Power Cord, Phone Cable (USB not included) |
Bundled Software | Printer driver, Fax driver, Scanner driver, MF Scan Utility, Address Book Tool |
Environmental Specifications
Power Consumption | Approx: Operation: 480 W, Standby: 5.6 W, Energy Saver: 1.2 W (USB), 1.3 W (wired), 2 W (wireless) |
Typical Energy Consumption | 0.9kWh |
General Specifications
Dimensions | 15.4"(W) x 14.9"(D) x 14.2"(H) |
Unit Weight (without/with cartridge) | 28.9 lbs. w/o cartridge, 30.3 lbs. w/ cartridge |
Package Weight | 37.5 lbs |
Cartridge Type | Cartridge 137 (Yields approximately 2,400 pages), Single Cartridge System *Yields based on ISO/IEC Standard |
LCD Display | Tiltable, Touch LCD |
Duty Cycle | Up to 15,000 pages per month, RMPV (Recommended Monthly Print Volume): 750 - 3,000 pages |
Security | IP/MAC address filtering, IEEE802.1x, SNMPv3, HTTPS/IPPS |
Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Simplified Chinese, Traditional Chinese, Korean |
Warranty | 1 year limited exchange/carry-in warranty13 (Extended warranty available) |
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
