Canon Support for imageCLASS MF264dw | Canon U.S.A., Inc.
imageCLASS MF264dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Products | ChromeOS |
imageCLASS MF269dw / MF267dw / MF264dw Spec Sheet
imageCLASS MF269dw / MF267dw / MF264dw | |||
imageCLASS MF269dw | imageCLASS MF267dw | imageCLASS MF264dw | |
MAIN UNIT | |||
FUNCTIONS | Print/Scan/Copy/Fax | Print/Scan/Copy | |
CONTROL PANEL | 6-line LCD | 5-line LCD | |
MEMORY | 256 MB | ||
STANDARD INTERFACE CONNECTION | USB Device 2.0 High-Speed, 10/100 Base-T Ethernet (Network), Wi-Fi 802.11 b/g/n, Wi-Fi Direct Connection | ||
PAPER INPUT / OUTPUT CAPACITY (LETTER, 20 LB. BOND) | 250/50 Sheets | ||
PAPER SOURCES (LETTER, 20 LB. BOND) | 250-sheet Paper Cassette, 1-sheet Stack Bypass | ||
SUPPORTED MEDIA TYPES | Cassette/Bypass: Plain, Recycled, Thick, Bond, Label, Envelope | ||
SUPPORTED MEDIA SIZES | Cassette/Bypass: Letter, Legal, Statement, Executive; | ||
SUPPORTED MEDIA WEIGHTS | Cassette/Bypass: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2) | ||
WARM-UP TIME | From Power On: 15 Seconds or Less; | ||
DIMENSIONS (W x D x H) | 15.4" x 16.0" x 14.8" (390 mm x 405 mm x 375 mm) | ||
WEIGHT (MACHINE ONLY / BOXED WEIGHT) | 29.3 lb. (13.3 kg)/37.4 lb. (17.0 kg) | 27.3 lb. (12.4 kg)/35.2 lb. (16.0 kg) | |
PRINT SPECIFICATIONS | |||
PRINTING METHOD | Laser Beam Printing | ||
PRINT SPEEDS1 | Up to 30 ppm (Letter); Up to 24 ppm (Legal) | ||
FIRST PRINT-OUT TIME | Approx. 5.1 Seconds | ||
RECOMMENDED MONTHLY PAGE VOLUME | 250 - 2,500 Pages | ||
PRINT RESOLUTION (dpi) | 600 x 600 | ||
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II-LT, PCL®6, PCL®5e | ||
TWO-SIDED PRINTING | Automatic (Standard) | ||
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES2 | Canon PRINT Business, Apple® AirPrint®, Mopria™ Print Service | ||
OPERATING SYSTEMS (PRINT / SCAN) | Windows® 10/8.1/7, Windows Server® 2016/ 2012 R2/ 2012/ 2008 R2/ 2008; Mac OS 10.8.5 and Up. | ||
COPY SPECIFICATIONS | |||
COPY SPEED | Up to 30 ppm (Letter); Up to 24 ppm (Legal) | ||
FIRST COPY-OUT TIME (LETTER) | 8 Seconds or Less | ||
COPY RESOLUTION (dpi) | Up to 600 x 600 | ||
COPY SIZE | Platen: Up to Letter; | ||
PRESETS | Magnifications: 25% - 400% (1% Increments) | ||
SCAN SPECIFICATIONS | |||
TYPE | Duplexing Automatic Document Feeder | Automatic Document Feeder | |
DOCUMENT FEEDER PAPER CAPACITY (20 LB. BOND) | 50 Sheets | 35 Sheets | |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | Legal, Letter | ||
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single-sided Scanning: 13 - 28 lb. Bond (50-105 g/m2) | Single-sided Scanning: 13 - 28 lb. Bond (50-105 g/m2) | |
SCAN RESOLUTION (dpi) | 600 x 600 | ||
SCAN TO MOBILE DEVICES | Canon PRINT Business | ||
SCAN SPEED (LETTER) (IPM) | Single-sided (Color/BW): 7.7/11.6 | Single-sided (Color/BW): 8 /10.6 Two-sided (Color/BW): N/A | |
SEND SPECIFICATIONS | |||
DESTINATION | Email (SMTP), SMB, Super G3 FAX | NA | |
ADDRESS BOOK | Local (50) | ||
SEND RESOLUTION (dpi) | 300 x 300 | ||
COMMUNICATION PROTOCOL | File: SMB; Email: SMTP, POP3 | ||
FILE FORMAT | TIFF, JPEG, PDF (Compact, Searchable) | ||
FAX SPECIFICATIONS | |||
MODEM SPEED | Super G3: 33.6 kbps | NA | |
RESOLUTION (dpi) | 200 x 400, 200 x 200, 200 x 100 | ||
SENDING / RECORDING SIZE | Statement to Letter | ||
FAX MEMORY | Up to 256 Pages | ||
SPEED DIALS | Max. 104 | ||
GROUP DIALS / DESTINATIONS | Max. 50 Dials | ||
SEQUENTIAL BROADCAST | Max. 114 Addresses | ||
FAX FEATURES | Rx Mode, Resolution, Two-sided Original, Density, Sharpness, Duplex Fax | ||
SECURITY SPECIFICATIONS | |||
NETWORK | IP/MAC Address Filtering, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP | ||
WI-FI® AUTHENTICATION METHODS | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) | ||
ENVIRONMENTAL SPECIFICATIONS | |||
OPERATING ENVIRONMENT | Temperature: 50 to 86º F; | ||
POWER CONSUMPTION | Maximum: Approx. 1080 W or Less; | ||
STANDARDS | ENERGY STAR® Qualified, Rated EPEAT Silver3 | ||
FOOTNOTES | |||
1 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper. |
PRODUCT LIMITED WARRANTY
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
