Canon Support for imageCLASS MF269dw | Canon U.S.A., Inc.
imageCLASS MF269dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.11.25
File Size 1.20 MB
Date 09.16.24
File Size 1.32 MB
Date 02.03.20
File Size 652.13 KB
Date 04.26.23
File Size 460.45 KB
Date 01.30.23
File Size 2.92 MB
Date 04.23.19
File Size 408.63 KB
Date 12.23.20
File Size 819.56 KB
Date 04.19.22
File Size 1.50 MB
Date 07.19.23
File Size 154.27 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 01.30.23
File Size 144.76 KB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 07.19.23
File Size 146.85 KB
Date 03.23.23
File Size 1.60 MB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 12.19.23
File Size 476.17 KB
Date 10.03.19
File Size 2.92 MB
Date 04.23.19
File Size 815.66 KB
Date 09.24.23
File Size 1.20 MB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
imageCLASS MF269dw
imageCLASS MF269dw
Products ChromeOS
imageCLASS MF269dw
imageCLASS MF269dw / MF267dw / MF264dw Spec Sheet
imageCLASS MF269dwimageCLASS MF267dwimageCLASS MF264dw
MAIN UNIT
FUNCTIONS
Print/Scan/Copy/Fax
Print/Scan/Copy
CONTROL PANEL
6-line LCD
5-line LCD
MEMORY
256 MB
STANDARD INTERFACE CONNECTION
USB Device 2.0 High-Speed, 10/100 Base-T Ethernet (Network), Wi-Fi 802.11 b/g/n, Wi-Fi Direct Connection
PAPER INPUT / OUTPUT CAPACITY (LETTER, 20 LB. BOND)
250/50 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
250-sheet Paper Cassette, 1-sheet Stack Bypass
SUPPORTED MEDIA TYPES
Cassette/Bypass: Plain, Recycled, Thick, Bond, Label, Envelope
SUPPORTED MEDIA SIZES
(CASSETTE, STACK BYPASS)
Cassette/Bypass: Letter, Legal, Statement, Executive;
Envelope: COM10, Monarch, C5, DL; Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassette/Bypass: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
WARM-UP TIME
From Power On: 15 Seconds or Less;
From Sleep Mode: 1.6 Seconds or Less
DIMENSIONS (W x D x H)
15.4" x 16.0" x 14.8" (390 mm x 405 mm x 375 mm)
WEIGHT (MACHINE ONLY / BOXED WEIGHT)
29.3 lb. (13.3 kg)/37.4 lb. (17.0 kg)
27.3 lb. (12.4 kg)/35.2 lb. (16.0 kg)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEEDS1
Up to 30 ppm (Letter); Up to 24 ppm (Legal)
FIRST PRINT-OUT TIME
Approx. 5.1 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
250 - 2,500 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II-LT, PCL®6, PCL®5e
TWO-SIDED PRINTING
Automatic (Standard)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES2
Canon PRINT Business, Apple® AirPrint®, Mopria™ Print Service
OPERATING SYSTEMS (PRINT / SCAN)
Windows® 10/8.1/7, Windows Server® 2016/ 2012 R2/ 2012/ 2008 R2/ 2008; Mac OS 10.8.5 and Up.
Drivers Available For Download From www.usa.canon.com/support
COPY SPECIFICATIONS
COPY SPEED
FIRST COPY-OUT TIME (LETTER)
8 Seconds or Less
COPY RESOLUTION (dpi)
Up to 600 x 600
COPY SIZE
Platen: Up to Letter;
ADF: Up to Legal
PRESETS
Magnifications: 25% - 400% (1% Increments)
Reductions
: 25%, 50%, 64%, 78%
Enlargements
: 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPE
Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY (20 LB. BOND)
50 Sheets
35 Sheets
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
Single-sided Scanning: 13 - 28 lb. Bond (50-105 g/m2)
Two-sided Scanning: 16 - 28 lb. Bond (60-105 g/m2)
SCAN RESOLUTION (dpi)
600 x 600
SCAN TO MOBILE DEVICES
SCAN SPEED (LETTER) (IPM)
Single-sided (Color/BW): 7.7/11.6
Two-sided (Color/BW): 2.4/4
Single-sided (Color/BW): 8 /10.6
Two-sided (Color/BW): N/A
SEND SPECIFICATIONS
DESTINATION
Email (SMTP), SMB, Super G3 FAX
NA
ADDRESS BOOK
Local (50)
SEND RESOLUTION (dpi)
300 x 300
COMMUNICATION PROTOCOL
File: SMB; Email: SMTP, POP3
FILE FORMAT
TIFF, JPEG, PDF (Compact, Searchable)
FAX SPECIFICATIONS
MODEM SPEED
Super G3: 33.6 kbps
G3: 14.4 kbps
NA
RESOLUTION (dpi)
200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement to Letter
FAX MEMORY
Up to 256 Pages
SPEED DIALS
Max. 104
GROUP DIALS / DESTINATIONS
Max. 50 Dials
SEQUENTIAL BROADCAST
Max. 114 Addresses
FAX FEATURES
Rx Mode, Resolution, Two-sided Original, Density, Sharpness, Duplex Fax
SECURITY SPECIFICATIONS
NETWORK
IP/MAC Address Filtering, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP
WI-FI® AUTHENTICATION METHODS
WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER CONSUMPTION
Maximum: Approx. 1080 W or Less;
Average: Approx. 340 W;
Sleep Mode: Approx. 0.7 W;
Typical Electricity Consumption (TEC) Rating: 0.33 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver3
FOOTNOTES
1 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
2 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
3 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Canon Laser Printer & Small Office Multifunctional Printer IP Stack protocol
Advisory Type
Date 09.29.20
Title Canon Support | Service Notice: Laser Printer & Small Office Multifunctional Printer cross-site scripting
Advisory Type
Date 12.30.21
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
Title Service Notice: Toner Cartridge Auto Replenishment Service (ARS) will be down for planned server maintenance
Advisory Type Service Notice
Date 03.03.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
