Canon Support for imageCLASS MF416dw | Canon U.S.A., Inc.
imageCLASS MF416dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
Printer Specifications
Printer Type | Monochrome Laser |
Print Speed | Up to 17ppm (2-sided plain paper letter) / 35ppm (1-sided plain paper letter)1 |
First Print Time | 6.3 seconds or less (letter)2 |
Printer Language | UFR II (Host-based), PCL6 (5c, XL) / PS |
Print Resolution | Up to 600 x 600 dpi; (1200 x 600 dpi quality) |
Maximum Print Size | Up to Legal (8.5 x 14 inches) |
Duplex Print | Yes |
Print Modes | Poster, Booklet, Watermark, Page Composer, Toner Saver |
Print Memory | 1 GB (Shared) |
Direct Print from USB | PDF/JPEG/TIFF formats |
Copier Specifications
Copy Type | Monochrome Laser |
Copy Speed | Up to 35ppm (letter) |
Duplex Copy Speed | Up to 17cpm (letter) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Text, Photo |
Halftones | 256 Levels |
Warm-up Time | 16 seconds or less from power on |
First Copy Time | 10 seconds or less3 |
Recovery Time | 5 seconds or less |
Maximum Number of Copies | Up to 999 copies |
Reduction/Enlargement | 25-400% in 1% increments |
Copy Size | Platen: Up to 8.5 x 11, Feeder: 5.1 x 5.5 to 8.5 x 14 |
Copy Features | Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Fax Specifications
Modem Speed | Up to 33.6 Kbps (Super G3)4 |
Fax Resolution | Up to 406 x 391 dpi (ultra fine) |
Transmission Time | Approx. 3 seconds per page (ECM-JBIG, transmitting from the memory at 33.6 Kbps) |
Memory Capacity | Up to 512 sheets4a |
Speed Dials | Up to 281 dials |
Group Dialing | 199 destinations |
Sequential Broadcasting | 310 destinations |
Duplex Fax | Yes |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | Fax forwarding, Dual Access, Remote Reception, PC Fax (sending only), DRPD, ECM, Auto Redial |
Memory Backup | Yes |
Activity Reports | Fax Activity / Result Reports, Fax Activity Management Reports |
pC Fax | Sending only |
Fax Forwarding | SMB, E-mail, FTP, iFax Simple |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical), 9600 x 9600 (software interpolated resolution) |
Scan Size | Platen: Up Letter, Feeder: Up to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA 2.0, ICA |
Output File Formats | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
Scan Features | Push Scan, Pull Scan, Scan to USB |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Send Specifications
Scan to Email | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
Scan to SMB | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette plus 50-sheet multipurpose tray5 |
Optional Paper Source(s) | 500-sheet cassette5 (PF-44) |
Document Feeder | Duplex Auto Document Feeder 50-sheets5 |
Paper Output | 150 sheets (face down) |
Paper Weight | 16-34 lb. (bond, plain paper) |
Media Sizes | Letter, Legal, A4, A5, B5, Executive, Statement |
Media Types | Plain, Heavy, Recycled, Color, Label (20 sheets, mp tray), Envelope |
Envelope Capacity | 5 (Multipurpose Tray) |
Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), 802.11 b/g/n Wireless6, Wi-Fi Direct Connection6a, NFC7 (Near Field Communication) |
WiFi Access Mode | Infrastructure Mode, WPS Easy Set Up |
WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
WiFi Encryption Modes | WEP (64/128 bit), TKIP, AES |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | Canon PRINT Business8, Apple® AirPrint®9, Mopria™ Print Service10, Google Cloud Print™11 |
Network Functions | Print, Scan (SMB, E-mail, FTP), PC Fax |
Embedded Web Server (Remote UI) | Yes |
Web Browser Support for Remote UI | IE 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
TCP/IP Set of Application Services | Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1 (IPv4,IPv6), SNMPv3 (IPv4, IPv6) |
OS Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012 R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac OS X® 10.6 & up |
Cable Included | Power Cord, Phone Cable (USB not included) |
Bundled Software | Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager |
Environmental Specifications
Power Consumption | Approx: 600 W (during operation), 9 W (standby), 2.2 W (energy saver / sleep mode) |
Typical Energy Consumption | 1.2kWh |
General Specifications
Dimensions | 15.4"(W) x 18.6"(D) x 17.0"(H) |
Unit Weight (without/with cartridge) | 40.6 lbs w/o cartridge, 42.3 w/ cartridge |
Package Weight | 51.6 lbs |
Cartridge Type | Cartridge 119 (Yields approximately 2,100 pages), Cartridge 119II (Yields approximately 6,400 pages) Single Cartridge System *Yields based on ISO/IEC Standard |
Department Counter | No |
LCD Display | 3.5 Inch, Color Touch LCD |
Duty Cycle | Up to 50,000 pages per month |
Department ID Management | Yes, up to 300 ID's |
Security | IEEE802.1x, SNMPv3, HTTPS, IPSEC, Secure Print (up to 32 jobs), Department ID up to 300 IDs |
Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
Warranty | 1 year limited exchange/carry-in warranty12 (Extended warranty available) |
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
