Canon Support for imageCLASS MF416dw | Canon U.S.A., Inc.
imageCLASS MF416dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.22.17
File Size 2.92 MB
Date 12.20.23
File Size 476.17 KB
Date 12.24.20
File Size 2.92 MB
Date 09.12.25
File Size 1.32 MB
Date 09.25.23
File Size 1.20 MB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 09.12.25
File Size 1.20 MB
Date 12.22.17
File Size 809.44 KB
Date 09.12.25
File Size 2.27 MB
Date 09.25.23
File Size 1.20 MB
Date 09.17.24
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 04.04.19
File Size 645.16 KB
Date 09.30.21
File Size 1.50 MB
Date 09.12.25
File Size 1.20 MB
Date 09.30.16
File Size 717.77 KB
Date 10.04.19
File Size 815.82 KB
Date 05.21.18
File Size 23.90 MB
Date 12.22.17
File Size 645.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.12.22
File Size 1.59 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 09.17.24
File Size 1.32 MB
Date 10.04.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
Date 02.04.20
File Size 649.44 KB
Date 12.24.20
File Size 819.56 KB
Date 12.24.20
File Size 649.44 KB
Date 04.27.23
File Size 1.72 MB
Date 03.27.17
File Size 716.21 KB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 12.22.17
File Size 647.92 KB
Date 04.27.23
File Size 460.45 KB
Date 04.04.16
File Size 27.48 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF416dw
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF416dw
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 17ppm (2-sided plain paper letter) / 35ppm (1-sided plain paper letter)1
First Print Time 6.3 seconds or less (letter)2
Printer Language UFR II (Host-based), PCL6 (5c, XL) / PS
Print Resolution Up to 600 x 600 dpi;
(1200 x 600 dpi quality)
Maximum Print Size Up to Legal (8.5 x 14 inches)
Duplex Print Yes
Print Modes Poster, Booklet, Watermark, Page Composer, Toner Saver
Print Memory 1 GB (Shared)
Direct Print from USB PDF/JPEG/TIFF formats
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 35ppm (letter)
Duplex Copy Speed Up to 17cpm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Text, Photo
Halftones 256 Levels
Warm-up Time 16 seconds or less from power on
First Copy Time 10 seconds or less3
Recovery Time 5 seconds or less
Maximum Number of Copies Up to 999 copies
Reduction/Enlargement 25-400% in 1% increments
Copy Size Platen: Up to 8.5 x 11,
Feeder: 5.1 x 5.5 to 8.5 x 14
Copy Features Frame Erase,
Memory Sort,
2 on 1,
4 on 1,
ID Card Copy
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)4
Fax Resolution Up to 406 x 391 dpi (ultra fine)
Transmission Time Approx. 3 seconds per page (ECM-JBIG, transmitting from the memory at 33.6 Kbps)
Memory Capacity Up to 512 sheets4a
Speed Dials Up to 281 dials
Group Dialing 199 destinations
Sequential Broadcasting 310 destinations
Duplex Fax Yes
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Fax forwarding, Dual Access, Remote Reception, PC Fax (sending only), DRPD, ECM, Auto Redial
Memory Backup Yes
Activity Reports Fax Activity / Result Reports, Fax Activity Management Reports
pC Fax Sending only
Fax Forwarding SMB, E-mail, FTP, iFax Simple
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical),
9600 x 9600 (software interpolated resolution)
Scan Size Platen: Up Letter,
Feeder: Up to Legal
Duplex Scan Yes
Compatibility TWAIN, WIA 2.0, ICA
Output File Formats JPEG, TIFF, PDF, PDF(Compact), PDF (OCR)
Scan Features Push Scan, Pull Scan, Scan to USB
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Send Specifications
Scan to Email JPEG, TIFF, PDF, PDF(Compact), PDF (OCR)
Scan to SMB JPEG, TIFF, PDF, PDF(Compact), PDF (OCR)
Paper Handling Specifications
Standard Paper Source(s) 250-sheet cassette plus 50-sheet multipurpose tray5
Optional Paper Source(s) 500-sheet cassette5 (PF-44)
Document Feeder Duplex Auto Document Feeder 50-sheets5
Paper Output 150 sheets (face down)
Paper Weight 16-34 lb.
(bond, plain paper)
Media Sizes Letter, Legal, A4, A5, B5, Executive, Statement
Media Types Plain, Heavy, Recycled, Color, Label (20 sheets, mp tray), Envelope
Envelope Capacity 5 (Multipurpose Tray)
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), 802.11 b/g/n Wireless6, Wi-Fi Direct Connection6a, NFC7 (Near Field Communication)
WiFi Access Mode Infrastructure Mode, WPS Easy Set Up
WiFi Authentication Methods WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon PRINT Business8, Apple&reg; AirPrint&reg;9, Mopria&trade; Print Service10, Google Cloud Print&trade;11
Network Functions Print, Scan (SMB, E-mail, FTP), PC Fax
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI IE 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1 (IPv4,IPv6), SNMPv3 (IPv4, IPv6)
OS Compatibility Windows&reg; 10, Windows&reg; 8.1, Windows 8, Windows 7, Windows Vista&reg;, Windows Server&reg; 2012 R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac OS X&reg; 10.6 & up
Cable Included Power Cord, Phone Cable (USB not included)
Bundled Software Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager
Environmental Specifications
Power Consumption Approx: 600 W (during operation), 9 W (standby), 2.2 W (energy saver / sleep mode)
Typical Energy Consumption 1.2kWh
General Specifications
Dimensions 15.4"(W) x 18.6"(D) x 17.0"(H)
Unit Weight (without/with cartridge) 40.6 lbs w/o cartridge,
42.3 w/ cartridge
Package Weight 51.6 lbs
Cartridge Type Cartridge 119 (Yields approximately 2,100 pages),
Cartridge 119II (Yields approximately 6,400 pages) Single Cartridge System
*Yields based on ISO/IEC Standard
Department Counter No
LCD Display 3.5 Inch, Color Touch LCD
Duty Cycle Up to 50,000 pages per month
Department ID Management Yes, up to 300 ID's
Security IEEE802.1x, SNMPv3, HTTPS, IPSEC, Secure Print (up to 32 jobs), Department ID up to 300 IDs
Languages English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean
Warranty 1 year limited exchange/carry-in warranty12 (Extended warranty available)
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
