Canon Support for imageCLASS MF455dw | Canon U.S.A., Inc.
imageCLASS MF455dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Products | ChromeOS |
Printer Specifications
Printer Type | Black and White Laser |
Print Speed | Up to 40 ppm (Letter); Up to 32 ppm (Legal) 3 |
First Print Time | Approx. 5.3 Seconds |
Printer Language | UFR II, PCL®6, PCL®5, Adobe PostScript 3® |
Print Resolution | 600 x 600 (dpi) |
Duplex Print | Automatic (Standard) |
Print Memory | 1GB |
Direct Print from USB | Available from USB memory (JPEG, TIFF, PDF) |
Copier Specifications
Copy Speed | Up to 40 ppm (Letter); Up to 32 ppm (Legal) |
Copy Resolution | 600 x 600 (dpi) |
First Copy Time | Approx. 6.2 seconds |
Maximum Number of Copies | Up to 999 Copies |
Reduction/Enlargement | Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
Copy Size | Platen: Up to Letter ADF: Up to Legal |
Copy Features | Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card |
Fax Specifications
Modem Speed | Super G3: 33.6 kbps G3: 14.4 kbps |
Fax Resolution | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
Memory Capacity | Up to 512 Pages |
Speed Dials | Max. 281 |
Group Dialing | Max. 299 dials |
Sequential Broadcasting | Max. 310 Addresses |
Fax Features | RX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax |
Memory Backup | Yes |
Scanner Specifications
Scan Type | Single-Pass Duplexing Automatic Document Feeder |
Scan Resolution | 300 x 600, 600 x 600 |
Scan Size | Legal, Letter, Statement |
Duplex Scan | Yes |
Output File Formats | Standard: TIFF, JPEG, PDF (Compact, Searchable) Optional: PDF (Encrypted, Digital Signature) |
Pull Scan | ScanGear MF for TWAIN, WIA, and ICA |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet Paper Cassette, 100-sheet Multipurpose Tray |
Optional Paper Source(s) | 550-sheet Paper Cassette (Cassette Unit-AH1) |
Paper Output | Standard: 65 Sheets |
Paper Weight | Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2) |
Media Sizes | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14") Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14") |
Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes) |
Connectivity and Software Specifications
Standard Interface(s) | USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection |
WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
Mobile Functions | Apple® AirPrint,® Mopria® Print Service, Canon PRINT Business |
Network Management Protocols | IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
OS Compatibility | UFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X v10.8.5 (or later) |
Environmental Specifications
Power Consumption | Maximum: Approx. 1330 W Standby: Approx. 10 W Sleep Mode: Approx. 0.9 W |
Typical Energy Consumption | 0.34 kWh |
General Specifications
Dimensions | Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm) |
Unit Weight (without/with cartridge) | Approx. 35.8 lb. (16.2 kg) 2 |
Package Weight | Approx. 45.9 lb. (20.8 kg) 2 |
LCD Display | 5" Color Touch-panel |
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
